B&k AV5000 II - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-15-2012, 06:33 PM - Thread Starter
toyo1's Avatar
Hello
I just picked up one of these amps and connected everything put got no power at all. Could it be a fuse that not working or where could i have gone wrong.
I have it connected to a B&k ref 20
Thank you
toyo1 is offline
post #2 of 3 Old 05-15-2012, 06:58 PM
Steve.'s Avatar
check the switch on the back to disable the power on trigger... try it without a trigger.
Steve. is offline
post #3 of 3 Old 05-15-2012, 07:21 PM - Thread Starter
toyo1's Avatar
Thanks for the tip
I tried that the red light comes on know but now i get no sound.
Has it been to long since i have done this but still i know how to hook up things. I am using bare speaker wire. Should i go out and buy better wire. Or once again what am i doing wrong. Thanks again
toyo1 is offline
