Onkyo TX-NR818 "official" owner's thread discussion - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
Old 12-18-2012, 12:54 PM
wlvca's Avatar
Yes, I am using the zone 3 trigger now for a separate power amp.
Had the 805 previously.
Would be nice if they had a zone 1 trigger in this unit.
I used the switched outlet on the 805 to trigger before (separate trigger device plugged in) and wish they had included a switched outlet on the 818.
wlvca is offline
Old 12-18-2012, 01:01 PM
NeilR99's Avatar
Originally Posted by Patrick Murphy View Post
Hi Neil,
I just measured mine and it was 18 1/2.
edit; that was only on the front I didn't do the sides.
Thanks Patrick, but I think you measured the width of the cabinet. The spec is 17 1/8" wide and deep. I need the distance from the front right corner to the rear left corner (or the opposite diagonal since both will be the same).
According to the formula for computing the hypotenuse of a triangle, the measurement should be just slightly over 24". But the 17.125" specified depth probably includes the front panel knobs as well as anything sticking out of the back (binding posts and etc). I think the critical measurement is the hypotenuse of the cabinet itself although that's fuzzy. Every inch, or fraction, is critical here.
NeilR99 is offline
Old 12-18-2012, 01:37 PM
ucfmat13's Avatar
Originally Posted by babgvant View Post
No. Could be one of the fans. If you're still in the return period replace it, otherwise contact Onkyo support.
Thank you...I will try to double check to make sure I'm not hearing fans. I didn't think that's what I was hearing, but I could be wrong.
Mine doesn't hum. You could try disconnecting everything hooked up to it and if it still hums it's likely a bad unit or perhaps a grounding issue. Try it in another room in your house with nothing connected.
Too bad about the problem.
Ok, thanks for the reply. I'll try it out in another room in the house.
ucfmat13 is offline
Old 12-18-2012, 05:16 PM
habe's Avatar
Quoted: 35 Post(s)
I thinking about grabbing an 818 tonight while Newegg still has the $679 price. My TV is capable of 24P. I still am a little confused by what I've read about the 24fps issue....
I read in this thread that the 24.976 bug is not on HDMI 2. Is that on HDMI 2 input or eliminated completely if use use HDMI 2 output?
Also, as I understand it, the 23.976 issue is still there even if receiver video processing is turned off? Is this correct?
habe
habe is offline
Old 12-18-2012, 06:46 PM
tildawn10's Avatar
I have poured through this thread and have an 818 on the way. Just to confirm, if I decide later that I want to add an external amp to my 7.1 setup, I could use it to power the fronts l c r and leave the rest of the surrounds to be powered by the 818 correct? I know that I'f you want 9.2 then you must assign certain speakers externally.
Thx!
tildawn10 is offline
Edmundo Lopez's Avatar
I received mine today from Amazon and it didn't come with the sticker in the face plate. It looks brand new, its just weird. I've bought Onkyos before and always have the sticker.
Edmundo Lopez is offline
Old 12-18-2012, 06:52 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
i would say that is a little odd. mine came from there as well(3 wks ago) with the mega sticker plastered on the front.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
Old 12-18-2012, 06:53 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
Thx!
yep...
Old 12-18-2012, 07:10 PM
boblinds's Avatar
Liked: 35
RE: the faceplate sticker:
I bought a "used" 818 from Amazon Warehouse Deals (not even going to mention what I paid because it was well lower than the current sale price) and even it had the faceplate sticker on it. I think the absence of the sticker is a red flag.
boblinds is offline
Old 12-18-2012, 08:35 PM
chrisu7582's Avatar
Hey folks. I just bought the 818 and will be pushing RtiA3's as my FL, FR, RSR and RSL.Center is a CSI A4 and TC80i's as SR and SL with a DSW440 sub.
Will the 818 be more than enough to push these to their potential or will a 2 channel 125 watt amp for the Fronts be better to clear up the rest of the amp for my other speakers?
I am new to the HT scene if you cant tell and any help would be great. I only have read the forums and many people suggest a amp for the mains.
If I do need a 2 channel amp, could you guys recommend me a decent amp that is around $200. Thanks again.
I have heard that Carver and Parasound are warm amps which will go good with my Polks.
The A3's power handling is 20-150 watts and sensitivity at 89db
The CSi A4 power handling is 20-180 wts and sensitivity at 89db
The TC80i handling is up to 125 wts and sesitivity at 90db.
chrisu7582 is offline
Old 12-18-2012, 09:00 PM
wlvca's Avatar
I think the 818 will drive your RTi3's just fine.
If you need amplification for additional channels check out Emotiva.com.
The offer a number of well priced amps in various configurations.
