Best Pre Pro for under $5000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 05-22-2012, 12:48 PM - Thread Starter
deeda's Avatar
I have looked at a number of the Pre Pro from Denon, Rotel, Anthem, Integra and others and I am not sure why anyone would look beyond the Integra DHC-80.3 Surround Processor for about $2000.
Can someone help me to understand what spending additional dollars on a Pre Pro between $2000 and $5000 and above $5000 gets me?
deeda is offline
post #2 of 27 Old 05-22-2012, 01:13 PM
ccotenj's Avatar
Liked: 101
imo, the "best pre-pro under 2k" is an avr... one that is more than competitive with the dhc-80.3 when it comes to feature set...
- chris
ccotenj is offline
post #3 of 27 Old 05-22-2012, 01:22 PM
Knucklehead90's Avatar
Quoted: 382 Post(s)
Liked: 332
A name? The Onkyo/Integra top shelf prepros are about as good as it gets at the $2k mark. A refurbished Onkyo 5508 will save a few bucks - get a Mack Camera Warranty to go with it - gives you up to 5 years of added coverage. The 5508 will do everything the 5509/80.3 can do - and for a few bucks less.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #4 of 27 Old 05-22-2012, 01:25 PM - Thread Starter
deeda's Avatar
How about above $2000 or even $5000?
deeda is offline
post #5 of 27 Old 05-22-2012, 01:31 PM
bfreedma's Avatar
Liked: 51
What features are you looking for? That would be a better way to get some advice than an arbitrary price range.
As has already been mentioned, due to economy of sales scale, an AVR is likely to be the best option, even if you choose to use it as a pre.
bfreedma is offline
post #6 of 27 Old 05-22-2012, 01:32 PM
Quoted: 382 Post(s)
Liked: 332
There is a point at which spending more money on audio components won't net you any more gains - for prepros its $2k IMO. Speakers? Probably around the $4-5k mark. Amplifiers? Probably not more than $1k per channel - if that. After that? Start looking for acoustic panels and bass traps. These are just my opinions - others disagree and thats ok. I'll use my money on something that makes a difference.
***GO SEAHAWKS ***
post #7 of 27 Old 05-22-2012, 01:33 PM
rickcfer's Avatar
Quoted: 44 Post(s)
Liked: 24
How about this one?
http://nadelectronics.com/products/h...eamp-Processor
Modular and upgradeable.
rickcfer is offline
post #8 of 27 Old 05-22-2012, 01:42 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 874
it only has MultiXT
tvuong is online now
post #9 of 27 Old 05-22-2012, 01:43 PM - Thread Starter
deeda's Avatar
I have an Onkyo TX-SR805 receiver and B&W CCM 818 in-ceiling speakers in 5.1 system with Rel sub. I am thinking of replacing the LCR in-ceiling with in-wall (possible Triad Silvers or B&W CWM 7.3). I may also go to bookshelf B&W 805D or similar priced speakers.
I will need a receiver or Pre Pro with Amp to run 5.1 or 7.1 system (or biamped front) and 2 other zones for 2 channel (one in the kitchen and one outdoors).
At this stage I am looking at options. I want something that is good for HT and music, is reliable and can play at reference or at least quite loud levels.
Your feedback in welcomed. Thanks
deeda is offline
post #10 of 27 Old 05-22-2012, 01:51 PM - Thread Starter
deeda's Avatar
I was intrigued with Arcam AVR 600 if I went the receiver route, but it did not have Audessy nor do they appear reliable. Marantz AVR 7005 seemed like another option at the $2000 Pre Pro level.
I will not be doing anything for 6 months to a year so can wait for something else to come to market. If I go with Pre Pro route, ampls will also need to be considered. I have listened to McIntosh and liked what I heard, but the price point is above my pay grade.
deeda is offline
post #11 of 27 Old 05-22-2012, 01:53 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
I see no advantage until you get into some of the upgradeable units like the Theta or Anthem D2V. Of course for the price of each upgrade you could just buy the latest and greatest AVR and have some change leftover.
saeyedoc is offline
post #12 of 27 Old 05-22-2012, 01:54 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
The best answer is a used/refurb Denon AVP-A1HDCI + $1000 for the Audyssey XT32/3D upgrade.
Sam S is offline
post #13 of 27 Old 05-22-2012, 02:00 PM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
Classe and Bryston both sell great sounding pre/pro products. The room correction is where the integra shines
mlknez is online now
post #14 of 27 Old 05-22-2012, 08:30 PM
rovingtravler's Avatar
Have you looked at the Anthem AVM50v?
You can get one for that price or less. Also a used D2V if you want the better DACs.
I paid less than your max for my AVM50v new. Great room correction. The only other I would say is the Integra 80.3.
The AVM is great, but not many bells like internet radio etc. You could use Anthem's AVR line MRX-300 r 700 as a pre/pro.
The AVM is very tweekable as audio and video are concerned, many many settings and you can set up to 4 profiles for each input so you can have 4 settings for BD, 4 for DVD etc etc.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #15 of 27 Old 05-25-2012, 07:50 PM
jkyte's Avatar
What about the Marantz 7005?? I'm also in the market for a pre pro, I had planned on going to the Onkyo PR-SC5508, but as an owner of a TX-NR5008 AVR, that is at the present time in the Onkyo factory authorized service center to repair their cable/corrosion problems..... Well, I've been really reconsidering this!! I had to go through a little bit to get it back for service. I've got an older TX-NR905 standing in until the change over, switch back to the 5008 is made.
I have just always liked the pre pro, amp route. Just the way I'd rather do things and if one disagrees, well that's cool too . I have an ARCAM 7 channel amp, that I'm just wanting to see how it all sounds through my Atlantic Technology THX 470 7.2 set up. Old school, I know, but.....
