The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 386 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #11551 of 11572 Old 01-10-2017, 09:52 AM
jdsmoothie's Avatar
Quoted: 13394 Post(s)
Liked: 6218
Originally Posted by deton8 View Post
Hi all,
My 2313ci recently started doing the old, "no sound to speakers" thing. I hear a click (like you get when the AVR powers on) then nothing. A couple of times there was a pretty awful buzzing instead of speaker output as well, though that is rarer.
For a while power cycling the unit restored functionality, and often I could just plug in headphones to get sound out. But then I had to start doing microprocessor resets for sound to come back, and then headphone input started conking out as well.
I tried the 5-6 microprocessor reset process, but the problem keeps coming back, so I'm guessing it's hardware.
Any idea what the faulty component might be, and how much it might cost to repair?
On older models (ie. 2010), there is an issue where the main zone speakers go silent because the headphone circuit is engaged due to dust build-up on the contacts. As a last test, try inserting/removing the headphone plug a few times in the headphone jack. If still no joy, this could be an issue of amp failure which is likely to cost at least $300 or so to repair. Likely better to put the money into a more current model, especially if planning on purchasing a 4k TV in the near future.
jdsmoothie is online now
post #11552 of 11572 Old 01-11-2017, 04:10 AM
deton8's Avatar
Thanks for the reply. I will see if I can clean out the headphone jack with some canned air or something.
If that doesn't do the trick I guess I will start shopping around for when it finally kicks the bucket altogether!
deton8 is offline
post #11553 of 11572 Old 01-16-2017, 10:25 PM
makaveddie81's Avatar
Quoted: 485 Post(s)
Liked: 277
My AVR-1713 is not outputting any sound out of the front left channel. I already swapped out the two front speakers as well as flipped the cables while using the test tone function and the issue persists.
Any ideas on what could be causing this? Is my only option sending it for repair or are there any DIY alternatives I can try?
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is offline
post #11554 of 11572 Old 01-16-2017, 10:47 PM
Quoted: 485 Post(s)
Liked: 277
Microprocessor reset did the trick. Helps to check the first post of this thread lol.
post #11555 of 11572 Old 01-17-2017, 01:20 AM
jdsmoothie's Avatar
Liked: 6218
Great! Thanks for reporting back with the solution.
post #11556 of 11572 Old 01-26-2017, 03:30 PM
Liked: 1
Just joined the AVS Forum. I wanted to thank all who have posted information about the "care and feeding" of the Denon AVR-XX13 series receivers. I was having trouble with my AVR-2313CI updating to the new firmware. I began the Google search and stumbled over this website and this thread. I would have never been able to unlock it from the "Update Retry" loop without your help! I was finally able to get my AVR-2313 updated using the USB method.
I did discover one item about the USB update that I did not notice in this thread. The read file that comes with the Denon firmware download file describes how to do an USB firmware update but leaves out one very important step! After loading the firmware folder onto a USB thumb drive, you make certain the AVR is turned off, then insert the thumb drive in the front USB slot. While simultaneously depressing the " Tuner Preset CH-" and "Status" buttons, power on the AVR. The display will show "USBUpdateStart".
The missing step is you must select "Enter" on the AVR original remote control to get the AVR to actually begin the update from the USB drive! Once you press "Enter" on the remote the display will show "UpdateFileCheck". After 30 seconds to 1 minute the display will switch to a time remaining countdown and the power indicator will switch to "red". After the process is complete, the display will show "UpdateComplete". Once complete, the Denon instructions recommend doing a microprocessor reset.
I apologize if this information is somewhere else in this thread--I didn't read all 11555 posts! I just wanted to make certain this info is out there for all to read.
batpig likes this.
jrtchalet is offline
post #11557 of 11572 Old 02-12-2017, 02:02 PM
Ak Gara's Avatar
Quoted: 24 Post(s)
2113ci owner, it's doing this thing where sound is horribly distorted, loud, clipped, and crackly, but ONLY when using headphones?? I'm going to try a different HDMI port on the denon to see if that helps but has anyone else heard of this problem?
[edit] Headphones work just fine on everything else, PC > green audio out > headphones work fine too, and PC > HDMI > Denon > Speakers work perfectly.
Ak Gara is offline
post #11558 of 11572 Old 03-05-2017, 10:46 AM
autzenpowers's Avatar
Greetings. I'm hopeful someone has a fix for this issue that recently popped up.
