Crestron AES Adagio Entertainment System - Setup - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2012, 05:47 PM - Thread Starter
Misha322's Avatar
Hello all,
Just purchased a used Crestron AES off of eBay and am having a problem setting it up and am hoping to find a few answers from someone that has done or witnessed an installation.
First:
The LCD screen is not legible and hard to see the writing unless you look at a cretin angle, almost as if the dimming on it is out of whack and is in need of adjustment. I was unable to find such a control.
Second:
Can't get in to Installer Tools Mode, when pressing Source + Room buttons it does not take me in to Installer Tools Mode as it should but takes me in to System Information where it shows previous owners information. Do I need to reset the system in some way to get access in to Installer Tools Mode?
Any help is appreciated as I need to determine if this is a setting thing or the item was sold to me broken.
Thank you,
Misha322 is offline
Old 05-09-2012, 06:51 PM - Thread Starter
Misha322's Avatar
Well I figured out how to reset the system to factory conditions but still can't figure out how to resolve the LCD screen issue. Can anyone help?
Misha322 is offline
Old 01-25-2013, 02:26 PM
Tchossa's Avatar
Hello,
What did you do to reset to factory?
Best
Tchossa is offline
Old 05-26-2016, 04:41 PM
Liked: 0
Crestron Adagio
A few years ago, I realize, but I'm desperate. How dis you get into the Adagio Installer Tools menu?
HikerDave is offline
