Marantz NR1403 and NR1603 Slim Line Receiver Thread - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #781 of 1020 Old 06-13-2014, 05:22 AM
jdsmoothie's Avatar
Quoted: 11770 Post(s)
Liked: 5378
TV - Anynet+ set to ON, audio set to External speakers
AVR - HDMI Control set to ON
Although the cable shouldn't matter, try changing the cable from the AVR to the TV. Also, there's always the optical from the TV to the AVR which for many is the better connection as it can pass DD 5.1 as well as the AVR not always changing to TV Audio when you don't want it to.
jdsmoothie is offline
post #782 of 1020 Old 06-13-2014, 11:26 AM
joeybutts's Avatar
Gang, I have one time been able to airplay over Zone 2 without interfering with zone 1. I got it to happen again but was a huge pita. Now I can't get it to do it.
Was I dreaming? what am I missing here? Thanks!
joeybutts is offline
post #783 of 1020 Old 06-13-2014, 06:16 PM
jdsmoothie's Avatar
Liked: 5378
Will normally interfere by design.
post #784 of 1020 Old 06-27-2014, 12:55 PM
Liked: 1
I had the Marantz NR1403,
I changed to the Yamaha slimline RX-S600.
The auto setup was spot on to my old manual settings.
I use Cambridge min 11 speakers,
The difference in sound was a walkover,
Sky tv Digital tv Disc players huge success soundwise
coenish is offline
post #785 of 1020 Old 07-01-2014, 04:44 PM
Liked: 0
Sorry in advance because I'm sure this has been asked a lot but are the 50 wpc in the NR 1403 enough to drive 5 channels? I have the andrew jones pioneer speaker set and everything I've read seems like it would be enough however I would like some owner input on this. My pioneer avr crapped out on me and I'm looking to replace it/ get a slight upgrade (it was the cheapest one I could find). thanks
majortom412 is offline
post #786 of 1020 Old 07-01-2014, 05:11 PM
jdsmoothie's Avatar
Liked: 5378
It wouldn't be sold as a 5CH AVR if it couldn't.
post #787 of 1020 Old 08-19-2014, 10:09 AM
zerodeefex's Avatar
Any clues as to the output voltage for the preouts on the 1603 model?
zerodeefex is offline
post #788 of 1020 Old 08-19-2014, 10:41 AM
insync44's Avatar
Quoted: 23 Post(s)
Would the Marantz 1403 be enough to drive my B&W 802 Matrix Series 2 speakers? Replacing my Yammy 671. Would that be considered a step up in sound? Only reason I'm asking is that I picked up the Marantz yesterday for $250 CDN at BestBuy.ca (one day sale only).
insync44 is offline
post #789 of 1020 Old 08-28-2014, 12:59 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Just bought an AppleTV and trying to determine which HDMI input to connect to, Media Player or Aux input? Is it possible to reassign HDMI imputs, can I reassign the CD input so it outputs audio and video?
mbroadus is online now
post #790 of 1020 Old 09-08-2014, 04:52 PM
ColdsnapBryan's Avatar
Quoted: 51 Post(s)
Whats the difference between the cheaper and more expensive mode?
ColdsnapBryan is offline
post #791 of 1020 Old 09-08-2014, 05:34 PM
jdsmoothie's Avatar
Liked: 5378
More features and better version of Audyssey.
post #792 of 1020 Old 10-21-2014, 03:31 PM
lacro's Avatar
Does anyone know if the 1403 receiver has any 12v 100 MA output ports that could trigger a Niles Audio SPK-1? It's a switching devise to be able to use 2 amps with one set of speakers. It works by using a 12V 100 MA (min.) trigger to switch to the second amp. On a receiver with a switched 120V outlet, a 12V wall wart will trigger the switch when the receiver is powered on. I just wondered if there is any of the ports on the 1403 that are used to trigger other components might have 12V's available. I can trigger the switch another way, but using the receiver would be ideal....