Any ideas on what would be a good pre pro in the sub $2500 range. The Onkyo is it hands down the one, with all it offers, but man after the problems with my 5008, well I'm kind of worried about the quality that the product line has now. And NO, I'm not trying to flame Onkyo!! I've always, I mean always been a long time Onkyo fan. I mean I've still got a TX-NR905, had an 875, I've also got the 5008 back at the service center. So, does this sound like I'm against Onkyo?? NO...... I even supported/ purchased way back in the 80's before most had even heard of Onkyo. Anyone remember the receivers that had that dynamic bass circuit?? I do, had it, CD player, speakers, all of it!! They made some pretty good speakers back in the day!!
No flame please, just an interested party that loves the same stuff as everyone else on here. I just want to find a good pre pro in the 2k range and this is without a doubt the place to come too!
James A. Kyte Jr.
jkyte is offline
post #16 of 27 Old 05-25-2012, 10:09 PM - Thread Starter
deeda's Avatar
What Arcam amp are you using? If you were to get another replacement today, what would you be looking at? Is it the P777. Since you are already a fan of Arcam, have you considered the AV888 as your pre pro?
Seems like one of the key features to get is Audyssey MultEQ XT32. I believe it is offered on the Integra DHC-80.3 pre pro and some of the higher end Dennon models.
I have been watching the thread on soon to be released Marantz pre pro. I am not sure what if any features will be upgraded from the AV7005.
deeda is offline
post #17 of 27 Old 05-26-2012, 01:00 AM
pokekevin's Avatar
Liked: 102
AT made a system 470??
pokekevin is offline
post #18 of 27 Old 05-26-2012, 08:26 AM
jkyte's Avatar
Haha, I meant THX 450!! As long as I've had these great speakers and I do that . But, I guess it happens when one gets older.
James A. Kyte Jr.
jkyte is offline
post #19 of 27 Old 05-26-2012, 09:00 AM
jkyte's Avatar
The Arcam I have is the P1000, think it's the 135 watt per channel amp. I haven't really looked at the Arcam pre-pro's. I've been pretty set on the PR-SC5508, until my issues with the TX-NR5008 starting going on and I mean it got so bad I had to stop using it and put the 905 back in my home theater.
I've just started worrying about the same issues with the 5008, as I'm aware of the fact that some of the 5508's do suffer from the same issues as my 5008 has, or had. I may get it back all fixed up!! But, then I just plan on selling to help fund my pre-pro.
The NAD looks pretty nice though!! The Marantz gets pretty good reviews.
James A. Kyte Jr.
jkyte is offline
post #20 of 27 Old 05-26-2012, 09:06 AM
Scout's staff's Avatar
Nice to see another with a similar brand mix. I have an Onkyo TX-NR3007 (running as pre-pro to a 7 channel Arcam amp to Atlantics. Mine are in-walls, but I do enjoy the set-up. I too am on my 3rd Onkyo AVR and will probably replace in a year or two with a true pre-pro. I will probably stay away from Onkyo/Integra this time given the build quality and I am really tired of the signal click every time the source signal changes.
I have been narrowing my search down to either Arcam or Anthem.
Scout's staff is offline
post #21 of 27 Old 05-26-2012, 06:25 PM
Kilian.ca's Avatar
Liked: 37
I have an Arcam AVR600 (very new 2nd hand at
If you hang around here for long enough you think you'd die without Audyssey. All I can say is there is life beyond Audyssey and I can live with what I have. I don't need most of the features other brands boast to have: networking, streaming, extra zones, extra channels or any surround processing modes.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #22 of 27 Old 12-14-2014, 07:43 AM
JimSatala77's Avatar
Quoted: 396 Post(s)
Liked: 139
I am trying to decide on a prepro. ..my dilemma is I don't know if I should wait until the new units come out in spring or ifor the units I'm looking at have true hdmi 2.0. ..been hearing different things. .trying to decide between the integra 80.6 and the yamaha cxa5000 or the marantz 7702..I really don't care about atmos because I don't plan on putting speakers in my ceiling but I do Have presence speakers and front high. ..
JimSatala77 is offline
post #23 of 27 Old 12-14-2014, 08:06 AM
Mike Garrett's Avatar
Quoted: 5554 Post(s)
Liked: 3539
The Marantz AV7702, if you want bang for the buck and want Atmos.
mjgarrett100@gmail.com
Mike Garrett is online now
post #24 of 27 Old 12-28-2014, 08:22 PM
Quoted: 396 Post(s)
Liked: 139
I ended up getting a good deal...(I think) on a New Krell Foundation 4k...let's just call it studio 53....now I have to decide whether to keep my XPRs 2&5 or take another good deal (I think) on a chorus 7200 that I can pick up on 63rd st and that's on the NEW side of town........Any suggestions? ?
post #25 of 27 Old 12-28-2014, 08:43 PM
bootman_head_fi's Avatar
Quoted: 534 Post(s)
Liked: 340
I hope the OP got something by now.
The post was over two years ago.
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
post #26 of 27 Old 12-28-2014, 09:02 PM
xcapri79's Avatar
Quoted: 110 Post(s)
Liked: 101
I'm curious as to what you would recommend?
xcapri79 is offline
post #27 of 27 Old 12-29-2014, 11:36 AM
Quoted: 534 Post(s)
Liked: 340
I would wait on more reports on the new Marantz 8802 that just came out.
but even that has compromises.
http://www.avsforum.com/forum/90-rec...etails-31.html
...did you have a specific model in mind?
Set an example:
