The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 196 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #5851 of 11557 Old 02-27-2013, 03:54 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
are you saying the pre-outs are disconnected when the last 2 amps are used for zone 2? Strikes me as surprising, just because it requires some engineering/relays/software that really doesn't make anything better. Nothing difficult or wrong with having the preouts active even if the receiver's own amps are powering zone 2 AFAIK. But I could be wrong
again.
JHAz is offline
post #5852 of 11557 Old 02-27-2013, 04:27 PM
suds2001's Avatar
Originally Posted by batpig View Post
So the Zone 2 pre-outs are active when the Amp Assign setting is 7.1, but are NOT active when the Amp Assign setting is Zone 2, correct?
It sounds like the receiver prevents you from using the Zone 2 pre-outs simultaneously with the powered Zone 2 option. That is probably just the way it works.
The step-up 2313 model has a pair of Rec Out pre-outs (Media Player) that are separate from the Zone 2 stuff, so that would do it for you.
again.
Ok, all the three - 5.1 setup, zone2 patio speakers and wireless headphones on pre-outs - are working simultaneously now.
The issue might have been just for the initial hookup. When I connected the wireless headphones to the pre-outs for the first time (the 5.1 setup and zone2 patio speakers were already functioning), I could not make the headphones work. After I changed the amp assign to 7.1 (and this was the only change I made), I could get the music to the headphones. And hence I put out this question to the forum.
Now, while listening to the headphones on pre-outs, I changed the amp assign back to 5.1, and can still listen to the music on my headphones, as well as on the 5.1 speakers and the patio speakers.
So, either it might have been just the initial hookup of the headphones on the pre-outs which required me to change the amp assign to 7.1, or I might have done something stupid on the settings.
suds2001 is offline
post #5853 of 11557 Old 02-27-2013, 04:35 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2986
What is "it"? You didn't say what setting you changed, we aren't mind readers wink.gif
Are you talking about the Amp Assign setting?
Hehe, yeah, Amp Assign. I have my set to Main Only.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
post #5854 of 11557 Old 02-27-2013, 04:37 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
OK good, my understanding had always been that the Zone2 pre-outs should still be active even when you are using the Zone 2 powered options with Amp Assign. Thanks for the follow up.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5855 of 11557 Old 02-27-2013, 04:38 PM - Thread Starter
batpig's Avatar
Liked: 3415
If you are only running a 3.1 setup the Amp Assign settting is largely irrelevant, as it only controls the last two (surr.back) amps. So leaving it on Zone 2 or whatever is fine.
Setup Guide and FAQ
batpig is offline
post #5856 of 11557 Old 02-27-2013, 06:00 PM
ProfD's Avatar
Quoted: 25 Post(s)
Just got an onscreen message for new firmware. Anybody got any idea what is in it?
ProfD is offline
post #5857 of 11557 Old 02-27-2013, 06:18 PM
dotCody's Avatar
Nope, but I hope it fixes my AirPlay problem... but I know it won't because the problem isn't caused by my beautiful Denon.
dotCody is offline
post #5858 of 11557 Old 02-27-2013, 06:43 PM
jdsmoothie's Avatar
Quoted: 12114 Post(s)
Liked: 5515
This thread covers 6 networking models so it always helps to indicate the model # in question when posting. smile.gif
jdsmoothie is online now
post #5859 of 11557 Old 02-27-2013, 06:45 PM
jdsmoothie's Avatar
Liked: 5515
Originally Posted by raymate View Post
Just got a new 2113ci, loving this AMP very pleased with it, I have one little problem
My cable box (Rogers) is connected via HDMI and it all work fine for video and sound but we have lost the caller ID feature.
When the home phone rings the caller ID would come up on the bottom of the screen if you are watching the cable box.
Now the phone ring the caller ID does not show, if I plug the cable box direct to TV the ID shows, but via the AVR no ID info ?
Not sure how to fix it, and ideas?
The best configuration with cable/sat boxes to avoid any type of HDMI related anomolies is going to be HDMI directly to the TV with optical from the cable/sat box to the AVR.
post #5860 of 11557 Old 02-27-2013, 06:47 PM
ProfD's Avatar
Quoted: 25 Post(s)
It was my 1613.
