The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #901 of 11626 Old 07-09-2012, 01:32 PM
ccotenj's Avatar
Liked: 101
@nhh2oskr...
- chris
ccotenj is offline
post #902 of 11626 Old 07-09-2012, 06:54 PM
Applemike68's Avatar
Quoted: 153 Post(s)
Hi all,
I am having an issue with my new Denon 1913 hooked to a new Panasonic 60GT Plasma. The issue i'm having is im not getting sound from any sources connnected via HDMI. I get picture from Apple tv, directv, bluray and xbox but no sound. Any one have these issues? Any suggestions would be helpful.
M
My equipment:
JVC RS620Anthem MRX 1120,Kaleidescape Strato,Apple TV 4,oppo 203, Roku Ultra, paradigm 95f , 55c , svs sb16 ultra
Current Setup 7.2.4 Atmos
Applemike68 is online now
post #903 of 11626 Old 07-09-2012, 07:20 PM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
^^Check the HDMI input from your TV and see if you set the sound for TV or receiver, also the check the assigned HDMI input from the Denon.
80sGuy is offline
post #904 of 11626 Old 07-09-2012, 07:47 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi Applemike68, check HDMI Audio Out is set to "Amp".
JChin is offline
post #905 of 11626 Old 07-10-2012, 06:44 AM
openchut82's Avatar
I have a 2313CI. After running Audyssey, I make a few changes. I change speakers to small, crossover for front, center,surround, and surround back speakers from 40 to 80. I usually raise the sub level a couple of dbs. I am running a 7.1 speaker setup.
After Audyssey before I make any changes, the volume on the AVR will go up to aound 94 or 95 while playing music. After I make the above changes, the volume will only go up to mid to low 70s. Does this mean anything or are the numbers for the volume not important.
The system plays fine at max volume, even when going to 94 or 95 on the AVR. I am just wondering why I lose max volume after these changes, at least according to the master volume number displayed.
openchut82 is offline
post #906 of 11626 Old 07-10-2012, 06:49 AM
jdsmoothie's Avatar
Quoted: 15046 Post(s)
Liked: 7262
First, I'm surprised you can get to 94-95 without blowing out the speakers or your windows as most would generally not be able to go above 80. eek.gif What speakers are you using? Are you also raising the volume of the individual speaker levels as well or changing the Source Level setting? When you say "the volume will only go to the mid 70's" you mean the volume indicator doesn't increase beyond that point?
Also what is the status of the Audyssey setup only going to 6 mic positions?
jdsmoothie is online now
post #907 of 11626 Old 07-10-2012, 07:09 AM
openchut82's Avatar
For the front and surround speakers I am using DCM12a, floor standing speakers rated at 250 watts. The center is a Polk Audio, I do not know the specs on it. The surround backs is the Polk Audio M40.
I am not raising any of the individual speaker levels except the sub. The sub is the PB12. I make no other changes in the AVR. Yes, the volume indicator numbers from the AVR master volume will not go any higher after the changes. I do not play music at that high of a volume for very long. Just trying to see how the complete setup handles and sounds a higher volumes.
The last time I ran Audyssey it gave me the 8 locations. That was running it through the speaker menu.
post #908 of 11626 Old 07-10-2012, 07:12 AM
BeeMan458's Avatar
Liked: 813
Is this perceived loss or verified with a SPL meter volume loss? What is the electric outlet circuit rated for and how many total watts are you pulling out of the wall when you have the volume cranked?
Based on your comment: "Yes, the volume indicator numbers from the AVR master volume will not go any higher after the changes," you've maxed your system (or house wiring) out and the internal amps are overheating. Just a possibility.
I'm an 80% kind-a-guy where none of my gear, whether hammer or receiver, at max-pain, should exceed 80% of rated capacity. If I'm exceeding this standard, I've made a bad purchase. Gear lasts a lot longer, whether garden hose or receiver if it's not stressed to max capacity.
BeeMan458 is offline
post #909 of 11626 Old 07-10-2012, 07:21 AM
openchut82's Avatar
I guess you could say it is perceived loss, at least by going by the master volume number. I have not a SPL meter, although thinking of purchasing one. I do not know what the electrical outlet is rated for or how many watts it is pulling or even how to check it. I am using a surge protector with 4 other components connected to it.
post #910 of 11626 Old 07-10-2012, 07:28 AM
BeeMan458's Avatar
Liked: 813
If you don't have the current going to your gear, then gear won't function at peak efficiency.
Depending on your budget, the Shack has a way cool SPL. I paid $85 for the SPL meter I have but that was twenty years ago. Who knows how pricing has changed since then, market efficiency coupled with inflation. Either which way, it never hurts to have a decent SPL meter in your lap while setting up a sound system or to know how many spare watts your wall plug has to share with your sound system.
