The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
Old 09-08-2014, 08:04 AM
jdsmoothie's Avatar
Quoted: 13250 Post(s)
Liked: 6126
Originally Posted by mtnbikefuel80 View Post
Any word on if the AVR-3313CI will receive a firmware update to HDMI 2.0? I searched the thread from when the announcement was made for the new HDMI 2.0 protocols but hadn't seen any mention of it.
You will need to upgrade to a new 2014 unit for HDMI 2.0, however, a dual HDMI 2.0 BDP will work just fine with your 3313CI passing the video to the TV and audio to the AVR.
jdsmoothie is offline
Old 09-08-2014, 04:15 PM
DavidBulluss's Avatar
AVR2113 DAC inputs
Hi, I have combed through fairly well but can't get the answer to this (my combing isn't as thorough today as before as it is directly proportional to the amount of hair left on my head!).
Which inputs on the AVR2113 can handle FLAC 24/192 files into the DAC... coax, TosLink?
David
DavidBulluss is offline
Old 09-09-2014, 02:16 PM
virre's Avatar
Volume drop
Hi guys!
I know I've read something about this issue once before but can't seem to find the post again.
I earlier had an issue that when navigating in the PS3 menu, the first or two clicks on the remote to move around in the menu didn't give any click sound from the avr.
The click sound gradually increased when moving fast back and forth in the menu until I stoped, then it acted the same way when I started to navigate again.
I first though it had something to do with the handshake between the PS3 and the receiver as the PCM icon on the display flashed each time I started to navigate.
I evetually got rid of it, but can't remember if it was with a processor reset of the receiver or if it dissapeared when I switched to a new PS3.
Now I have the same issue again but this time with my Apple TV.
The Apple TV is connected with a HDMI cable and it doesn't matter to which HDMI input I have it connected to.
I have tried different sound settings in both the avr and the Apple TV.
The PCM icon flashes onec on the display when I'm starting to navigate and the menu click sound increases gradually.
Any help would be much appreciated.
virre is offline
Old 09-09-2014, 04:35 PM
MarkEHansen's Avatar
Quoted: 24 Post(s)
Try changing the dynamic volume setting in the AVR.
MarkEHansen is offline
Old 09-10-2014, 08:54 AM
Alan P's Avatar
Quoted: 4893 Post(s)
Liked: 3531
Yes, turn OFF Dynamic Volume.
Alan P is offline
Old 09-10-2014, 12:25 PM
virre's Avatar
Still same... the only difference is that with Dynamic Volume set to On, the clicks sound louder as with the D.V. sett to Off.
Need to add that if I have the volume high enough on the receiver, say 40db+, the first click sound aswell, the second, third and fourth increases as each time I press the remote to navigate.
Here's a demo
virre is offline
Old 09-13-2014, 05:00 AM
virre's Avatar
Originally Posted by rudds View Post
One question that's perplexing me. I'm hooking up an Xbox 360 and a PS3, and the receiver is exhibiting a weird behavior with both of them. Initially I ran both consoles to my TV through HDMI and then ran an optical cable from TV to receiver, so I would only have to change inputs on the TV and leave the receiver on the same input all the time. When hooked up like this, the 360 worked fine, but I would hear no sound out of the PS3 for 2-3 seconds after it would start sending a signal to the receiver. For instance in the XMB menu, if I start navigating the menu, the little "ding" menu sound is missing for the first two or three movements, then kicks in afterward. If I let it sit for another 5 seconds and then start navigating again, same thing. It's almost like the receiver is going to "sleep" in the absence of a signal and then taking a few seconds to wake up again.
I tried instead connecting the consoles directly to the receiver's HDMI inputs and then running a single HDMI to the TV, and now the reverse is true. The PS3 outputs sound properly, but the 360 is exhibiting the weird sleep-lag phenomenon, so if I move around the dashboard menu, or go from silence to playing music, the first couple of seconds doesn't register and then it kicks back in.
This is the exact same issue that I have mentioned above. Did you ever get this solved?
virre is offline
Old 09-13-2014, 06:14 AM
virre's Avatar
Ok, I've found the source..
I went in to Input select, Decode Mode and changed it from Auto to PCM.
So I think that this occurs due to the fact that the receiver needs to auto detect the decode signal and that's why it lags for a second? Why doesn't it detect the mode right away and stays on that?
So the question is, can leave it on auto and hope that this doesn't affect anything when watching something through the Apple TV and hope that when it has already detected the decode mode it stay on that mode untill I get back to the menu?
My fear is that it accts like this in let say Netflix and that it can affects the sound... but that's maybe a dumb assumption?
EDIT: Setting decode mode premanently to PCM doesn't work for Netflix so I have to leave it on Auto.
virre is offline
Old 09-13-2014, 09:54 AM
Liked: 0
front right speaker has low volume
I've had my 2113CI for a year. Recently I found the front right speaker has much lower volume than the others. Initially I thought it's a connection problem so I switched speakers, speaker wires...but no luck.Even I give a 12db boost to the front right channel, it still sounds quiet and is with some noise. This happens for all audio modes when I use the HDMI as input. However, when I play network sources (pandora, mp3s from NAS), I can use the pure or pure direct mode to get normal/balanced sound output from the front speakers (this also confirms the connections and speakers are ok). In other modes (music stereo, mul ch stereo) playing network source, the front right speaker would have very low volume again....Tried resetting the micro-processor but it didt solve the problem....
