The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 367 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #10981 of 11634 Old 01-25-2015, 11:06 AM
Liked: 0
The same is likely to occur if an HDTV goes to sleep. Using a Harmony remote may be easier.
I don't believe my monitor has remote support. It's a fairly cheap Asus monitor. I might just plug all three monitors into one power strip with a switch so I can just turn them all on and off with one button.
Teeeejay is offline
post #10982 of 11634 Old 01-25-2015, 12:06 PM
alexandru27's Avatar
Hi,
when I watch a BD Denon 2113 displays Multi in, instead of Dolby True HD (which is the option I've selected in the BD meniu). If I put another BD the Denon display correctly shows DTS HD MA (which was selected in the BD meniu).
Why is that?
Also, to all the SACD I throw in, I get the same message displayed on Denon: multi in. But that should be normal, given that SACDs have lossless info other than DTS HD or DT HD.
Which is not the case for the BDs, on which the Denon should display Dolby True HD - if this is available and selected on the BD.
Any clues?
BDP is Pioneer 150
Denon AVR-2113, Monitor Audio BX2/BXC/BXFX, Pioneer BDP-150K, LG 37LH5000, Sennheiser PC-350
alexandru27 is offline
post #10983 of 11634 Old 01-25-2015, 12:51 PM
jdsmoothie's Avatar
Quoted: 15392 Post(s)
Liked: 7528
Although your BDP may be set to "bitstream," some BDs/DVDs have a PCM 5.1 audio track and so the AVR would display MULTI CH IN.
jdsmoothie is offline
post #10984 of 11634 Old 01-25-2015, 01:05 PM
Liked: 1
I've cut cable, and I'm now to run an antenna to get my local HD channels. That works (well, kind of). I'm getting picture and audio out of my LG monitor. However, if like the audio to go through my Denon 1713 receiver.
What I did was connect my tv audio out via optical cable to the AVR 1713 optical in. Additionally, The two are connected via HDMI, although My understanding is that isn't relevant for the antenna scenario.
I'm getting no sound. My TV's input is on Coax cable (not HDMI) in order to get the picture. I have no idea how to get the sound. What I tried was assigning digital input on the amp to Optical, and then while watching OTA broadcast, setting the amp to either TV Audio or CBL/SAT. Neither work.
Anyone know what I'm doing wrong?
coltrane59 is offline
post #10985 of 11634 Old 01-25-2015, 01:29 PM
jdsmoothie's Avatar
Liked: 7528
TV must be set to "external speakers" or "Home theater."
post #10986 of 11634 Old 01-25-2015, 06:01 PM
Liked: 0
One more quick question. Whenever I turn my AVR1613 on, my sub (Bic America F12) makes a quick thump. I have it plugged in through the sub out with a digital coax cable. Is this fault of the receiver, sub, or both?
Teeeejay is offline
post #10987 of 11634 Old 01-25-2015, 07:45 PM
Liked: 1
Thanks. I got it to work now.
post #10988 of 11634 Old 01-26-2015, 03:48 AM
jdsmoothie's Avatar
Liked: 7528
Sub amp issue ... either AUTO ON is no longer working well (set to ON to test) or sub amp itself needs to be powered on first before the AVR.
post #10989 of 11634 Old 01-26-2015, 05:54 AM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
Where do you connect the ac power to? Do you have a surge suppressor?
80sGuy is offline
post #10990 of 11634 Old 01-26-2015, 03:26 PM
enrite's Avatar
Two TV channels have some sort of audio encoding issue - Sound only at times
Hi,
I have had an AVR-1713 for several years with no issues but in December something changed. Now I don't get sound on shows and some commercials for two channels, but other commercials I do get sound. All other channels are fine. If I bypass the AVR for sound and use the TV direct sound all is good.
AVR-1713 Setup
Game = XBOX
Media Player = PS4
HDMI to TV HDMI (ARC)
I have FiOS service with an HDHomeRun cable card tuner. So I watch TV through Windows Media Center on the XBOX.
