Marantz NR1403 and NR1603 Slim Line Receiver Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
Old 12-11-2013, 04:26 AM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
Originally Posted by ramman949 View Post
Pulling my hair out!
Why does this stupid thing constantly change volume levels every single time I change the channel on my Motorola cable box? One channel is loud and clear but once I change it, the marantz will say "offset -7" or -4 or -5, etc. is there a way to stop this?
I've already disabled dynamic eq (now it sounds flat) and while it helped some, it's still doing it. I'm about to return this junk if any of you good people can't help me. My denon 3312 doesn't do this with the same cable boxes. Nor does my lower end demon 1613. So why this thing is doing it, I don't know but I'm frustrated beyond words right now.
How can I stop this or disable the "offset -7" thing every time I change the channel.
/end rant.
Sorry! Just upset. Anyone got any advice?
Thank you.
As noted on p. 77 in your 1403 Owner's manual ... this offset is embedded in Dolby Digital tracks and cannot be turned off and actually should display the same on your 1613 and 3312 as well. You will find the same note below in those Denon model manuals as well.
ramman949 likes this.
jdsmoothie is offline
Old 12-11-2013, 05:30 AM
Cudi912's Avatar
Thank you JD for your help.
I did figure out the Foxtel issue, like you said, it was a menu setting on the box.
Re tv audio, I did attempt that previously but didn't turn off TV n AVR like you suggested. Also got a bit confused as I use a harmony remote. But I will give it another shot tonight. This will definitely come in handy for when my BD player displays the cinavia warning next time. Thanks again.
Cudi912 is offline
Old 12-11-2013, 06:05 AM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Is this related to reference level at all?
milehighou is offline
Old 12-11-2013, 09:20 AM
ramman949's Avatar
Thank you JD.
This is unfortunate news. While both my Denons might have this feature, I only see the volume change per input. Not every time I change a channel. If they are doing it per channel, they must be doing a better job at it than this Marantz is because the volume is not changing as drastically. With the Marantz, going from one channel to another has the differences of either not hearing the people speak or the volume being where you want it or too loud. So if Im watching TV at night while the wife sleeps and I cant hear anything on a channel, I turn it up. But once I change it to another channel, it might be way to loud and wake her up. You really tell a difference at lower volumes. But neither my Denon 3312CI or 1603 do this. What a bummer. Its a nice looking unit. I only bought it because of its size. I should have just got another 1603. Its just for bedroom tv use.
I guess I will be returning this thing if there is no way to stop that issue.
Thank you JD.
ramman949 is offline
Old 12-11-2013, 06:31 PM
jdsmoothie's Avatar
Liked: 5508
Both of my Denon AVRs do this so I'm quite surprised yours don't when connected to the same cable box. You may also want to consider using Dyn Volume and setting the Dyn EQ Reference Level Offset to 10db both of which will help to improve the center channel dialogue.
Old 12-12-2013, 02:25 PM
Gogx's Avatar
I am in dilemma between Marantz 1403 Vs Yamaha RX-V 375.I prefer music and from specification it seems that Marantz is better choice.On the other hand Yamaha have some advantages like usb,4k audio,conections..Anyone has experience with this two receivers?
Thanks for help guys!!
Gogx is offline
Old 12-12-2013, 04:18 PM
jdsmoothie's Avatar
Liked: 5508
The Marantz will likey produce better audio fidelity as it can EQ the sub while the Yamaha cannot. Also, unless you plan on buying a new 4K BDP and 4K TV (> 85") this feature will likely be of no real benefit to you, not to mention by the time there is an abundance of real 4K content available there will likely be yet another HDMI spec change.
Old 12-12-2013, 06:04 PM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
I was considering the Yamaha too, but decided on Marantz due to all the great reviews. I think it's a better quality AVR. Look at the THD of the two receivers. Yamaha's is 0.9% while Marantz's is only 0.08%. That's a whole order of magnitude difference.
