The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 361 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #10801 of 11559 Old 10-25-2014, 03:54 PM
Liked: 0
No Sound, no GUI on television, dropping connection to home network.
Hi All,
Hoping to get some help because my AV guy seems to be MIA.
My setup is the following:
Denon AVR 2113CI
C-Series Multizone Controller Amplifier MCA-C3
Russound AB 3.2 automatic switcher
There's also an airport express giving me airplay throughout the house via the zone controller.
All of my inputs are HDMI.
A little while ago, i tried to do a firmware update on the denon. It failed. It then sent my receiver into a downward spiral. I've had to reset the network controller as well as the processor. That got me out of the cycle of the receiver displaying "update retry" but then the network connectivity stopped.
I waited a few days and then magically, the receiver pulled an IP and I was able to access to the receiver through the web administration. At the same time, the Amp B assignment on the AB switcher, either isn't recognizing a signal coming from the Denon or it's broken, as the green light to indicate that the 'Home Theatre' is in use.
Additionally, the GUI for the denon wasn't working. I unplugged all sources and grabbed a small display and HDMI cable just to eliminate any external factors and plugged it in, still no luck on getting the GUI up.
The receiver keeps dropping the connection to my home network making any sort of set up frustrating — especially since the GUI doesn't work either.
Airplaying music from my iphone through to the zone controllers seems to work fine so I suspect there is something screwey going on with the denon. I just don't have enough experience to figure it out.
Does any of this make any sense to anyone? help would be appreciated.
Steve
Steeben is offline
post #10802 of 11559 Old 10-25-2014, 04:23 PM
80sGuy's Avatar
Quoted: 179 Post(s)
Liked: 34
Last resort: remove the panel and check for any blown fuse(s) inside. Replace if necessary.
80sGuy is offline
post #10803 of 11559 Old 10-25-2014, 09:00 PM
Mareirox's Avatar
The 1913 has fuses? Any idea where??? Thanks!
Mareirox is offline
post #10804 of 11559 Old 10-25-2014, 10:02 PM
80sGuy's Avatar
Quoted: 179 Post(s)
Liked: 34
I believe all amps/receivers do. Not sure exactly where.
80sGuy is offline
post #10805 of 11559 Old 10-26-2014, 11:09 AM
Mareirox's Avatar
OK. I was able to check the fuses without opening the cover. They seem fine. Gosh... This thing is still under warranty. Anyone knows if Denon honors its warranty overseas with an authorized dealer? (I bought this in the US less than 2 years ago, but had to relocate abroad). I don't want to pay a load of cash for repairs, and where I am now, well, receivers cost roughly double of what they cost back home.
Mareirox is offline
post #10806 of 11559 Old 10-26-2014, 11:52 AM
Kuriin's Avatar
Hiya. I've had a Denon AVR 1913 for a year or two now and everything has been working fine up until now. As far as I can tell, it is connected to the router, however no noise will come out of it when it tests it. Pandora now says, "Cannot connect" and it basically seems like the internet has died.
Does anyone know what gives? It's connected via DHCP mode, so it puts everything automatically in the information. Should I copy and paste what is in my router? It has been working fine up until now. I did a factory reset and it still doesn't work. :\ I can't check for updates or anything.
Kuriin is offline
post #10807 of 11559 Old 10-26-2014, 01:29 PM
manfrog's Avatar
Quoted: 59 Post(s)
Look for confirmation of my choice....haha
I am looking at a factory refurb of either the 3313ci or the 2313ci as the backbone for a new media room build that will be building. The reason I have chosen these as the price point is good now that discontinued, the Denon name and rep, and I can get what I want "now" as I build up pieces of the HT.
To give you some bkgd in the room...I am renovating (soon I hope) and essentially making two smaller rooms to make one dedicated 18*25 (9 ft ceiling) media room. I am not talking THX certified but something that sounds good for daily viewing but can make you "feel" the sound when warranted. Mostly TV (sports and such), movies and maybe music will become more if a priority with a good sound system. Room will be have two "screens" as I will use my current 65" led and install a motorized projector that will cover LED for dedicated movies. It will be wired for Atmos and projector, but will start with 5.1...moving towards 9.2.2 if it is warranted.