I updated firmware on the TV (Panasonic TC-P60ST60) and AVR.
I don't have the sound problems:
- Through a TV with an HTPC
- Through a TV with XBOX directly (no receiver)
- On the problematic TV if I use the TV for sound directly
The problematic channels are NBC and ComCast Sportsnet...and there is a certain sporting event on NBC this Sunday!
I also no longer have sound on the XBOX in WMC (the launch screen, navigation beeps, etc.).
I have played with using optical audio, moving around the HDMI inputs but no success. Any suggestions?
Ian
enrite is offline
post #10991 of 11634 Old 01-26-2015, 03:34 PM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
^^Do a reset on the receiver.
80sGuy is offline
post #10992 of 11634 Old 01-26-2015, 05:50 PM
jdsmoothie's Avatar
Liked: 7528
Originally Posted by enrite View Post
Hi,
AVR-1713 Setup
Game = XBOX
Media Player = PS4
Ian
There have been issues reported when using Verizon Fios boxes. Denon is reportedly working with Verizon to resolve the issue. Try passing HDMI to the TV and optical back from the TV if you only tried optical from the Xbox.
post #10993 of 11634 Old 01-26-2015, 06:24 PM
enrite's Avatar
Re: Reset. Thanks, I tried a soft and hard reset but no change.
Re: FiOS and Denon. Hmm...I actually tried to upgrade to the FiOS Quantum Gateway router (our dog bought it as a Christmas gift ), but it apparently doesn't like to play with repurposed MI424WR's as moca bridges. Lots of pixelation issues and actually this sound issue so I had to return the QG. Verizon did a reset on my outside box. Going back to my current router it solved the pixelation issues but not this sound issue. Playing with it tonight I noticed that at least for NBC the picture expands beyond the screen. I can't say that I noticed this before, though.
Re: Optical. I have HDMI Monitor to HDMI (ARC). Nothing from the XBOX to the TV. Optical is only out for the TV so I will play with it to the AVR tomorrow.
Probably very unrelated but worth mentioning...while I have been able to update the AVR firmware I have never been able to hear a test internet radio sound. I figured that has something to do with a Pandora or XM subscription.
Thanks for the help!
enrite is offline
post #10994 of 11634 Old 01-26-2015, 06:28 PM
jdsmoothie's Avatar
Liked: 7528
Internet radio is free just like FM and AM. Pandora has a free account option, however, you must sign up for it either via the AVR or your laptop or phone.
post #10995 of 11634 Old 01-27-2015, 12:27 PM
Liked: 0
Auto on should be working fine given that the sub is brand new.
Both the receiver and the subwoofer are plugged into separate surge protectors.
Teeeejay is offline
post #10996 of 11634 Old 01-27-2015, 01:06 PM
jdsmoothie's Avatar
Liked: 7528
Take the surge protectors out of the loop as a test.
post #10997 of 11634 Old 01-27-2015, 04:58 PM
mwg47x's Avatar
Liked: 88
I'm having a major issue with my 3313ci.
Starting last night the AVR will not stay powered on.
It powers up (green light flashing) get booted all the way to a solid green light and stays on for about 2 or 3 seconds after that.
It then reboots all by itself and start the loop again.
I have done 5 microprocessor resets and a couple of network resets to no avail.
Any ideas or am I screwed?
mwg47x is offline
post #10998 of 11634 Old 01-27-2015, 05:18 PM
MarkEHansen's Avatar
Quoted: 31 Post(s)
Auto-On Should be working fine on a new sub. You're absolutely correct there. However, you shouldn't be getting a popping sound either. Perhaps you should switch it to On as a test, just to make sure that's not the problem anyway?
MarkEHansen is offline
post #10999 of 11634 Old 01-27-2015, 05:21 PM
jdsmoothie's Avatar
Liked: 7528
Disconnect all cables/speaker wire from the AVR. If it still shuts down, likely amp failure. Otherwise, start reconnecting one device at a time to see which one is shutting it down. If a surge suppressor is in the loop, disconnect it and connect directly to the wall outlet.
post #11000 of 11634 Old 01-27-2015, 05:24 PM
mwg47x's Avatar
Liked: 88
Will do JD.
