The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #5221 of 11557 Old 02-03-2013, 06:34 AM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5518
Originally Posted by RAYARTS View Post
Hi, currently I own a 2010 Sony Bravia TV set and a Denon 2113. Connected through HDMI. I also have connected an XBOX360, TviX mediabox and my UPC mediabox.
How do I configure that if I turn on the TV, my Denon is automatically turned on at the same HDMI input?
And, vice versa, when I shut off the last HDMI device, the Denon goes into standby mode?
Any help appreciated.
DJR.
You must change the HDMI Control setting (p. 106 OM) from it's default of "OFF" to "ON". Doing so "should" power off the devices although powering on again is not guaranteed. In some instances even the power off won't work ... just depends on how well the devices play together. smile.gif
jdsmoothie is online now
post #5222 of 11557 Old 02-03-2013, 06:54 AM
BuffmanUK's Avatar
Thanks for getting back to me. The problem exists on more than one HDMI input port. At present I am not even sure whether it is a general bug in the equipment, I have a wrong setting somewhere or one (or both) of the AVR and bluray is defective.........
BuffmanUK is offline
post #5223 of 11557 Old 02-03-2013, 06:56 AM
BuffmanUK's Avatar
Originally Posted by jdsmoothie View Post
Try connecting the 1713 to each of the other HDMI inputs on the AVR to see if you get the same result. If not, leave it in that HDMI input. If yes, then the issue either lies with the DBT 1713 or the 2313CI. As you have a work around to resolve the issue (ie setting DBT1713 to PCM) you can either stick with that or perhaps try exchanging the 2313CI. The PCM setting results in no loss in audio quality.
post #5224 of 11557 Old 02-03-2013, 06:59 AM
jdsmoothie's Avatar
Liked: 5518
More than one, but have you tried them all?
post #5225 of 11557 Old 02-03-2013, 07:04 AM
BuffmanUK's Avatar
Just checked. Problem is on all HDMI ports.
post #5226 of 11557 Old 02-03-2013, 07:21 AM
jdsmoothie's Avatar
Liked: 5518
When having an issue with a particular device, it's always important to try EVERY available HDMI input as they are not all created equal. That said, as you can create the issue with more than one device it may be AVR related.
post #5227 of 11557 Old 02-03-2013, 07:28 AM
ProfD's Avatar
Quoted: 25 Post(s)
I personally hate having one HDMI port on the front of my 1613. I bought a 1912 last year, and I am almost certainly never going to use the new front HDMI port. I realize it was a strongly desired feature, but now I have one less HDMI port in the back of the 1613 over the 1612. Yes i know i could have purchased a more expensive 1713 or 1913 or higher for more HDMI ports, or a 1612, but I wanted the xx13, and I would prefer one more in the back over the front on my 1613.
ProfD is offline
post #5228 of 11557 Old 02-03-2013, 07:40 AM
jdsmoothie's Avatar
Liked: 5518
post #5229 of 11557 Old 02-03-2013, 08:26 AM
ProfD's Avatar
Quoted: 25 Post(s)
Thanks !!!
ProfD is offline
post #5230 of 11557 Old 02-03-2013, 09:24 AM
jlpowell84's Avatar
Quoted: 1614 Post(s)
Liked: 712
I noticed after I hooked up the Denon 3313 yesterday after I got it home there is a faint humming coming from my tv (Panasonic 50st50) in the upper right corner on one of the circuit boards. It was isolated to when I unplug/plug in the single hdmi from the 3313. It was actually in and out humming sound that I heard from 15 ft away at first. Never heard it before. It resided to a faint humming. But the initial loudness was briefly worrisome. I called Panasonic and thats when we isolated it to the plugging/unplugging the hdmi from the AVR.
jlpowell84 is online now
post #5231 of 11557 Old 02-03-2013, 09:26 AM
jlpowell84's Avatar
Liked: 712
Originally Posted by jlpowell84
I changed it to bitstream but it's still got the 'multi ch in' option. Does this mean it's still feeding pcm to my 3313?
As a reminder, this question and many more troubleshooting tips are answered in the troubleshooting guide linked in my sig.
Ok. Problem solved, secondary audio needed to be off...
post #5232 of 11557 Old 02-03-2013, 09:26 AM
jdsmoothie's Avatar
Liked: 5518
Have you tried the other HDMI output on the 3313CI? Otherwise, it could be an issue with the HDMI board on the TV, especially if you have tried it on another TV and the issue doesn't present.
post #5233 of 11557 Old 02-03-2013, 09:50 AM
Ken Ross's Avatar
Quoted: 5700 Post(s)
Liked: 6068
Originally Posted by Alan P View Post
The 2313 is 4K ready, as is the current HDMI spec (if you have HDMI 1.4, 1.4a or 1.4b cables, you won't need new ones). I wouldn't hold my breath waiting for content, or affordable display devices...could be awhile yet. Although, if you DID find a display you can afford, the 2313 will upconvert all sources to 4K - how that will actually look, I have no idea.
I see these receivers 'upscale' to 4K from the Denon website, but it seems less clear if they can leave a 4K signal untouched and simply pass it through. Does anyone know for sure?