What could be wrong? Any suggestion is greatly appreciated!
xhubei is offline
Old 09-13-2014, 11:22 AM
jdsmoothie's Avatar
Liked: 6126
Try doing 5 micro resets in a row. If no joy, the unit has a 3 year warranty. Check Denon's website for any authorized repair facilities in your local area, otherwise call the factory repair center PanurgyOEM in NJ.
Old 09-13-2014, 11:36 PM
Saliss's Avatar
Exclamation All HDMI Ports Dead on 3313CI including HDMI Ports of TV and Projector
Out of the blue, All the HDMI ports (all input and output) seems to be dead on my Denon 3313ci. Not only the AVR is affected but no HDMI ports on my Samsung ES7500 series TV and EPSON 2030 projector are dead to.
So far I have did a soft reset of all devices, disconnected all cables and tested each of them separately with a known good source but no use. TV and Projector are also not taking any direct HDMI connections on any of the HDMI ports. There is no apparent signs of shorting or burning on any of the equipment. The common point between all the devices is Denon 3313ci.
I have done a factory reset of TV and directly connected a source to it but TV cannot detect any HDMI source connected. I will be trying a hard reset of the AVR but I suspect it will be also of no use.
I'm totally baffled and have searched the net but haven't came across any similar case, where the AVR and all the connected equipment HDMI get screwed up like this.
Any help would be appreciated.
Saliss is offline
Old 09-14-2014, 01:03 AM
jdsmoothie's Avatar
Liked: 6126
If there was a nearby thunderstorm, it's possible a lightning strike took out all of the HDMI boards. Try unplugging the devices over night and try again the next day. If still no joy, time to call the insurance company.
Old 09-14-2014, 01:23 AM
Saliss's Avatar
Unhappy
No thunderstorm .... just didn't know what happened. Already kept them unplugged all night and did a 5 time microprocessor reset for Denon. Guess there is nothing that can be done
Saliss is offline
Old 09-14-2014, 01:47 AM
jdsmoothie's Avatar
Liked: 6126
HDMI boards are fairly sensitive, so apparently your home's electrical had some sort of power surge. So time to get Home Owner's insurance involved.
Old 09-14-2014, 07:35 AM
explorz's Avatar
1713 won't release airplay connection
When I choose the 1713 as one of my speakers through iTunes Airplay, the receiver turns on and properly plays the music.
The problem occurs if I stop the song in iTunes or quit iTunes. The receiver holds onto the connection and won't release it. In the display it still shows the name of the last song played.
The result is that when I then go to start a new song or start iTunes again, I get the message that the Denon can't be accessed because it is already in use by another device.
Power cycling the receiver fixes the problem but is obviously a pain in the ass since the receiver is in the other room.
The 1713 is connected to my network directly through an Ethernet cable running into my Airport Extreme.
Any ideas for fixes or any others have this issue?
explorz is offline
Old 09-14-2014, 07:54 AM
jdsmoothie's Avatar
Liked: 6126
Try stopping the network connection as well using the Denon remote by pressing/holding the ENTER button.
This and many more troubleshooting tips are provided in post 3 of this thread. Review posts 3-6 for more helpful information.
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
Old 09-14-2014, 08:41 AM
explorz's Avatar
Not really a solution to have to stop the network connection every time I start and stop iTunes. Is that what you're suggesting?
And I just tried that and it still doesn't release the connection. When I restart iTunes and try to send music to the Denon, it says that it is in use by another source.
Thanks though.
explorz is offline
Old 09-14-2014, 08:55 AM
jdsmoothie's Avatar
Liked: 6126
Correct. That is the solution. If not working for you, trying doing a soft reset by unplugging the AVR for 10 minutes.
Old 09-14-2014, 09:29 AM
explorz's Avatar
Hmmmmm, Not really a solution since I can already get it to reset by doing a power recycle. I am not interested in having to do anything at all (work arounds) to my receiver in order to get it to work properly and release the airplay connection when iTunes stops sending data.
Thanks anyway for trying, but really this is not a solution since it involves having to mess with my receiver every time I start and stop iTunes from the other room.
explorz is offline
Old 09-14-2014, 03:38 PM
Liked: 0
Try doing 5 micro resets in a row. If no joy, the unit has a 3 year warranty. Check Denon's website for any authorized repair facilities in your local area, others call the factory repair center PanurgyOEM in NJ.
Thanks. Did 5 resets in a row, no joy...
for a last try before I'd sent it to the shop, I plugged in a USB stick and played the MP3s on that drive....and...for no good reason, the front right speaker's volume magically got back to normal! Then I tried the other sources.. the front right channel's output is still normal...
