Onkyo TX-NR818 "official" owner's thread discussion - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
Old 12-06-2012, 08:46 AM
codoug's Avatar
Originally Posted by ccotenj View Post
an airport extreme basestation is NOT needed to use an airport express in the way you are describing...
You are correct. I was thinking of something else. Sorry for the confusion.
codoug is offline
Old 12-06-2012, 11:36 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Originally Posted by Coolerman View Post
I know my room calibration is going to be challenging for the receiver. Log walls, vaulted cathedral 24' ceilings, hardwood floors, stone fireplace with large windows on one wall, room is much longer in one dimension than the other with the speakers at one end of this. Couple that with the small Polk RTiA3 main fronts and the JBL 100 watt powered sub and I fear I won't be able to obtain the "room filling" sound needed for good special effects. I don't know enough about modern systems to know what they are capable of, so until I have run the setup I'll keep the questions and bitching to a minimum. wink.gif
I think you will be pleasantly surprised at what you can achieve in your room (which sounds, if you will forgive the unintended pun, delightful). It's more a question of how close you sit to the speakers (and sub) than the absolute volume of the room. If you are sitting a few feet away - say no more than 10 feet - you may well be happy with the result.
If not, then a more powerful sub and a more powerful amp may be required (and maybe speakers that can handle the power at high SPLs). Be sure to come back and let us know what you find once you are all set up.
kbarnes701 is offline
Old 12-06-2012, 12:06 PM
asere's Avatar
Quoted: 1376 Post(s)
Liked: 261
I'm learning here so forgive me. Before I bought the HSU sub I was told that it does not matter what speakers one has. Do the speakers have to be able to handle high SPL's and why? Thank you!
asere is online now
Old 12-06-2012, 12:18 PM
codoug's Avatar
One clarification to make sure we are not confusing folks: the Airport express will work wirelessly in the way that I described with most other wireless router/base stations. However, it will not work wirelessly to extend the network. In other words, configured to wirelessly connect to the router/ base station, the Airport Express will only work in Client Mode to stream music to the receiver. If you wish to extend the network to connect wireless devices via the Airport Express, you must connect the Airport Express via the ethernet port.
From the Apple Airport Express FAQ: "Question: I have a third-party 802.11b/g/n wireless access point. I want to put AirPort Express next to my home theater and stream iTunes to it. Can AirPort Express join the third-party network?
Answer: Yes. AirPort Express can join a third-party network in client mode, or if it is connected via Ethernet to a LAN port on the non-Apple wireless access point."
codoug is offline
Old 12-06-2012, 04:31 PM
sbvballer's Avatar
Amazon is only selling the 818 through 3rd party, atm.
sbvballer is offline
Old 12-06-2012, 08:45 PM
Slingblayde's Avatar
Liked: 64
Has anybody ordered a rack shelf with a custom faceplate for the 818 yet? I looked at Stayonline for it and it isnt available in the list, theres a lot of other Onkyo's, but not the 818. I imagine it is 5U height? its almost 8 inches high.
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
Old 12-06-2012, 10:17 PM
iculookn's Avatar
Just wanted to add my comments on the 818, Have 2 of them now for 3 months and they are fantastic. Upgrading from a 8 year old Rotel, so a lot has changed in technology.
I have one setup in the Entertainment room (attic) with Oppo/XBOX/PS3/Streamer connected to 7.1 Definitive Technology ceiling speakers/SVS Sub and a 64" Samsung Plasma
The other is in the Family room connected to the Cable box/Bluray
Pro's
Great Sound
Good remote - setup as a universal was quite easy and works not too bad, but have added a a few Harmony 900's so I could hide all the equipment.
Easy to setup
Great Sound
Doesnt get too warm
Quiet - Compared to my Cisco switch in the same cabinet.
Great Sound
Con's
The DLNA is crap. Very poor implementation of DLNA.
Dynamic Volume - I really wanted this to control the variations in channels/Ads coming from the cable box. Now, either I havent set it up properly, or it really just doesn't work.
Wouldn't bother with any of the network apps, they are really slow. The Oppo seems to have better quality apps, but still think a dedicate streamer or full PC is the best option
Have not noticed video dropouts that some people have.
