The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 352 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #10531 of 11557 Old 05-31-2014, 11:54 AM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
Originally Posted by pjtroy34 View Post
I apologize if this has been asked...did a quick search and didn't find a solution.
My setup is:
AVR-1713
Samsung F8000
Directv box
Samsung Bluray
I'm running the Directv box to CBL/SAT on the receiver with HDMI. HDMI out from receiver to television.
I've run an optical from the receiver to the television to allow for surround sound on the television's smart apps...Netflix, MLB, Amazon, etc.
When I go to the smart apps the receiver automatically switches to TV Audio, which I believe it should, but on initial startup of the system (television, directv, and receiver all powered on) when I want to just watch directv, the receiver starts on CBL/SAT and then flips to TV Audio after a few seconds which means I lose the directv signal and I have to manually put it back into CBL/SAT mode.
What setting do I have wrong? I would love it to stay in CBL/SAT until entering the smart apps then automatically switch to TV AUDIO until done with them.
Thanks in advance.
Happens to me too on occasion. Only fix is turning HDMI-CEC of but then you have to switch to TV audio manually anyway when on SmartHub. By any chance do you have SmartHub starting up at power on?
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #10532 of 11557 Old 06-03-2014, 08:58 AM
mrbubblewrap's Avatar
Hi guys, I'm currently using a Denon 2313 but my question can probably be answered for most Denon receivers. I ran Audyssey which set center and fronts to large so I set them back to small and I'm still testing out which crossover I wanna run. So far so good. Now for movies I wanna use the crossover but for Stereo I just wanna use the fronts without the sub. I usually listen in direct mode so there its not an issue. But if want to listen in "Music" stereo mode do I have to change the setting back to large everytime? Is it not possible to have different settings for different sound modes?
Any help or workaround is appreciated.
mrbubblewrap is offline
post #10533 of 11557 Old 06-03-2014, 10:08 AM
jdsmoothie's Avatar
Quoted: 12144 Post(s)
Liked: 5532
Custom 2CH settings is only available on the 3313CI.
jdsmoothie is offline
post #10534 of 11557 Old 06-03-2014, 10:16 AM
Ah! :) Thanks, I'll be upgrading to the x4000 soon enough so good to know.
post #10535 of 11557 Old 06-03-2014, 10:20 AM
jdsmoothie's Avatar
Liked: 5532
post #10536 of 11557 Old 06-03-2014, 10:46 AM - Thread Starter
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
Originally Posted by jdsmoothie View Post
Not exactly -- remember that starting with the 4520 Denon changed the operation of the 2ch settings so they ONLY work if you have a SEPARATE set of 2ch speakers (i.e. using the "Front B" amp assign setting or the "7ch/2ch" mode). You can no longer use the 2ch settings menu to map a second set of bass management settings for a single set of front speakers used for both multich and 2ch audio.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10537 of 11557 Old 06-03-2014, 11:34 AM
judge_dredd's Avatar
I thought you could just go into the audio settings when you were in stereo mode, and turn the subwoofer off? Won't this treat the front L/R speakers as large? If not, what would a compelling reason for turning off the subwoofer be?
judge_dredd is offline
post #10538 of 11557 Old 06-03-2014, 11:46 AM
Damn. :D So there's no way around going into the menu and changing the crossover frequency manually if I want different crossovers for music and HT?
The whole reason for this is that I find most subs not that musical (including mine but off great for HT) and my fronts (RF 7II  go pretty low) so I'd rather have a lower crossover for music than for HT.
post #10539 of 11557 Old 06-03-2014, 02:30 PM
jdsmoothie's Avatar
Liked: 5532
Ah yes, I had indeed forgotten about that caveat.
post #10540 of 11557 Old 06-03-2014, 02:47 PM
jdsmoothie's Avatar
Liked: 5532
Correct. However, it would have to manually be done every time this configuration was desired.