ProfD is offline
post #5861 of 11557 Old 02-27-2013, 06:49 PM
walke108's Avatar
Liked: 25
Question regarding my 1913- I recently upgraded from the 1911. I have noticed that I can't really hit reference anymore without my mains starting to physically make my ears extremely uncomfortable. -10 is about as high as I can get. Previously on the 1911 I could get to reference no problem. It was still loud of course but not uncomfortable ear piercing. I turned off Dynamic Volume and it doesn't seem to change with either Dynamic EQ enabled/disabled. Any ideas as to why my mains would be running that much hotter? It seems Audyssey set the distances and channel level almost identical to the 1911. Thanks for any ideas.
walke108 is offline
post #5862 of 11557 Old 02-27-2013, 06:49 PM
jdsmoothie's Avatar
Liked: 5515
Originally Posted by meddler76 View Post
Ok. New plan:
I am trying to power two Zone 2 speakers that are oriented back-to-back serving two adjacent rooms. Because they are facing opposite directions, I need to monaurally downmix the stereo signal to each speaker. My plan is to output the audio from the AVR via the pre-amp outs to an AudioSource AMP-100 auxiliary amplifier. This amp can bridge to mono and it has auto-on ability.
I would also like to be able to control Zone 2 wirelessly via the Denon Remote App and Airplay. My concern is that using the aux amp will prevent me from remotely adjusting the volume via the AVR.
Anyone have thoughts on whether my plan will work?
Again another nod goes to the 2313CI or 3313CI both of which can control Zone 2 volume via the AVR/remote app as the 2113CI only has fixed volume control wherein the external amp must be used to control the volume.
post #5863 of 11557 Old 02-27-2013, 06:53 PM
jdsmoothie's Avatar
Liked: 5515
It was my 1613.
And you installed the Pandora update back in Dec already?
post #5864 of 11557 Old 02-27-2013, 06:55 PM
jdsmoothie's Avatar
Liked: 5515
Originally Posted by chrisjmccord View Post
So what is the difference in the Dynamic EQ and Dynamic Volume? If I have Dynamic EQ Off, does it matter what the Dynamic Volume is set at?
What is a normal setting, or the majority of people, what do they do? If one is off, should the other be off? Etc...
I think right now I have Dynamic EQ off, and Dynamic Volume at Med or High.
Dyn EQ will boost the bass/surround audio at volume levels below 80/0db while Dyn Vol will attempt to normalize the total volume level. Dyn EQ must be ON in order for Dyn Vol to be ON. Generally you'll want to leave Dyn EQ ON for all sources all the time, and Dyn Vol ON for TV and late night movie watching only (where others are sleeping or living in an aparment).
post #5865 of 11557 Old 02-27-2013, 07:03 PM
ProfD's Avatar
Quoted: 25 Post(s)
Yes but then I did an exchange. I don't remember if I also updated the exchanged model... That is possibly it. However Pandora works fine as of yesterday anyway.
ProfD is offline
post #5866 of 11557 Old 02-27-2013, 07:16 PM
jdsmoothie's Avatar
Liked: 5515
Originally Posted by shashchatter View Post
Hi all,
I have seen various posts that talk about looking at the post-calibration Audyssey filters. I don't see a way to get a graph/raw-data from the AVR-1613/MultEQ, can it be done? Or from the AVR-2113/MultEQ XT which I am planning on getting (wondering if this is something the web interface provides, which 1613 does not have)? Or, are people doing off-board spectrum analysis?
Shash
The answer to all three questions is yes. IIRC you should be able to see the very rough graphs via the Parameter Check (p. 26 1613 OM) settings.
post #5867 of 11557 Old 02-27-2013, 07:45 PM
nemesyssoft's Avatar
I have what I think is an easy question.
I have the 3313CI and use a PlayStation 3 to play Blu-Ray discs. The PS3 is connected to the 3313CI through HDMI. The instructions on Sony's website to set the output correctly recommends to use the HDMI output (checked) and mentions:
"To output in 7.1 channel surround sound, the audio must be outputted via the HDMI port on the PlayStation 3 and connected a display or AV amplifier (receiver) that is compatible with Linear PCM 7.1 Ch. supported by Dolby TrueHD or a similar format. With system software version 2.30 or greater, DTS-HD Master Audio and DTS-HD High Resolution Audio output is now supported."
I'm guessing that the 3313CI supports Linear PCM 7.1 but I'm not sure. I searched everywhere and couldn't find this clearly mentioned (not in the user manual, not on Denom website, etc.).
So, does the 3313CI supports Linear PCM on the HDMI input? When I play a Blu Ray, the display on the receiver says "MULTI CH". Is that the correct status (it will read Dolby Digital when watching cable)
Thanks in advance!
nemesyssoft is offline
post #5868 of 11557 Old 02-27-2013, 07:52 PM
jdsmoothie's Avatar
Liked: 5515
Yup, p. 76 OM ....
