Advise Needed for new receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-23-2012, 11:33 AM - Thread Starter
byappt's Avatar
I am seeking advise for a AVR upgrade. Currently I have
Integra 7.3 Reciever
Def Tech BP2004s, C/L/R 2500, Supercube I, and Def Surrounds (don't know model at moment)
Samsung D8000 LED 3d Television
Samsung 6500 3d Bluray Player
Logitech Harmony One Remote
DirecTV (HD)
Apple TV
Panamax
I am really confused espically since current model are being replaced by newer ones. I have a moderate understating of electronics and technology. I am considering the following: Denon 3312/13, Onyko 809/818, and Integra 40.3. Just seeking opinions I know what sounds best to my own ears is whats best. Had a opportunity to buy the 3312 for $900 was sure however. I like the sound of my Integra but it doesn't have HDMI or latest bell & whistle offerings. I'm trying to stay under $1000 or less.
Thanks in advance for opinions.
byappt is offline
post #2 of 21 Old 05-23-2012, 12:08 PM
DonoMan's Avatar
Any particular features you are looking for? Might help us if you told us if there are any features that you just don't care about/won't use, as well, so we can try not to recommend something that is too expensive for no reason (for you). e.g. ethernet, Airplay, internet radio, preamp outputs, multiple zones, 12v trigger, OSD over HDMI, good video deinterlacing... etc.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #3 of 21 Old 05-23-2012, 02:40 PM - Thread Starter
byappt's Avatar
Well let's see I'd like good video process. I don't thing pre outs are necessary. Nice LSD over hdmi Ethernet and Internet radio etc. 7.1. I don't want it to be obsolete in the near future. I mostly use it for movies. Not sure if I covered it all but it's a start.
byappt is offline
post #4 of 21 Old 05-23-2012, 02:49 PM - Thread Starter
byappt's Avatar
I would also like excellent calibration maybe the latest. I want excellent video output because I have a really nice led tv
byappt is offline
post #5 of 21 Old 05-23-2012, 03:17 PM
ccotenj's Avatar
Liked: 101
if you have a "really nice display", the last thing you need to worry about is video processing in the avr...
- chris
ccotenj is offline
post #6 of 21 Old 05-23-2012, 04:12 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If preouts are not necessary you could probably get away with a Denon AVR 2312 or Marantz 5006. They both have Audyssey MultiEQ XT
Afro GT
afrogt is offline
post #7 of 21 Old 05-23-2012, 05:14 PM
Frank L01's Avatar
I recently upgraded from a Sony ES to a Denon 3312. The sound quality of the Denon is amazing. Also I noticed that the 3312 retains a .05 distortion rate yet the newer 3313 is up to .08. Thats almost 40% difference. I am very pleased with the 3312 once I got it all calibrated and if you look around you can find then NIB (not refurbished) in the sub $800 range. I am very pleased with the Denon
Frank L01 is offline
post #8 of 21 Old 05-24-2012, 06:19 AM
ccotenj's Avatar
Liked: 101
and a difference that is COMPLETELY inaudible... and you need to check your math...
fwiw, there are many errors on the denon spec pages... but even if this isn't an error, it makes no difference whatsoever....
that being said, if there aren't any features on the 3313 that the user "wants", the 3312 would certainly be a logical alternative (but not based on the thd spec)....
- chris
ccotenj is offline
post #9 of 21 Old 05-24-2012, 06:49 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I'm happy that you are pleased with your purchase, but the comment about distortion may need some clarification.
Virtually all modern power amps have 0.02% or less THD provided that they are not pushed to or near clipping. This is even true of PA amps and car amps.
Let's say that manufacturer specs were actually connected with reality, which may be a stretch. ;-)
In the lab I can take the same amp and measuring it as having 0.01% 0.02%, 0.05%, 0.08%, 1% or 10% THD. The difference would depend on the power output that I speced along with the THD rating. The difference might be 80 wpc for 0.01%, 90 wpc for 0.02%, 100 wpc for 0.05%, 105 wpc for 0.08%, 120 wpc for 1% and 160 wpc for 10% THD. This is all for the identical same piece of equipment!
As a practical matter, an AVR might live its entire life in a HT room and never put out more than 50 wpc. Or it might get clipped out every weekend that the kids come home from college. In either case, the difference among the specs I gave above would have no significance at all.
arnyk is offline
post #10 of 21 Old 05-24-2012, 07:01 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I would suggest the Onkyo 709; it has full preouts, which can be good to have.
