AVR controling my PC volume? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-11-2012, 11:20 PM - Thread Starter
petriebird's Avatar
I have my PC hooked up to my denon 1712 through hdmi and when I turn the volume all the way down it also turns my headphones down that are hooked to my PC. It doesn't adjust the windows control volume but still I can't hear anything on my headphones.
I want to display video from my PC and listen to my headphones at the same time, how can I do this?
petriebird is offline
post #2 of 8 Old 05-11-2012, 11:33 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Do you mean from the same source or different sources?
If the same source why not connect your headphones to the receiver's headphone jack?
Afro GT
afrogt is offline
post #3 of 8 Old 05-11-2012, 11:44 PM - Thread Starter
petriebird's Avatar
I broke one adapter and can't find the other, I'll have to get another one.
But I don't see any way to shut off my speakers, on my old reciever I could just click the A button and turn off my speakers.
post #4 of 8 Old 05-12-2012, 12:11 AM
Knucklehead90's Avatar
Quoted: 384 Post(s)
Liked: 332
HDMI is a two way street. One device is capable of controlling another device over HDMI. You might be able to turn that feature off in your video card control panel.Look for a feature called CEC - Consumer Electronics Control connection.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 8 Old 05-22-2012, 02:41 PM
jharrison.mfsr's Avatar
Its most likely CEC like petriebird said. That can usually be turned off on the TV/Monitor side of things.
jharrison.mfsr is offline
post #6 of 8 Old 05-22-2012, 07:02 PM
51dueller's Avatar
Videocards do not support CEC. By the sounds of it, you aren't switching audio devices. Windows 7 only supports ONE output device at a time. You can't have HDMI audio and headphones. You have to go into the audio control panel on the computer and change it from hdmi to analogue.
51dueller is offline
post #7 of 8 Old 05-29-2012, 08:32 PM - Thread Starter
petriebird's Avatar
Thanks, thats what I ended up doing, just setting my rear panel as primary and it disabled my hdmi.
post #8 of 8 Old 05-29-2012, 09:19 PM
Brocken_5110's Avatar
My WinXP Pro PC does multiple sound outputs. I have headphones plugged into the Gigabyte GA-P35-DS4's onboard headphone-out jack, and audio also runs to my receiver via a DVI+TOSLINK-to-HDMI converter box. Windows controls the headphone-out jack, but doesn't control the TOSLINK-out volume.
Brocken_5110 is offline