I use an Emotiva XPA-5 with my 818
wlvca is offline
Old 12-18-2012, 09:19 PM
chrisu7582's Avatar
Thanks for the response.
Although they def. pass the eye test in my book, I'm afraid the Emotiva is a little too much $$ than I wanna spend.
I may just look for a cheaper 2 channel amp. The cheapest I could find a 2 channel Emotiva was $600. Thanks again for the quick reply
Old 12-18-2012, 09:49 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 333
Check ebay or the Emotiva Lounge Emporium for a UPA-2 amp if you need external amps. They are a great little 125wpc amp and most will still have something left of a 5 year warranty. I'm kind of partial to the older Acurus amps and will be using an A200 two channel and A200x3 three channel with my new NR818 that gets here Thursday. I could not pass up the NewEgg sale either. XT32 for under $700? Whats not to like.
The amps in the 818 are pretty robust and should make most users happy. Give it a try before you sink money where you might not need it. Maybe a new sub - or just a bunch of beer.biggrin.gif
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
Old 12-18-2012, 10:10 PM
GoatLocker's Avatar
Mine arrived from Amazon at 4:30 this afternoon. Swapping it out with the HT-RC180 (basically an NR807) was a breeze. I made it through 3 positions in the Audyssey setup before my daughter came home, making silence impossible, so I wrapped it up for now. I only had a little time for listening, but I immediately noticed a difference from the '180. I have Energy RC-70 fronts that have a dip in the high-mids that the RC180 with MultEQ did not do well at correcting. This had a negative effect on some instruments, particularly strings, and women's voices, leaving a slightly recessed character to these sounds. I listened to some Norah Jones, Dido, and Lindsey Stirling, all of which were significantly improved. My impression from this short session is very good and I'm looking forward to spending some quality time with this AVR.
By the time my wife got home, everything was cleaned up like nothing ever happened. Also, the UPS guy brought her a box from Zappos, which always makes her happy. I wonder when she'll notice? biggrin.gif
GoatLocker is online now
Old 12-18-2012, 10:18 PM
chrisu7582's Avatar
You are not the first person to recommend a new sub for me as well. I got this from crutchfield on sale so I only paid $129 for it. I figured if all else fails I could sell it and get my money back and buy something that would better fit my needs. I agree that I will listen to the 818 before I buy an external amp. Thank you so much for the suggestions though. I will def. keep an eye for those if I decide I need one!
Old 12-18-2012, 10:32 PM
wlvca's Avatar
The Emotiva XPA-200 is $299 on sale now and the XPA-500 is $349 on sale now, page two of the Amplifier listing.
http://shop.emotiva.com/?page=2
wlvca is offline
Old 12-18-2012, 10:37 PM
chrisu7582's Avatar
Wow. Sorry for my stupidity. I didnt even see the 2nd page. Will test the 818 when it gets here and if I need the 200, I will jump on that deal. Thanks alot
Old 12-18-2012, 10:52 PM
dstew100's Avatar
Show me anything ballbark to this sentence's awesomeness. I paid even more but received an enormous value of the lowest priced fully equipped XT32 4k receiver ever made. Still lovin mine and wouldn't trade the time I've had with it for the price difference. But you all are getting the steal.
The UPA-500 is 349...not the XPA-5
Edit: UPA-200@299 too. XPR my desire, XPA my possession, UPA there are cases where I see a fit but for the most part I'm not seeing it.
dstew100 is offline
Old 12-19-2012, 03:09 AM
saginawjuggalo's Avatar
Quoted: 47 Post(s)
Liked: 51
I also bought a "used" 818 from Amazon Warehouse Deals, it had all of the front panel stickers, but I ended up returning due to it missing the Audyssey Mic. I just received a "new" backordered 818 from B&H Photo and it didn't have any frontplate stickers other than a "Spotify Inside". Everything looks new here confused.gif
JVC DLA-RS40 w/003 lamp,DIY False-wall 125" acoustically transparent screen,Darbee Darblet,Sanyo PLV-Z2000 (gaming),7.1 DIYSoundGroup 1099 x3 LCR & Slanted Volt 6 rears x4,Onkyo TX-NR818,Emotiva LPA-1,Behringer EP4000 (x2),Sealed Stereo Integrity HT18"s (x8),Balanced MiniDSP,Cross·Spectrum UMIK-1,DIY Acoustic Treatments,PS3,Sony BDP-S590,Seiki SR4KP1 Region Free BDP,Toshiba HD-A1,Roku,Outdoor Antenna,APC H15 power conditioner,Harmony Smart Control,Rebuilding*HTPC,Leather Theater seating etc.
saginawjuggalo is offline
Old 12-19-2012, 03:23 AM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5511
Just a thought for next time ..... as Onkyo sells the mic for about $22, probably would have been much easier to just get Amazon to credit you that amount and just order it direct from Onkyo.
jdsmoothie is offline
Old 12-19-2012, 09:03 AM
Patrick Murphy's Avatar
Quoted: 67 Post(s)
Liked: 64
Oh, OK, it's 23 1/16. That's the metal case and faceplate only-no knobs or connectors.
