Marantz NR1403 and NR1603 Slim Line Receiver Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 46Likes
post #901 of 1023 Old 05-05-2015, 12:59 AM
nikica's Avatar
The safe max volume limit is 80 so best to set the Volume Limit setting to 80 to ensure no one can accidentally go above that level.
Thanks for your reply. So you're suggesting that I should avoid listening to music at levels higher than 80. As mentioned I have used volume at 85 and I haven't noticed any strange sounds, but maybe I'm wrong
nikica is offline
post #902 of 1023 Old 05-05-2015, 04:25 AM
jdsmoothie's Avatar
Quoted: 15072 Post(s)
Liked: 7274
Originally Posted by McGowdog View Post
I've noticed that I have to crank this rcvr up to rock out.
This is normal with any modern D&M AVR as it uses a logarithmic volume scale such that average volume will be 50-70% of max.
McGowdog likes this.
jdsmoothie is offline
post #903 of 1023 Old 05-06-2015, 07:40 AM
zibanez's Avatar
Quoted: 36 Post(s)
Hi jdsmoothie,
I have question,
I want to use sub in direct mode, so i change bass management to LFE+Main
Bookshelf speaker set to small. connection to sub using sub out-->lfe
The question, "is the crossover setting in avr still applied in direct mode?"
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Rythmik Audio CI 15" HP600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
post #904 of 1023 Old 05-06-2015, 08:09 AM
jdsmoothie's Avatar
Liked: 7274
There is no bass management when using DIRECT mode so the FL/FR speakers are treated as LARGE and get a full range signal. If you are passing a stereo 2.0 signal, the sub will not be active. If you do want the sub to receive a signal, set the sub to LFE+MAIN and the lower freq < FL/FR crossover will ALSO be sent to the sub in addition to being played by the FL/FR speakers (aka "double bass" mode).
post #905 of 1023 Old 05-06-2015, 09:54 PM
zibanez's Avatar
Quoted: 36 Post(s)
I have bookshelf speaker that capable produce lowest freq around 48-50hz, so if want the sub blend with speaker and minimize the double bass effect, i should adjust the crossover in sub woofer?
Bedroom theater
zibanez is offline
post #906 of 1023 Old 05-07-2015, 03:07 AM
jdsmoothie's Avatar
Liked: 7274
Best configuration is to set bookshelf speakers to SMALL/80Hz.
post #907 of 1023 Old 05-31-2015, 03:30 PM
Dargent0628's Avatar
Quoted: 117 Post(s)
Liked: 57
Hello all--please forgive if this question has been previously posted and answered, I confess I haven't read the entire thread (lots of it, though...) My question concerns the 1403. I am seriously thinking of picking one up from A4Less at their nice price and using its FL pre-outs to drive an external two-channel amp for my Boston Acoustics T1000s. I am looking at the Crown XLS1000 but am concerned that the voltage output of the Marantz will not be sufficient. I THINK that the 1403 outputs 1.3 volts, but I'm not SURE on that spec. I THINK the Crown requires 3.0 volts to be cleanly driven, but I'm not SURE on that spec, either! Any experts out there that can help me with this question? Also, any one else using an external amp with the 1403 that wants to chime in with what amp they're using and their opinions, please do!
Dargent0628 is online now
post #908 of 1023 Old 06-01-2015, 06:00 AM
lacro's Avatar
I have used the 1403 preouts with a class D TPA3116 DIY amp, and it works great, but I don't know if the 1403's output voltage is an issue with the Crown.
BTW/ why do you think you will need more power to drive the T1000's? I think the 1403 should have plenty of power to drive those fairly efficient speakers. I think everyone gets nervous when they see "50 WPC" That 50 watts is at a low distorion, and is plenty enough power for most applications.
IMO the 1403 is the sweetspot in AVR's It is not bloated with bells and whistles, has enough power, it's a small profile, and most of all, it REALLY sounds good.
lacro is offline
post #909 of 1023 Old 06-01-2015, 06:22 AM
Quoted: 14 Post(s)
Liked: 5
Thanks lacro I don't doubt the 1403 will drive the T1000s but what I'd love is the flexibility of an outboard amp stable at 4 ohms so I can swap out any speakers I might pick up off Craig's etc...(I love checking out different speakers esp vintage.) From your comment it sounds like the 1403 can drive the crown effectively...
dargent062801 is offline
post #910 of 1023 Old 06-07-2015, 09:39 PM
McGowdog's Avatar
I wouldn't have bought the 1403 if it didn't have preamp outs to the towers.
McGowdog is offline
post #911 of 1023 Old 06-09-2015, 05:24 AM
jdsmoothie's Avatar
Liked: 7274
One of the differences between the Marantz and Denon models is that all Marantz models have at least FL/FR pre-outs (NR series) with the SR series having a full set of at least 7.1 pre-outs.
post #912 of 1023 Old 06-09-2015, 07:16 AM
Quoted: 14 Post(s)
Liked: 5
Anyone else with opinions about driving a crown amp with the 1403? Of course the investment would be so modest I suppose I can just go ahead and see for myself!
post #913 of 1023 Old 06-10-2015, 09:41 AM
D54Smith's Avatar
From what I see of the specs... I don't see a problem. I have a SR5009, but they have the same voltage specs... I am driving an external amp with the same voltage specs as the Crown. It works fine/great.
dargent062801 likes this.
D54Smith is offline
post #914 of 1023 Old 07-08-2015, 08:38 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
While watching a movie and the there's an immediate loud boom, my NR1504 immediately goes into standby mode. After a few seconds I'm able to turn the receiver on and it works fine. This has happened several times while watching movies and it's becoming annoying. Is there any way to disable the protection mode?
