The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 334 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #9991 of 11634 Old 12-24-2013, 04:37 AM
chocks86's Avatar
Hey guys, I just recently bought a 2313ci last week and so far things have been great. I have read through aloft of this thread and have been using a lot of what I learned here and from th Audyssey setup thread and am pretty happy with the results. There is however, a setting in the 2313ci that I came across last night that I am unsure of. I did a search for it here and outside of this site but did not find much information about it other than what is stated in the Denon manual, which is unfortunately not much. The setting is the Dialogue level under the audio settings. This particular unit I own was used but is in perfect condition, so when I set up the receiver the Dialogue level was set at -7.0db. I would like to know if this is correct or it is just personal preference or it is even best to use this particular setting at all. I pretty sure this is different from the Dolby Digital Dialogue Normilization from which I read that I have pretty much no control over. If someone could clarify this for me and tell me what the best thing to set this to if it is not personal preference, I would greatly appreciate it. Thanks and Merry. Christmas guys. smile.gif
chocks86 is offline
post #9992 of 11634 Old 12-24-2013, 05:12 AM
jdsmoothie's Avatar
Quoted: 15372 Post(s)
Liked: 7517
It is nothing more than the volume level setting for the center channel ... so adjust to suit your preference. smile.gif
jdsmoothie is offline
post #9993 of 11634 Old 12-24-2013, 05:16 AM
chocks86's Avatar
Cool... thank you very much.
chocks86 is offline
post #9994 of 11634 Old 12-24-2013, 05:28 AM
jdsmoothie's Avatar
Liked: 7517
It should also be noted, that whenever you get a used/demo or otherwise "not new in box" unit, you should reset the microprocessor as the first step to return all settings to their factory defaults and then run the Audyssey Auto EQ program to calibrate your speakers/sub in your setup.
post #9995 of 11634 Old 12-24-2013, 05:33 AM
chocks86's Avatar
You know what, that is great advice and I have not done that so, I will do it as soon as the girlfriend wakes up. Don't want to disturb her sleep with my "obsession". rolleyes.gif Lol. They will never understand. Thanks again.
chocks86 is offline
post #9996 of 11634 Old 12-24-2013, 04:10 PM
mauricejohnson's Avatar
How can you set analog audio to the component input? I'm trying to hook up my Wii to the stereo, and it only comes with RCA left and right audio cables along with the component cables. I got it to set component to a specifit input (game) but it seems I can only set optical audio along with it.
mauricejohnson is offline
post #9997 of 11634 Old 12-24-2013, 04:16 PM
jdsmoothie's Avatar
Liked: 7517
As the analog audio inputs are not assignable, you must use a source name that also has matching analog audio inputs (ie. cannot use GAME). Then set the INPUT MODE for that source name to "Analog".
post #9998 of 11634 Old 12-24-2013, 10:13 PM
chocks86's Avatar
Hey JD,
I have been playing around a bit more on my 2313 today and performed a microprosser reset and ran Audyssey again. Audyssey picked up most of everything correctly except my subwoofer which it always seems to set at -12db even with the gain dial almost at the minimum on the sub itself. I will play around with it more when I get a chance. Furthermore, I think I have been able to determine that the dialogue level setting in the audio submenu and the center speaker chanel level setting in the speaker menu are infact the same. The reason I came to this conclusion was because I had just finished calibrating the speaker levels with an spl meter and then was making sure the rest of the settings on the receiver were correct when I noticed that the dialogue level was at -7.5db which is the same level in separate speaker level settings. The same scenario for the subwoofer level. I just want to make sure that these two settings are one and the same and that by changing one is the same as changing the other. Can you please clarify for me. I appreciate it. And once again Merry Christmas.
chocks86 is offline
post #9999 of 11634 Old 12-24-2013, 10:50 PM
Makes sense. Thanks, man.
post #10000 of 11634 Old 12-25-2013, 12:49 AM
jdsmoothie's Avatar
Liked: 7517
Originally Posted by chocks86 View Post
Hey JD,
You'll want to lower the sub gain on the sub down further (even if it's only 1 of 10) until the final sub trim is no longer -12db. And yes, the Dialogue Level is the same as the center channel volume setting.
chocks86 likes this.
post #10001 of 11634 Old 12-25-2013, 01:06 AM
chocks86's Avatar
Will do. Thank you again. And it is only fitting that you get that 10000th post. biggrin.gif
chocks86 is offline
post #10002 of 11634 Old 12-26-2013, 07:15 AM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 47
Due to the HDMI handshake issues common with some cable/sat boxes, connecting the HDMI directly to the TV with optical from the box to the AVR would resolve your issue.