Patrick Murphy is offline
Old 12-19-2012, 09:40 AM
TheeOracle's Avatar
Originally Posted by alexwill22 View Post
Guys,
I am interested in this receiver and after reading this thread it inspired me to upgrade my system. So, I was reading the manual interested in the bi-amp option, but I notice that I am limited to just 5.2 surround and the pre out for the "Ext Amp" will be deactivated. Would I be able to use a External 2ch Amp for the other pre out for SB/FH/FW and bump it up to 7.2 surround?
Second question, would bi-amping my front speaker enhance my experience when watching a movie or would it be better for listening to music or is it a waste of my time? I know what bi-amping does for the front speakers, but I want someones personal opinion with this setup.
I have been trying to find out more information about bi-amping the front speakers while maintaining 7.1. I called Onkyo support and I was told that as long as I biamp the front speakers I will need to stay with 5.1. Is it true? Even if I have external amp powering the front speakers?
Thanks for any expert advice in advance!
TheeOracle is offline
Old 12-19-2012, 09:41 AM
NeilR99's Avatar
Thanks! That's a big inch :-). Last night I got a ship notice from Amazon (ordered it in the am). It's on the UPS truck. If I had known I was getting it today I would not have bothered anyone over this :-)
NeilR99 is offline
Old 12-19-2012, 10:11 AM
wlvca's Avatar
Sorry, my error.
wlvca is offline
Old 12-19-2012, 11:40 AM
GoatLocker's Avatar
My problem is that my setup is in a very old built in cabinet that cannot be easily changed. The cabinet is exactly 25.25" wide. Ans 25.25" deep (perfectly square). My concern is if the cabinet is wide enough to turn the 818 sideways to do the cabling.
I know its not cheap, but my solution was to install a Middle Atlantic REB series sliding/rotating shelf. Swapping receivers yesterday was an absolute breeze!
Old 12-19-2012, 12:27 PM
cissado's Avatar
Hello, I just got the 818 since BF deal... It replaced a very old Onkyo which has lasted me for 10+ years. (TXDS-787) I was happy with it but wanted the xt-32 mostly and hdmi switching. I couldn't pass up the price when deciding between this and the 4311. I have a Parasound 2205AT amp (220wpc x 5) driving everything in a 5.1 system. Studio 40 v2 speakers, center, and Servo 15 sub.... In ceiling surrounds, but oh well.
Anyway, I've lost a lot of spl's. Where did the volume go? I will try and do the calibration again, maybe in a tighter position but I doubt that ill fix things. Also Audyssey calibrated the fronts and center to 40! Seriously, Studio 40 speakers? I'm a bit confused. I did however change them back to 80 all around (btw the rears were set to 50)
After about a week, I couldn't take it anymore soI upped the levels a bit on some speakers. Of course I'll have to redo the calibration but it sounds slightly better now. The bass was almost non-existant. I've known that the right bass is supposed to be lower than what we're used to, but damn.... I was missing it.
Could the Audyssey settings at 40 be that something is wrong? The distances seemed OK. Plus I did not find where the speakers say "Large or Small".
Other than that, the sound IS "tighter" or "cleaner" to me. I'm having a hard time with sound settings though, in terms of PLII Music, movies..etc... Music sounded better to me because of the aforementioned spl levels and bass.
cissado is offline
Old 12-19-2012, 12:41 PM
Adam James's Avatar
Quoted: 24 Post(s)
I love my 818 for movies, I think the Multeq xt32 does a great job with imaging and sound stage for home theater, but I'm not that impressed with its 2 channel music performance. For some reason it sounds thin and grainy in pure direct mode, compared to my Yamaha rx-a2010 which sounds warm, full and more detailed.
What do you guys think of the two channel sound?
Adam James is online now
Old 12-19-2012, 12:47 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
If you take this over to the Official Audyssey Thread, I can give you some pointers that might help. It's OT here.
kbarnes701 is offline
Old 12-19-2012, 01:31 PM
Quoted: 67 Post(s)
Liked: 64
Try using 'Stereo'.
Old 12-19-2012, 01:39 PM
Adam James's Avatar
Quoted: 24 Post(s)
Try using 'Stereo'.
I have, and it sounds better, just wondering why pure direct sounds so bad on the Onkyo compared to the Yamaha.
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