I'll chime in tomorrow or Thursday with results.
I knew you would have something for me to try.
BTW, these have a 3 year warranty, correct?
I assume from the day I purchased from Electronics Expo?
mwg47x is offline
post #11001 of 11634 Old 01-27-2015, 05:29 PM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
Check ALL your speaker wires and make sure there are no bare wires touching against each other thus causing the short.
80sGuy is offline
post #11002 of 11634 Old 01-27-2015, 05:37 PM
jdsmoothie's Avatar
Liked: 7528
Will do JD.
Correct. All "CI" series models have a 3 year warranty, while the non-CI series have a 2 year warranty.
post #11003 of 11634 Old 01-28-2015, 03:36 AM
Moochy82's Avatar
Liked: 0
Had an issue with my avr 3313 last night. I unplugged a hdmi cable from a wall plate and now I can't seem to get any picture from either zone onto the TV. The receiver recognises the hdmi input from whatever source on the display however no picture comes up. Move had dual zone working fine for years and now this! Any ideas?
Moochy82 is offline
post #11004 of 11634 Old 01-28-2015, 03:55 AM
jdsmoothie's Avatar
Liked: 7528
Describe the purpose of the "wall plate" and cable lengths. Try powering off and unplugging power to the AVR and all source devices for 10 minutes. Replug and power on TV, waitt 5 secs, AVR, wait 5 secs, and then the source.
post #11005 of 11634 Old 01-28-2015, 05:06 AM
enrite's Avatar
Still working through my sound issues.
I took a different angle. Since I am watching TV through XBOX / Windows Media Center, cycled through the XBOX audio options (Dolby Stereo, Dolby 5.1, Dolby with WMA) and the AVR Decode Mode but no success. Interestingly though, when I would assign the mode to either PCM or DTS I would not get sound. Only on Auto.
I then switched my setup to this:
XBOX HDMI to TV
TV Optical Out to AVR
I now get sound from the TV but not the AVR. On the AVR I have tried alternating Digital Assign CBL/SAT and TV to Optical but still no sound. Even another reboot did not work. So I am either missing a step on the new setup or I think something on the AVR is kablooey. My next step is to get another optical cord and try it to see if the cord is the issue. Any suggestions on what I might be doing wrong would be appreciated. Otherwise I think I will be in the market for a new receiver.
Ian
enrite is offline
post #11006 of 11634 Old 01-28-2015, 05:14 AM
jdsmoothie's Avatar
Liked: 7528
In order for the TV to pass audio to the AVR, it most likely has an audio setting for "external speakers" or "home theater."
post #11007 of 11634 Old 01-28-2015, 07:46 AM
enrite's Avatar
Thanks, but there is not an option for the ST60. I am going to head over to the forum for the TV and see if folks have had issues with the optical setup.
enrite is offline
post #11008 of 11634 Old 01-28-2015, 08:54 AM
jdsmoothie's Avatar
Liked: 7528
On the ST60 set Speaker Output from "TV" to "Home Theater."
post #11009 of 11634 Old 01-28-2015, 09:26 PM
Gmonski's Avatar
Originally Posted by lloydus View Post
My 2113 just started misbehaving the other day and I cannot figure out for the life of me the problem. I was doing to do a firmware upgrade to see if that would sort it out but when I click the "check for update" button I get a response that connection failed. I know my network is OK as all other devices can connect to the internet. Anyway I am firmware version 1490-3169-0000-2211-1097. Can anyone tell me if this is the latest version anyway?
Thanks, Lloyd
Was this ever answered?
Gmonski is offline
post #11010 of 11634 Old 01-29-2015, 06:50 AM
Liked: 0
Did that, didn't change anything.
It's not really a pop sound. I may have described that incorrectly. It kind of sounds like a low kick drum. However, I still don't believe that it's correct. Auto on is working, and both when it's set to on or auto on, it does this.
Teeeejay is offline
Denon , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