That's a great idea, thanks. With the harmony remote I just got for Christmas, it wont be that much of an inconvenience to switch between sources on the AVR and TV at the same time. I'll dig around my cable Tupperware box, I'm pretty sure there's an optical cable in there.
jvh4 is offline
post #10003 of 11634 Old 12-26-2013, 07:19 AM
jdsmoothie's Avatar
Liked: 7517
In lieu of an optical cable you can also use a coax digital cable to which a "yellow" composite video cable makes for a good suitable substitute.
jvh4 likes this.
post #10004 of 11634 Old 12-26-2013, 08:21 AM
jcalifornia's Avatar
I have the AVR-1613 and finally got a tripod to run Audyssey. I have Definitive Tech speakers and Klipsch Sub. It set my Center and Fronts Crossover to 150Hz and my rears to 110Hz. I am shocked to see the 150Hz setting. When I ran Auduyssey without a tripod it set the Fronts and Center to 120Hz. 150Hz seems really high for the 3 fronts. My room is rather large, 20'x20'x10' with a huge opening in the back to the kitchen and hallway. Any ideas why it set the Fronts to 150Hz?
Center: XTR-40 on top of stand
LR Fronts: DI 6.5s (in walls)
LR Sourround: UIW63/A (in ceiling)
Sub: Klipsch RW-12D
jcalifornia is offline
post #10005 of 11634 Old 12-26-2013, 09:50 AM
jdsmoothie's Avatar
Liked: 7517
The first thing to keep in mind is that the AVR crossover settings go from .....,100Hz, 120Hz, 150Hz ... so if your speakers are in between two settings, they could easily cycle between 120Hz to 150Hz between different Audyssey runs/mic positions. Next, did you place the mic at ear height (above any high back rest) using all 6 mic positions with mic positions #2-5 within a 2'-3' radius around that #1 mic position? Try running a few more Audyssey setups to see if you get similar results. Also keep in mind that your in wall speakers will react very differently when dealing with your room dynamics as opposed to the ideal conditions used by Def Tech. Note too that Def Tech only rates the XTR-40 down to 100Hz so a 120Hz/150Hz crossover is not unusual for that speaker at all.
post #10006 of 11634 Old 12-27-2013, 03:37 PM
metalsaber's Avatar
Quoted: 1029 Post(s)
Liked: 844
Stupid question (which might have been answered in this behemoth thread), but can someone explain what the difference is between the Subwoofer level under the Audio menu vs the Subwoofer level under the Speaker menu when you are manually adjusting levels?
I have both set to -3, but not sure that is correct.
metalsaber is offline
post #10007 of 11634 Old 12-27-2013, 03:50 PM - Thread Starter
batpig's Avatar
Quoted: 3729 Post(s)
Liked: 3607
They are the same thing. The Audio menu just makes it easier to access this adjustment on the fly rather than having to dig deeper into the speaker config menu.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10008 of 11634 Old 12-27-2013, 03:54 PM
metalsaber's Avatar
Liked: 844
Awesome. Thx
post #10009 of 11634 Old 12-28-2013, 09:31 AM
skidog's Avatar
Liked: 27
Ok fellas, here's my problem.
I am trying to use the media server function of my 2113ci and the only folder it sees is the sample music folder which contains 3 songs that apparently came with my computer.
The first thing I tried was to download an album from Amazon cloud player. That worked fine even though it shows a lock symbol next to each song(which is a question I have but that can wait). This made a folder in My Music called Amazon MP3 which then has a sub folder for each Album I save to my computer.
So I enter media server but can't find the folder only Sample Music folder is accessible, so I move the music into the Sample Music folder but it still doesn't show up only the 3 songs that were there to begin with. Ugh wtf!.
I did discover that i can right click on the Album and get a drop down menu then click the play to option and choose my 2113ci and it will play. Is this how this is supposed to work? I thought I would be able to access my folders and see all my music. This is what i want to do so please tell me if I'm crazy for thinking this is the way it should work.
So after all the previous frustration I decided I would download Exact Audio Copy and try ripping a cd to flac which seems to have worked,(I have never done any of this before so bear with me). I saved that album in the Sample Music folder but they don't show up on the Denon only the original 3 songs that were there to begin with.
So what the hell am I doing wrong?? It seems like this shouldn't be that hard, I realize I'm not the very savvy at this kind of thing but gee whiz I'm ready to pull what hair I have left out! It's not noon yet but I am going to have a beer and patiently wait for any help. I tried googling and using the search feature here but have not found anything to answer my questions.
I am using a Toshiba L455 laptop running win7 if that is helpful.
Sorry about the novel but i wanted to be as thorough as possible as to my problem.
Thanks for helping.
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #10010 of 11634 Old 12-28-2013, 09:59 PM
SuprJoinT's Avatar
I've been having my 2113 for over a year now, and recently i unplugged it for a few days to go out of town. Came back and all was fine. Then out of the blue, I stopped getting a video signal from HDMI, on both sources (PS3 and cable). I fooled around with it for hours and finally got video back.
I forgot what I did but it seemed to have something to do with the zones, as it flashed patio or something and I hit a cpl buttons on the unit itself and all came back, worked for about an hour, then I turned it off, and the same thing again. no video at all.
I cannot even get into the setup or anything.
I did a master reset and all, to no avail.
I know it must be something simple but I cant for the life of me figure it out, and I am frustrated to say the least!
Can anyone think of what I have done, or offer any suggestions????
Thanks in advance. I've looked through a LOT of these pages but could not find a similar problem.
Edit: I can go to network and see my media player or to ipod, but when playing something I get NO audio as well...
SuprJoinT is offline
post #10011 of 11634 Old 12-28-2013, 10:03 PM
jdsmoothie's Avatar
Liked: 7517
post #10012 of 11634 Old 12-29-2013, 12:04 PM
skidog's Avatar
Liked: 27
Not sure if you were responding to my post or the next. I did do some resets and it still didn't see any of the other folders besides the Sample Music folder. So I decided to try using Windows Media center with my xbox 360. After setting that up I could play the albums I downloaded from Amazon Cloud. I then exited that and went back into the media center on the Denon and suddenly there was the Amazon mp3 folder, cool! Still no Flac files though so I don't know what the issue is. Could it be that I'm wireless with the computer and the file is too big?
Denon 2113ci
Klipsch RW12-D x 2
skidog is offline
post #10013 of 11634 Old 12-29-2013, 05:21 PM
whotony's Avatar
On my second 3313 since September. First one continually turned on and off by itself.
Now six weeks into the second one I can't figure out how to make turn off at all.
Attempting to turn it off only provides a front display saying main zone off but the receiver still is actually on.
Did I accidentally change a setting to make this happen?
How do I get it to actually turn all the way off?
whotony is offline
post #10014 of 11634 Old 12-29-2013, 05:42 PM
jdsmoothie's Avatar
Liked: 7517
The 3313CI has 3 zones and the front panel display is telling you that only the main zone is off while either or both of the other zones still remain on so simply turn Zones 2 and 3 off. smile.gif
post #10015 of 11634 Old 12-29-2013, 06:01 PM
whotony's Avatar
Thanks that was it. Not sure how those zones got turned on.
whotony is offline
post #10016 of 11634 Old 12-29-2013, 06:04 PM
jdsmoothie's Avatar
Liked: 7517
If you are using a universal remote, the basic power on sequence may be powering on all Zones, and if that is the case you may want to teach the universal remote the discrete power on sequence for each zone. Note also that you can power on the main zone only by selecting a specific source on the Denon remote rather than selecting the power on button.
post #10017 of 11634 Old 12-29-2013, 11:44 PM
bdlchicago's Avatar
I made a rather startling discovery the other day.
I recently switched from an iPhone to an Android device. One thing I lamented just a little was the loss of Airplay to send tunes from my phone to my receiver. I didn't use it that much owing to the fact that my macbook is connected to the 2313CI via an optical cable for audio and HDMI via am adapter for video, but I hate to leave features in the dust. I'm using the Android DoubleTwist application for playing music on my Android phone, and it has a feature that DoubleTwist developed called MagicPlay.
Imagine my surprise when I clicked the MagicPlay button and lo and behold, the Denon Receiver was listed there as a MagicPlay device. And upon pressing the button to turn it on, my receiver switched inputs and started playing the track that was selected on my phone, exactly as if it was an iPhone using Airplay! Pretty slick!
SanchoPanza likes this.
bdlchicago is offline
post #10018 of 11634 Old 12-30-2013, 05:59 AM
jdsmoothie's Avatar
Liked: 7517
There are actually a number of Android apps that are available that can use DLNA to stream content to the AVR. smile.gif
post #10019 of 11634 Old 12-30-2013, 07:29 AM
bdlchicago's Avatar
I see that now, though I still don't know why they didn't give the Denon the ability to receive video as well as audio, but I'd assume I have a way to do this using a PS3 and something like Skifta?
post #10020 of 11634 Old 12-30-2013, 08:15 PM
Ryan25's Avatar
Or you could try HDMI...
Ryan25 is offline
Denon , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
