The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #631 of 11556 Old 06-25-2012, 09:16 PM
xb1032's Avatar
Liked: 26
Originally Posted by batpig View Post
...If you can afford the 4311 at current (sub $1300) street pricing, then I think it's a no brainer. Even if you won't go beyond 7.1 channels, the XT32 calibration and upgraded amp section is a big difference maker (although the latter is likely less important)...
Can someone PM me where this receiver is available for this type of pricing from an authorized dealer? I tried a mono-price switch for 3D but it just isn't passing 3D. I'm either considering the 4311, 3312/3313, or just buying a 2nd blu-ray player and keeping my 3808CI which is still a great receiver.
xb1032 is offline
post #632 of 11556 Old 06-26-2012, 03:39 AM
mrol's Avatar
Originally Posted by jdsmoothie View Post
Both models (2313CI and 3313CI) feature dual HDMI monitor outputs to the main zone so just depends on whether you need the additional features offered by the 3313CI. Note that when connected to the AVR, the PS3 only requires the HDMI cable.
Thanks JD
I didn't realize that the slim PS3 could now handle HD audio for 3D. You advice made me do some research on my old problem and it looks like the 3.70 update fixed the HD audio for 3D. It will only be useful once I get a 3D AVR but it clears up what models will do the job.
Thanks again
mrol is offline
post #633 of 11556 Old 06-26-2012, 05:21 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
You can check with several of the more often suggested resellers (AV Science, Electronics Expo, J&R). The switch experience is normal as it is designed to be connected to HDMI 1.4 displays/devices to work correctly, which is why you either need an HDMI 1.4 AVR or a dual HDMI 1.4 BDP if you want to continue using the 3808CI.
jdsmoothie is offline
post #634 of 11556 Old 06-26-2012, 06:34 AM
patnshan's Avatar
Location: close to Milwaukee, WI but far enough from the hood!
Just ordered the 2113CI from Vann's. They dropped the price to $550, so I bit. Can't wait to get it hooked up!
Pat
patnshan is offline
post #635 of 11556 Old 06-26-2012, 06:47 AM
jdsmoothie's Avatar
Liked: 5502
Sounds about right ... generally takes about 1-2 months on average for the prices to start dropping from those resellers that do discount ... sooner if the predecessor model is no longer in stock.
post #636 of 11556 Old 06-26-2012, 07:22 AM
Hamel's Avatar
Pat
Vann's is offering the AVR-3313CI for below MSRP as well.
Hamel is offline
post #637 of 11556 Old 06-26-2012, 11:19 AM
mdenning's Avatar
If you have a Frys in your area, they will price match with Vanns. Picked my 3313CI up last night biggrin.gif
mdenning is offline
post #638 of 11556 Old 06-26-2012, 01:57 PM
Pram Banga's Avatar
EE is offering 2113CI for $499.99
Pram Banga is offline
post #639 of 11556 Old 06-26-2012, 03:11 PM
patnshan's Avatar
Just looked at their site and it's $649, so not sure where you saw the $500 price. In store maybe?
Pat
patnshan is offline
post #640 of 11556 Old 06-26-2012, 03:12 PM
ccotenj's Avatar
Liked: 101
- chris
ccotenj is offline
post #641 of 11556 Old 06-26-2012, 03:35 PM
Hamel's Avatar
Hamel is offline
post #642 of 11556 Old 06-26-2012, 03:41 PM
Redbeemer's Avatar
Has anyone actually picked up a 3313ci yet? If so, can you comment on it, how you like it and do you use the network streaming, DLNA, etc.
Redbeemer is offline
post #643 of 11556 Old 06-26-2012, 04:47 PM
mchrisbrown's Avatar
Originally Posted by vansos View Post
Thanks Chris and JDSmoothie!
I don't think that's the problem because my display supposedly accepts the following: "1080/60i, 1080/50i, 1080/24p, 1080/24sf, 1080/25p, 1080/30p, 720/60p, 720/50p, 480/60p, 480/60i signal compatibility" as can be seen here http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=94540&catGroupId=16818&surfModel=TH-50PHD8UK&displayTab=O
But, who knows....that could be wrong. Furthermore, what slightly concerns me is that the monitor (from Panasonic's "Business" line not its "Consumer" line) did not come with a built in HDMI input and I had to purchase a separate "card panel" that added that input to the monitor. So, there might be something strange with the HDMI input itself, or, maybe I'm not getting all the display options, etc... Again though....it did work with the AVR-4306 for the last five years and it does receive the setup menu screen from the receiver when I switch to an unoccupied Input slot.
