Marantz NR1403 and NR1603 Slim Line Receiver Thread - Page 30 - AVS | Home Theater Discussions And Reviews
post #871 of 896 Old 03-28-2015, 12:09 PM
Liked: 0
Originally Posted by RRDave View Post
Tell me a bit more about the Bluetooth transmitter you have such as type and model number and I'll look.
Sent from using Tapatalk
It is a Rayson BTA-131.
Thank you for your help.
I ordered a headphone amplifier from Amazon just in case it works with the Marantz pre out.
Aradman is offline
post #872 of 896 Old 03-28-2015, 12:43 PM
RRDave's Avatar
Wouldn't it be possible to just use the existing 1/4" headphone jack on the 1403 with a adapter cable as the input to the Rayson box? It looks like it has a 3.5mm input jack. Otherwise if this is not possible, than this:
http://www.parts-express.com/topping...utput--310-310
should work.
RRDave is offline
post #873 of 896 Old 03-28-2015, 12:50 PM
RRDave's Avatar
If the headphone jack on the 1403 is available, than this:
http://www.parts-express.com/parts-e...-6-ft--240-069
May be all you need.
RRDave is offline
post #874 of 896 Old 03-28-2015, 01:02 PM
Liked: 0
If the headphone jack is used, the speaker outputs are disabled. My wife wouldn't like that. She is listening to the TV using the speakers.
The pre out works in parallel with the speakers. I bought the https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 to amplify the pre out output. What do you think?
Thank you
Aradman is offline
post #875 of 896 Old 03-28-2015, 01:04 PM
RRDave's Avatar
I see. Didn't know that. Than the amp may be your best bet.
RRDave is offline
post #876 of 896 Old 03-28-2015, 01:08 PM
Liked: 0
Did you see my edited comment on the amplifier I bought?
Aradman is offline
post #877 of 896 Old 03-28-2015, 01:08 PM
RRDave's Avatar
Might even want to check Craigslist. Really most any stereo amplifier would work as long as it has the inputs and headphone jack.
RRDave is offline
post #878 of 896 Old 03-28-2015, 01:35 PM
RRDave's Avatar
I think the Pyle amp will not work. I believe this amp functions more as a "splitter", taking a already amplified headphone level output as its input and then splitting it to four outputs. The 12VDC, 150ma input seems to confirm this. That is not enough power for a true headphone amplifier.
If you would like to learn more, here's a good read:
http://www.goodcans.com/HeadphoneRev...oneAmp101.html
Dave
RRDave is offline
post #879 of 896 Old 03-28-2015, 01:40 PM
Liked: 0
Dave
Are you sure? I am really upset by all of this.
Aradman is offline
post #880 of 896 Old 03-28-2015, 02:09 PM
RRDave's Avatar
Pretty sure without actually trying it out myself. I know with certainty the topping amp would work. The unknown is the Rayson box. It's data sheet is vague in regards to its input specs "·2.5mm phone jack that accepts various kinds of Audio sources." It says to plug into a headphone jack, which means to me it is expecting an already amplified signal.
RRDave is offline
post #881 of 896 Old 03-28-2015, 02:56 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3714 Post(s)
Liked: 2181
The 1403 is still available at accessories forless.com. They are the authorized Marantz reseller for last year models and factory refurbs. Full factory warranty I believe.
Full 3 year factory warranty is only available with "new" in box units, while an authorized refurb would only have a 1 year warranty.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #882 of 896 Old 03-30-2015, 06:52 PM
Liked: 0
You were absolutely right. It did not work.
Now I am finally going to do what I should have done first. I am going to get a couple of handymen to unmount the TV off the wall and I am going to connect the TV audio out to my hearing aid transmitter. End of story!!!
Aradman is offline
post #883 of 896 Old 03-30-2015, 11:58 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Originally Posted by Aradman View Post
I have hearing aids that can accept a Bluetooth audio signal from a Bluetooth transmitter that gets a stereo audio signal. I have used my DirecTV box audio out to stream the audio to my hearing aids but I would like to have any device connected to my receiver (DirecTV, DVD, Apple TV) audio to be streamed.
I found out that Marantz has such an audio signal called Pre Out. I tried to connect it to my Bluetooth streamer but nothing is coming out. I even put a set of headphones on it but I hear nothing whether the HDMI sound goes to the TV or the Amplifier.
So my question is: Is the Pre out signal, from the Marantz NR-1403, a regular audio signal that I can use with my Bluetooth audio streamer?
If you are using the red/white analog outputs from your DTV box connected to your Bluetooth transmitter, then as long as the AVR is set to STEREO mode, so to should the FL/FR pre-outs of the AVR work as well.
Doing so would require you connecting all of your sources directly to the TV instead of the AVR otherwise when connected to the AVR will only be transmitting video to the TV but no audio.
post #884 of 896 Old 03-31-2015, 08:02 AM
Liked: 0
You are not correct. You missed an important part of the thread where I wrote that I currently have a Pioneer receiver that has all of my home theater devices as HDMI inputs with one HDMI output to the TV. I am returning the Marantz receiver which I bought because I got misleading information that its pre-outs would be compatible with the Bluetooth transmitter. They are not and even the headphone amplifier did not generate a proper signal from those pre-outs.
