Reset sequence for Marantz SR7002-flashing red light - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-15-2012, 04:21 PM - Thread Starter
kghaddon's Avatar
I have the dreaded "flashing red standby" light error on my beloved Marantz SR7002. This happened after a lightening storm and I am hoping that I can reset the circuitry and not have to send the unit away for a month.
Does anyone know the reset sequence on the front panel to reset the microprocessor?
kghaddon is offline
post #2 of 10 Old 05-15-2012, 04:33 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
Although the reset procedure is listed on p. 82 in your Owner's manual (press/hold MULTI and Speakers A/B buttons while powering on); note that when the AVR shuts down in protection mode, it's most often due to a speaker wire from one post touching another post, so pull out the AVR and visually check all speaker wires are cleanly connected.
Also, is the power ring light blinking at 2x/sec (speaker wire or playing 4Ω speakers too loud) or more rapidly at 8x/sec (amp failure)?
jdsmoothie is offline
post #3 of 10 Old 01-01-2013, 09:48 PM
33charlie's Avatar
Hit 7.1. Pure direct. And clear buttons on front panel all at the same time. Got it from marantz tech support. It's not in the manual. It works. But if it goes back in protective mode it will need service
33charlie is offline
post #4 of 10 Old 05-15-2013, 01:15 PM
AVgrunt's Avatar
Thank you very much. I had my unit setting at a local repair guy checking the outputs for a short for 2months( older guy ). He concluded it was the microprocessor. Which. He did not have the ability.to test. I was going to the local shipping office this afternoon. To ship it to an authorized repair shop 150 miles away. Read your post, ran an extension cord out to my sefvice truck during lunch to test your magic press buttons and Bingo!!!!
AVgrunt is offline
post #5 of 10 Old 07-06-2013, 12:05 AM
Thebes's Avatar
Hi,
thank you very much.
I had the same problem with my Marantz and this is the only way I've found to reset my amplifier. Very useful smile.gif
Thebes is offline
post #6 of 10 Old 01-01-2014, 02:00 AM
sryans's Avatar
Life saver! Experienced the dreaded flashing Standby and after following your reset instructions, I was back in business. Many thanks as this was the only posted reference on the web that worked!
sryans is offline
post #7 of 10 Old 03-03-2014, 02:58 PM
Karlo Bazdan's Avatar
Hello,
I am knew to Marantz - was able to obtain a used one, which has the 'red light blinking' problem. Don't have the exact model in front me, but I assume they all work under the same principle.
Could you care to explain how I can reset the unit, and what exactly I need to do to fix the 2/sec blinking.
Thanks a lot,
K
Karlo Bazdan is offline
post #8 of 10 Old 03-03-2014, 03:23 PM
jdsmoothie's Avatar
Liked: 5500
The reset procedure depends on the model number, however, the issue is likely a result of one of the following issues ...
1. A loose speaker wire from one speaker post touching another speaker post.
2. Driving 4-ohm speakers too loud.
3. Amp failure.
post #9 of 10 Old 08-06-2015, 01:15 AM
Liked: 0
Which exactly buttons and in what order?
"Hit 7.1. Pure direct. And clear buttons on front panel all at the same time. Got it from marantz tech support. It's not in the manual"
Please, let me know how to "clear button on the front panel at the same time"? Which exactly bitton should I press for this?
Thanks in advance!
Balio Dinev is offline
post #10 of 10 Old 08-06-2015, 01:30 AM
jdsmoothie's Avatar
Liked: 5500
Thanks in advance!
It is indeed confusing the way it was originally posted. It should read as the following:
Press and hold the following three buttons on the front panel: 7.1 CH Input + Pure Direct + Clear
Power on the AVR and continue holding the 3 buttons for at least 4-5 seconds.