I will play with the resolution setting as well as try the HDCP reset and splitter/switch options tonight when I get home. Hopefully one of those options will do the trick as I'd really hate to buy a whole new TV just because I bought a new receiver.
Thanks very much for the input and I'll report back so that other users can benefit.
Vansos,
Please let me know how this went. I have the same EXACT model TV as you with the same HDMI board as you and need to know if I can make this work with the 3313. I hope I can but if not I need to know so I can put my AV refresh project on hold. Thanks in advance for your input.
Thanks again,
Chris Brown
mchrisbrown is offline
post #644 of 11556 Old 06-26-2012, 08:33 PM
David Williams's Avatar
Anyone with one of the xx13 models... do you have SiriusXM streaming working? I've been waiting for a couple weeks for "level 2" tech support to call me back from Denon and I haven't heard anything about anyone else having problems either...
David Williams is offline
post #645 of 11556 Old 06-26-2012, 08:53 PM
mdenning's Avatar
I just got mine last night, and was replacing an old burned-out (no more HDMI signal) HK 354, so far I really like it. I was excited to set up DLNA and stream video without having to use my PS3, but it looks like it will only stream audio, which was kind of disappointing, but oh well. I haven't messed with any other network streaming yet, though.
I'm waiting until my new sub & speaker wire get here tomorrow, and then I will give more input as to how I like it
mdenning is offline
post #646 of 11556 Old 06-27-2012, 04:31 AM
jdsmoothie's Avatar
Liked: 5502
AVRs cannot stream video ... you'll need a 3rd party device connected to the AVR for that (eg. PS3, AppleTV, etc.).
post #647 of 11556 Old 06-27-2012, 08:58 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Sammy2 is offline
post #648 of 11556 Old 06-27-2012, 04:07 PM
jsprague's Avatar
Can I use the second sub output of the 3313 in zone 2?
Basically I'd like to run 5.1 in zone 1 for movies in the bedroom and 2.1 in zone 2 for music on the patio. No need to run them at the same time.
Also, I know this has been covered but can I control pandora from the denon remote app on my android phone? ie, select thumbs up, change stations, skip to the next song, change volume, etc..
jsprague is offline
post #649 of 11556 Old 06-27-2012, 04:13 PM
jdsmoothie's Avatar
Liked: 5502
The dual sub pre-outs are simply a single main zone sub signal with an internal "Y" splitter, so you could use it if playing the same source in both the main zone and Zone 2. Note however, that the Zone 2 HDMI will pass a 2.1 signal so if it were connected to a Zone 2 AVR, that AVR would process and provide the 2.1 audio to your Zone 2 speakers/sub or soundbar/sub.
post #650 of 11556 Old 06-27-2012, 06:17 PM
spager's Avatar
The only avr that I am aware of that has a sub zone 2 out is the pioneer elite sc 61 (same price as 3313) and higher up elite models.
spager is offline
post #651 of 11556 Old 06-27-2012, 09:54 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Zone 2 sub out is really a superfluous feature anyway, since zone 2 is just stereo and you already have both RCA pre outs and speaker output options for zone 2.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #652 of 11556 Old 06-27-2012, 10:04 PM
JakeRobb's Avatar
Okay you new XX13 model owners ... how about answering a few questions for me for a change? smile.gif
  1. How effective is the new "Dialogue Level" setting on improving center channel dialog?
  2. What is the temp of the top of the 1913 and CI models (ie. luke warm or hot)?
  3. Size of SAVE file to PC using Web Control (ie. 384k)?
1. Haven't tried messing with it, and don't have much to compare against. Audyssey set my dialog level to -2.5dB, and center channel dialog sounds great, with no clarity issues at all.
2. Under what conditions? I'm happy to answer -- this is as good excuse as any to buy one of those IR thermometers. smile.gif
3. 348k on my 2313ci.
