Bose statement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-11-2012, 05:14 PM - Thread Starter
otherc's Avatar
I just sold a Bose 321 GS series iii (yes i commit that mistake of bought it, but it was my first contact with the hifi world, now i have denon and B&W) and realized that i keep a sheet of paper saying among other things the next:
"...We strive to reproduce the musical sounds as closely as possible to those of the original performance. And we strive to avoid flashy sounds, such as those associated with accentuated bass and/or treble frequencies. While those sounds may be initially attractive to the novice, they are not real and are not enduring..."
What does Bose are refering to that statement???
otherc is offline
post #2 of 7 Old 05-11-2012, 05:31 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Marketing...don't overthink it
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 7 Old 05-11-2012, 06:38 PM
zoetmb's Avatar
Quoted: 67 Post(s)
Liked: 62
In the world of high-quality audio reproduction, formerly known as "hi-fi", you ideally want to have a flat frequency response. That is, if you plotted the frequency response of the unit on a graph, you would see essentially a flat line. When you see a frequency response rating of something like 20-20KHz +1db -2db, it means that the actual measured response doesn't vary by more than 1db in the positive direction and 2db in the negative direction from that flat line.
The only problem is that a device with such a response probably sounds kind of dull, even though it might be very "accurate". Most people prefer more bass and treble (a boost and the low end and the high end), especially when listening at low volumes.
Stereo receivers used to have a "loudness compensation" switch that would boost the highs and lows at low volumes, although most people kept it switched in place all the time. It was to make up for the fact that we perceive less bass and treble at low volumes. The loudness compensation circuits worked according to what was known as the Fletcher-Munson curve.
What Bose is referring to is the fact that they claim their systems have a very accurate response, rather than pushing the lows and highs to ridiculous extremes. Think of the guy in the hot rod with the giant bass speakers in the trunk with the levels turned up so that it rattles all the metal in the car.
Many decades ago, I sold audio equipment at retail. At the time, AR, which made incredibly fine and accurate speakers had at the bottom of the line a $49 speaker ($278 in 2012 dollars). Great speaker...I owned a pair. At the store, we had that speaker as well as a competing $49 "house brand". The AR was the better speaker. The house brand had more bass and treble, which doesn't mean they produced lower or higher frequencies than the AR - it means that at certain low and high frequencies the volume was pushed up. People would come in and ask for the AR and would be resistant to even audition the house brand. But once they did, they would always go for it. Most people don't like accuracy. It's the same as when you go to an electronics store and they have the brightness, contrast and color turned up on the TVs instead of showing a properly calibrated picture. They do that because that's what sells.
My problem with Bose is not that they claim to strive for a flat response. It's that they charge a lot of money for products that have very shoddy construction. My ex had a Bose System which comprised of a tiny control amp with a built-in CD player, small satellite speakers and a subwoofer. It didn't sound terrible, but the head unit was made of cheap plastic and the CD player couldn't have cost them more than $5 to make. It died after just a few years. Now she just drives computer speakers from her Mac either using iTunes or Pandora and she's more than happy with that.
On the high-end, Bose has made some good speakers. At J&R Records in New York, they have old Bose speakers in the back of the store and something else, maybe JVC speakers, in the front. When you're in the front, you think it sounds okay until you walk into the back where the Bose speakers have an extended, but accurate, high-end response and they're much smoother overall and sound far better. Then you walk back in the front and you realize how much you're missing.
zoetmb is offline
post #4 of 7 Old 05-11-2012, 06:49 PM
Quoted: 266 Post(s)
Liked: 148
I once heard a Bose set speaker at some electronics shop, and it sounded fine. I once heard the Wave radio, and it was far from as great as they claim.
Hard to say, but the sat sounded more or less natural. The wave radio did not.
post #5 of 7 Old 05-12-2012, 03:32 PM
dean-l's Avatar
In other words --- "we have inadequate bass and crappy tweeters, so don't expect it."
Bose "fills" a room with sound very nicely. And for most people that sounds good and is simple enough for them to handle setup. I'd go into demos, but you can probably fill that in yourself.
Of course, bad "muffled" upper/high-end sound has been an epidemic in mid-fi forever. Home theater has not helped with it's bass centric crowd. It's a BIG part of the reason room correction is so "great" for many people.
For some, the only clear upper-end of sound they get are things breaking from vibrating off the shelves.
Moderator harassment is wrong and immoral.
dean-l is offline
post #6 of 7 Old 05-14-2012, 01:10 PM - Thread Starter
otherc's Avatar
because i wonder if then the bass and treble coming out from my b&w are not real
seriously i don't know why Bose say that to their customers. I think the majority of them don't understand what Bose refers to.
otherc is offline
post #7 of 7 Old 05-14-2012, 02:12 PM
The Scott's Avatar
The first nice speakers I owned were a pair of Bose 901s (series V or VI?) and they were/are a quality piece of equipment. I still have them boxed up but to use them I require a receiver with a tape loop, something that is not readily available today and I would also have to place them in a different room for just listening to music.
Not going to happen anytime soon. Had them sold years ago along with a turntable to a good friend but my wife nixed that deal and she doesn't even like music. I think their headphones are good but to date I have not bought anything else made by them.
The Scott is offline
