The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 343 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #10261 of 11626 Old 03-11-2014, 11:02 AM
isagreg's Avatar
Question regarding 2113ci DAC:
The user manual says: Hi Res Audio Support over USB and Network: 96kHz/24-bit FLAC and 48kHz/24-bit WAV, nothing about ALAC
But the website says: Hi Res Audio Support over USB and Network: 192kHz/24-bit FLAC & WAV, 96kHz/24-bit ALAC
Which one is correct?
isagreg is offline
post #10262 of 11626 Old 03-11-2014, 11:32 AM
jdsmoothie's Avatar
Quoted: 15093 Post(s)
Liked: 7286
The 1913 and higher models received a firmware update 09/12 that added the 24/192 gapless ALAC/FLAC capability.
jdsmoothie is offline
post #10263 of 11626 Old 03-11-2014, 11:39 AM
isagreg's Avatar
So the hardware was capable of 24/192 but it was restricted to 24/96?
And with firmware update they enabled it back to 24/192? AND added support for gapless playback?
Is that what you're saying?
isagreg is offline
post #10264 of 11626 Old 03-11-2014, 11:43 AM
jdsmoothie's Avatar
Liked: 7286
post #10265 of 11626 Old 03-11-2014, 02:52 PM
justtaint's Avatar
Originally Posted by C51rider View Post
Anyone have or know where to get a service repair manual with schematics or just schematics for an avr-1513? Trying to repair a damaged one I bought. Thanks a lot...
The only thing I was able to find was the Service Manual for the 1613/1713/1723.
http://www.scribd.com/doc/197212600/Denon-AVR-1613-1713-1723
Tom
justtaint is offline
post #10266 of 11626 Old 03-12-2014, 09:45 AM
pndiku's Avatar
Is there any way to get a direct download link to the new 3313 firmware?
pndiku is offline
post #10267 of 11626 Old 03-12-2014, 10:57 AM - Thread Starter
batpig's Avatar
Quoted: 3707 Post(s)
Liked: 3582
No, firmware can only be downloaded / updated through the receiver's built-in network interface.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10268 of 11626 Old 03-13-2014, 06:16 AM
Tomiii's Avatar
Anyone else having problems with Denons spotify after the latest firmware update?
My 2113 spotify menu has slowed down significantly and when pressing play on a starred track, no matter which one, it always flashes green screen once and gets stuck. After flashing green the screen stays black. It also did the same a couple of times when pressing the search option on the menu. When stuck the only thing I can do is to shut the AVR off.
What's new section plays and works just fine.
Edit: Also the problem isn't caused by a faulty ethernet connection.
Tomiii is offline
post #10269 of 11626 Old 03-13-2014, 12:36 PM
flydeep's Avatar
Liked: 41
Setting up 2 Subs in 3313CI
I am considering upgrading my subwoofer to a dual setup. I see that the Denon 3313CI has a preout for a second SW but the manual shows setups for different versions using a single sub. Can the Audyssey calibrate two independent subwoofers connected to SW1 and SW2 in 3313CI?
TIA!
Fronts: KEF Q900's, KEF 600c, Rear: Mirage OMD-15's, SW: PSA triple XS30se(BASH)+miniDSP
AVR: Denon 3313CI, Amp: Emotiva XPA-5
PJ: Benq HT1075, Screen: STR-169150 Silver Ticket 4K 16:9, 150"(White)
Sources: HTPC (J River Media Center)
Unraid Server with 50TB+
flydeep is offline
post #10270 of 11626 Old 03-13-2014, 12:41 PM
jdsmoothie's Avatar
Liked: 7286
Sorry, but no rather the dual sub pre-outs are nothing more than an internal "Y" splitter, rather you would need to upgrade to the more current X4000 to get dual sub calibration.
flydeep likes this.
post #10271 of 11626 Old 03-13-2014, 12:50 PM
flydeep's Avatar
Liked: 41
jdssmoothie - Thanks for the quick response. Upgrading to the x4000 gives XT32 and independent calibration of the two subs? I wonder what I am going to do with the 3313CI which is perfectly fine. Any suggestions where I can offload the 3313CI and how much I can expect for it?