A suggestion, lose the surge protector and change out your wall plug box from a duplex box and plug to a four-plex box with a pair of duplex outlets as a single surge protector will limit the amount of energy available to your high demand situation.
I had an electrician come out and make the change for eighty dollars. I had hospital grade outlets put in. Hospital grade outlets are better constructed, more resistant to heat and have better gripping capability onto the tangs of the plug; quality of plug contact.
An under explored issue is wall wiring as today, with all our electronic devices, we tax these systems and because wiring is hidden behind a wall, we forget to explore this issue as a power limiting problem in need of being looked into.
post #911 of 11626 Old 07-10-2012, 07:29 AM
openchut82's Avatar
What is the max safe temp for the 2313? I remember seeing mine up to 79 degrees I believe.
post #912 of 11626 Old 07-10-2012, 07:43 AM
BeeMan458's Avatar
Liked: 813
I don't know what it's operating temperature restrictions are. Most consumer electronics are limited below 105F. I can only find that it consumes 600w.
post #913 of 11626 Old 07-10-2012, 08:31 AM
jdsmoothie's Avatar
Liked: 7262
The DCM12a speakers are very efficient with a sensitvity rating of 97db, so the AVR has to attenuate their volume most likely by more 12db or more (ie. FL/FR both set to -12db). This is why you can raise the volume so much higher than normal although not sure why it's reduced when you effectively increase the headroom from the amp by raising the crossover settings.
Also thanks for the info on the 8 vs. 6 mic positions ... I'll update the info in post #4.
post #914 of 11626 Old 07-10-2012, 08:44 AM
BBQ Lover's Avatar
I got a new 3313 last week and it has occasional (once every hour or two) static noise in the left surround channel. I have Bose acoustimass speakers, so all of the speaker wires go into the subwoofer module then come out and go to the speakers. I have performed the following trouble shooting:
  1. Totally redid my setup while paying special attention to not having any bare wires contact the receiver body. This had no effect.
  2. Reset the microprocessor. This had no effect.
  3. Physically swapped my surround satellite speakers. This had no effect, therefore the speaker is not defective.
  4. Swapped the surround wires coming out of the subwoofer. The noise moved to the right surround speaker, therefore the problem is not in the wire leading from the subwoofer.
  5. Swapped the surround wires at the receiver while leaving the wires coming out of the subwoofer switched. The noise moved back to the left channel, therefore the problem is not in the subwoofer or the wires leading to it.
The 3313 is the only new component in my home theater system and it seems like the problem is definitely in the receiver. I did add an ethernet switch so that I could hard wire everything instead of using wifi, but I don't think that that would cause this problem. Is it time to send this unit back, or is there something else that I can try?
BBQ Lover is offline
post #915 of 11626 Old 07-10-2012, 08:50 AM
mdenning's Avatar
Originally Posted by mdenning View Post
Er, I meant the Zune app in the 360. So same input, heh.
I found out last night that I did not actually fix the problem, I just somehow faked the stereo output to 5.1, which made things sound really odd (center channel audio coming from rear speakers, etc). I reset again and cable works fine now, but the 360 is still screwed up with audio, so it may be a 360 issue now.
Update to this problem. Actually figured out the issue last night. It seems the woofers in my front and right speakers (Polk RM7s) blew at the same time, causing only the tweeters to play. This would explain why stereo output (Zune app, Netflix app, etc) did not play.
Talking to Polk now about replacement, but guessing as itll probably fall into "usage break", I may just need to buy new speakers. As I was only at about -25db, not sure how I wouldve blown them frown.gif
mdenning is offline
post #916 of 11626 Old 07-10-2012, 08:55 AM
Selden Ball's Avatar
Quoted: 3429 Post(s)
Liked: 1700
Sorry: you'll have to get the receiver replaced. The unit you have is defective.
Selden
Selden Ball is offline
post #917 of 11626 Old 07-10-2012, 08:59 AM
jdsmoothie's Avatar
Liked: 7262
post #918 of 11626 Old 07-10-2012, 09:07 AM
BBQ Lover's Avatar
Thanks for the quick replies Selden and JD. I will send it back.
post #919 of 11626 Old 07-10-2012, 10:02 AM
Tool Dude's Avatar
Has anyone been successful at controling the volume of the receiver via arc with a factory tv remote? In particular, I have a GT50 that when combined with a panny soundbar, offered incredible ease of use and integration. I was very disappointed when the sound quality was not what I required.
Tool Dude is offline
post #920 of 11626 Old 07-10-2012, 10:14 AM
ccotenj's Avatar
Liked: 101
- chris
ccotenj is offline
post #921 of 11626 Old 07-10-2012, 10:16 AM
Helguera's Avatar
Hi!
