The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 154 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #4591 of 11632 Old 01-07-2013, 05:20 PM
clev1's Avatar
Hi jpsmoothie. Sorry, but I can't get the 'quote and reply' button to work. Anyway, I 'think' the unit is still on because the display is fully lit. "Main Off......" Plus other small writing at the top of the display.
clev1 is offline
post #4592 of 11632 Old 01-07-2013, 05:22 PM
jdsmoothie's Avatar
Quoted: 15331 Post(s)
Liked: 7485
So then if the main zone and Zone 2 are confirmed off ... perhaps Zone 3 is ON?
jdsmoothie is offline
post #4593 of 11632 Old 01-07-2013, 06:29 PM
Tunneller's Avatar
Hi, I have a related thread. Cable modem comes into a Airport Extreme router upstairs. I have an older Airport router that worked more-or-less fine but was getting to be a lot slower than everything else on the line. The old router does have the ability to be a bridge, I think - it can take wireless in and Ethernet cable out. (I think).
So I think what I am reading is that I can have CableModem->WirelessTransmitter->WirelessBridge->Ethernet->Denon.
Is that right?
My Denon 2313 doesn't arrive until tomorrow. I'm pretty excited .. :-) Trying to get everything else set up for it.
Tunneller is offline
post #4594 of 11632 Old 01-07-2013, 06:47 PM
nevets72's Avatar
LisaF,
From everything you have mentioned if you replace your active amp with a passive speaker selector like this http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10903&cs_id=1090305&p_id=8229&seq=1&format=2#descriptionyou will be probably be fine, you could even split up the speaker sets that go to the different areas.
I looked up the amp you mentioned and it only had 2 sets of speaker terminals. Did they hook all the speaker wires up to just these 2 terminals, or do you have some sort of distribution block? IF you have some sort of distribution block, with only 2 sets of speaker wires going to the amp, you could definitely try hooking those up to the 1913 and seeing if everything works the way you want it too. And even if all the wires hook directly to the amp, you could try moving them all to the 2nd zone speaker terminals on the 1913, but from my experience this isn't a good long term solution. Too many wires in too small a place, it's easy for something to come loose and then you can have speakers loosing signal. Also I want to make sure that the only connections you were using on the back of the amp were the input (red and white wires) and the speaker connections. If you were using some of the other external control features on the amp, you may have to reset that up as well.
Good luck. I also must admit that I really did cringe when I read that you had cut off the ends to the red and white wires and hooked them up to the speaker terminals. On some amps that could have done some real damage to them, I'm glad it didn't do anything to yours.
nevets72 is offline
post #4595 of 11632 Old 01-07-2013, 07:08 PM
clev1's Avatar
Jpsmoothie, I haven't done anything with Zone 3, so no, I haven't checked it, but I will. Also, can you tell me where to find and set Surround Fields in the menu?
clev1 is offline
post #4596 of 11632 Old 01-07-2013, 08:57 PM
Alan P's Avatar
Quoted: 5135 Post(s)
Liked: 3828
Originally Posted by jdsmoothie View Post
On the 7.2 AVRs, dual subs are still only calibrated as one.
Thanks for the correction JDS! I knew I shouldn't try to help out in this thread...I am woefully underinformed. rolleyes.gif
Alan P is online now
post #4597 of 11632 Old 01-07-2013, 09:28 PM
marinated's Avatar
Is that right?
I have a similar setup for my 2313 - I have a cable modem + router upstairs and an airport express near Denon and with an ethernet connection to it
Works fine including software updates (that some have had challenges)
marinated is offline
post #4598 of 11632 Old 01-08-2013, 02:22 AM
jdsmoothie's Avatar
Liked: 7485
Is that right?
post #4599 of 11632 Old 01-08-2013, 02:24 AM
jdsmoothie's Avatar
Liked: 7485
If the AVR isn't shutting down it generally means that there's a Zone still ON. You can change surround modes by pressing/holding the MOVIE or MUSIC buttons.
