The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 374 - AVS Forum | Home Theater Discussions And Reviews
post #11191 of 11212 Old 06-04-2015, 01:14 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4453 Post(s)
Liked: 2388
1. Set HDMI-CEC (BraviaSync) on the TV to ON and TV audio to "external speakers"/"home theater".
Set HDMI Control on the AVR to ON.
Connect HDMI cable from HDMI monitor output 1 to the HDMI(ARC) input on the TV
Power off both devices.
Power on the TV, wait a few seconds, power on the AVR.
2. Power consumption is minimal (1W).
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #11192 of 11212 Old 06-04-2015, 05:01 PM
jayhansen369's Avatar
Hi:
Quick follow-up. Assuming connection of HDMI ARC to Monitor 1 out - I am trying to figure out the Harmony One programming. In looking at the Harmony One programming software, I am prompted for which Input on the TV and for the Denon. Using the ARC, I am a bit unsure of the best choices.
The TV is connected via a network cable to our home network rather than a standard input. Does not seem to be an obvious choice on the Harmony One software for that. Similarly, the HDMI cable is hooked up in the manner suggested above (Monitor 1). The inputs specified through from the Harmony One setup are the array of inputs rather than an ARC type option.
Thoughts?
jayhansen369 is offline
post #11193 of 11212 Old 06-04-2015, 06:39 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
If the HDMI(ARC) connection is working correctly, all you should have to do is turn on the TV followed a few seconds later by the AVR. No source on the AVR is required, as the source is the TV and it's already been turned ON.
post #11194 of 11212 Old 06-06-2015, 08:43 AM
Hi:
Getting closer - but something still not quite right. I think it has to do with the way the receiver is set on input.
At this point I have the TV set for the audio to go via ARC and the HDMI Control on set on the AVR. The TV remote is sending controls to the receiver, as the power button powers off both and controls volume of receiver when TV is receiving inputs from the Cable Box, for example.
But, when I go to watch content from the TV Network connection (Netflix through the TV, for example), there is no audio from the receiver. I note that the AVR still shows the input as the last device that was delivering audio (Cable Box, in this case).
I was under the impression that the AVR would sense the ARC audio input and select that as the audio source. I am unclear on how to configure this piece.
Thoughts?
post #11195 of 11212 Old 06-06-2015, 09:08 AM
I currently don't have the TV Audio input "configured" as the TV Audio input options are only for separate physical connections (ARC is not an option noted on the Setup Assistant)
post #11196 of 11212 Old 06-06-2015, 09:40 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
There is no other setting on the AVR required other than setting HDMI Control to ON. Bottom line is that HDMI(ARC) doesn't always work with some TVs. A work around would be to simply connect an optical cable from the TV to the AVR which many actually prefer anyway.
post #11197 of 11212 Old 06-22-2015, 08:40 AM
.piff's Avatar
Liked: 2
Hello everyone. It's really a pleasure to be part of this forum.
I'm starting in the fantastic world of Hi-Fi audio.
Really useful information in this thread!!!
I just bought a Denon AVR 2113 receiver and I wanted to get it up to date to get the Spotify feature but the salesman told me not to update firmware because a "virus was reported by Denon".
For me makes no sense but before starting the process I wanted to ask all of you if you heard something.
Thanks in advance and I'll try to be active in the forum.
Have a great day.
.piff is offline
post #11198 of 11212 Old 06-22-2015, 09:38 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
You'll have to get the salesman to be more specific .... what virus? And do you have an international unit or a unit purchased from the USA?
post #11199 of 11212 Old 06-22-2015, 09:49 AM
.piff's Avatar
Liked: 2
I assume it's an international unit.
It's any way to verify this?
Are there different firmware versions for US and International units?
Thank you!
.piff is offline
post #11200 of 11212 Old 06-22-2015, 12:02 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
Yes, there can be different versions of firmware as the models in other regions outside of the USA can be different.
post #11201 of 11212 Old 06-22-2015, 12:29 PM
.piff's Avatar
Liked: 2
Thanks again!
I think it's nonsense that a company like Denon could release a corrupted or "virus" infected firmware.
What is your advice? I take the risk updating or not?
Have you ever heard something like this?
.piff is offline
post #11202 of 11212 Old 06-22-2015, 12:44 PM - Thread Starter
batpig's Avatar
Quoted: 1831 Post(s)
Liked: 2015
Originally Posted by .piff View Post
Thanks again!
I've never heard of such a thing. And I've read a lot of Denon threads
.piff likes this.
batpig is online now
post #11203 of 11212 Old 06-22-2015, 12:57 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
Thanks again!
Again, I would follow up with the salesman and get the specifics on why he believes a "virus" was released.
.piff likes this.
post #11204 of 11212 Old 06-22-2015, 09:50 PM
David James's Avatar
Quoted: 36 Post(s)
Liked: 77
I just received a Crown XLS2000. I attached the Denon's Front Preouts to the Crown and the speakers to the crown. I'm driving 4 OHM speakers. I wasn't expecting a ton of increased power, after all I'm only increasing the watts by between 2x & 3x. However, while I haven't done any actual measurement, it seems I have less power then I had before.
I did some research (yeah, now, should have done it first), and I may have a a mismatch between the output voltage of the preouts and input sensitivity of the Crown. I just found this post from 3 years ago:
Originally Posted by SubSolar View Post
Is anyone running a 3313 with a Crown Xls amp? I'm thinking of buying an xls 2500 but I believe it recommends a preout output of 1.4v and the 3313 only puts out 1.0. Will this be an issue?
No one responded.
So, did my failure to do the research first bite me in the butt or am I missing something?