Back to receiver question...as mentioned I will be looking at doing is starting with (likely) a 5.1 system (speakers to be bought), but looking to go to 7.2 in the 6 months after "kick-off" of the room. So I would want the receiver to handle up to 7.2 until Atmos (if I even go there). If I do go Atmos then the receiver I am open to replacing. If I don't go Atmos then I will want the receiver to hold me through for longer.
So questions about these receivers...
1. Do I need to go to 3313ci to handle the two displays in the one zone? There will not be another zone in this house at this time or foreseeable future.
2. Am I giving up much more between 3313 and step(s?) down as I have options to get a lower CI model.
Thanks...sorry for ramble but more info on room and thinking seems helpful for those answering
manfrog is offline
post #10808 of 11559 Old 10-26-2014, 02:15 PM
jdsmoothie's Avatar
Quoted: 12355 Post(s)
Liked: 5643
Originally Posted by Mareirox View Post
Thanks jdsmoothie.
Tried all that, no luck.
I am at my wits' end....
Try doing at least 4-5 microprocessor resets in a row.
Warranty is only valid in the USA.
jdsmoothie is online now
post #10809 of 11559 Old 10-26-2014, 02:21 PM
jdsmoothie's Avatar
Liked: 5643
Try rebooting the router and if still no joy, review post 5 of this thread and do a "network reset."
post #10810 of 11559 Old 10-26-2014, 02:25 PM
jdsmoothie's Avatar
Liked: 5643
1. Nope. 2313 has 2 main zone HDMI outputs as well. 3313 simply adds a 3rd HDMI out for Zone 2 as well.
2. Nope. 3313 simply offers more features.
post #10811 of 11559 Old 10-26-2014, 03:22 PM
manfrog's Avatar
Quoted: 59 Post(s)
Thanks JD!
So really I am not giving much up (based on my setup and plans) then dropping down to the 2313CI I am taking it. Spend more elsewhere I guess
Just curious as well...what model replaced the 2313ci? x3000 or x3100w? as the x2000 drops to the 95 watts
manfrog is offline
post #10812 of 11559 Old 10-26-2014, 04:40 PM
jdsmoothie's Avatar
Liked: 5643
Both.
2012 - 2313CI (2 main zone HDMI outputs)
2013 - X3000 (1 main zone / 1 Zone 2 HDMI output)
2014 - X3100W (1 main zone / 1 Zone 2 HDMI output)
post #10813 of 11559 Old 10-26-2014, 04:46 PM
Kuriin's Avatar
Sill no dice. Doing the network reset was essentially a factory reset -- where I had to enter "English" and do Speaker Setup, then Network Setup, etc. :\
Kuriin is offline
post #10814 of 11559 Old 10-26-2014, 05:50 PM
manfrog's Avatar
Quoted: 59 Post(s)
Thanks again!
I am correct in ruling out the x3000 as I need 2 separate zone hdmi outs for the two different screens (led& projector) in the one media room? Or will just the 2 hdmi out (even for separate zones) work? This seems to have been present on the 2313ci, but dropped for the x3000.
I will not have 2 zones....just the two displays in one room again :-)
manfrog is offline
post #10815 of 11559 Old 10-26-2014, 09:01 PM
f00bs's Avatar
Quick update: After processor reset I had been skipping the speaker and input setup steps to get right to the network setup (and test if the network was working). After going through the speaker and input setup instead of skipping the network setup passed right away. So either there was some sort of network issue preventing the network setup from working initially (and then resolved itself) or the setup of speakers and inputs is a required step for the network setup to succeed.
At any rate, I am back to normal.
