Pioneer VSX-520-k / Klipsch F-30: Help!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-14-2012, 07:44 AM - Thread Starter
Urobulus's Avatar
Hello all!
(really not sure where to post thise since it's about both amp and speakers :S)
I really need some help for something I don't understand at all, and I will try to give as many details as possible. I am an audio noob so bear with me :P
I had my Pioneer VSX-520-k amp for almost 2 years now and the whole time I never had speakers hooked to it: was only using it with my headphones to play my games and watch my movies.
Recently I finally decided to buy a pair of speakers after shopping for a couple of weeks and stopped my choice on a pair of Klipsch F-30. Was expecting great results since I heard a lot of good things about them from all the reviews and topic I read.
But unfortunately I am not super satisfied, and here's why.
For the 2 years I used my headphones (which are noise cancelling and a quality pair) I always had a great sound: receiver was always setting itself to STEREO (of course) since headphones were plugged in and everything sounded really nice, no matter if it was a movie (bluray) or games. Background music, voices, explosions, footsteps, the wind, etc.: could hear everything, nothing was drowned by another sound or frequency at the same time (or whatever it's called).
But since I bought my new F-30 something's wrong: I can play the same sequence (let's take Gears of War 3 here) and it won't sound the same AT ALL through the speakers vs. my headphones. With my HP everything sounds great: voices are loud, gunshots are punchy, footsteps in the grass sounds clear and crisp, I can hear EVERYTHING, nothing's missing.
With my new speakers it's just not the same at all: with the same sequence (above) some sounds seems to be either missing or are very VERY low compared to the rest... Like my previous example: gunshots sound distant and weak and footsteps in the grass are barely audible... It feels like half of the sounds are still there and playing nicely (explosions, voices) but another half is either missing or faint (gunshots, footsteps).
Now for the current setup: Everything is connected to the receiver through HDMI and a single HDMI cable goes to the TV for the video signal. Speakers are both in a corner of the room facing my couch 9 feet away (45 degrees angle). Each speaker is around 9 feet away from the receiver, total of 18 feet distance approximately between the speakers. They are not phased out (double checked the connections like 5 times) and I have a feeling that the problem might be my amp and not the speakers. When I say the problem is the amp I mean something's probably configured the wrong way, in the options I mean. Tried every single option and although it does modify the sound a bit it is not enough to see a real different and fix the problem above: ALC, Stereo, Pure Direct, Auto-Surround, disabled the surround speakers and center one since I'm only running 2, etc I tried everything. I know I don't have the best amp out there and it's a low-end one and I'm actually also wondering if maybe the amp is just not good enough for the speakers or something like that? But again it would sound weird too in my headphones no?
So for whoever has this amp, or can share some light on the situation: WHAT THE HELL IS WRONG?!?!? Lol I'm going to loose my mind here :P Had to play with my headphones the whole weekend because I just wasn't satisfied with the sound coming out of the speakers, and really stresses me out since I just paid a hefty sum for them
Any tips, recommendations or ''try this'' will be very appreciated: I know I have nice speakers and want to get the most out of them. Just not happening right now...
Urobulus is offline
post #2 of 5 Old 05-14-2012, 09:01 AM
ccotenj's Avatar
Liked: 101
nothing is "wrong"...
your headphones are on, well, your head...
your speakers are in a room...
it's not the amp...
fwiw, speakers and cans will always give a "different" experience...
i'd get the speakers out of the corners and get them closer together as a start...
- chris
ccotenj is offline
post #3 of 5 Old 05-14-2012, 09:16 AM - Thread Starter
Urobulus's Avatar
Oh no I understand and fully expected a ''different'' sound experience, just not THAT different... It's litterally to the point I'm almost loosing some sound effects...
Urobulus is offline
post #4 of 5 Old 06-02-2012, 08:04 AM
The_BladeDTS's Avatar
I have 520 too. Try using the gains on each speaker
The_BladeDTS is offline
post #5 of 5 Old 06-02-2012, 08:20 AM
I´m sorry i forgot you have stereo setup. Either way you can still try the gains, loudness and midnight modes. These last two adjust the eq curve for better dialog clarity and improved effects
Pioneer Vsx 520 K 5 1 Home Theater Receiver
