Marantz NR1403 and NR1603 Slim Line Receiver Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #991 of 1020 Old 03-10-2016, 01:41 PM
chas_w's Avatar
Originally Posted by steddye View Post
The reply I recived is not helpfull too:
updates can be downloaded at http://www.marantz.co.uk/uk/support/pages/support.aspx obviously if available for your model. For our part the last update for NR1403 goes back to March 2014 (playback of DTS-HD Master) but is not about netflix functions which are web services used by LAN, but about playback of DTS-HD Master.
Best regards.
I am baffled by the answer, I don't think that the firmware update can be found online and I didn't ask if there was an update for Netflix obviously. Tomorrow I'll write them again.
I had a brief back and forth replying to the message they sent and unfortunately their responses to me provided zero information. Thanks again....let us know if you hear any more.
chas_w is offline
post #992 of 1020 Old 03-10-2016, 02:01 PM
steddye's Avatar
Another mail sent, more exhaustive this time, waiting..............................
steddye is offline
post #993 of 1020 Old 03-11-2016, 05:08 AM
steddye's Avatar
They have confirmed that there is a firmware update for the NR1403 (March 2014) but it is not clear if it will solve the problem. € 61 + shipping charges
what to do now?!
I have to think about it..
steddye is offline
post #994 of 1020 Old 03-11-2016, 07:01 AM
chas_w's Avatar
what to do now?!
Thanks for the update...nice that there is firmware but I think I will live with the issue rather than invest money without any guarantees that it will solve the issue. Maybe I'll look at the NR1506.....
chas_w is offline
post #995 of 1020 Old 03-11-2016, 10:27 PM
steddye's Avatar
This evening they sent me a new email on their own initiative:
" For what concerns the update, we recheck and we can confirm:
firmware update (March 2014) for NR1403 -- solves anomalies and noises with DD + -- "
This month I can't but next one I'll give it a shot.
steddye is offline
post #996 of 1020 Old 03-12-2016, 06:17 AM
chas_w's Avatar
That's encouraging...keep us posted. Thanks.
chas_w is offline
post #997 of 1020 Old 06-01-2016, 10:33 AM
brycefunk's Avatar
Originally Posted by heresnowhy View Post
<div class="quote-container" data-huddler-embed="/t/1409015/marantz-nr1403-and-nr1603-slim-line-receiver-thread/720#post_24472619" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Selden Ball</strong> <a href="/t/1409015/marantz-nr1403-and-nr1603-slim-line-receiver-thread/720#post_24472619"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
heresnowhy,<br><br>
You didn't explicitly mention if you used the TV's ARC HDMI connection. Usually ARC is available on only one of the TV's HDMI inputs, although CEC is available on all of them.</div>
</div>
<br>
Yes, It's in both ports marked ARC, on the TV and the Receiver. I even brought over my old Pioneer receiver and placed it in the position of the Marantz. ARC worked perfectly with the Pioneer. It has to be an issue or setting with the Marantz. I'm not a novice by any means, just unfamiliar with the Marantz nuances....
had the same problem and it drove me crazy. hdmi control stopped working between marantz nr1403 and panasonic 50 inch .
FOUND THE CULPRIT.
removed the hdmi connection from the panasonic dvd player to marantz.
somehow that was interfering. i noticed also guys complaining about ps3 connection causing the same issue.
try removing all hdmi output from marantz one by one and see if hdmi control returns.
brycefunk is offline
post #998 of 1020 Old 06-30-2016, 11:00 AM
jsutton2871's Avatar
New nr1403 user
Only the "networking" models were listed for the update; however, as the NR1403 is not a networking model, only a Marantz authorized authorized repair facility would be able to install a firmware update if available. Best to contact Marantz directly.
As a new NR1403 user with a new unit, i'm trying to determine what the best settings for a 5.1 setup for broadcast tv, streaming and BD dvds would be. The user guide tells you what each function does, but now to configure your system. Should I use default or what parameters are best changed for my setup? Thanks for any help.
jsutton2871 is offline
post #999 of 1020 Old 06-30-2016, 11:13 AM
jdsmoothie's Avatar
Quoted: 12075 Post(s)
Liked: 5499
Dynamic EQ - ON
Dynamic Volume - OFF
Select either DD or DTS depending on whether DD or DTS audio is being received.
jdsmoothie is offline
post #1000 of 1020 Old 06-30-2016, 12:08 PM
New nr1403 user
Thanks JDSmoothie, thats just what I've been looking for.
post #1001 of 1020 Old 06-30-2016, 12:35 PM
New nr1403 user
Edit I seem to have lost Dolby digital. Playing a BD disk set to Dolby 5.1 my only available modes are DTS or Dolby ProgramLogic, Multi ch. vertiual, no Dolby Digital.
post #1002 of 1020 Old 06-30-2016, 12:48 PM
jdsmoothie's Avatar
Liked: 5499
Ensure your BDP is set to "bitstream" + Secondary Audio/Mix set to OFF.
post #1003 of 1020 Old 08-09-2016, 02:28 PM
lussierj's Avatar
I just purchased a NR1403 but it didn't come with a remote. Does anyone have a suggestion of where to get one? Do the remotes from other models work with NR1403? My concern with universal remotes is I have read I cannot access the setup menu with them. Thanks in advance!!!!
lussierj is offline
post #1004 of 1020 Old 08-09-2016, 03:56 PM
RRDave's Avatar
I can access the setup menu with my harmony one.
Sent from using Tapatalk
RRDave is online now
post #1005 of 1020 Old 08-09-2016, 09:20 PM
jdsmoothie's Avatar
Liked: 5499
Any of the various Harmony remote models should work just fine after downloading the NR1403 settings to the remote.
