The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 375 - AVS Forum | Home Theater Discussions And Reviews
post #11221 of 11228 Old 07-17-2015, 02:17 PM
Liked: 0
Just reconnected it. Still no display on the front. I also can not get the on screen menu to work on the tv BUT I could connect to it via the phone app and the web gui. I could even change some basic config items but could not get it to play sound. I tried multiple sources net/usb, cable tv and FM and was unable to get audio from any of them.
Kind of ironic with the history these have with network issues that now the only thing that appears to be working is the network.
blackbirdpilot is offline
post #11222 of 11228 Old 07-17-2015, 02:42 PM
Liked: 0
To clarify that last post a bit:
Via the app it was connecting and indicating that on net/usb it was streaming pandora or when on FM I was able to tune in stations and even see the station/artist/song info but was getting no audio.
Since this thing is out of warranty is there any benefit to cracking it open and looking around or is it a waste of time since I prob would not be able to order parts for it anyway?
post #11223 of 11228 Old 07-17-2015, 03:01 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4793 Post(s)
Liked: 2501
No reason not to open it up. Perhaps you can see a loose board or something out of the ordinary.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective? Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #11224 of 11228 Old 07-17-2015, 04:53 PM
Liked: 0
I opened it up for a look hoping for something obvious. I am a UNIX admin and I have seen servers with fewer cards. I looked it over for anything loose or the tell tale signs of the magic smoke having escaped but everything I could see looked fine.
post #11225 of 11228 Old Today, 10:22 AM
johnc847's Avatar
I have a AVR-1913 and when using airplay from my iPhone, every once in a while the screen flashes green and the audio skips and it lasts a few seconds then it is back to normal. It does this a lot at times and sometimes not at all. I'm using a Netgear R6250 router and with a 3ft CAT6. I saw this post but it references it could be the HDMI cable. I'm not sure that could be the case with the Audio issues when the audio isn't even going through the HDMI cable. Anyone have ideas? I've tried resetting the microprocessor and that didn't solve it. I reset my router as well and nothing helps.
johnc847 is offline
post #11226 of 11228 Old Today, 10:34 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2501
You could try doing a soft reset by unplugging the power cord for 10 minutes. Could be the video card is going bad. Does it happen with video source devices?
post #11227 of 11228 Old Today, 10:35 AM
johnc847's Avatar
No it only happens with AirPlay. Never with other sources. Would that mean my video card is good?
johnc847 is offline
post #11228 of 11228 Old Today, 01:18 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2501
Likely yes. For Airplay you may want to consider purchasing an AppleTV which would also allow streaming of video as well.
Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver , Denon
