Marantz NR1403 and NR1603 Slim Line Receiver Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #541 of 1020 Old 10-04-2013, 11:57 AM
Bieffe's Avatar
Originally Posted by jdsmoothie View Post
Greyed out options mean they do not apply to the surround mode you currently have selected. Select a surround mode that uses the center channel.
You are a great help. Really know ur stuff inside out!
Bieffe is offline
post #542 of 1020 Old 10-05-2013, 03:14 AM
zibanez's Avatar
Quoted: 36 Post(s)
Hi JD, If i change speakers crossover value, will it affect in direct mode? FYI , i'm using exterenal amp and assigned it to front
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Rythmik Audio CI 15" HP600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
post #543 of 1020 Old 10-05-2013, 06:08 AM
jdsmoothie's Avatar
Quoted: 12138 Post(s)
Liked: 5527
If the FL/FR speakers are set to SMALL/80Hz (as is recommended), then no as there is no bass management in DIRECT mode as the speakers would be treated as LARGE. For the crossover to be in effect with DIRECT mode, you would have to set the sub to LFE+MAIN (which is not recommended).
jdsmoothie is offline
post #544 of 1020 Old 10-05-2013, 08:22 AM
zibanez's Avatar
Quoted: 36 Post(s)
thanks for the info, btw i've got another questions.
if i increase channel level for front LR and i'am using ext amp for front speakers. Let say i set the value to +10. Is it pushing the external amp or avr amp?
Bedroom theater
zibanez is offline
post #545 of 1020 Old 10-05-2013, 09:07 AM
jdsmoothie's Avatar
Liked: 5527
External amp. Unless the speakers are connected to the speaker posts on the AVR, the AVR's amps are not being used.
post #546 of 1020 Old 10-07-2013, 02:07 AM
zibanez's Avatar
Quoted: 36 Post(s)
thanks jd
Bedroom theater
zibanez is offline
post #547 of 1020 Old 10-11-2013, 03:50 PM
djlman's Avatar
Follow up to September update breaking Airplay.
No luck with the soft reset. Have also tried a microprocessor reset with no luck also.
I thought it may have something to do with iOS 7, but my MacBook that has not had a recent update can't see the amplifier either.
Very frustrating, as this is one of the reasons I bought the Marantz. frown.gif
System components:
Marantz NR1603 AV Amplifier
Bose Lifestyle 15 Speakers
Sony BDP-S373 blu-ray
Apple TV, 3rd Generation
HUMAX youview PVR
Sony Playstation 3, 3rd Generation
Nintendo Wii
djlman is offline
post #548 of 1020 Old 10-13-2013, 11:02 AM
jwc13ac's Avatar
Hello crew,
I'm looking to upgrade my marantz 6003 to one of the slim lines (potentially)
I had a question, can you watch one source and listen to another via hdmi, or any other method? Right now I have my computer connected via optical and it allows me to listen to music while watch tv. It's kind of a workaround rather than a feature, and somehow it works.
If that doesn't, can you listen to airplay while watch a different source via hdmi? This would almost be better.
Thanks for any help!
_______
~ Joe
jwc13ac is offline
post #549 of 1020 Old 10-14-2013, 11:48 AM
beowulf's Avatar
Hi all,
I purchased a NR1403 last month and have been very happy with it, except for a recent issue with the center channel audio from Netflix streaming on the PS3. When the Netflix app is set to output audio in Dolby Digital Plus format, the center (dialogue) channel has a sound that I would describe as "warbling" or "clipping". This is most noticeable on "ess" syllables in the dialogue, particularly at higher volume; if the problem is present in channels other than the center I haven't been able to hear it. I was intiially prepared to chalk this up to poor compression on Netflix's end, but I did find another post on the forums describing an identical issue with a different Marantz product:
http://www.avsforum.com/t/1420942/marantz-sr7007-av-receiver-owners-thread/480#post_23283269
Depending on the particular program being streamed, I can sometimes resolve the issue by disabling Dolby Digital Plus output on the PS3, forcing it to fall back to regular DD output. This doesn't always fix the problem though. I've been unable to replicate the problem outside of Netflix, but then I also don't have immediate access to other DDP sources. Everything else appears to be working great - no problems with Netflix stereo encoding, Blu-rays, games, etc.
Any thoughts?
beowulf is offline
post #550 of 1020 Old 10-16-2013, 12:10 PM
Bklynblaze's Avatar
Hey everyone-
Just bought the 1403 along with Energy 5.1 Take Classics to go along with my Samsung UN60F8000. Ready to blow the wife and neighbors away. Lol
Anyway, my question was what is the best way to set up the speakers for sound? Do you recommend hooking up all components (STB, PS3, etc..) to Television then have one optical out to receiver or vice versa? To be honest with you this is my first time hooking up a 5.1 surround sound system and could use some help. I don't want to have to give Geek Squad a call. Haha
Bklynblaze is offline
post #551 of 1020 Old 10-16-2013, 01:05 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 757
That would be the worst way because your audio will likely be limited 2 channel stereo coming from the TV optical out.
Connect all your devices to the receiver with HDMI first so you can get the best possible audio such as TrueHD and DTS-Master Audio from Blu Ray.
Afro GT
afrogt is online now
post #552 of 1020 Old 10-16-2013, 02:44 PM
Bklynblaze's Avatar
Ah gotcha. Then one HDMI from TV to receiver for video for all components? Thanks for your help.
post #553 of 1020 Old 10-16-2013, 02:52 PM
Selden Ball's Avatar
Quoted: 3070 Post(s)
Liked: 1501
Yes, that should work. However, some cable and satellite set-top-boxes have HDMI limitations which cause intermittent problems when plugged into receivers. They work fine when plugged directly into TVs, though.
Selden
Selden Ball is offline
post #554 of 1020 Old 10-16-2013, 03:04 PM
Bklynblaze's Avatar
It will be a Verizon Fios STB. Should that work?
post #555 of 1020 Old 10-16-2013, 03:27 PM
jdsmoothie's Avatar
Liked: 5527
His comment was likely really more of a general comment as the issue can be present in some models of a particular provider and not others, there is no list as to which works and which doesn't. You'll just have to wait to connect your particular model box to find out which configuration you'll have to use.
post #556 of 1020 Old 10-16-2013, 09:18 PM
Bklynblaze's Avatar
I understand...makes sense. But if I hook up the way you recommend can I get sound from my tv speakers only if I want, instead of full blown surround sound? And how? For example if I just wanna watch the news or don't want to wake the wifey up with thundering bass.
post #557 of 1020 Old 10-17-2013, 01:57 PM
Nymeria's Avatar
Hi all,
Happy owner of a Marantz 1603! Just one question:
While playing an mkv film using an SRT subtitle the Marantz receiver fails to consistently playback the subtitle. The first line of the subtitle is fine, however every second line of sub is 'blocked' somehow. There is also a hiccup in sound.
I'm using a Popbox V8 media streamer. I havent had this problem with my old receiver, so i know it's not the popbox that's causing the problem.
anyone else had this issue? Help needed!
Thank you in advance.
Nymeria is offline
post #558 of 1020 Old 10-17-2013, 03:14 PM
jdsmoothie's Avatar
Liked: 5527
Yes. The AVRs have a feature called "HDMI Standby Pass Through" which will pass HDMI audio/video through to the TV when the AVR is in Standby. Although as already mentioned, you may want to avoid and possible HDMI handshake issues with the cable box by connecting the HDMI directly to the TV with optical from the box to the AVR.
post #559 of 1020 Old 10-23-2013, 04:49 AM
sublimerocks86's Avatar
Hello everyone, my apologies if this has been covered before but I have recently acquired a SonyBDP-S5100 Blu Ray Player to be hooked into my 1603. Right now, all my films are only playing in either multi channel stereo or a setting called multi channel out. When my ps3 was playing Blu Ray films, I was able to play films in Pro Logic II. I've now lost that ability.
Does anyone know how to fix this? I'm at a loss...thanks! I've tried to mess with the player but it didn't seem to work thus far.
Thanks for any assistance!
sublimerocks86 is offline
post #560 of 1020 Old 10-23-2013, 05:41 AM
afrogt's Avatar
Liked: 757
Are you watching really old movies or something? Blu Ray movies should be either TrueHD or DTS-MA. If the player is doing the decoding it would send the high res audio as Multichannel PCM.
Sounds like neither one of your players are set up properly. Are they both connected via HDMI?
Afro GT
post #561 of 1020 Old 10-23-2013, 06:17 AM
jdsmoothie's Avatar
Liked: 5527
Sounds like you never reset the PS3 or the new Blu Ray when you connected it to the 1603 otherwise both would be able to output DD/DTS 5.1 rather than just the stereo 2.0 you are currently getting now. Set the Secondary Audio mix to OFF on the new player as well as resetting it while connected to the 1603.
post #562 of 1020 Old 10-23-2013, 06:17 AM
Well the ps3 was fine. The Blu Ray player is connected via HDMI and is only playing as mentioned. I'm watching Avatar. I have it hooked into the Game port. Will that make a difference?
post #563 of 1020 Old 10-23-2013, 06:24 AM
jdsmoothie's Avatar
Liked: 5527
If the AVR was displaying "Pro Logic II" when a movie was playing on the PS3, that meant the PS3 was only passing a stereo 2.0 signal, as would be required when connected directly to the TV. You need to reset the PS3 so it can play DD/DTS 5.1. The new Sony BDP simply needs to be set to "bitstream" and Secondary Audio disabled as the player is currently doing the decoding.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_L25
post #564 of 1020 Old 10-23-2013, 11:58 AM
boochydog's Avatar
i have a question regarding this comment. i have the Home Theater set-up in my Signature line below - all HDMI hook-ups. I am playing the "Inception" Blu-Ray Disc in my PS3. The TV info screen for the movie shows it is playing at "DTS-HD MA 5.1 Ch." However, on the front panel of my NR1403, the display states "Auto MCH STEREO" with both the PCM and DIG lights on. Am I right to think that if i press the PURE button on the remote to the AUTO option that it will default to the original sound source for the movie (in this case, DTS-HD MA)? Also, the MOVIE button on my remote does not give me a DTS-HD MA option to select from.
Also, if the receiver is playing DTS sound quality, shouldn't the DTS input signal light be illuminated on the receiver panel? I have already messed around with the Sound Options on the PS3 itself. Am I missing something here?
Marantz NR1403 AV Receiver
Samsung Series LN46C650 LCD TV
Klipsch F-20 Floorstanding Front Speakers
Polk TSi100 Rear Speakers (Floorstands)
Klipsch WC-24 Center Channel Speaker
Outlaw M8 Subwoofer
PS3 (3G)
Blue Jeans Canare 4S11 & Belden 5T00UP Cables (w/ Banana Plugs), GE Digital Fiber Optic Cable
boochydog is offline
post #565 of 1020 Old 10-23-2013, 01:13 PM
boochydog's Avatar
Originally Posted by boochydog View Post
i have a question regarding this comment. i have the Home Theater set-up in my Signature line below - all HDMI hook-ups. I am playing the "Inception" Blu-Ray Disc in my PS3. The TV info screen for the movie shows it is playing at "DTS-HD MA 5.1 Ch." However, on the front panel of my NR1403, the display states "Auto MCH STEREO" with the PCM and DIG lights on. Am I right to think that if i press the PURE button on the remote to AUTO option that it will default to the original sound source for the movie (in this case, DTS-HD MA)? Also, the MOVIE button on my remote does not give me a DTS-HD MA option to select from.
Also, if the receiver is playing DTS sound quality, shouldn't the "dts" input signal light be illuminated on the receiver panel? I have already messed around with the Sound Options on the PS3 itself. Am I missing something here?
well, i think i actually solved this issue using a PS3 related comment from two pages back. i went to the PS3 screen under "Video Settings" and changed one of the settings from "LPCM" to "bitstream." when i made the switch, there was a warning that all sound from the BD may not be heard, but after the change the NR1403 display now says "DTS-HD MA" and the "dts" light is lit up when Inception is playing at 1080p and 48 kHz. the PCM light is also no longer lit on the display. in addition, DTS-HD MA is now an option when i press the MOVIE button on the remote. i think that took care of it!!!
Outlaw M8 Subwoofer
PS3 (3G)
post #566 of 1020 Old 10-28-2013, 09:10 PM
Cudi912's Avatar
Greetings everyone!
I have the Marantz NR1603 and am struggling to play music through the media player via the network. Internet radio works fine so no issues connecting with the network.
I have run the settings as suggested in the pdf and have ensured network sharing is enabled on my PC (windows 7) and have 'allowed' access between the Marantz and my PC.
But when I click on Media Player, the next screen says, 'empty' and I cannot select anything.
Like I said, I've changed the settings on my computer as instructed in the pdf, the network is active and working regarding the internet radio etc. so I can't figure out why 'empty' is appearing when I click media player.
would appreciate any assistance in this matter.
thank you!
Cudi912 is offline
post #567 of 1020 Old 10-28-2013, 10:19 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3095
Originally Posted by Cudi912 View Post
Greetings everyone!
thank you!
I´ve had this issue with my NR1602. It´s generally fixed by unplugging the receiver, waiting 30s or longer and then plugging it back in. The NIC resets and then media server access is restored.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #568 of 1020 Old 10-29-2013, 12:23 AM
Cudi912's Avatar
Great, will try out tonight.
Cudi912 is offline
post #569 of 1020 Old 10-29-2013, 05:19 AM
jdsmoothie's Avatar
Liked: 5527
Greetings everyone!
thank you!
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_L29
post #570 of 1020 Old 10-29-2013, 09:42 PM
Cudi912's Avatar
I've turned off the switch at the power source but to no avail. I will try unplugging the receiver to see if that makes a difference.
Cudi912 is offline
Marantz Nr1403 Slim Line Av Receiver , Marantz Nr1603 Slim Line Av Receiver
