Denon 3312 Zone Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-08-2012, 11:40 AM - Thread Starter
mlx52's Avatar
I'm trying to figure out if my current Denon 3312 is capable of doing the following, or if I need to upgrade models. Currently my Denon 3312 is hooked up to a 3.1 speaker setup feeding a HDMI Panasonic Plasma (with 5 HDMI sources) and a composite video source. I'd like to use the Zone 2 option to feed 2 more rooms (if anyone has a suggestion for a HDMI matrix that can split to two displays + audio, I'd appreciate it). Is it possible to use Zone 2 and have the zones use two separate HDMI sources at the same time, or does it have to mirror the content.
Ideally I'd like to be able to watch, for example, the Tivo in the living room (zone 1) and then the AppleTV in the two bedrooms (zone 2). No additional speakers, HDMI audio through the TV in the bedrooms is just fine. Is this possible to do?
mlx52 is offline
post #2 of 4 Old 05-08-2012, 11:47 AM
ccotenj's Avatar
Liked: 101
no...
you can't send hdmi to zones, period...
- chris
ccotenj is offline
post #3 of 4 Old 05-08-2012, 11:51 AM - Thread Starter
mlx52's Avatar
Originally Posted by ccotenj View Post
no...
It seems like the 3313 will be able to do this, is that correct?
mlx52 is offline
post #4 of 4 Old 05-08-2012, 12:34 PM
ccotenj's Avatar
Liked: 101
maybe... it appears as if there will be a "zone hdmi out", it remains to be seen exactly what that means.... our best guess is that it works like a matrix switch... in which case it should do most of what you want, anyway...
- chris
ccotenj is offline