Thanks everyone.
f00bs is offline
post #10816 of 11559 Old 10-27-2014, 03:49 AM
jdsmoothie's Avatar
Liked: 5643
A network reset resets the network as well as does a microprocessor reset. Try 4-5 of these in a row and if still no joy, check if there is an IGMP Proxy setting on the router and disable it. If still no joy, either try using a different model router or send in for repair.
post #10817 of 11559 Old 10-27-2014, 03:55 AM
jdsmoothie's Avatar
Liked: 5643
Thanks again!
You are contradicting yourself. You simply have 2 monitors in one zone, so do not need 2 separate zone outputs. However, the X3000 and X3110W only offer a Zone 2 output as the 2nd output, so as long as you are only connecting HDMI sources only to the PJ and the PJ is able to receive multi channel audio, the X3000/X3100W would work; otherwise, you would need to select the 2313CI/X2100W or X4000/X4100W for the 2nd main zone output in order to play multi channel audio using your 5.1/7.1 surround speakers.
post #10818 of 11559 Old 10-27-2014, 08:34 AM
Kuriin's Avatar
Wow, I am absolutely retarded. I blocked the Denon on my router a week ago when we had guests staying in the downstairs. I didn't realize it was the Denon because it does not have any information that it IS the Denon. Unblocked it and now everything works. x_x
Thank you, though, for pointing me into the right direction (check the router!).
Kuriin is offline
post #10819 of 11559 Old 10-27-2014, 09:31 AM
jdsmoothie's Avatar
Liked: 5643
Great! Back in operation again.
post #10820 of 11559 Old 10-29-2014, 08:30 PM
atoner's Avatar
DirecTV HDMI dropouts
Originally Posted by Selden Ball View Post
Report the problem to DirecTV, with details of set-top-box TV receiver model, serial number, etc., including the date when it stopped working.
Many models set-top-box satellite and cable TV decoders tend to have problems when used with the type of HDMI repeaters used in A/V receivers. DirecTV in particular has been reported to make unannounced firmware updates which cause their units to stop working when connected to receivers, which were fixed by a subsequent firmware update.
Because of this unreliability, the standard workaround is to leave the STB's HDMI output connected to the TV and run a S/PDIF audio connection to the AVR.
Does anyone know if HDMI compatibility has improved in the past year between DirecTV and Denon? I tried several months ago and still had problems.
I've had a DirecTV HR24-500 DVR for 3 years and a Denon AVR-2313CI receiver for almost 2. Pretty soon after installing the receiver I figured out that HDMI from the DVR to the receiver wasn't going to work. I'd get audio & video droputs lasting up to a couple of seconds. Since then I've been using optical digital audio from the DVR to the receiver but HDMI from the DVR to my TV. HDMI works fine from my Sony Blu-ray and AppleTV through the Denon receiver.
My AVR-2313CI reports it has the latest firmware 1490-3169-0000-9211-1097. I'm pretty sure the DirecTV DVR has automatically updated a few times.
I haven't noticed this issue between a DirecTV H25-100 and a Denon AVR-X1000.
atoner is offline
post #10821 of 11559 Old 10-29-2014, 08:36 PM
atoner's Avatar
Won't power on, must unplug cord
Originally Posted by davekro View Post
2113 won't power off or accept any commands. Not via remotes OR even manually on unit. All knobs/buttons on 2113 do nothing. [Edit: unplugged 1 min. Seems back to normal now.]
I've never had this problem in almost 2 years, but now I've had it 3 times in one week. Annoyance factor is increasing when wife and kids start complaining. My Denon AVR-2313CI won't power on via remote, front panel, or iPhone app. The front power light will be red with no other lights or activity. I have to unplug the power cord then plug it back in.
Receiver claims it has the latest firmware 1490-3169-0000-9211-1097. No changes to AV or network system hardware recently.
atoner is offline
post #10822 of 11559 Old 10-30-2014, 05:55 AM
jdsmoothie's Avatar
Liked: 5643
Depends on the devices in the HDMI chain as I've never had any problems with Denon AVRs and DirecTV DVRs.