post #4600 of 11632 Old 01-08-2013, 02:35 AM
jdsmoothie's Avatar
Liked: 7485
Not at all ... would much rather get feedback from current owners regarding your own personal experience. If it's off track, then we'll get you back on track. smile.gif And when I'm off track because I don't have the unit in front of me (as you do), I get corrected as well. smile.gif
As a followup ... only until you get to a model with XT32+SubEQ HT (eg. 4311CI, 4520CI) will the dual subs be handled differently. The models with dual sub pre-outs (eg. 2313CI, 3313CI) use an internal "Y" splitter which can be easily replicated on the lower level models with only a single sub pre-out by using a $3 RCA "Y" splitter cable.
post #4601 of 11632 Old 01-08-2013, 07:24 AM
Nate427's Avatar
Apologize upfront if I'm posting this in the wrong place but I'm an AV Novice here and hoping that I have an issue that someone here is familiar with....
I've had my AVR 1913 for just a few months now with no issues (really enjoying it). Recently the receiver will not turn on (via remote or front power button). To resolve I have to unplug the receiver and plug it back in...I hear a switch inside and seems to reset itself. After doing this I am able to turn it on via remote (or front power button). I've then tested it by turning it off and on several times to see if the issue is resolved and it reponds and turns off and on (seems like the problem is fixed). But if I leave it on for a little while and then turn it off (via remote) it will not turn back on. As a result I need to go through the whole process of unplugging it to "reset it"
The other thing that I noticed (which I'm not sure is normal) is when I unplug and then plug it back in and turn it on - the green Power button flashes several times and you can hear clicking/switching inside the unit.
Appreciate any help/expertise to help resolve!!!
Nate
Nate427 is offline
post #4602 of 11632 Old 01-08-2013, 07:45 AM
Alan P's Avatar
Liked: 3828
Hmmmm....is it overheating at all? Sounds like it might be going into protection mode.
Have you tried a microprocessor reset?
post #4603 of 11632 Old 01-08-2013, 08:04 AM
Nate427's Avatar
can't be overheating...since it can be sitting idle for hours and then when I go to turn it on it won't turn on. Once I unplug it and then plug it back in - that's when it turns on. Again, it's like it's resetting itself.
And I haen't tried a microprocessor reset yet - sorry for asking, but how would I do that?
Thx for the help!
Nate427 is offline
post #4604 of 11632 Old 01-08-2013, 08:27 AM
Alan P's Avatar
Liked: 3828
Manual, page 176. Be aware that this will wipe all of your settings so save them with the web interface first!
post #4605 of 11632 Old 01-08-2013, 08:43 AM
romena54's Avatar
Hello,
I posted this question on a separate thread, but haven't gotten any responses yet. I'm leaning towards getting the Denon 1613, but was wondering if anyone knows of a list of internet radio stations available? All the literature says there's 10,000+ stations available, but I haven't found any full lists. I'm specifically looking for Shoutcast availability. If they don't support Shoutcast, am I correct in assuming that I can play it from my laptop and run HDMI through the front port to get it?
romena54 is offline
post #4606 of 11632 Old 01-08-2013, 08:59 AM
mooshwa's Avatar
Considering purchasing a Denon 1913 Receiver.
Does anyone have any experiencing using a Tivo series 2 remote to control the volume of this receiver?
mooshwa is offline
post #4607 of 11632 Old 01-08-2013, 09:02 AM
Alan P's Avatar
Liked: 3828
Probably not much help, but my Direct TV Tivo remote works with my 2113. I would guess yours would work, too.
post #4608 of 11632 Old 01-08-2013, 09:24 AM
Super Moderator
markrubin's Avatar
Quoted: 1297 Post(s)
Liked: 2786
could use some advice:not sure if this is correct thread?