I bought a Denon 2113 this saturday, but have problems with the display/screen when I use the network-function. I`ve connected the receiver to my internet connection. But it looks like the software has big problems, both with stock firmware and with the updated firmware. Now the picture is totally green when I use the network-function with Internet radio etc.
I`m not sure if this works any good, but I`ll try to share these video via dropbox displaying the problem (Pretty large files, so it may take a while to load):
https://dl.dropbox.com/u/32731427/Denon1.mp4
https://dl.dropbox.com/u/32731427/Denon2.mp4 (This is taken just a couple of minutes after the first video)
Do anybody else have this problem? Any good ideas hos I can fix it?
Helguera is offline
post #922 of 11626 Old 07-10-2012, 10:21 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by ccotenj View Post
Grammar Luke; use the force.
(So there's no misunderstanding, I'm referring to the poster's grammar, not yours.)
post #923 of 11626 Old 07-10-2012, 10:36 AM
jdsmoothie's Avatar
Liked: 7262
So what you want is to control the Denon AVR with your GT50 remote? In order to do that the Denon would have to be in the GT50's data base of AUX devices it can control. If not, then no joy. Can you elaborate on why you feel the sound quality is not what you require? Is it just center channel dialogue that is the issue? What surround mode are you using?
post #924 of 11626 Old 07-10-2012, 10:39 AM
jdsmoothie's Avatar
Liked: 7262
Originally Posted by Helguera View Post
Hi!
Try following these "green screen" tips ---> http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_L9
Also, what do you mean by "stock firmware" and "update firmware"? Do you mean the issue still occurs even after the firmware was updated?
post #925 of 11626 Old 07-10-2012, 11:34 AM
mchrisbrown's Avatar
Originally Posted by mchrisbrown View Post
Okay, I understand now. I guess I'm back to using an optical (toslink) to analog converter box (fairly cheap but just trying to shrink the birds nest of cables) from the Google TV box to use as my double connection. The google TV has only 2 connections - HDMI and optical. Thanks guys.
Oh one last thought, I usually have the same source on for both zones at any given time so wouldn't mind using "front B" to the speaker posts to make this work but I would lose independent volume control for each zone right? In other words I can't turn the volume way down in the main zone and crank zone 2 to a higher volume, correct?
Well I thought I understood but I was looking at features on the Denon website and it states that the 3313 has a digital to analog record out - see here: http://usa.denon.com/US/Product/Pages/productcomparision.aspx?pIDs=AVR4311CI%28DenonNA%29|AVR3313CI%28DenonNA%29&catID=AVReceivers%28DenonNA%29 . It seems that you could indeed take this analog out and just loop it back into the receiver as an analog input? If this won't work can someone please explain the digital to analog record out feature? Thanks in advance for any input.
Chris Brown
mchrisbrown is offline
post #926 of 11626 Old 07-10-2012, 11:36 AM
No ... he understands ... the only way to get any audio out of the Media Center analog output is by connecting a source with analog cables (ie HDMI (Media Center) will not go out the analog (Media Center)).
Sorry for the double post but this is the one I probably should have quoted. Question repeated below:
post #927 of 11626 Old 07-10-2012, 11:38 AM
Helguera's Avatar
I have now tried the "green screen"-tips, but without luck.
"Stock firmware" -> Original firmware (Firmware out of the box). And yeah, the green screen still occurs even after I have updated the firmware. Did the firmware-update from the Denon setup-menu without getting any errors.
I have several HDMI-inputs connected (sat-box, PC and PS3) to my AVR-2113, and they all work fine, no green screen. The only time the green screen occurs is when I use the network-functionality (Internet radio, flickr, last.fm...). I get sound from the Internet radio, so there should be no problem with the Internet connection.
So shouldn`t this relate to the software in the receiver? One of the reasons getting the 2113 was because of the network-functionality (and the upcoming spotify integration), so its pretty annoying.
Helguera is offline
post #928 of 11626 Old 07-10-2012, 12:02 PM
BeeMan458's Avatar
Liked: 813
What did Denon tech-support say on the issue?
post #929 of 11626 Old 07-10-2012, 12:20 PM
Helguera's Avatar
I got the problem just some hours ago, so I haven`t tried to call or email Denon Tech-support. Visited the Denon homepage, but it doesnt look like Denon have any dedicated customer support here in Norway. Suppose I have to go to the local hifi store i bought the receiver tomorrow. Do you think they have any knowledge, or is it best to send an email to Denon USA or something?
Helguera is offline
post #930 of 11626 Old 07-10-2012, 12:35 PM - Thread Starter
batpig's Avatar
Quoted: 3706 Post(s)
Liked: 3576
that is likely a typo on the spec sheet, the 3313 removed the digital>analog conversion for Zone 2/3 and the REC OUT feed is tied to the Zone 2 source. There is no mention of that capability in the manual. So it almost certainly will not work, sorry.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Denon , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