Bottom line, I am back with the Pioneer for all my devices to use with my TV and I am going to connect the Panasonic TV Prog Out RCA audio outputs to my Bluetooth transmitter. I should have done that first instead of trying all of the other things.
Aradman is offline
post #885 of 896 Old 03-31-2015, 08:09 AM
RRDave's Avatar
Have you already confirmed that the Panny's RCA audio outputs work with the Bluetooth transmitter? Those may also be pre-out level output level connections where you may be in the same boat as the Marantz receiver, in other words looking for a proper amplifier to boost the signal to where the BT transmitter will work.
RRDave is offline
post #886 of 896 Old 03-31-2015, 09:11 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
More likely simply an incorrect setting on the AVR, but if you have already returned it, no way to confirm. However, my second note still applies ... no audio from the TV unless playing smart apps from the TV or sources connected directly to the TV.
post #887 of 896 Old 03-31-2015, 11:01 AM
Liked: 0
The manual for the Panny shows the audio Prog. Out going to a VCR as an audio input. That is good enough for me.
Aradman is offline
post #888 of 896 Old 03-31-2015, 11:06 AM
Liked: 0
Incorrect again on the first part.
I checked all the AVR settings for the receiver, read the detailed manual that I got on-line and even called Marantz support. They confirmed that the Pre Out audio outputs are not suitable as regular audio inputs to other devices.
Like you said, I returned it and it is over for that approach.
As far as the second part, incorrect again.
Please see my response above to another post.
Aradman is offline
post #889 of 896 Old 04-02-2015, 12:19 PM
RRDave's Avatar
Not sure if you have the solution for this in place or not, but I just saw this:
http://www.mcmelectronics.com/produc...1343-/50-14818
In a catalog. Relatively cheap at $25. Disregard if solved.
RRDave is offline
post #890 of 896 Old 04-05-2015, 07:27 AM
drogulus's Avatar
I'm using my NR1403 with optical out from my Sony TV feeding a 2.1 system. I have a media player (WDTV) and cable box connected by HDMI directly to the TV then through the optical to the receiver. The problem is the optical 2 channel connection sounds like it doesn't mix down multichannel at all, probably because the TV only sends LF/RF with some sound schemes. Rather than connect a bunch of devices directly to the receiver, can I do the ARC connection from receiver to TV with my devices connected to the TV and get sound that way? That would allow me to keep my input settings for cable and media player. The question is whether all TV sound would go to the receiver with ARC (Amazon VOD, WDTV, cable). Thanks for any guidance.
ernie
drogulus is offline
post #891 of 896 Old 04-05-2015, 07:39 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
There would likely be no difference whether you use the optical output or HDMI(ARC) as the TV is likely only capable of receiving 2CH audio from the source device.
post #892 of 896 Old 04-05-2015, 08:51 AM
drogulus's Avatar
I see, it's a receive problem, not a send. My WDTV sends DTS/DD and the TV only sees LF/RF with no mixdown, which is OK for cable and Amazon, definitely not for the media player. So I connect everything to the receiver and lose the ability to set separate video settings (PC for WDTV, for example).
ernie
drogulus is offline
post #893 of 896 Old 04-20-2015, 08:14 AM
YungHeat's Avatar
How is this reciver is it loud and how is the sound quality I'm torn between this one and the pioneer elite vsx-80
YungHeat is online now
post #894 of 896 Old 04-21-2015, 07:07 AM
mbroadus's Avatar
Quoted: 356 Post(s)
Liked: 107
Originally Posted by YungHeat View Post
How is this receiver is it loud and how is the sound quality I'm torn between this one and the pioneer elite vsx-80
Sound quality is very good...not sure how loud you like to listen and the size of your space but its more than powerful enough for my space. It would not have enough power to listen at reference level for a large dedicated theater room.
Panasonic P60VT60 Calibrated by Chad B / Marantz NR-1504 / SVS PC-2000 / Velodyne CHT Front Row / AppleTV 3 / Sony PS4
mbroadus is offline
post #895 of 896 Old Yesterday, 10:27 AM
Daman S's Avatar
Hello! Need some advice from the folks here.
I need a decent musical pre-pro to drive a B&K amp(connected to stereo setup of Dali Helicons) and I'm thinking of getting the Marantz 1403.
Can anyone share if there are any issues with the analog pre-outs as such? I currently have an older Harman Kardon receiver that this will replace as that unit does not have pre-outs.
Thanks in advance!
My HT Setup
My Blu-Rays
PSN Id:blitz500
Daman S is online now
post #896 of 896 Old Today, 06:33 AM
Daman S's Avatar
Thanks in advance!
Well I went out and bought it last night, so far so good. It sounds decent off the bat, but I'm the SQ will improve a bit once the initial burn in happens.
My HT Setup
My Blu-Rays
PSN Id:blitz500
Marantz Nr1403 Slim Line Av Receiver , Marantz Nr1603 Slim Line Av Receiver
Gear in this thread - Nr1403 by PriceGrabber.com