I would also suggest that you get rid of those speakers and get some better ones. That is where my money would go if I had some to spend.
DirecTV (HD)
Apple TV
Panamax
commsysman is online now
post #11 of 21 Old 05-24-2012, 09:45 AM - Thread Starter
byappt's Avatar
Currently my front runners are Denon 3312, but still unsure if the Onkyo 818 would be smarter because of the XT32 and the THX Select 2 certification, or maybe my ears won't know the difference. My theater is set up in my basement so its a nice size room but more long that wide.(If that helps any)
byappt is offline
post #12 of 21 Old 05-24-2012, 10:21 AM
mjpearce023's Avatar
Quoted: 34 Post(s)
Liked: 38
XT32 would make a bigger difference than THX. I love my 3311 but I would probably have to pick the 818 for XT32. The only thing that would bother me is the lack of quality control that Onkyo has shown over the last few years. There is already some issues with the HDMI on the 616 so I would take that into consideration.
mjpearce023 is offline
post #13 of 21 Old 05-30-2012, 11:48 AM - Thread Starter
byappt's Avatar
Well I was able to get a Denon 3312 for $800.00 couldn't wait for the new Onkyo 818. I can return the Denon if I'm unhappy but so far I like it a lot. Only problem is getting my apple tv setup correctly. I'll have to dig here a little deeper. I got everything else going ok but I want to dig in and do more tweaking. Thanks to all who replied.
byappt is offline
post #14 of 21 Old 05-30-2012, 12:04 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 874
^^World Wide Stero via Buy.com is selling the 3312 for $698 shipped. Have them price match or return it.
http://mobile.buy.com/ibuy/Product.aspx?sku=222045211
tvuong is online now
post #15 of 21 Old 05-30-2012, 12:08 PM - Thread Starter
byappt's Avatar
Thanks I'll look into it
byappt is offline
post #16 of 21 Old 05-30-2012, 09:26 PM
tsturbo's Avatar
How about the Marantz sr6006, 7.1 / 770 watt
Was $1199 now available at $400 less at $799 brand new at several reputable dealers.
I think this is a great deal, I was waiting for the sr7005 to price drop, but now may go for the 6006
tsturbo is offline
post #17 of 21 Old 05-31-2012, 07:56 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I'm sure you'll be happy with that, I'm running the 2312 and it's incredible. Probably should've gotten the 3312 for the extra watts per channel.
I've always had trouble understanding the features of Denon, but I really do love them, on my third.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #18 of 21 Old 05-31-2012, 08:05 AM
Quoted: 34 Post(s)
Liked: 38
The few extra watts are not worth it so if the 2312 has all the features you need then you made the right decision. I used a Denon 2310 and then got a Denon 3310 and the difference in power had no effect on sound quality.
post #19 of 21 Old 05-31-2012, 09:04 AM
DonoMan's Avatar
Yeah, don't step up to the 3312 just for power. If you want the preouts or other extra features then that is why you'd go with it. You wouldn't even notice the difference in power unless you were doing a head-to-head comparison.
-Dan D.
DonoMan is offline
post #20 of 21 Old 06-09-2012, 05:27 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
So then a separate amp is really the only way to substantially increase the sound?
Denon X3100W
LG 50LB5900
TiVo Roamio
post #21 of 21 Old 06-09-2012, 08:55 AM
MCF34's Avatar
Quoted: 63 Post(s)
So let's keep this going. I got a 2312 and just don't like the sound paired with my Klipsch r25 series speakers. I calibrated many times and tweaked and played with setting and could never get a better sound to me compared to my HK AVR635. I reconnected my HK AVR635 this morning and it just sounds more crisp compared to the 2312CI. Any suggestions for another receiver? I like the HK except it has no HDMI inputs or outputs. I would like at least a true 110 per channel at 8 ohm. Network capable, 4 HDMI inputs and one HDMI output. Clear crisp dialogue is critical to me. What I am noticing instantly with the HK vs the denon is the dialogue out of the center channel is much 'cleaner' than with the 2312CI I will be returning to onecall on Monday.
Jutter is gone..zipadeedoodah zipadeeday!!!
MCF34 is offline
