Bi-amp Denon 4311CI for 5.1? - AVS Forum | Home Theater Discussions And Reviews
Old 04-30-2012, 04:23 PM - Thread Starter
DDBear's Avatar
I have a Denon 4311CI that I will be moving over to my new 5.1 setup with 5 of the B&W CM1 speakers. I'm a newbie when it comes to setting up receivers beyond stereo mode (previously it was just on a 2.1 setup). Should I take advantage of the bi-amp capability in the 4311CI and wire the tweeter and the midrange speaker on the front CM1s separately (removing the metal bridge on the back of the speaker)? I am in the middle of running 14/4 wire to each CM1. Does bi-amping apply to just the front left and right, or also the center speaker?
DDBear is offline
Old 04-30-2012, 04:44 PM
Kal Rubinson's Avatar
Quoted: 681 Post(s)
Liked: 461
It will make little or no difference with the CM1s.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 04-30-2012, 04:51 PM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
The feature only applies to the FL/FR speakers, although as Kal notes, save your speaker wire and just wire them up normally.
For more questions on your 4311CI, join us in the Denon 4311CI Owner's thread.
http://www.avsforum.com/avs-vb/showthread.php?t=1274153
jdsmoothie is online now
Old 04-30-2012, 05:54 PM
KidHorn's Avatar
Quoted: 1379 Post(s)
Liked: 886
Just out of curiosity, why did you buy a 4311 for a 5.1 setup?
KidHorn is online now
Old 05-01-2012, 02:28 PM - Thread Starter
DDBear's Avatar
KidHorn, mainly because I tend to "buy the best" and hold on to it for 10-20 years. I hate having to constantly upgrade gadgets .. then they own my life with the time I spend researching every purchase. Instead I buy higher quality than what I really need go longer in between upgrades.
DDBear is offline
Old 05-01-2012, 03:37 PM
Nethawk's Avatar
Liked: 118
Smart man!
Nethawk is offline