Old 12-13-2013, 07:45 AM
Gogx's Avatar
Thank you both for quick answers.4K is as you say still in "future" especialy here where I live in Bosnia and Herzegovina.I do not have much choice here and price both of this receivers is about 400$-very expensive compare to USA.Also I noticed that Yamaha do not have HDMI pass through so you must have always receiver on if you are watching tv.As soon as I bought receiver I will write about my impressions.
Gogx is offline
Old 12-13-2013, 09:17 AM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Good luck! For the same price, I think the Marantz is definitely a better deal smile.gif
Old 12-14-2013, 12:11 PM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Can someone verify this is correct? I'd like to have my sub (and only my sub) EQ'd when listening to 2-channel music. I think I can achieve this by running the AVR in "bypass L/R" mode. I still like to have DEQ engaged with a reference offset of 10. Since I'm in bypass mode, DEQ will not affect my main speakers, either, right?
Old 12-14-2013, 01:35 PM
jdsmoothie's Avatar
Liked: 5508
All speakers and the sub are EQ'd when the Audyssey setup is run. The "Bypass L/R" feature simply allows you to turn off the EQ processing on the FL/FR speakers, however, the other speakers and the sub would still have the EQ processing applied. With only a 2.1 setup, the effect of Dyn EQ would only apply to the subwoofer.
Old 12-14-2013, 03:19 PM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Awesome, that's exactly what I was hoping for. I'm glad Marantz decided to include this option. I guess all receivers don't have this choice.
Old 12-15-2013, 05:28 AM
jdsmoothie's Avatar
Liked: 5508
Old 12-16-2013, 07:02 AM
Bieffe's Avatar
Originally Posted by boochydog View Post
well, i think i actually solved this issue using a PS3 related comment from two pages back. i went to the PS3 screen under "Video Settings" and changed one of the settings from "LPCM" to "bitstream." when i made the switch, there was a warning that all sound from the BD may not be heard, but after the change the NR1403 display now says "DTS-HD MA" and the "dts" light is lit up when Inception is playing at 1080p and 48 kHz. the PCM light is also no longer lit on the display. in addition, DTS-HD MA is now an option when i press the MOVIE button on the remote. i think that took care of it!!!
But how abt what is said here
http://www.engadget.com/2009/04/21/hd-101-how-to-use-dolby-truehd-and-dts-hd-with-your-ps3/
So is urs correct or what is said here?
Bieffe is offline
Old 12-16-2013, 12:36 PM
ramman949's Avatar
*Update*
I called Marantz to see if they had anything to offer before I returned this thing. They told me that the "-7 reference" thing I see every time I change a channel is NOT normal behavior. They told me to disable Audyssey and dynamic volume all together. IF that didnt stop it, then to reset the unit and rerun Audyssey. And if that didnt fix it, to call them back. Hope it works because the volume offset thing every time I change the channel is bugging me.
Old 12-16-2013, 01:06 PM
ramman949's Avatar
Disabling both and resetting didn't stop the reference thing.
JD, are you saying the "reference -7" is normal every time I change channels?
Old 12-16-2013, 01:11 PM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
I think this is normal. Whenever I switch HD cable channels, I see the same thing pop up for a few seconds (although, the numbers change).
Old 12-16-2013, 02:06 PM
ramman949's Avatar
Thank you for confirming. That's exactly what mine does. -7 to -4. How do you cope with that? It drives me nuts. Especially at night time listening when its low enough not to wake my wife, but the second I change channels its to quiet or too loud. Im constantly messing with the volume. I hate it.
Old 12-16-2013, 02:37 PM
CTOM9's Avatar
Here is what my new setup will be comprised of:
TV – Samsung 8500 (3D capable)
STB – FIOS HD
Blu Ray DVD – Oppo 103D
Media Player – Western Digital
Receiver – Marantz NR1403 (3D processing capable)
Ideally I am looking to leverage the Oppo video processing and Darby technology as much as possible. As I watch tv content well more than I will be using the Media Player, I am intending to run the FIOS STB into the Oppo and the Media player straight into the Marantz receiver. The receiver would then feed the TV as a single video source.