I am looking for a receiver for my office: all I need is stereo but multichannel is OK
I bought an Onkyo TX-8050 and it is nice but my main listening is Sirius: the Onkyo uses the Sirius internet service which has occasional dropouts on a high speed cable service (many users share this)
Now I notice most of the new Denon's also use Sirius via Ethernet
so my question: which Denon models offer Sirius using the external Sirius module and antenna? I do want a networking receiver and iPad app interface
TIA
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #4609 of 11632 Old 01-08-2013, 09:48 AM
Alan P's Avatar
Liked: 3828
Can't you use the external Sirius module with any receiver? It just plugs into an A/V input like any other component, right?
post #4610 of 11632 Old 01-08-2013, 10:07 AM
Super Moderator
markrubin's Avatar
Liked: 2786
no: there is a connector on back of older Denon receivers to accept the Sirius module for control (a round DIN connector)
post #4611 of 11632 Old 01-08-2013, 10:31 AM
Indiana627's Avatar
I'm thinking of getting a USB powered cooling fan from Coolerguys and was going to plug it into the front panel USB on my 2313. Is that port only active when the receiver is on? I only want the fans running when the receiver is on. Thanks.
Mark
"We named the dog Indiana."
Directv since '03
Indiana627 is offline
post #4612 of 11632 Old 01-08-2013, 10:39 AM
clev1's Avatar
That fixed the problem; now I can turn everything off. Thanks.
Also, I can click 'quote and reply' on my laptop but not my iPhone.
clev1 is offline
post #4613 of 11632 Old 01-08-2013, 10:41 AM
clev1's Avatar
Yes, I discovered changing movie modes by accident, but I'm still searching the manual for information.
clev1 is offline
post #4614 of 11632 Old 01-08-2013, 11:24 AM - Thread Starter
batpig's Avatar
Quoted: 3720 Post(s)
Liked: 3592
clev1 -- I have a full post explaining how to use surround modes on my site: http://batpigworld.com/wp/?p=150
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #4615 of 11632 Old 01-08-2013, 11:24 AM - Thread Starter
batpig's Avatar
Liked: 3592
Yes, the USB port is only active when the receiver is on.
Setup Guide and FAQ
post #4616 of 11632 Old 01-08-2013, 11:27 AM - Thread Starter
batpig's Avatar
Liked: 3592
I think his point was you could use an external Sirius receiver module with audio outputs (RCA or optical or whatever) and just plug it into any receiver as you would any other audio component.
The downside is that you wouldn't get the integration (e.g. displaying channel info on the display).
AFAIK the Denon line dropped the Sirius DIN connector integration a couple of years ago, after the xx10 models.
Setup Guide and FAQ
post #4617 of 11632 Old 01-08-2013, 12:07 PM
clev1's Avatar
Thanks bp, I've downloaded your guide and have been using it. I missed the Sur Snd part. One other thing, is Standby mode and power off the same thing? I've been reading about Pass Through to watch the TV when the receiver is off. As far as I know, I have all settings correct, but when I power off the receiver, I have no signal passing to the tv.
clev1 is offline
post #4618 of 11632 Old 01-08-2013, 12:19 PM
clev1's Avatar
OK, I have Pass Thru working with Main HDMI, but not Zone 2 HDMI. Does that take a special setting?
clev1 is offline
post #4619 of 11632 Old 01-08-2013, 12:31 PM
Super Moderator
markrubin's Avatar
Liked: 2786
understood and I considered that but without integration there is no way to even change channels!
anyway I found a Sirius radio tuner in the attic (SR H2000) and will give that a try: next challenge is to see if I can get a signal to it without having to drill holes for the antenna lead
post #4620 of 11632 Old 01-08-2013, 01:11 PM
Alan P's Avatar
Liked: 3828
OK, so I'm getting my new XS15s from PSA tomorrow (YEAH) and was just thinking that I could sell my old subs (2 / Velodyne F1500s) OR I could re-purpose them.
I've got two options I'm considering:
  • Run all 4 subs from the one sub out on my AVR (Denon 2113ci)
  • Use the speaker level inputs on the F15s and run them between my AVR and FL/FR speakers (Klipschorns)
If I were to run them between the AVR and my K-Horns, would I then set the fronts to LARGE in the Denon? What should I set the F15s crossovers to (40-100hz)?
Denon , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