Just go buy it. Stop sitting on the fence.
iculookn is offline
Old 12-06-2012, 11:37 PM
sullivt5's Avatar
Hi All ,
I have had my 818 for a little over a week and I need some help with my sub set up. I have a dual sub set up fed by a single amp that is all ultra 2 rated, with that being said the manual for the amp says that if I have a THX rated receiver that I need to turn the THX setting on the amp to yes this disables the gain control and boundry gain control on the amp and the receiver will control everything when I turn the U2 setting on for the sub control. The issue I am having when you run the Audyssey set up I cant set the db level for the subs because the gain control is disabled and after I run the set up my sub distance is .5 feet and have a -12.5 offset when they are about 13.5 away. If I shut the THX stuff off I get a distance of 24 feet and a -5.5 offset. I would just go with which one sounds better but I want to make sure my set up is right and I am not feeling it right now. Any ideas on how I can get it where it needs to be?
sullivt5 is offline
Old 12-07-2012, 07:36 AM
Jagged68's Avatar
First that setup and apartment is amazing. Thanks for the recommendation.
My unit is being shipped now and I'm having buyer's remorse because I didn't want to spend even the $650 I got the 818 for on a receiver. Even worse, I'm moving Monday and my new room doesn't have space for 5.1 so I'm probably running 2.1 on this unit.
Jagged68 is offline
Old 12-07-2012, 08:32 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
Pro's
Great Sound
Easy to setup
Great Sound
Doesnt get too warm
Great Sound
Con's
i agree. dyn vol to me isn't doing anything. i leave it off and have eq on w/ dlo at -10 which seems to do ok. now if you really what to tame the peaks then use dolby volume, but the caveat here is that it turns off the eq for all sources. ie: blu-ray...so when i want to watch one of those i have to go into the set-up menu and turn it back on.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
Old 12-07-2012, 09:24 AM
markus767's Avatar
Quoted: 3631 Post(s)
Liked: 1294
Do you guys in the US still have problems with loud commercials? Rules according to the CALM act should take effect next Thursday, latest.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 12-07-2012, 10:13 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Yes and the dynamic volume (or whatever it's called) does not work.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
Old 12-07-2012, 10:14 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Ok - just my observations regarding the 1080p/24 'issue'. I only see this when watching Comcast. Nothing else. I have also noticed that when watching a scene from Comcast (I have an HD TiVo) that if the picture does jutter, if I jump back 15 seconds it doesn't jutter. Weird.
I'm not so concerned w/the 24 issue when watching Comcast as much as I would be when watching my Popcorn Hour, 3D BD player or PS3.
Wryker is offline
Old 12-07-2012, 11:07 AM
bootman_head_fi's Avatar
Quoted: 534 Post(s)
Liked: 340
Comcast (or any provider) doesn't transmit anything in 24p.
The only native content in 24p is Bluray.
If you are taking 60p contenet and trying to convert it to 24p, you will most likely get crappy results.
Even top of the line VPs can't do this that well. (and why would you want to since most displays are not native 24p)
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
Old 12-07-2012, 11:16 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
I know they don't - never said they did. My point was to the setting for 1080p/24 on this AVR and the jutter issues people have. I have the AVR monitor set to 1080p/24 (the MAIN) which most people don't.
Wryker is offline
Old 12-07-2012, 12:20 PM
asere's Avatar
Liked: 261
Ok I do not own the 818 but speaking of 1080/24 on my panasonic bluray player there is an option to set 24 on or off? FYI: Bluray is connceted to my Denon and HDTV.
asere is online now
Old 12-07-2012, 12:29 PM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
On.
asere likes this.
Wryker is offline
Old 12-07-2012, 12:43 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
On.
ON-only if your'e set can accurately render 24p. my sharp doesn't so i leave it off it uses 3:2 pulldown instead.
Old 12-07-2012, 01:06 PM
Quoted: 534 Post(s)
Liked: 340
OK.
What I'm saying is that if you keep your display at 24p all of the time, judder is likely with non 24p material regardless of AVR/AVP/VP.
Set an example:
Old 12-07-2012, 01:13 PM
markus767's Avatar
Liked: 1294
It does work but probably not the way you expect it to. Unfortunately you have to live with highly compressed commercials until CALM act is effective. If there's still a problem you can report stations to the FCC.
P.S. Are you sure you're not confusing Dynamic Volume with Dynamic EQ?
Markus
Old 12-07-2012, 06:31 PM
iculookn's Avatar
Yes we could be... so how can you control the varying volume coming from one source. i.e Cable box. (Calm is US only)
iculookn is offline
Old 12-07-2012, 08:24 PM
codoug's Avatar
Great Sound
Con's
I have to agree with your comments on DLNA. I have gone to pushing iTunes via the Airport Express over DLNA via the wireless network adapter. My problems with DLNA include the very crude file/folder view and inability to properly control sound volume. The last issue is the deal breaker. Even with the receiver set to "min" via the volume control, the sound is unpleasantly loud. Fortunately, the iTunes via Airport Express works seamlessly.
codoug is offline
Old 12-07-2012, 11:44 PM
iculookn's Avatar
I have a few different DLNA Servers/Clients around the house and yes, the Onkyo is very poor, but not an issue as I didn't buy it for that purpose. Currently testing Plex on my Samsung 2012 TV, connecting to a QNAP NAS running the plex server. Works surprisingly well. Slight lag on some screens while scrolling, but very usable. Only problem is it wont play ISO files. Plus I now need to work out ACR so the Audio from Plex TV goes back into the 818.