flydeep is offline
post #10272 of 11626 Old 03-13-2014, 01:07 PM
jdsmoothie's Avatar
Liked: 7286
I've had several 3313CI owners who have ordered the X4000 do just that. You should expect maybe $600. Note also the dual sub calibration feature is accomplished using Audyssey Sub EQ HT which would then pass on the level/delay information to Audyssey MultEQ XT32 to use to EQ the subs together, however, you would still have individual sub volume level control. When using MultEQ XT on your 3313CI, to ensure the best EQ, with identical subs, locate them each equidistant from the main listening position.
post #10273 of 11626 Old 03-13-2014, 02:38 PM
quattroginger's Avatar
Some of my front speakers started clicking in and out. I can hear that clicking noise from receiver and speakers go dead. Only about split second. Clicks out and right back in. Nothing moved nothing has changed. Any ideas? Doing system update now in case it might help
quattroginger is offline
post #10274 of 11626 Old 03-13-2014, 05:45 PM
Sting5920's Avatar
Is there a way to us my laptop to access my AVR1713 to help me set up the internet radio favorites buttons
HDTV: LG 47LA7400
Blu-Ray Player: BP530 3D Surround
Keyboard: Logitech K400R
OTA only - Antenna: Ebay junk - [works great]
AV Receiver: Denon AVR 1713 5.1 3D
Center Speaker: Cambridge Audio S50
Front Left Right: Cambridge Audio S70
Surround: Acoustimass® 5 Series II system
Sub-woofer:  Yamaha
Sting5920 is offline
post #10275 of 11626 Old 03-14-2014, 05:17 AM
jdsmoothie's Avatar
Liked: 7286
You may be able to do it using the Web Control feature (p. 76 Owner's manual).
post #10276 of 11626 Old 03-14-2014, 05:35 AM
Sting5920's Avatar
can win 7 OS pc detect the AVR address thru the hub of the ISP supplied modem-- and connect --or is this a manual network thing? I wish those instructions on page 76 would be a bit more detailed.
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #10277 of 11626 Old 03-14-2014, 06:41 AM
jdsmoothie's Avatar
Liked: 7286
Yes, Win 7 OS should work just fine. Simply enter the your AVR's IP address into your laptop's browser (eg. 192.168.0.232).
Sting5920 likes this.
post #10278 of 11626 Old 03-14-2014, 12:51 PM
flydeep's Avatar
Liked: 41
Disable HDMI turn on for 3313CI
I have a Sony smart tv connected to my 3313ci receiver and I like to have HDMI pass through from cable input to the tv (when I am not around) so that the audio is through tv speakers. I switch on the receiver and use the 5.1 setup when I need it. This works quite well except for the fact that, if I have used the receiver 5.1 setup previously and the next time I do not have the receiver on, the TV searches for a connected receiver and switches it on automagically.
Is there a way I can disable this hdmi control while having the HDMI control on (for a signal pass-through)? I have looked in various settings when connected to the receiver through my computer and cannot find any.
flydeep is offline
post #10279 of 11626 Old 03-14-2014, 05:21 PM
jdsmoothie's Avatar
Liked: 7286
Not on the 2012 XX13 models no as HDMI Control must be enabled for the Standby Source to work. D&M separated the settings out on the 2013 models such that these newer models now no longer require HDMI Control to be enabled. Your work around is to connect the cable box (HDMI) directly to the TV with cable box (optical) to the AVR.
post #10280 of 11626 Old 03-15-2014, 06:11 PM
bodean's Avatar
Quoted: 180 Post(s)
Liked: 43
What does it mean when my receiver says " Multi IN" Is this something that I want to be seeing? I see it when using my Xbox One.
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #10281 of 11626 Old 03-15-2014, 08:18 PM - Thread Starter
batpig's Avatar
Liked: 3582
This means you are getting a multichannel stream of uncompressed PCM audio. It's all good.
