The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 360 - AVS Forum
post #10771 of 10785 Old 10-13-2014, 04:52 PM
Impala1ss's Avatar
On that model, the Zone 2 pre-outs are your only option. You would have to upgrade to the 3313CI to get the FL/FR pre-outs.
No amps/pre-amps can be used with the 2113?
Impala1ss is offline
post #10772 of 10785 Old 10-13-2014, 05:33 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 1372 Post(s)
Liked: 1597
Zone 2 only.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Pioneer Elite, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #10773 of 10785 Old 10-16-2014, 11:46 AM
gdog5775's Avatar
Hi all...another zone 2 question. I have the 1713 and I'm struggling with why I just don't use a separate setup in zone 2 vs running a 50 foot RCA cable and then have to have two receivers/amps running just to listen to music in zone 2? Other than the cost savings of a simple two channel unit vs. a fully functional receiver of course. Can anyone give an example of their "real life" zone 2 setup when using the pre-amp outputs?
gdog5775 is offline
post #10774 of 10785 Old 10-16-2014, 12:04 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1597
Useful only if you want to pass a 1713 source to the Zone 2 amp without having to bother about dedicated sources in Zone 2.
post #10775 of 10785 Old 10-17-2014, 04:45 AM
raymate's Avatar
Adding another HDMI connection:
Can I do this:
I have the following setup and need to add another HDMI device.
HDMI IN:
1. CBL/SAT - Cable Box
2. DVD - Blu-ray Player
3. Blu-ray (empty)
4. Game - WiiU console
5. Media Player - AppleTV
I also have Component Video in RGB for "Wii Console" and have this assigned to use the Blu-ray input.
As you can see I have the "blu-ray" HDMI empty but if I attach the new device will it stop the "Wii" working?
Or will it only display what is powered on so in theory I could have two different devices plugged into the same input
Hope that makes sense.
AVC-A1SE with mission speakers and REL sub
AVR-2113CI with Polk TL350s and Polk sub
raymate is offline
post #10776 of 10785 Old 10-17-2014, 04:53 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1597
Although you can double up, might be easier to just assign new source (or Wii) to "AUX."
post #10777 of 10785 Old 10-17-2014, 05:44 PM
raymate's Avatar
Cheers for that, why didn't I think of that. That worked fine.
raymate is offline
post #10778 of 10785 Old 10-18-2014, 08:51 AM
Impala1ss's Avatar
Zone 2 only.
JD - not sure I understand. I know Zone 2 is a pre-out but do you mean that no other amp(s) can be added to the 2113 to increase the number of pre-outs, whether on the 2113 or on the amp??
post #10779 of 10785 Old 10-18-2014, 08:59 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1597
Correct. The 2113CI has no main zone pre-outs. The 3313CI and 4520CI are the only 2012 models with main zone pre-outs.
post #10780 of 10785 Old 10-19-2014, 02:05 PM
hooderAZ's Avatar
I have a Denon 1713 that is having issues. One night, not one HDMI port would work. It took 3 micro-processor resets before it finally started working again. The following night while watching a movie, my sound went from DTS-HD to Stereo then back to DTS-HD. it did this a couple times but it hasn't done it since. Should I be worried about this receiver? Is this a sign the HDMI board is going out?
hooderAZ is offline
post #10781 of 10785 Old 10-19-2014, 02:24 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1597
Could be, yes.
post #10782 of 10785 Old Yesterday, 10:58 AM
beerisgood's Avatar
I have a Denon 1613. The front HDMI input doesn't work, yet the USB input right next to it does work. Any suggestions?
Also, can the 1613 play music from airplay source, with the TV input on the screen at the same time?
beerisgood is offline
post #10783 of 10785 Old Yesterday, 11:55 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1597
Has it ever worked or you're just trying it for the first time? Try first doing a soft reset (ie. unplug the power for 10 minutes), otherwise, if no joy then try resetting the microprocessor as noted in post 5 of this thread. The "Video Select" setting can be used with an audio source while playing a non-HDMI video source.
post #10784 of 10785 Old Yesterday, 12:48 PM
hooderAZ's Avatar
JD-
With these HDMI issues I have encountered, would it be wise to replace this receiver? Or does the micro-processor reset usually fix these? I figure if the hDMI port is going out,it would be fairly expensive to get repaired.
hooderAZ is offline
post #10785 of 10785 Old Yesterday, 01:15 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1597
In some cases a microprocessor reset(s) will help, but if continued resets are required, then repair/replace the unit. If purchased with a credit card, the card may add an additional 3rd year of warranty.
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
Gear in this thread - 2113ci by PriceGrabber.com