Larry
lacro is offline
post #793 of 1020 Old 10-21-2014, 03:47 PM
jdsmoothie's Avatar
Liked: 5378
No it does not as this is a feature only offered on the "SR" models.
post #794 of 1020 Old 10-23-2014, 01:32 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Would like to add a turntable to my NR-1504, first, can I do this? Looking at the Marantz TT42P Fully Automatic Belt Drive Turntable with On-Board Phono EQ (Link to turntable) The instructions indicate that I can plug it into the CD input, I'm assuming I connect the RCA plug into the CD Audio In on the receiver? Anyone know of a turntable that uses HDMI?
post #795 of 1020 Old 11-24-2014, 02:09 PM
cacophonix's Avatar
Quoted: 24 Post(s)
I've a 1603 that i bought from best buy early this year, and off late, its display seems to turn off. Every thing works ... i can change inputs, volume etc, but the display on the receiver goes blank after a few seconds of turning it on.
Anyone have this problem?
cacophonix is offline
post #796 of 1020 Old 11-25-2014, 06:32 AM
jdsmoothie's Avatar
Liked: 5378
The unit is likely set to PURE DIRECT mode which will cut off analog video processing to include the front panel display as you describe.
post #797 of 1020 Old 11-25-2014, 11:03 AM
cacophonix's Avatar
Quoted: 24 Post(s)
Thanks for the response.
Turns out that the problem was with the display settings in the Menu. No idea how that happened,but somehow the display was turned off. Once i selected auto-off or on, the problem went away.
Great receiver though. Works very well and does what is expected of it.
post #798 of 1020 Old 11-25-2014, 11:11 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Having a problem with my NR-1504 pass through when the receiver is on standby mode. When I turn my Panasonic 60VT60 on to watch TV without the receiver, the pass through will switch from cable/sat to TV audio and does not pass the signal to the display. I then have to use the remote to change the input to cable/sat which turns the receiver on and when I turn the receiver back off, it continues to work fine until I turn the TV off. Then we're back to square one when I turn the TV on the next time. Suggestions?
post #799 of 1020 Old 12-03-2014, 07:48 AM
milehighou's Avatar
Quoted: 827 Post(s)
Liked: 183
Anyone have recommendations for the best way to play Spotify through my AVR? I have a PS4 connected, but of course, it doesn't work with Spotify (thanks Sony). I'm thinking just connecting my laptop to my AVR would work well. It has a single line-out for audio (headphone jack) but I have an adapter that splits it into RCA jacks.
milehighou is offline
post #800 of 1020 Old 12-03-2014, 09:00 AM
jdsmoothie's Avatar
Liked: 5378
Set HDMI Control to OFF on the NR1504.
post #801 of 1020 Old 12-08-2014, 07:34 AM
ww3869's Avatar
Does anyone know the model number of the NR1403 setup microphone? I basically inherited a home theater setup that came with the nr1403, but the audyssey setup microphone wasn't included so I want to find one online. I keep running in to models acm1h and acm1hb. Can anyone verify which one came with their nr1403? I have contacted Marantz support but haven't heard back yet and I'm kind of wanting to order it today( to have it by this weekend when I will have some time to set it up). Thanks!
ww3869 is offline
post #802 of 1020 Old 12-08-2014, 08:06 AM
jdsmoothie's Avatar
Liked: 5378
Either of those mics will work with the NR1403, although as noted on p. 2 of the Owner's manual, it comes with the ACM1HB.
post #803 of 1020 Old 12-08-2014, 08:09 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
FWIW...I have the NR1504 and mine uses the ACM1HB microphone.
post #804 of 1020 Old 12-22-2014, 10:07 AM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
Hi All:
I am an audio noob so please bear with me if I am using incorrect terminology to describe what I am trying to do. I could really use some help on an issue I am trying to figure out:
I have an older Yamaha receiver that has great sound, does the majority of the newer (7 channel +) sound formats (it will mainly be used for movies etc.) but does NOT have HDMI.
