Belkin PureAV PF31 Power Problem HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-16-2012, 06:45 PM - Thread Starter
crazyinsane51's Avatar
I have a Belkin PureAV PF31. When the lights go off in the house from a lighting strike or something I have to unplug it to restore power. I've tried pressing and holding all the buttons on the unit and still nothing. What do I do? This has been going on for quite sometime. I've tried searching and found that 1 guy said his unit was no good. So I'm thinking my unit is having the same problem or maybe I'm doing something wrong.
crazyinsane51 is offline
post #2 of 9 Old 05-16-2012, 07:20 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 40
That doesn't sound right. Every time your power goes out the Belkin should power up without unplugging it. Every time your power goes out the Belkin isn't absorbing a strike. If you did get hit the unit should sacrifice itself to save your gear. Then it would be toast. I would return the unit. I think you have a bad unit.
Secret Squirrel is offline
post #3 of 9 Old 05-16-2012, 08:03 PM - Thread Starter
I think it's bad to unless someone else has some input. I'll be doing some upgrading over the weekend so I'll have some time to play around with it some more and get to the bottom of this little problem.
post #4 of 9 Old 05-17-2012, 08:31 AM - Thread Starter
bump
post #5 of 9 Old 05-17-2012, 08:42 AM
ClarkeBar's Avatar
Quoted: 25 Post(s)
Liked: 25
Hello,
I have the PF30 model and it has never restarted for me when there has been a shutdown for whatever reasons. Usually 3 lights stay lit and I must then manually press and hold the power button until the fourth light is lit and stays on. Then everything is normal.
Sounds like your unit either got zapped or is malfunctioning.
ClarkeBar is offline
post #6 of 9 Old 05-17-2012, 12:39 PM - Thread Starter
I have one light that under the lowest voltage that is red when I have no power. But when I do have power than I get the 3 green lights and the 4th when switched.
post #7 of 9 Old 05-17-2012, 07:24 PM - Thread Starter
bump anybody else have anything to say?
post #8 of 9 Old 05-18-2012, 05:11 AM
SpotcheckBilly's Avatar
Just personal opinion - I bought a Belkin PF31 when I first installed my HT. It went defective after the third day. No lightning strikes, no power surges, nothing. I was less than pleased by Belkin customer service. I have since gone to APC and never looked back.
Just my own experience, nothing more.
Cheers,
SB
SpotcheckBilly is offline
post #9 of 9 Old 05-18-2012, 06:36 AM - Thread Starter
If I replace it...I'm definitely looking to get a APC. I have APC on all my computers and never had 1 problem.