Ken Ross is offline
post #5234 of 11557 Old 02-03-2013, 10:43 AM
jdsmoothie's Avatar
Liked: 5518
Yes, the Denon "CI" models can both pass through and upscale 4k.
post #5235 of 11557 Old 02-03-2013, 10:44 AM
Mike_L_H's Avatar
I'm thinking about replacing my 2309 with a 2313 because I would like to be able to access all of my music files (maybe video also) on my PC (Win 7) via wireless. I have searched this thread and believe that in addition to my existing router, I'll need to purchase a wireless bridge that then connects to the LAN port on the 2313. Am I correct so far? My question is, do the music files appear on the TV as they would on your PC and are you then able to navigate and create playlists without accessing the PC that resides in another room? Also, is there any limitation to the file size? Thanks for your help. Mike
Mike_L_H is offline
post #5236 of 11557 Old 02-03-2013, 10:53 AM
BuffmanUK's Avatar
Any clue what?
post #5237 of 11557 Old 02-03-2013, 12:49 PM
jdsmoothie's Avatar
Liked: 5518
Sorry, but no. If you can easily exchange it, I'd go that route.
post #5238 of 11557 Old 02-03-2013, 12:51 PM
jdsmoothie's Avatar
Liked: 5518
Anyone sitting on the fence waiting for a good deal on a 2113CI may want to check out my post in the Great Found Deals forum. If you are considering a 1913 this sale may be incentive to upgrade to the 2113CI instead. smile.gif
post #5239 of 11557 Old 02-03-2013, 02:05 PM
BuffmanUK's Avatar
Does anyone else have any suggestions. Batpig?
post #5240 of 11557 Old 02-03-2013, 03:15 PM
jlpowell84's Avatar
Liked: 712
What listening mode do you guys watch movies in? I have been testing the Dolby try HD audio on blu rays. I did notice some of my blu rays don't have the master hd audio. Why is that? Can you get them in the hd audio format?
post #5241 of 11557 Old 02-03-2013, 03:32 PM
metalforever's Avatar
Hey everyone - quick newb question. I recently upgraded to the 3313CI and am running Polk spkrs throughout - RT18 fronts, CSI-3 center, FXI3 surround (just 2) and a PSW404 sub. It seems as though I need to crank the volume to 3/4 or higher to get a nice loud sound in the room, and was wondering if I was missing something? I have been through the set up several times. Any suggestions would be AWESOME!
metalforever is offline
post #5242 of 11557 Old 02-03-2013, 03:45 PM
jdsmoothie's Avatar
Liked: 5518
Modern AVRs use a logarithmic volume scale such that the volume levels you are experiencing are to be expected and normal.
post #5243 of 11557 Old 02-03-2013, 03:49 PM
jdsmoothie's Avatar
Liked: 5518
DD and DTS are competing audio technologies. Some BDs are recorded using DD TrueHD and others in DTS HD-MA. For a current list of those using each edit the "Audio" field on the right side of the page in the link below.
http://www.blu-raystats.com/Stats/TechStats.php
post #5244 of 11557 Old 02-03-2013, 03:57 PM
jlpowell84's Avatar
Liked: 712
I appreciate that link. Of the ones that still use LPCM it's not like it sounds like crap. The 3313 and 7.1 Definitive setup helps
post #5245 of 11557 Old 02-03-2013, 04:01 PM
jdsmoothie's Avatar
Liked: 5518
Still use LPCM? LPCM is the audio that is played by the AVR regardless of whether it's on the BD or results from the audio being decoded by either the Blu Ray player or the AVR, however, as it takes up far more space than either DD TrueHD or DTS HD-MA so most BDs do not have it. However, note that DD TrueHD and DTS HD-MA are simply "containers" that must be decoded/unzipped to LPCM which the AVR then can play. The audio is the same quality whether in LPCM form or it must be decoded from the DD/DTS format.
post #5246 of 11557 Old 02-03-2013, 05:19 PM
jlpowell84's Avatar
Liked: 712
Ok, bare with me as my knowledge level is slim. Some of my blu rays say PCM 5.1 for audio rather than DTS Master or another. I put in Blood Diamond after I got the settings on my blu ray right and didn't have the option for DD TrueHD or DTS HD-MA.
post #5247 of 11557 Old 02-03-2013, 05:23 PM
jdsmoothie's Avatar
Liked: 5518
If you are familar with compressed PC files called "zip" files that must be "unzipped" before they can be read the same thing applies to audio. DD and DTS tracks are similar to "zip" files and must be "unzipped" to PCM in order for the AVR to play them. BDs that have PCM 5.1 audio is already "unzipped" so there is no further work required other than to just play them.
post #5248 of 11557 Old 02-03-2013, 05:34 PM
jlpowell84's Avatar
Liked: 712
So how come the DD True HD and DTS Master HD was removed from my listening mode list? It was there one movie then not the next?
post #5249 of 11557 Old 02-03-2013, 05:40 PM
jdsmoothie's Avatar
Liked: 5518
The AVR can only play what is available on the BD/DVD. On the BD you were watching apparently the PCM 5.1 track was the only track on that BD so there's no reason for the AVR to display the DD or DTS options in the GUI menu.
post #5250 of 11557 Old 02-03-2013, 06:04 PM
jlpowell84's Avatar
Liked: 712
^So they are different then right? OR else the same listening modes would be available for each. That is when the back of the dvd say pcm 5.1 as opposed to one of the HD DD or DTS versions.
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
