How far does airplay reach? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-07-2012, 10:40 AM - Thread Starter
blackrain's Avatar
Quoted: 20 Post(s)
I have a home theater in my basement. I would like to use my backyard deck as zone 2.
How well does airplay work? Will it reach from outdoors to my basement? Or is it meant to be mostly indoor?
blackrain is offline
post #2 of 3 Old 05-07-2012, 10:56 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
It'll reach as far away as your Wifi device can access your home network which should easily include the deck.
jdsmoothie is offline
post #3 of 3 Old 05-07-2012, 11:54 AM
Ross Ridge's Avatar
Liked: 81
Hmm... I think you may be confused about what AirPlay is.
It will only handle sending music from a device you're using on the backyard deck, through your home network, to an AirPlay compatible receiving device located in your basement.
AirPlay won't help you in getting zone 2 audio from your basement to the speakers on your deck.
If you were intending for the AirPlay compatible receiving device to a new AV receiver with built-in support for AirPlay there are a couple of possible limitations of going this route. One is that I don't think any such AV receiver has wireless networking built-in. You'd either need to connect the AV receiver to your home router through a wired Ethernet cable or use a wireless bridge to connect it. The other is that many AV receiver with built-in AirPlay support only support it in the main zone, not zone 2.
Otherwise it's like jdsmoothie said. AirPlay uses your home network. If you can get good connectivity with your iPhone or iPad on your backyard deck then you shouldn't have a problem with AirPlay.
Ross Ridge is offline