Although if you have the PS3 slim, you'll want to set it to "bitstream" rather than "LPCM" to see the DD/DTS audio track in the display rather than the PCM track "Mult CH IN".
post #5869 of 11557 Old 02-27-2013, 10:23 PM
dotCody's Avatar
I also received a Firmware update notification today. I have the AVR-1713.
dotCody is offline
post #5870 of 11557 Old 02-27-2013, 11:12 PM
rich7sena's Avatar
Ditto, I have the 1713.
rich7sena is offline
post #5871 of 11557 Old 02-27-2013, 11:17 PM
Yup, p. 76 OM ....
Thanks for trying to help, jdsmoothie!
I do have the slim PS3. I saw that table but unless I'm missing something, it doesn't mention linear or bitstream PCM. How did you find out?
What about Dolby TrueHD? I read that Blu-Ray are supposed to be encoded to TrueHD. If I want to listen to them in that format, what do I need to do? Basically, where does the selection of the encoding is done? In the PS3 or in the 3313CI? This is incredibly confusing! I guess I would first have to read every single page of the OM...
Thanks in advance!
post #5872 of 11557 Old 02-28-2013, 12:54 AM
spawn1980's Avatar
Quoted: 13 Post(s)
Question I had a faulty harman 1565 with drop video signal. So i'm deciding between the avr 1612 and 1613.
I can get a new 1612 for $200 and a Refurb 1613 for $250... Yes I know I hate refurb but denon website offer a 1yr warranty
(The AVR-1613 Integrated Network AV Receiver is backed by a two-year warranty. (One-year warranty on Refurbished model) )
sad to say my budget is $200. $250 is MAXED OUT.
My main usage is 3d movies and pc gaming all on my pc... I will also be using the internet radio/Pandora
i7 3930k w/ Asus Sabertooth x79 / Level 10 GT Case
Samsung Evo 850
GTX 980ti SLI
32gb DDR3 1866
Evga 1300
Win 10 Pro
spawn1980 is offline
post #5873 of 11557 Old 02-28-2013, 01:51 AM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
I just ordered a refurb 1913 for $280. Now I'm having second thoughts and I'm now wondering if I should try to cancel and go for the 1712 for $20 more since it has Audyssey MultEQ XT. Any opinions on this idea?
squeakybirnbaum is offline
post #5874 of 11557 Old 02-28-2013, 05:41 AM
raymate's Avatar
Oh no, I got a this new gear so we do not need to keep changing the av input on the TV I told my wife "it's ok we can have this new amp it lets us control all out stuff from one input" this means I'm back to square one, bugger
AVC-A1SE with mission speakers and REL sub
AVR-2113CI with Polk TL350s and Polk sub
raymate is offline
post #5875 of 11557 Old 02-28-2013, 05:42 AM
raymate's Avatar
Is there any official thread with firmware releases info and change logs / bug fixes etc.
Does Denon update often, just got a 2113
raymate is offline
post #5876 of 11557 Old 02-28-2013, 06:48 AM
praz's Avatar
Liked: 26
Post #6 of this thread. I suggest reading posts #1 - #6.
praz is offline
post #5877 of 11557 Old 02-28-2013, 07:47 AM - Thread Starter
batpig's Avatar
Liked: 3415
The main difference is that the 1613 has networking, the 1612 doesn't.
Setup Guide and FAQ
batpig is offline
post #5878 of 11557 Old 02-28-2013, 07:50 AM - Thread Starter
batpig's Avatar
Liked: 3415
The 1712 will have slightly better sound quality because of the XT version of Audyssey but you will give up network features and analog video conversion. It's up to you if the trade off is worth it.
Setup Guide and FAQ
batpig is offline
post #5879 of 11557 Old 02-28-2013, 07:54 AM - Thread Starter
batpig's Avatar
Liked: 3415
Yup, p. 76 OM ....
Thanks in advance!
Not sure what you r looking at but the table clearly shows multichannel PCM, JD even highlighted it for you in yellow!
You don't have to read the whole OM, JD was just illustrating that it did support that audio format, but all you need to know is that this receiver supports EVERY audio input format. Pretty much any modern HDMI receiver does. Everything else is up to the source. If the disc has Dolby TrueHD on it then you can play it... Not all discs do. But the selection is done at the source, if the receiver gets a MultiCH format it will automatically decode it.
Setup Guide and FAQ
batpig is offline
post #5880 of 11557 Old 02-28-2013, 08:05 AM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
Your receiver will report as Multi channel as batpig said, as the PS3 decodes pretty much any HDMI signal to that if you set it to PCM mode, but fear not, it will be the highest quality audio as advertised by the Blu ray (Dolby True, DTS Master, etc.). You can reassure yourself by hitting "select" on your PS controller during the movie and on the top part of the screen you'll see the format it's playing as in non PCM format (ie. DTS-MA).
CheYC is offline
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