Try unplugging the unit for at least 10 minutes. If still no joy, reset the microprocessor (see post 5 of this thread).
post #10823 of 11559 Old 11-01-2014, 09:44 AM
raymate's Avatar
Firmware, I guess there comes a time when Denon will no longer update our amps.
How long has it been known for Denon to continue updating an amp for?
Having the 2113 and not seen much in the way of updates now for months
AVC-A1SE with mission speakers and REL sub
AVR-2113CI with Polk TL350s and Polk sub
raymate is offline
post #10824 of 11559 Old 11-02-2014, 02:10 AM
jdsmoothie's Avatar
Liked: 5643
Generally only for 1.5-2 years after being released, unless there is a major issue that needs to be resolved.
post #10825 of 11559 Old 11-02-2014, 09:41 AM
Liked: 0
AVR 2313 CI Shut down, Won't factory reset?!
Hello All. I have a Denon 2313CI I got almost 2 yrs ago open box at Best buy. I have 2 Def Tech towers and def tech pro center 1000. Last night I was changing settings ie dynamic volume and also center channel volume (for better dialogue) I went up to +5, I believe. Continued to watch edge of tomorrow movie and a few minutes later I believe it was the center channel that made a sound like wooooop. Like a robot dying.. Sorry that’s the best way I can explain the sound. The avr shut down and I haven’t been able to factory reset it. I have a fast red blinking light. I push power button to turn off. At the same time hit 2 channel butons +/- along with power button and display will flash at 1 sec intervals (as far as I can tell) and I wait 4/5 secs and release channel buttons then power button. It will turn on and say av receiver, $$#@!, cable/sat and then turn off and I get fast red blinking light. I’ve tried the reset a few different ways, no go. Ive unplugged the power cord for 5 mins.. plugged back in.. didn’t work. Unplugged 10 mins… didn’t work. Even tried network reset but nothing. I tried factory reset multiple times in a row.
Is there anything left to try? Am I doing the factory reset the wrong way? Does it have to be done perfectly?
briang3506 is offline
post #10826 of 11559 Old 11-02-2014, 05:39 PM
jdsmoothie's Avatar
Liked: 5643
Sounds like you're doing the reset correctly. Disconnect all cables/wires from the AVR. If it still shuts down when powering on, then try 5 resets in a row. If still no joy, send in for warranty repair.
post #10827 of 11559 Old 11-02-2014, 07:23 PM
Liked: 0
I have disconected all speakers wires and only had the power cord in. NO dice! Guess I will have a tech look at it
post #10828 of 11559 Old 11-04-2014, 02:57 PM
tornadog's Avatar
Quoted: 61 Post(s)
So I decided to reset my 2113CI to see if I could fix a input source only sending output in Stereo. I used webcontrol to save the config to my pc. Then reset the AVR and when it started up skipped all the configurations except language and network. Then went into the webcontrol and loaded the config.dat file and its been sitting at Loading since then(almost 4 hours now). What can I do to recover? Can I restart the device or is it bricked?
tornadog is offline
post #10829 of 11559 Old 11-04-2014, 04:33 PM
jdsmoothie's Avatar
Liked: 5643
In case you missed it, there are lots of tips and helpful information provided in posts 3 - 6 of this thread to include the following on the LOAD procedure ...
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
post #10830 of 11559 Old 11-06-2014, 07:29 PM
bodean's Avatar
Quoted: 173 Post(s)
Liked: 43
So I have my Xbox One hooked up to my 2113Ci via HDMI
I also have an optical cable running from my xbox one to my receiver.
However, when I go into xbox, turn off HDMI Audio, and enable Optical audio, I hear nothing.
I thought the receiver would automatically switch to optical if that is what I selected on my xbox one. Is there another step involved?
Under Setup/ input assign / I have for my HDMI 1 set to Hdmi / HDMI1, Digital / OPT
A music game I have, recommends audio over optical. So I am running optical and HDMI from my xbox one to my denon receiver.
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