post #10541 of 11557 Old 06-03-2014, 04:15 PM
Unless I am misunderstanding what you want to be able to do, you can just switch the sub to off in stereo, and you are good to go. It will always be off in stereo (with your fronts treated as full band), and it will be on when you are in any surround mode with your crossovers observed.
post #10542 of 11557 Old 06-04-2014, 06:44 PM
jaycam's Avatar
Just a quick question. I've had to rearrange and no longer have the space for my surrounds. When I set my 2313 surrounds to "none" the avr will not process any surround modes like Dolby and DTS. Is there a setting I'm missing or do I just need to leave the surround speakers set to small?
jaycam is offline
post #10543 of 11557 Old 06-04-2014, 07:19 PM - Thread Starter
batpig's Avatar
Liked: 3420
Can you provide some more specifics?
- what is the current config? 2.1 or 3.1 after you remove the surrounds?
- how do you know it's not processing the signal? When you try to play one of these tracks what is the receiver reporting as the input signal format and what is the surround mode?
Setup Guide and FAQ
batpig is offline
post #10544 of 11557 Old 06-04-2014, 09:01 PM
jaycam's Avatar
The current set up is 3.1.
While watching cable that is normally Dolby Digital the receiver display changes to Prologic once I set the surrounds to "none" in the settings.
jaycam is offline
post #10545 of 11557 Old 06-05-2014, 01:29 AM
jdsmoothie's Avatar
Liked: 5532
This would indicate the cable channel is only passing a stereo signal. Ensure the cable box has Dolby Digital set to ON and you're actually watching a channel that is broadcasting 5.1.
post #10546 of 11557 Old 06-05-2014, 09:23 AM
jaycam's Avatar
I was watching a channel last night that is DD 5.1. I went into the AVR settings and turned off the surrounds and when I backed out of the setup menu the AVR was displaying ProLogic II. I didn't think to go into my cable box settings and toggle surround off/on. I'll try that tonight.
jaycam is offline
post #10547 of 11557 Old 06-05-2014, 09:37 AM - Thread Starter
batpig's Avatar
Liked: 3420
That's specifically why I asked about input signal and not just surround mode. As JD said it sounds like the cable box itself is the problem, it is choosing to set itself to stereo output based upon the edid info from the receiver.
Do you have any other sources to test? DVD / BD player or video game system or something?
Honestly if other source work fine it's not something I would worry about to much. For cable tv programming with a 3.1 setup a stereo signal with pro logic extracting the center channel output should sound virtually as good as the discrete 5.1 mix.
Setup Guide and FAQ
batpig is offline
post #10548 of 11557 Old 06-05-2014, 09:40 AM - Thread Starter
batpig's Avatar
Liked: 3420
Oh also I assume you are hooked up with HDMI? One option is to send audio via a digital optical / coax cable instead of HDMI. Since optical/coax doesn't have 2-way communication the box won't "know" that the receiver doesn't have surrounds hooked up and may stick to 5.1 output.
sikclown likes this.
Setup Guide and FAQ
batpig is offline
post #10549 of 11557 Old 06-05-2014, 09:49 AM
jaycam's Avatar
batpig, another good suggestion. I'll try that tonight too. I do have other sources I can test, PS3 and Xbox 360. I wasn't aware that PL would be so close to DD. I guess my main concern is having a signal sent to the surround speaker posts. Does turning off the surrounds cut power to the surrounds? Should I really be concerned about that or is it not a huge deal?
jaycam is offline
post #10550 of 11557 Old 06-05-2014, 11:05 AM
khans's Avatar
I have a Denon 3312CI which had been running fine until I tried to install the most recent firmware upgrade.
I've managed to isolate the problem down to the networking on the receiver going down in the "authenticating" phase of the firmware update process. Putting the unit in standby and removing the power cable and keeping the unit off for a while appears to bring the network on it back up.
I've tried network card resets (power + 1 + 2) and microprocessor (power + 2 + 3) resets.