Setup Option #1:
1. FIOS STB into Oppo
2. Oppo into Marantz
3. Media Player also into Marantz
4. Marantz into TV
All above the above via HDMI
Or
Setup Option #2:
1. FIOS STB into Marantz
2. Media Player into Marantz
3. Marantz into OPPO
4. Oppo into TV
Questions:
1. Option #1 - If I have the Oppo send into the Marantz, and then Marantz into TV – does anyone know if I will lose the Darby enhancements by putting the marantz between the OPPO and the TV? Or, can I expect that the Marantz will pass through the Darby enhancement to the TV?
2. Option #2 - Can I have the FIOS STB, and Media player go into the Marantz, then have Marantz into Oppo with Oppo into TV? If I go this route – how can I ensure that Audio output stays at the Marantz and doesn’t get transferred up to the Oppo?
Thank you!
CTOM9 is offline
Old 12-16-2013, 02:47 PM
jdsmoothie's Avatar
Liked: 5508
Option #2 is out as there would have to be a cable back from the Oppo to the Marantz for BD/DVD audio and doing so may cause feedback. So Option #1 would likely be your best bet.
Old 12-16-2013, 02:50 PM
jdsmoothie's Avatar
Liked: 5508
*Update*
Sorry, but you were given bad info ... it is indeed very normal and listed in your Owner's manual as I pointed out to you last week.
Old 12-16-2013, 03:03 PM
wronganswer's Avatar
I
I have a Denon 1913 and it does the same. Is normal in Marantz and Denon avr's
wronganswer is offline
Old 12-16-2013, 03:11 PM
CTOM9's Avatar
Option #2 is out as there would have to be a cable back from the Oppo to the Marantz for BD/DVD audio and doing so may cause feedback. So Option #1 would likely be your best bet with the video processing in the AVR disabled.
So I'm disabling the AVR in the Marantz - and this would serve to have it act strictly as a pass through for video correct? (Same video signal it gets in is what it would also send out to the tv?) Thanks.
CTOM9 is offline
Old 12-16-2013, 03:13 PM
jdsmoothie's Avatar
Liked: 5508
Old 12-16-2013, 04:52 PM
ramman949's Avatar
Originally Posted by wronganswer View Post
I
That's crazy. I have the denon 1613? And 3312 and they only do this between inputs, not channels. If they are doing this under my nose, they are doing a much better job at it. Because on the same tv, same cable box, my volume is not going all over the place.
Old 12-16-2013, 08:25 PM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
I don't notice big differences in sound when changing channels, although maybe it's related to your cable? Some of my channels are a little different. I might not notice it much because I don't do a lot of channel surfing. Most of the time, I'm watching shows I recorded on DVR.
Old 12-16-2013, 10:48 PM
ramman949's Avatar
I suspect its a combination of my cable box and the Marantz. I plugged the optical cable from the cable box to the Marantz and it STOPPED showing "offset -7" every time i switched channels, but it limited me to PLII sound output only. No more Dolby digital or DTS. I give up. Im off to find another slim looking AVR.
Thank you to everyone who helped.
Old 12-17-2013, 05:42 AM
jdsmoothie's Avatar
Liked: 5508
There is no DTS on cable/sat TV rather the best that can be passed is DD 5.1 which can pass over an optical cable. Check the settings on your cable box. The offset display will appear whenever there is a change in value (eg. going from SD PCM 2.0 channel to a HD DD 5.1 channel).
Old 12-17-2013, 05:46 AM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
^^^ This.
Usually there is a setting under "audio" on your cable box where you can tell it optical, HDMI, etc.
Marantz Nr1403 Slim Line Av Receiver , Marantz Nr1603 Slim Line Av Receiver