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #915 of 1023 Old 07-08-2015, 08:44 AM
jdsmoothie's Avatar
Liked: 7274
Although you cannot disable protection mode (for obvious reasons), you can either simply lower your subwoofer volume level or enable Audyssey Dynamic Volume and Audyssey Dynamic EQ.
post #916 of 1023 Old 07-08-2015, 08:56 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks...I'll check my Audyssey settings when I get home.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #917 of 1023 Old 07-09-2015, 07:57 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Per Audyssey, my subwoofer level is -6.5dB, Dynamic Volume is Off & Dynamic EQ for movies is On with Ref Level Offset at 0dB. Should I decrease the Reference Level Offset? The receiver went into standby mode again last night during a borage of gunfire while watching a movie.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #918 of 1023 Old 08-12-2015, 07:03 AM
solobaric's Avatar
1403 owner here. I believe my FL channel is on the way out. I can barely hear any audio coming out of it. I've swapped to other speakers and cables for the front left with the same results. Any ideas what might be starting to malfunction ? Also, I'm not under warranty anymore, any body have an idea what a repair may cost through Marantz.
solobaric is offline
post #919 of 1023 Old 08-12-2015, 07:10 AM
jdsmoothie's Avatar
Liked: 7274
Check the Owner's manual and try resetting back to factory defaults. If still no joy, give an authorized repair center in your area a call to see if they'll give a phone estimate otherwise likely about $200. If you have another AVR or 2CH amp you can use, connect it to the FL/FR pre-outs on the 1403.
post #920 of 1023 Old 08-12-2015, 07:25 AM
solobaric's Avatar
Thanks jd. Do you think a factory reset would really help on a channel issue? Just wondering what would have happened that a reset could fix.
post #921 of 1023 Old 08-12-2015, 07:37 AM
jdsmoothie's Avatar
Liked: 7274
No, but if you are considering repair/replacement it is the final step to take ... just in case it might resolve an issue.
post #922 of 1023 Old 08-13-2015, 05:24 AM
lacro's Avatar
That's a good idea! It will let you know if the preamp side is still functioning properly. If it turns out the power amp side is the issue, and the cost to repair is too prohibitive, I suggest you consider just connecting a class D stereo amp to F/L preouts. I build these little amps using cheap Chinese boards (TPA3116 chip), and I have tried using them on the preouts of my 1403. To my ears, the SQ is better than the amp in the 1403! These amp boards cost $5-20 without a case, without case $25-50.
lacro is offline
post #923 of 1023 Old 08-24-2015, 06:32 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Have the NR-1504 and looking to add a Denon DP-300F turntable and a Emotiva XPA-3 amp but do not see any phono or amp connections on the back of the receiver. Can the phono be connected to the CD player input? How would the XPA-3 be connected? Thanks.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #924 of 1023 Old 08-24-2015, 07:04 AM
Quoted: 14 Post(s)
Liked: 5
You'll need an external phono preamp for the turntable. The emotiva connects through your preouts clearly marked in white I believe.
post #925 of 1023 Old 08-24-2015, 07:05 AM
jdsmoothie's Avatar
Liked: 7274
All Marantz AVRs have FL/FR pre-outs at a minimum. The "NR" series have only the FL/FR pre-outs. So you can connect 2 of the 3 available amps on the XPA-3 to the FL/FR pre-outs (see image below). Only the SR6000 series and SR7000 series have a PHONO input; however, the DP-300F has a built-in pre-amp (otherwise if it did not you would need to purchase a 3rd party Phono pre-amp) so you can connect it to any of the analog inputs on the NR1504 (eg. CD).
mbroadus likes this.
post #926 of 1023 Old 08-24-2015, 08:42 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks JD...appreciate it! Probably doesn't warrant the purchase of a 3 channel amp amp with the NR-1504 since I can only connect 2 of 3 channels.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #927 of 1023 Old 08-29-2015, 04:14 AM
Nickxwood's Avatar
NR1063 and Monitor Audio BX6's and BX2's...
Hi Everyone,
This is a great thread which helped me buying my NR1603 originally and I must say that I love it as a receiver! But now for a new question as I'm still not as savy as most of you on here!
I've currently got my NR1603 set up on a 4.0 system with two Monitor Audio BX2s (which I love) at the front and two Cambridge Audio Minx Min 21 at the rear, which has been working really well. We're about to move to a house with a larger room and I'm seriously considering adding a pair of Monitor Audio BX6's to the mix.
My question is would the NR1603 be powerful enough to power a 6.0 system with the BX6s at the front, BX2s at the rear and the Min21 at the sides? Would it be able to go loud whilst watching films / listening to music (currently never go beyond 55 volume). I'd happily give up the Min 21 speakers if that helped the situation.
Any help or advice would be greatly appreciated!
Thanks in advance
Nick
Nickxwood is offline
post #928 of 1023 Old 08-30-2015, 02:14 AM
jdsmoothie's Avatar
Liked: 7274
Originally Posted by Nickxwood View Post
Hi Everyone,
Thanks in advance
Nick
Although it would likely be possible, you would be much better served instead adding a center speaker rather than the rear surrounds.
post #929 of 1023 Old 09-09-2015, 08:38 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
@jdsmoothie - do the speaker terminals in the back accept 10 or 12 AWG wire? Specifically, Blue Jean Cable Belden 5000 Series Cable? Thinking of changing all connections to bare wire instead of banana plugs. Thanks.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #930 of 1023 Old 09-09-2015, 08:58 AM
jdsmoothie's Avatar
Liked: 7274
12AWG should be possible .. 10AWG may be a little to thick, however, banana plugs would be best.
Marantz Nr1403 Slim Line Av Receiver , Marantz Nr1603 Slim Line Av Receiver