I've also tried plugging the unit into a different switch, straight into my cable modem out as well - same behavior.
Can people who have run into something similar comment on whether this is a hardware or a software problem.
Also - how bad is it to stay on a less than most recent firmware - from a functionality / quality standpoint.
thanks!
khans is offline
post #10551 of 11557 Old 06-05-2014, 03:51 PM
jdsmoothie's Avatar
Liked: 5532
3312CI or 3313CI as this is the XX13 thread? Review post #6 of this thread or post #6 of the XX12 thread linked below. The most recent update to the 3312CI was basically the Netflix DD+ noise fix and no likely to get any more updates in the future, so no big deal if not installed and you don't plan on using Netflix.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#post_20422390
post #10552 of 11557 Old 06-08-2014, 03:32 PM
StickyFingaz's Avatar
I have a denon avr 1613 I am having an issue playing my I pod using the ipod/usb port on the front of my receiver. I thought it would simply require me plugging my ipod cord into the usb and connecting to my ipod. Am I missing something or is there possibly an issue with the usb port. Wen I switch to the ipod the display on the receiver says: please wait...
Thanks for your consideration guys!
StickyFingaz is offline
post #10553 of 11557 Old 06-08-2014, 06:33 PM
shiseido's Avatar
can someone tell me if in the 3313 hdmi passtrought, having the denon in standbye i can choose the source to be showed in the tv, juts with the remote? i ve had this possibility in my last yama 773 but i cant see if its possible to do it in the denon...
shiseido is offline
post #10554 of 11557 Old 06-09-2014, 04:10 AM
jdsmoothie's Avatar
Liked: 5532
No, not possible, rather the setting must be a specific source (eg. CBL/SAT) or the LAST source used before going to Standby.
post #10555 of 11557 Old 06-09-2014, 04:13 AM
jdsmoothie's Avatar
Liked: 5532
Try unlugging the 1613 for 10 minutes and reset the iPod before plugging back i again and follow instructions on p. 29 in the Owner's manual.
post #10556 of 11557 Old 06-09-2014, 07:58 AM
jwpjax's Avatar
I asked this question awhile back but didn't see a reply about it. I may have missed it.
My Denon 1913 have developed a problem while streaming SiriusXM. It started out just changing channels randomly, but now has decided to change channels as soon as the connection is made to SiriusXM. I see a server disconnect message, then a channel change every 2 or 3 minutes.
I have done a network reset twice, Denon says it SirusXm, and SiriusXm says it the receiver. My router is current on firmware, as is the 1913.
FYI, the computers on the network do not have any issues like this. Anyone have any other ideas as to what to check? This problem didn't exist when I first got the 1913, only developed over time, which leads me to believe that it has something to do with the firmware updates?
Thanks JWP
jwpjax is offline
post #10557 of 11557 Old 06-09-2014, 08:42 AM
jdsmoothie's Avatar
Liked: 5532
Sirius/XM server disconnect: Some Sirius/XM subscribers have noted an issue with connecting to the Sirius/XM servers after the most recent Netflix firmware update. Apparently Sirius/XM made some recent changes that are causing this issue. Denon is aware of the problem and is expected to release a firmware update by the end of June to resolve it.
post #10558 of 11557 Old 06-09-2014, 10:20 AM
jwpjax's Avatar
I heard this response from a Denon Tech Sup Rep a few months ago. Apparently, between the two of them SiriusXM and Denon, they can't seem to get if fixed. The new problem, server disconnects just started, and no updates from either source have been applied.....?????
I suppose I will contact my retailer.(Crutchfield) and see about a swap out before my warranty runs out. I have already swapped the 1912 for the 1913 for another issue.
Thanks for the update!
JWP
jwpjax is offline
post #10559 of 11557 Old 06-09-2014, 04:45 PM
shiseido's Avatar
shiseido is offline
post #10560 of 11557 Old 06-09-2014, 09:42 PM
Thanks for the reply will try when I get back into town from business tomorrow.
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