My Denon 1713 recently stopped reading the hard drive I use to play stored music through the iPod/USB port. It used to work flawlessly. So far I have tried (1) resetting the microprocessor, (2) updating the firmware, (3) first aid on the hard drive, (4) erasing, reformatting, and reloading the hard drive, and (5) cleaning/tightening the USB connection on the receiver. I'm still getting a "No Connection" message from the receiver. The files on the hard drive are all readable and playable through VLC on my computer. Any fixes for this?
autzenpowers is offline
post #11559 of 11572 Old 03-05-2017, 12:47 PM
jdsmoothie's Avatar
Liked: 6218
Try doing a "network reset" on the 1713 as noted in post 5 of this thread, doing it a few times in a row. If still no joy, you may need to use another source device (eg. BDP, game, etc.).
post #11560 of 11572 Old 03-07-2017, 01:07 AM
80sGuy's Avatar
Quoted: 185 Post(s)
Liked: 35
Make sure to also check the micro-USB cable housing/connection end from the drive. Those things are really pesky, any slight bends or angles can completely shut down your connection, especially if it is a Seagate. Grab the end of the plastic cable housing and bend it around to see if it makes contact, or try a different cable.
80sGuy is offline
post #11561 of 11572 Old 03-17-2017, 05:52 PM
hikouka's Avatar
Originally Posted by raymate View Post
calibrating my TV
And after owning my 2113 for over a year just noticed the denon brightness control set to 0 is clipping the blacks
I moved it up to 1 and it seems to stop clipping the blacks
Is that right and moving to 1 fixes it.
I was doing a below video black test and every test bar below video blacks was missing until I set the denon brightness to 1
Any ideas
mine doesn't even do that, it always clips blacks unless i'm changing the wrong setting, where did you find yours?
Hey, I'm a firm believer in the philosophy of a ruling class
Especially since I rule.
hikouka is offline
post #11562 of 11572 Old 03-20-2017, 05:31 PM
Thanks for the advice. I tried several network resets and it didn't help. I plugged in a USB jump drive with an LED that lights up when connected to a computer and it stays dark when connected to the Denon. I'm thinking maybe the USB port failed mechanically. How would I hook a hard drive up to another source device as suggested above? Thanks again!
post #11563 of 11572 Old 03-21-2017, 02:21 AM
jdsmoothie's Avatar
Liked: 6218
Any source device that will accept a USB input (eg. Blu Ray player, PS3, PS4, XBOX, TV, etc.).
post #11564 of 11572 Old 04-25-2017, 04:26 PM
Transmaniacon's Avatar
Quoted: 1581 Post(s)
Liked: 1379
I've got a AVR-1713 and would like to connect an amp and speakers to the Zone 2 pre-outs, what sources am I limited to playing on Zone 2? Was hoping to use the receiver's networking functions to stream Tidal via Airplay to Zone 2.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is online now
post #11565 of 11572 Old 04-25-2017, 06:33 PM
jdsmoothie's Avatar
Liked: 6218
Analog, network (to include Airplay), AM/FM Tuner, and USB; however, Airplay will first hijack the main zone and once playing there can be selected in Zone 2, and although the main zone source can be reselected, the main zone cannot be powered off if not being used.
post #11566 of 11572 Old 04-26-2017, 03:06 AM
Liked: 1379
So I will have to play content on both zones in order to use some 2? That kind of defeats the purpose for me, maybe I'll try it out and see if I can find a solution that works.
post #11567 of 11572 Old 04-26-2017, 03:10 AM
jdsmoothie's Avatar
Liked: 6218
No, Airplay can be playing in Zone 2 with nothing playing in the main zone; however, unlike more current models, the main zone must be left powered on.
post #11568 of 11572 Old 04-26-2017, 03:13 AM
Liked: 1379
Ohh I see, thanks, I think this should work out then.
post #11569 of 11572 Old 05-08-2017, 03:12 PM
jnak's Avatar
Quoted: 47 Post(s)
I'm not sure if this has been brought up before - I tried searching and didn't find anything that would help. Lately, my 1713 seems to have very low volume, and very low bass output to my subwoofer. I'm using it in 3.1 configuration and have the rear channels turned off. Where I used to listen to it at volume level 20-25, now I find I have to turn it up to 35-40 and the subwoofer seems to output very little bass. I have not changed any of my equipment or settings when this happened.
The network card in the receiver died ages ago so I can't back it up, and would like to leave the network reset as a last resort as I'd have to re-set it all up.
jnak is offline
post #11570 of 11572 Old 05-08-2017, 04:52 PM
jdsmoothie's Avatar
Liked: 6218
Most likely repair or replace but a reset would be the next step.
post #11571 of 11572 Old Today, 01:22 PM
Liked: 0
Arv 1513
Yo everyone, total noon here. I just purchased a denon arv 1513 with the Boston acoustics speakers. So far I'm enjoying it, and also learning about the settings (because that's fun too!) I have learned though, that under "input mode" there is a "decode mode" where my options auto, pcm, and dts. For whatever reason, sound only comes through when "auto" decode mode is selected. Why can I not select PCM? Did I reconfigure one of the other settings incorrectly?
Thanks in advance,
Neil
Neilph7 is offline
post #11572 of 11572 Old Today, 01:51 PM
afrogt's Avatar
Quoted: 1196 Post(s)
Liked: 853
Why do you need to set the mode to PCM? Leave it on Auto.
Afro GT
afrogt is online now
Denon , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