You should also be able to purchase RC018SR directly from Marantz Parts.
http://us.marantz.com/us/support/pages/order_parts.aspx
post #1006 of 1020 Old 10-23-2016, 11:16 AM
Liked: 0
Hi,
I use this item for weeks now.
I saw on specs sheet
this:
-Standby source setting via HDMI control
-Pass through in Standby mode
When i put the NR1603 on standby mode, i can't switch to other HDMI source. I have to turn on the AVR, switch to the HDMI source i want and turn off the AVR.
So can we switch HDMI sources on standby mode with NR1603 as specs sheet says?
nowayno is offline
post #1007 of 1020 Old 10-23-2016, 12:17 PM
jdsmoothie's Avatar
Liked: 5499
Originally Posted by nowayno View Post
Hi,
this:
No, however, that is not what the spec sheet says ... rather simply that a source can pass through in Standby mode. Note the newer 2016 models are able to change the HDMI pass through source without powering on the AVR.
post #1008 of 1020 Old 10-23-2016, 03:40 PM
Liked: 0
Thanks for answering.
I will check new slim 2016 models.
nowayno is offline
post #1009 of 1020 Old 12-03-2016, 07:20 PM
Expidia's Avatar
Quoted: 233 Post(s)
Liked: 210
I have a marantz 1403 . . . anyone know what the port on the back that says flasher?
I was hoping it was an IR in port so I could control the amp on and off with it inside a cabinet.
I picked this up on amazon but it does not work when I pug it into that port:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Anyone know what I can plug into that flasher port to allow me to turn it on and off with the remote when it is shooting from the side of the cabinet?
My tivo remote is Rf controlled, so that unit is not an issue.
thx
UNK65KS8500 (curved model)
HW-J950 Samsung Atmos soundbar-with rears
HW-J8500 Samsung Soundbar (sold 10-24-16)
Sanus universal soundbar speaker mount SA405B1
Samsung 4K Ultra HD Bluray player UBDK8500
Harmony 650 remote ($43 amazon)
Expidia is offline
post #1010 of 1020 Old 12-07-2016, 01:38 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
thx
The manual says, "Used when using a control BOX or other such control devices to control this unit." I believe you can only control the inputs.
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #1011 of 1020 Old 12-08-2016, 02:09 AM
evan1's Avatar
thx
You can use this plugged into the MX port but I don't think it's available anymore
http://us.marantz.com/us/Products/Pa...roductId=RX101
Almarra 318B-Zu Audio Omen-Marantz SA15S1-Nottingham Analogue Interspace Jr.-BlueSound Node-Schiit Modi Uber-AQ CV4 72v dbs speaker cables-Clarity HarvestII Interconnects-TWL powercords-ATS acoustic panels-Echo Buster corner trap
evan1 is offline
post #1012 of 1020 Old 12-11-2016, 05:19 AM
Gunnar's Avatar
Quoted: 13 Post(s)
1603 sometimes won`t turn on, need to unplug first
Hi! I recently got this AVR, and it works great, except that it sometimes won`t turn on. Neither with the remote, nor the power button. If I unplug the power, and plug it in again immediately, it powers up normally. It seems that this happens when I leave it unused for a few days, but this could be just a feeling.. Any advice is appreciated.
Gunnar is offline
post #1013 of 1020 Old 12-11-2016, 11:45 AM
jdsmoothie's Avatar
Liked: 5499
There is always power going to the AVR unless you have it connected to a smart strip in which case, try taking the smart strip out of the loop.
post #1014 of 1020 Old 12-12-2016, 02:18 AM
Gunnar's Avatar
Quoted: 13 Post(s)
i`m not using a smart strip, and it`s plugged in all the time. There is orange light above the power switch, but noting happens when I push the switch (or press the power button on the remote).
Gunnar is offline
post #1015 of 1020 Old 12-12-2016, 02:37 AM
jdsmoothie's Avatar
Liked: 5499
When HDMI Control and/or IP Control are set to ON, ON/Standby power light changes from "red" (normal standby) to "orange".
As this is a 4 year old model, you likely purchased it used, and therefore should perform a series of 4-5 microprocessor resets (p. 154 USA Owner's manual) in a row to ensure all settings are returned to their factory defaults. If the issue still persists, return to seller.
mbroadus likes this.
post #1016 of 1020 Old 12-13-2016, 07:39 AM
Gunnar's Avatar
Quoted: 13 Post(s)
Thanks! Yes, it looks like new, but is used. I`ll do the resets and try again
Gunnar is offline
post #1017 of 1020 Old 12-13-2016, 12:53 PM
Gunnar's Avatar
Quoted: 13 Post(s)
I reset the AVR, but now many options are greyed out. Is there an "advanced" setting..
Gunnar is offline
post #1018 of 1020 Old 12-13-2016, 01:03 PM
jdsmoothie's Avatar
Liked: 5499
All settings have been returned to factory default. So you've got to run Audyssey again and do the speaker/sub configuration.
post #1019 of 1020 Old 12-13-2016, 02:25 PM
Gunnar's Avatar
Quoted: 13 Post(s)
Yes, but eg "Settings" under "Network" was greyed out, and not selectable. But I unplugged the unit for a while, and now the menues are back! Hopefully the power-up problem is also gone..
Gunnar is offline
post #1020 of 1020 Old 12-26-2016, 01:12 PM
Gunnar's Avatar
Quoted: 13 Post(s)
Seems that a few resets did the trick, the unit has started up normally since :-)
Gunnar is offline
Marantz Nr1403 Slim Line Av Receiver , Marantz Nr1603 Slim Line Av Receiver
