Denon AVR-1713 vs discounted Denon AVR-1912 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-10-2012, 01:51 AM - Thread Starter
cmclean3's Avatar
I've looked at the info for the soon to be released (in my country) Denon AVR-1713 and i think it has everything i want/need. I asked my local hifi shop when it would arrive and was told at least 2 or 3 months.
They offered me the 1912 heavily discounted if i didn't want to wait. I've compared both and they seem quite similar (apart from the obvious 7ch vs 5ch). Is there anything in this season's models that i should especially wait for?
The only feature i really want to be able to do is to control the system (turning it on and off, changing source, volume etc) via and ipad/iphone remote as well as being able to use airplay for music. I'm going to be using it mostly for my tv decoder, apple tv, ps3 games and blurays as well as streaming airplay.
thanks for your opinions in advance
cmclean3 is offline
post #2 of 15 Old 05-10-2012, 05:45 AM
jdsmoothie's Avatar
Quoted: 12151 Post(s)
Liked: 5533
Outside of the USA, the 1912 features the same more advanced Audyssey MultEQ XT as does the 1713 so no difference there.
1912 -
a. 7.1 or 5.1/Zone 2 (cannot have 7.1 in main zone w/2 extra speakers on the patio as there are no Zone 2 preouts to connect to external amp)
b. Cannot SAVE config file (to include Audyssey settings) to PC for easier loading after resetting the microprocessor (ie. must do AUTO SETUP again)
c. When Airplay is selected for Zone 2 audio, it must also be selected for the main zone (ie. cannot have independent source in main zone while Airplay is playing in Zone 2) Note: You can avoid this limitation by using the Apple TV instead of the on board Airplay feature.
d. GUI overlays 2D video only
1713 -
a. 5.1 w/Zone 2 preouts (ie. can add Zone 2 speakers with 2CH external amp)
b. Able to SAVE/LOAD config file to/from PC
c. Airplay can play independently to Zone 2 with another source in main zone
d. GUI overlays 2D and 3D video
If none of the above is a concern for you, then the 1912 would be the better choice.
Also depending on which model you purchase, join us in either the Denon AVR-XX12 Owner's thread (linked in my sig) or the newly created Denon AVR-XX13 Owner's thread.
jdsmoothie is online now
post #3 of 15 Old 05-10-2012, 06:09 AM - Thread Starter
cmclean3's Avatar
thanks jdsmoothie for a solid reply
thinking about it since i first posted i'm probably over analysing and both will do what i need them to do. i'd love to say the restriction of not being able to able to independantly airplay into zone 2 is a deciding factor but realistically its not going to matter until i move houses and by then i'll have probably upgraded to something bigger and better. and the 7.1 will be nice is i ever upgrade from 5.1 in the mean time.
for now my biggest deciding factor is the ipad remote. do you know if they are both controlled by the same remote app and have the same functionality?
cmclean3 is offline
post #4 of 15 Old 05-10-2012, 06:15 AM
jdsmoothie's Avatar
Liked: 5533
Yes, they can both be controlled by iphone/iPad using the Denon remote app.
Also note, that with the AppleTV, there is no such limitation of having to play Airplay to both main and Zone 2. Additionally, the AppleTV can stream video which the on board Airplay application cannot do. You're much better served using the AppleTV for Airplay with either model.
post #5 of 15 Old 07-18-2012, 07:12 AM
honeymonster's Avatar
The only other factor you might consider is re-sale value if you were to upgrade in the next 12 months - I'd rather buy last years model than a model two season old, so that would tend to put the Denon AVR-1713 as favourite for me smile.gif
honeymonster is offline
post #6 of 15 Old 08-01-2012, 11:11 PM
Frink76's Avatar
I just wanted to jump into this thread because I have a question regarding these 2 receivers. Would I be able to hook up 3 pairs of speakers that I have in the kitchen, dining room and deck. Each pair have their own independant volume control.
Frink76 is offline
post #7 of 15 Old 08-01-2012, 11:23 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
No,
The 1912 only does 2 zones.
The 1713 is only a 5.1 receiver, so you'd need a seperate amp even for a second zone.
You're going to need to purchase some type of speaker selector if you want seperate volumes in 3 rooms.
Afro GT
afrogt is offline
post #8 of 15 Old 08-01-2012, 11:46 PM
Frink76's Avatar
thanks for the quick reply. Actually I was thinking of setting up my older receiver to run the house speakers. I guess the 1713 has zone 2 pre-out, meaning they are unpowered. So can I simply input them into an older receiver and run my 3 sets that way using the A and B settings. The 1912 has powered zone 2, so I wil not be able to run this into a seperate receiver. Am I somewhat making sense?
Frink76 is offline
post #9 of 15 Old 08-01-2012, 11:53 PM
afrogt's Avatar
Liked: 757
you can run 2 sets of speakers using A and B settings on your old receiver but I don't see how you can get different volumes in each room...
Afro GT
afrogt is offline
post #10 of 15 Old 08-02-2012, 12:00 AM
Frink76's Avatar
I have volume controls on the wall for each pair of speakers. 1 on the deck, 1 in the kitchen and 1 in the dining room. I have been running my 3 pairs using this receiver for some time and its been ok. I just dont put all 3 on at the same time and have never cranked the volume up so I figure it would be ok. I guess my question is... is there a difference between the zone 2 in the 1713 and the 1912.
Frink76 is offline
post #11 of 15 Old 08-02-2012, 12:07 AM
afrogt's Avatar
Liked: 757
None other that one needs external power and the other uses the receivers built in amps.
Afro GT
afrogt is offline
post #12 of 15 Old 08-02-2012, 12:16 AM
Frink76's Avatar
thx for answering all my questions. Would I be able to power 3 speakers from the 1912 or is that too much power for the zone 2 outs? I feel as though, the 1713 pre-out may be the better choice as I already have an extra receiver to use as the amp. On a bit of a different note... would I be able to play music via Apple TV into my zone 2 or would I just use the included Airplay since I cannot use HDMI feeds into zone2.
Frink76 is offline
post #13 of 15 Old 08-02-2012, 12:59 AM
afrogt's Avatar
Liked: 757
How are you going to power 3 speakers from zone 2 when it only has two speaker terminals. You're asking questions I can't even visualize.
I don't have answers to any of those questions, maybe you should send a PM to jdsmoothie or post in the XX12 and XX13 Owners Threads.
Goodnight...
Afro GT
afrogt is offline
post #14 of 15 Old 08-02-2012, 03:05 AM
jdsmoothie's Avatar
Liked: 5533
As long as you continue the practice of not having all 3 additional zones on at the same time, you could connect a multi zone impedance matching speaker selector to the Zone 2 speaker posts on the 1912, the limitation being that Airplay on the 1912 would also have to be selected in the main zone when playing to Zone 2. Using the 1713 would be much safer with the Zone 2 pre-outs going to your old receiver (as you are currently doing now) and there is no Airplay restriction (ie. Airplay can be independent to this old receiver with other audio selected in the main zone). Also note that whether using the speaker posts (1912) or the pre-outs (1713), Zone 2 audio is limited to NET/USB and "analog" connected sources only (ie. no HDMI or optical/digital coax).
post #15 of 15 Old 09-18-2012, 07:54 AM
alboon2000's Avatar
Hi,
Can somebody tell me if it's possible to navigate through the network mp3 files using the 1713 amplifier OSD, or is it compulsory to switch on the TV ?
Thank you.
alboon2000 is offline
Denon Avr 1912 Receiver , Denon Avr 1713 Receiver