Would be great if Onkyo built a Plex client into the device, but I don't like our chances or the quality will not be up to scratch.
iculookn is offline
Old 12-08-2012, 11:45 AM
TheaterChad's Avatar
Quoted: 25 Post(s)
Liked: 31
Option1:
I have found this rack shelf for my Slim 5 rack at B & H Photo for the 818
, Raxxess is made by Chief MFG, the blue print of this rack shelf is here.
This option so far is the cheapest option, unless you find it on ebay....
Option2:
Another option is here, if you own a Middle Atlantic Rack, a Zero Space rack shelf option is available that mounts to the inside of the rack, priced a little more than the other option, but can be found on ebay way cheaper, this option is nice as the shelf can hold over 200 lbs, and it's supported in the front and the rear of the rack, so no worries of it falling, but also you would have to use some washers to " shim " the face plate flush as to the same level of your other face plates, only if you use the flat piece to cover up the phillips head screws, if you don't, then it's ok the way it is.
Specs of the zero space rack shelf is here.
I'm custom cutting my own face plates for all my individual AV components rack shelves, as I have access to a cnc machine.
Here is the link to Middle Atlantics web site that shows how many rack spaces and depths for all brands of AV components, I used the 809 specs of 5U spaces, as the 818 is not listed, same dimensions per spec sheets for height & depth of the receivers.
I may be looking at options of DIY, and seeing what some sheet metal or sheet aluminum would cost and just make my own, but doubt it would be cheaper than option 1.
B & H Photo have very good prices, but you have to pay for shipping, which adds to the cost, look on ebay, look on craigslist, as long as you have some time to look and not need this very second, you can find deals.
Slingblayde likes this.
TheaterChad is offline
Old 12-08-2012, 11:58 AM
Mike Butny's Avatar
Quoted: 330 Post(s)
Liked: 591
Sorry for being lazy but I just picked up the 818, it replacing a Classe ssp30 mk2 pre-amp. I'm going to use the 818 as a preamp hooked up to Marantz amps. The first question is the 24fps bug I just read about, is there a fix? maybe using hdmi sub out? bypassing the VP? And how would u bypass it? Sorry for being lazy I just do not have much time to read the whole thread, thanks in advance.
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7009 Receiver, 3-Marantz Ma700 and 2-Ma6100 mono blocks, 9.2 set-up, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Infinity ( soon to be replaced by B&W ) bookshelf Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, PSA S3600I & XS30SE subs, Richard Grey, Monster Power, and Panamax powerline conditioning/surge protection.
Mike Butny is offline
Old 12-08-2012, 01:53 PM
markus767's Avatar
Liked: 1294
Not yet. Onkyo is aware of the problem but we don't know if or when they will fix it.
Markus
Old 12-08-2012, 02:30 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
That is the workaround, yes.
fahrenheit is offline
Old 12-08-2012, 02:52 PM
Mike Butny's Avatar
Quoted: 330 Post(s)
Liked: 591
so I can use main out for 60fps content and still enjoy the VP benefits, 720p to 1080p, 1080i to 1080p, and use sub out for 1080p 24fps content?
Old 12-08-2012, 02:57 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
If you are talking about gaming, then you should know that Main is laggy. But if its just 60fps video content, then sure.
Old 12-08-2012, 04:12 PM
Liked: 64
Originally Posted by TheaterChad View Post
Option1:
Option2:
Thanks for the links TheaterChad. I have been keeping an eye on the Detroit area craigslist for shelves, I even posted a Want Ad on there, but havent found anything. I also have the Slim 5 rack, but I dont have any shelves for it at all yet. Things are SO much easier to buy online for someone who lives in the US, being in Canada is a drag, I see so much stuff I could have bought with just a couple clicks and Boom, shipped right to my door. Ebay, CL, Amazon, Kijiji all blow here in Canada. I found a nice set of 24 banana plugs on the US Amazon site, 39 bucks shipped, exact same set of plugs on the Canadian Amazon site, 97 dollars after tax and shipping. Ugh...
I know I will have to bite the bullet and order some and have them shipped to my buddy's house over in Detroit and go pick them up. Its ok, but I dont like doing it too often. I feel guilty having all kindsa stuff shipped to his house.
I too have access to a CNC machine, Ive been running them for the last 26 years lol. I just havent tried to make my own faceplates. Usually when I leave work, I dont like to go back and work on home projects.
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