I think the problem is gone!
xhubei is offline
Old 09-16-2014, 08:19 AM
Liked: 0
Hey All,
I have the Denon 1613. Works great, but with TV audio, how can I make that go through the receiver and the surrounding speakers? I'm running the HDMI from the TV (which has the audio return capability), but when I select "TV audio" on the Denon remote, I still only get audio from the TV directly.
kraftomatic is offline
Old 09-16-2014, 09:00 AM - Thread Starter
batpig's Avatar
Quoted: 3653 Post(s)
Liked: 3493
Originally Posted by kraftomatic View Post
Hey All,
1. Make sure the HDMI cable is plugged into the input labeled "ARC" on both devices
2. Make sure HDMI Control is enabled on the receiver
Beyond that it's up to the tv settings. If you've done the above and don't get audio when you hit the "tv audio" button on the Denon remote, then you need to find the setting in your tv me is to enable external audio output.
batpig is offline
Old 09-17-2014, 08:47 AM
Liked: 0
1. Yes, both are.
2. I'll double check. I assume HDMI is enabled, since I use the receiver on other HDMI devices.
I checked the TV. Nothing special. It's a year-old Panasonic. External output options are either HDMI or optical and it's set to HDMI ..
Old 09-17-2014, 08:52 AM
jdsmoothie's Avatar
Liked: 6126
Panasonic - set VierraLink to ON as well as audio to "Home Theater"
AVR - HDMI Control is set to ON
Once set, power both devices OFF and then power on the TV followed 4-5 seconds later by the AVR. You'll know it's working correctly when the AVR automatically switches to the "TV Audio" input.
Old 09-17-2014, 04:42 PM
Quoted: 24 Post(s)
His suggestion is to do a soft reset of the AVR as a way to resolve the problem. The hope is that after the soft reset, it will start working properly.
Remember that the AVR is basically a specialized computer. Sometimes, it gets into a snit and won't play correctly. Various reset methods are like a "re-boot" - the hope being that it will get out of its snit and resume correct operations.
To be clear, he wasn't suggesting that you unplug the AVR each time you finish listening to iTunes
Old 09-17-2014, 04:45 PM
jdsmoothie's Avatar
Liked: 6126
Yes, thanks for clearing that up.
Old 09-17-2014, 05:28 PM
explorz's Avatar
Ahhhhh, good to know. I had asked "Not really a solution to have to stop the network connection every time I start and stop iTunes. Is that what you're suggesting?" And the reply was, "Yes, that is correct."
So, I thought he meant each time.
I did do the soft reset and also unplugged the receiver for 10 minutes.
Unfortunately the issue remains. When iTunes stops sending data via airplay, my Denon 1713 does not release the connection and blocks any attempts for any other machine or even the same machine to connect through iTunes. Powering off and on is the only thing that forces the Denon to release the connection.
I appreciate the clarification and the ideas.
explorz is offline
Old 09-18-2014, 04:33 AM
jdsmoothie's Avatar
Liked: 6126
To be clear ... you asked if stopping the network every time was the solution to which I answered "that is correct." I then responded that if that didn't work, a soft reset would be required, but gave no indication as to it being required every time.
Old 09-19-2014, 07:19 AM
Liked: 0
This worked JD, thank you. Much appreciated.
Old 10-01-2014, 10:50 AM
derkleia's Avatar
Question AVR 3313 Unwanted output to Zone 2 and Dialogue Volume issue
Hello All!
It's time again for one of my occasional posts asking for help on functionality of my Denon 3313. I have really been enjoying it in my new home after purchasing it in Sydney last year and then moving here (Thailand) where I set it up "properly".
I could probably read the manual to answer the below questions but often find it confusing so thought I would post here first in the hope of a quick answer from one of the gurus.
1. Multi-Zones Setup
I have all three zones set up with each on a different level in our property. Zone 1 is my main listening and watching zone. Zone 2 is our shop downstairs (cafe) where I have a TV connected from HDMI Out for Zone 2 (using HDMI over CAT 6) and a separate pair of external speakers directly cabled from the Receiver (Assignable Surround Back). Zone 3 is connected via the pre-out for Zone 3 to an Amp on a floor above us.
My issue is that I have been finding that if I "accidentally" use/try certain Surround programs (eg DTS + PLII Cinema or any modes) which are 7.1 I get the audio piped to the shop (Zone 2 Assignable Surround back) in addition to the Main Zone. This occurs regardless of zone 2 being on or off. Is there a way I can ensure that unless I have Zone 2 powered on this cannot or does not happen as we are concerned I may start piping unwanted audio into the shop during trading hours. I'm not worried about Zone 3 as it is passed through another amp which is off unless I am specifically using it on that floor.
2. Dialogue Volume
Is there a way to alter the dialogue volume balance with music and effects? I often find I am straining to hear the dialogue over the music and/or effects volume. I find myself often tweaking the volume control up or down to hear the dialogue or lower the music/effects volume which seems considerably louder.
Thanks as always!
derkleia is offline
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
