Switching Power Supply Power Consumption? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-12-2012, 11:31 PM - Thread Starter
davidlan's Avatar
Hi,
I'm looking for the approximate idle power consumption (turned on with no sound being sent to amp) of the following power supply:
http://www.parts-express.com/pe/psho...20-314&scqty=1
when connected to the following amp board:
http://www.parts-express.com/pe/show...=Bazaarvoiceps
I tried asking on partexpress, but 1 answer I got said it would be less than 2 watts and another said it would be on the order of 10-15 watts. The 2 watt explanation went like this:
The rated idle (0dB) current consumption of the TDA7498 6x100w board is 40mA or around 1 watt when supplied 24VDC.
This power supply is rated to consume <2mA at idle plus 12% of 114% of the load's consumption at 24VDC (because it is rated 88% efficient) - or about 0.15 watts.
So including wire losses/etc, expect this unit to consume about 2 watts when powered on and connected to that amplifier board while not receiving any signal.
But then I saw elsewhere someone said:
As a rule a SMPS will draw on the order of 10-15 W at idle, since you are still powering the electronics.
Does anyone know which one is accurate and which is inaccurate?
Thanks a lot,
David
davidlan is offline
