Need help Fast! Looking for receiver =] - Page 3 - AVS Forum
post #61 of 77 Old 05-04-2012, 04:03 PM
Sammy2's Avatar
Quoted: 25 Post(s)
Liked: 169
Read the AVR Manual! I gave you a link to it.
Sammy2 is offline
post #62 of 77 Old 05-04-2012, 04:06 PM - Thread Starter
vvilliamm's Avatar
yep lol i actually have the book reading it
croosover freq is 80 by default< in the pioneer it says "Crossover Network
• Default setting: 80Hz" so.. crossover network is freq right?
i set it to 150 as said by the manul in my klipsch hd 500
"NOTE: The A/V receiver/surround sound processor must be set to “Subwoofer On”
and all speakers set to “small”.
The suggested crossover point is 150 Hz. If 150 Hz is not available, use 120 Hz."
i dont have the mic yet but i want to plug everything in and see how it sounds =]
i guess i will just leave it at crossover network 80hz by default.
vvilliamm is offline
post #63 of 77 Old 05-04-2012, 04:20 PM
afrogt's Avatar
Quoted: 76 Post(s)
Liked: 353
Set the crossover to 120 or 150. Your HD500 speakers don't go down to 80hz.
Afro GT
afrogt is offline
post #64 of 77 Old 05-04-2012, 04:25 PM - Thread Starter
vvilliamm's Avatar
thanks only got 80-100-150-200 so.. 150 it is lol.
well im going to read the manual a bit more to amke sure by default its 8ohms
pluggin in speakers!!!!
post #65 of 77 Old 05-04-2012, 04:36 PM
Sammy2's Avatar
Quoted: 25 Post(s)
Liked: 169
What size are the largest drivers? I am concerned if you set it for 150Hz, you'll have a hole in the mid-bass between maybe 120Hz and 150Hz but I haven't seen the fr graphs for your speakers either. Thing is the sub may be diving off before the mid range can pick it up if you set the cross over too high. Too bad you don't have something between 100 and 150 to use there. That's a big span in the mid bass to not have a place to set the cross over frequency. Go with 150. If it sounds too tinny then try 100.
Sammy2 is offline
post #66 of 77 Old 05-04-2012, 04:37 PM - Thread Starter
vvilliamm's Avatar
http://mediacdn.shopatron.com/media/...pdf?1288063778 << not really sure.. lol
if anything i could set at 100hz right? then were good?
http://www.klipsch.com/high-definiti...theater-system
TURNING ON>.. atm!!! EPIC TIME!
post #67 of 77 Old 05-04-2012, 04:42 PM
Sammy2's Avatar
Quoted: 25 Post(s)
Liked: 169
Sounds like Afro GT knows more about those speakers than I do. I'm guessing they're HTiB type speakers?
Sammy2 is offline
post #68 of 77 Old 05-04-2012, 04:44 PM - Thread Starter
vvilliamm's Avatar
well it picked up the spif 96 digital and sound works now after restarted comp! awesome!
post #69 of 77 Old 05-04-2012, 05:00 PM
Sammy2's Avatar
Quoted: 25 Post(s)
Liked: 169
Originally Posted by vvilliamm View Post
well it picked up the spif 96 digital but no sound gg... i nub
Don't. Know what this means at all.
Sammy2 is offline
post #70 of 77 Old 05-04-2012, 05:02 PM - Thread Starter
vvilliamm's Avatar
sorry lol i had to restart my comp and the sound works i get full 5.1 surround in dts but everything else cant pick up the signals now waiting for analog wires to come!
post #71 of 77 Old 05-04-2012, 05:06 PM
afrogt's Avatar
Quoted: 76 Post(s)
Liked: 353
3 x 1pair banana plugs closed
3 x 15 3.5mm stero mal to 2 rca male 22awg cable
1 x 12 feet coax subwoofer cable rca
1 x 50 ft 16awg enhanced loud oxygen free copper speaker wire
1 x 15 feeet optical toslink
1 x adjustable cable stripper
1 x toslink female to toslink mini male adapter
sounds good?
3 pair for banana plugs will enable you to connect 3 speakers or 3 sets of speaker terminals on the receiver. Each channel needs one pair, one plug each for + and -. Since you have the HD500 they only need bare speaker wire but you can use banana plugs on the back of the Pioneer receiver which is very convenient. You've got a 5.1 speaker system, you need 5 pair of banana plugs and one subwoofer cable. Order two more sets of banana plugs.
Afro GT
afrogt is offline
post #72 of 77 Old 05-04-2012, 05:08 PM
afrogt's Avatar
Quoted: 76 Post(s)
Liked: 353
http://www.newegg.com/Product/Produc...82E16882780018
System: 36Hz - 20kHz
Satellite Speaker: 150Hz - 20kHz
Subwoofer: 36Hz - 200Hz
Set the crossover at 150hz.
Afro GT
afrogt is offline
post #73 of 77 Old 05-04-2012, 05:27 PM - Thread Starter
vvilliamm's Avatar
so um these speakers are pretty good yea?
post #74 of 77 Old 05-04-2012, 06:45 PM
afrogt's Avatar
Quoted: 76 Post(s)
Liked: 353
They're okay. Just satellite speakers. I prefer larger bookshelf speakers that go down to 80hz.
Afro GT
afrogt is offline
post #75 of 77 Old 05-04-2012, 06:53 PM - Thread Starter
vvilliamm's Avatar
well at least down the road!! i could get two front bookshelf speakers and put my front 2 into my rear back rear right then that will be FULL 7.1 !!! but um for future purposes.. any recommendations?
post #76 of 77 Old 05-04-2012, 07:56 PM - Thread Starter
vvilliamm's Avatar
planning to buy these
http://www.staples.com/3M-Command-Ad...ropdown_396131'
to mount my speakers without drilling since my landlord doesnt allow drilling
post #77 of 77 Old 05-07-2012, 12:14 AM - Thread Starter
vvilliamm's Avatar
out of curiosity in the future could i hook up a pair of audioengine a2 to my receiver? then put 2 of my satellites as my rear for 7.1 surround
User Tag List