Living Room: Denon 2113ci + BIC V1020 + Panasonic BDT220 + AppleTV + uVerse DVR + Panasonic P42S2 plasma
Theater: Denon 2313ci + Klipsch RW12d + Panasonic BDT220 + Mac mini + uVerse wired receiver + Epson 8350 PJ + 100" screen
JakeRobb is offline
post #653 of 11556 Old 06-28-2012, 04:41 AM
jdsmoothie's Avatar
Liked: 5502
Thanks for responding.
1. So you're saying that after running AUTO SETUP, the default setting changed from 0db to -2db? Does adjusting it to -12db or +12db make any difference?
2. Powered on with either no audio or average volume audio playing.
3. So then it seems the file size hasn't changed from last year's models. Good to know.
post #654 of 11556 Old 06-28-2012, 06:21 AM
JakeRobb's Avatar
Works fine on my 2313ci. I had to pay ~$36 for a year's worth of internet streaming.
The official Denon Android app is not yet available. There's a third party app that is functional but not as nice as Denon's official iOS app. I'm not a Pandora user, so I don't know the answer to your specific question for either version of the app.
I never looked at the settings prior to running the setup wizard, but I assume everything started at zero. I'd wake my wife if I tried it right now; I'll play with that later.
I just ordered a Raytek MT4; you'll have your answer in a few days unless someone else beats me to it. smile.gif How long do you think I should have it powered on before measuring to let it reach operating temp?
JakeRobb is offline
post #655 of 11556 Old 06-28-2012, 06:45 AM
jdsmoothie's Avatar
Liked: 5502
Likely no more than 15-30 minutes. The new Analog Devices Inc. video chips run much hotter than the previous ABT chips in the XX11 models. I'm curious whether the newer ADI chips in the new XX13 "CI" models are any cooler than the older ADI chip in the 1913. This would be detected on the left side of the AVR as you face it.
post #656 of 11556 Old 06-28-2012, 09:18 AM
Hamel's Avatar
So, with recent-year Denon AVRs, how often have owners had to resort to resetting their microprocessors? (I've never had to do this with my old AVR-4306.) And if the microprocessor is reset, does that typically fix for good the problem that the owner had been having with the unit?
I bought a new 3313CI last weekend and have had the unit lock up on me on four occasions already. (By lockup, I mean that the unit becomes unresponsive to the remote and to button pushes on the unit itself (e.g., I can't even turn the unit off).) I have to unplug and then replug the 3313CI in order to regain control of it. (And yes, early on I did indeed install the latest firmware update.) So, last night, after the fourth lockup, I reset the microprocessor and will be watching closely for any recurrence of this problem. If a lockup does happen again, I guess I will try to return the unit to the retailer and get a new one.
Hamel is offline
post #657 of 11556 Old 06-28-2012, 10:16 AM
jdsmoothie's Avatar
Liked: 5502
Regardless of whether it occurs again or not, as long as you're still within your return period, I'd suggest just exchanging it.
post #658 of 11556 Old 06-28-2012, 12:40 PM
jsprague's Avatar
Does anyone know when the official android app is coming out?
This is one of the main reasons I was going to buy the new model. The denon website say's it's already out:
"Intuitive Graphical User Interface and Remote App
The AVR-3313CI features a Setup Assistant along with a graphical user interface that simplifies the initial setup and daily operation of the receiver. In addition, the receiver supports the Denon Remote App, which lets you operate the receiver's main controls from your iPad, iPhone, iPod touch, or Android smartphone."
jsprague is offline
post #659 of 11556 Old 06-28-2012, 12:57 PM
jdsmoothie's Avatar
Liked: 5502
Last I heard it was scheduled for release at the beginning of this month, however, has apparently had some setbacks causing the release to be delayed. It is expected out anytime now.
post #660 of 11556 Old 06-28-2012, 01:16 PM
Redbeemer's Avatar
I am considering either getting a Denon 4311ci or the new 3313ci. Does anyone have any thoughts on those two AVR's, other than the obvious price difference? The main difference I see in looking at the specs of both is that the 3313 does not have the multi-channel analog inputs and doesn't have hdcd decoding(but my player does). Any other major considerations I should be aware of; the amp difference is unimportant to me as I will be using three separate power amps which I already own? Finally, I have confirmed with Denon that both units will stream 24/96 FLAC files over the ethernet or into the usb ports, but I forgot to ask about 24/96 WAV files as I do have a number of albums in that format.
Thanks for any input or comments, especially from anyone who has/had either of these receivers.
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