Setup Guide and FAQ
batpig is offline
post #10282 of 11626 Old 03-15-2014, 09:09 PM
Ealitz's Avatar
Hello i have avr 3313ci and i just did a firmware update yesterday march 12th. It has messed up the ui and will not play Pandora anymore. Is there anyway to revert the update? Thank u. Apologize if i posted in the wrong forum.
Ealitz is offline
post #10283 of 11626 Old 03-16-2014, 03:15 AM
jdsmoothie's Avatar
Liked: 7286
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_L25
post #10284 of 11626 Old 03-16-2014, 03:17 AM
jdsmoothie's Avatar
Liked: 7286
You're in the correct thread as it covers all of the Denon XX13 models. smile.gif
That said, there is no way to revert back to earlier firmware, rather first try a soft reset by unplugging the unit for 10 minutes and if still no joy, try a network reset as noted in post #5 of this thread.
post #10285 of 11626 Old 03-16-2014, 08:49 AM
alanh220's Avatar
Small and odd issue with my AVR-3313CI. After applying the latest firmware update (3/10/2014?) my Radiodenon/vTuner account has completely vanished and all the saved favorites purged.
I had to recreate the vTuner account with the receiver MAC address and my e-mail and now all seems well again.
Not a big deal - I think vTuner is kind of crappy compared to just saving stations in receiver memory under Internet Radio - but thought I'd mention. I was using vTuner as a kind of "backup" for the presets stored on the receiver, but I make sure to back up receiver settings every time (before and after) I do a firmware update.
Anyone have any general views pro/con/meh about Radiodenon/vtuner?
alanh220 is offline
post #10286 of 11626 Old 03-16-2014, 11:16 AM
pjtroy34's Avatar
I have an AVR-1713. Today I was listening to my iPhone via USB tether because the AirPlay kept cutting out. It worked fine for about 30 minutes to an hour, but then it started turning off, turning on, reconnecting to iPod input, 5 seconds of music or so, turning off, turning on, etc. I unplugged the tether and turned off the receiver thinking it was an iPhone deal.
Now I'm trying to watch TV and it is doing the same thing...turning off, on, CAB/SAT connect, 5 seconds of viewing, and then repeating the cycle.
What is going on?
Sorry if I missed an earlier post regarding this...tried a quick search, but didn't see anything and kids are driving me crazy since they can't watch "their show".
pjtroy34 is offline
post #10287 of 11626 Old 03-16-2014, 12:09 PM
pjtroy34's Avatar
What is going on?
I tried unplugging for a half hour...power still cycles.
I tried resetting the microprocessor...power still cycles.
pjtroy34 is offline
post #10288 of 11626 Old 03-16-2014, 04:42 PM
jdsmoothie's Avatar
Liked: 7286
Sounds like a candidate for repair if still under warranty.
post #10289 of 11626 Old 03-18-2014, 08:52 AM
StanGeek's Avatar
Quoted: 124 Post(s)
Liked: 43
Originally Posted by batpig View Post
All Audyssey settings are controlled in the GUI under the AUDIO menu (in the Audyssey submenu).
You can also change these settings pretty easily using the web browser interface.
They "layer" on each other, so Dyn EQ will not be available unless the EQ setting is on one of the Audyssey curves (Audyssey, Flat, or Bypass) and Dyn Vol will not be available unless Dyn EQ is on.
Note also that all settings in the Audyssey submenu are memorized separately by INPUT. So the BD input can have different settings than the SAT/CBL input.
How do you guys use the web interface to make changes? I have never been able to do that with ANY of the Denon receivers I have owned. The settings display in the browser, but after I make any change, the screen refreshes and the old setting comes back.
StanGeek is offline
post #10290 of 11626 Old 03-18-2014, 09:06 AM
Alan P's Avatar
Quoted: 5088 Post(s)
Liked: 3773
I had problems with the web interface as well until I switched browsers. Sorry, but I can't remember if it is Chrome or IE that works better...I can tell you one works better than the other. smile.gif
Alan P is offline
Denon , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