I also have the Marantz NR1403 which is a great little receiver, has HDMI but is only 5.1.
I would like to use the Marantz for video inputs/output and then output the audio to the Yamaha for sound.
I planned on using the optical out for sound from the TV back to the Marantz in addition to the HDMI ARC, as there are apps on the TV that I will use and will need to send the sound back to the receiver (I had read in an earlier post in this thread that using optical was better than just relying on the ARC).
I wanted to know if I could output the audio from the 1403 to the Yamaha via the pre-outs and use the Yamaha for the newer/larger sound formats to drive my speakers. Can the Marantz pass through these sound formats via the preouts to the Yamaha or will it only send 2 channel audio?
Is this approach even advisable or should I just rewire the speakers to the marantz and stick with 5.1 while I wait?
I am doing this while I wait for a single receiver solution that has hdcp 2.2 and hdmi 2.0 etc. all settled that I will add a 4k Blu Ray player to when these come out.
Many thanks in advance for any guidance on this issue.
W.
wicklow is offline
post #805 of 1020 Old 12-22-2014, 10:14 AM
Galager's Avatar
^Do you have enough speakers to run 7.1? Using two AV receivers is a little crazy to me. Either use the yamaha for sound and run the hdmis directly to the tv and change inputs on the tv or get an HDMI switch box. You are not gaining anything by using the marantz for video switching. Either go all in with it, or leave it out of the loop.
wicklow likes this.
Galager is offline
post #806 of 1020 Old 12-22-2014, 10:46 AM
wicklow's Avatar
Quoted: 327 Post(s)
Liked: 277
Thanks for the response Galager.
Yes, I do have enough speakers already set up for 7.1. its a weird situation I kind of inherited the older set up from the previous owner of the house who gave it all to me when he left. Back in the day I'm sure it was a great set up but no HDMI makes it a bit messy to deal with.
That makes a lot more sense to be honest. So run each component (BR Player, XBONE, PS4, STB) directly to the TV and then run optical out from the TV to the Yamaha and do away with the Marantz altogether. However, I don't believe that optical can carry 7.1 surround sound formats which when I think about it negates my first idea as well. If my marantz cannot do 7.1 but can accept HDMI, and my yamaha can do 7.1 but cannot accept hdmi then how do i get 7.1 from my tv to the yamaha?
You know, thinking it through, I am just going to take the Yamaha out of the mix and go with the Marantz and 5.1 for the moment. It will be easier to connect all of the other components and when I get the new receiver I wont have to try to get behind the TV (which is quite difficult as it is).
Thanks again for helping me think this through, appreciate it.
W.
wicklow is offline
post #807 of 1020 Old 12-25-2014, 03:02 PM
solobaric's Avatar
Need some help with some lip sync problems I'm having with a 1403. I'm using a Ps3 as my source. With Blu rays predominantly I'm having some lip sync issues. Sometimes it's really noticeable other times it's not. Any solutions to this besides the manual adjustment under Audio Delay in the main menu of the 1403? Hate adjusting this every single time I start to notice the lip sync.
solobaric is offline
post #808 of 1020 Old 12-25-2014, 07:13 PM
jdsmoothie's Avatar
Liked: 5378
Consider using an optical cable from the PS3 in addition to the HDMI cable if it resolves the issue.
post #809 of 1020 Old 12-26-2014, 03:13 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
W.
Best choice.
wicklow likes this.
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
post #810 of 1020 Old 12-26-2014, 09:59 PM
solobaric's Avatar
Will give it a shot. Will the optical cable automatically be recognized by the marantz/Ps3 or is there a setting I need to look for? Also would a better quality or different hdmi cable possibly make a difference?
Marantz Nr1403 Slim Line Av Receiver , Marantz Nr1603 Slim Line Av Receiver