David James is online now
post #11205 of 11212 Old 06-23-2015, 12:38 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
RCA pre-out voltage is spec'd as 1.2v in the back of the AVR Owner's manual.
post #11206 of 11212 Old 06-23-2015, 06:52 AM
Quoted: 36 Post(s)
Liked: 77
Thanks. I'll have to actually have to break out the SPL meter to see if my impressions are correct. I've found a good article trying to explain how to calculate the impact of the mismatch but my brain can't seem to comprehend it.
post #11207 of 11212 Old 06-23-2015, 07:44 AM
GuyH's Avatar
Maybe there was a miscommunication along the way somewhere. I was told by Denon NOT to update firmware unless I really needed the new features as the process is very delicate and not infrequently results in serious problems, such as losing the network card permanently which requires the unit being sent in for repairs. Apparently this happens when your connection is lost to the Denon server during the download process. The loss of communication could come from your ISP, their server, your modem, your router, or anywhere else along the way.
I've updated mine (2113 and 3313) a number of times without problem, but did lose one of my units (3313) due to a failure in the update.
One of the things they recommended is to plug your AVR directly into the modem instead of the router in eliminate 1 possible failure point.
best of luck
.piff likes this.
GuyH is offline
post #11208 of 11212 Old 06-23-2015, 07:49 AM
.piff's Avatar
Liked: 2
Great advice.
I've done the process successfully yesterday!
Spotify works perfectly and all the other features as well.
It's a mystery why he told me the "virus" thing.
Thanks everyone for the help.
.piff is offline
post #11209 of 11212 Old 06-29-2015, 10:18 AM
Question on IR in and Out
Hi Guys:
I have a question on the operation of the IR In and Out on the AVR 3313 unit.
I am trying to control a Sony TV with an IR controller that purportedly requires a 3.5MM stereo input. I am evaluating various options for connecting (due to cabling limitations, etc. One such option is plugging the Output from the AVR to the TV.
So, I would like to better understand how the IR out works. Is that simply a pass through of the IR input signal?
And, if so, would a 3.5mm stereo able connected to the Sony IR input likely work?
Thanks for any suggestions.
post #11210 of 11212 Old 06-29-2015, 10:23 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
Originally Posted by jayhansen369 View Post
Hi Guys:
Not much known there, but generally designed to be connected to other Denon products as the Denon IR codes would not likely work on your TV.
post #11211 of 11212 Unread Today, 03:15 PM
gdoan's Avatar
Help...AVR-3313CI won't turn on - sometimes.
Ok, I've read the FAQs, I searched this and other forums. I'm hoping one of you can provide that secret answer... A guy can hope, right?
I've owned the 3313 since new (~11/2012). I take care of it. Cooling fans, lots of reading manuals, FAQs, etc. It's been pretty decent until recently. About a week and a half ago, I went to power on the unit (Harmony activity). Everything powered on but the 3313. Red power light is lit solid. Tried original remote - nothing. Pressed the power button - nothing. To the forums Batman... Quick perusal and I try the soft reset (unplugged for ~10 mins.) Plug it back in and it powers up and all seems right with the world. Not so.
The next day, same thing, won't power on. Soft reset revives it, again. Already getting old... But, since I had been having one mild, nagging issue (when accessing the web interface through the browser, the second screen, after selecting the 'main zone power' option wouldn't render all the way. Pressing F5 would 'fix' it) I thought, let's do the microprocessor reset and see if it solves it all. Do the reset and set everything back up and . . . drum roll . . . next day same thing. I read more here and elsewhere. I read the many implores to do microprocessor resets 5 times. I do that; set things back up (network connection seems spotty, but I don't use that much) and, next day - same thing.
I read more. I do supposedly undocumented network interface and microprocessor reset 5 times. I think you know what's coming the next day... I break down and call Denon. We go over symptoms and all I've done. Guy tells me that the solid red light in Standby indicates an overload or some sort of error condition. This doesn't sound right. It looks the same when it does turn on. Then he says there's an'extended soft reset' I should try. That involves disconnecting EVERYTHING and unplugging for 10 mins. This way, he says, no power leaks in via connected devices. (So, he says, that means unplugging my speakers, too . . .) So, 95% of my rig is connected to a UPS. I power it down and unplug or disconnect the couple of other things. I let it sit for ~30 mins. Connect it all back up, power it back up, all works. Next day . . . Really getting old now.
I call Denon back. This guy tells me the first guy was an idiot.; that if I've done a microprocessor reset and it's still happening, it's repair time. This is where I learn (I gloss over those parts when reading posts here) that Denon's idea of warranty repair sucks and that there are apparently only about 4 repairs centers in the Milky Way. Now, I exaggerate - a little, Closest repair place is 40 miles away and I live in the center of the Capitalistic world! (DC area). I'm fine with taking it in and I *think* I can survive without it for a while. (I have my AVR-2807 still...) I just want to know that there's nothing left to try. I can detail what's connected, if someone things it's needed. Nothing special. 5.1 set up. 5 HDMI devices - 73" Mitsubishi DLP (still works great!), Verizon FiOS VMS1000, LG Blu-ray for those nostalgic days, Apple TV, and a Roku 2 XS. 5 of the 5.1 are pre-outs to an Outlaw amp and the sub is a Sony 100W job.
But, before I yank it all apart and slug it over there, is there anything else anyone can suggest? Nothing has changed in the last month. I haven't added or removed anything in over a month.
Thanks for reading and any help!
Greg
gdoan is online now
post #11212 of 11212 Unread Today, 05:09 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2388
Repair is the next step, however, I'd get an estimated time to repair from your "local" shop as it can often be many weeks vs. only 1-2 weeks if shipped up to the factory repair facility United Radio in NY.
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
