Onkyo TX-NR818 "official" owner's thread discussion - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #8191 of 10506 Old 10-06-2013, 04:01 PM
sahmen's Avatar
Originally Posted by Kelvin1965S View Post
The only issue I'm having is that I can't configure the 12 volt trigger to switch on my power amp without having to manually select the zone 2 on the remote. Having discussed this on the UK AVForums there doesn't seem to be a way round it unless anyone on here knows a solution:
Ideally I need for anyone in the family to be able to simply press the front panel button on the 818 and for the power amp to be triggered on (and off again for the reverse). I'm 99% sure it can't be done, but just incase anyone here has found a workaround I'd be glad to hear before I go to the trouble of building a separate device to do this for me.
All the "workarounds" i know of would involve more than that "one-button-press" solution, so can't help you there... If all else fails, you can try teaching your family the zone 2-trigger method: they might turn out to be more tech-savvy than you're giving them credit for, especially if you can demo the procedure for each member repeatedly until they get it smile.gif Sorry I can't be of more help than that.
Kelvin1965S likes this.
sahmen is offline
post #8192 of 10506 Old 10-06-2013, 04:10 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Originally Posted by EternalFlame View Post
Hello
If someone can help me with info, I want to use my old Denon AVR-3802 as preamp for onkyo tx 818 is this posible?
Thanx
You could do two ch from the 3802 preouts to one of the line level inputs on the 818, but the 818 doesn't have multich inputs...
lovinthehd is offline
post #8193 of 10506 Old 10-06-2013, 04:13 PM
sahmen's Avatar
Onkyo 818 + Oppo bdp 103 video output configuration:
1. How do I configure video output between these two units in order to get the best results in pq on my tv?
2. Implied in the above question: which of the two does the best video processing?
3. In case I need the hdmi video signal of the Oppo to go through the 818 untouched, what settings should I use on the 818?
4. Last question, which may or may not be related to the previous ones: What functionality will I gain or lose by using the 2nd (or sub) hdmi output jack on the 818 for video?
PS... I could also opt to have video from my Apple tv and Roku 3 processed through the Oppo if it can do a better video processing job than the onkyo, so please take that into account if you respond to this query.
sahmen is offline
post #8194 of 10506 Old 10-06-2013, 04:56 PM
Quoted: 303 Post(s)
Liked: 43
hey guys, im moving into a new apartment and its a smaller place, now, im having some issues with the WAF in regards to the living room home theatre setup, she doesnt want me to have a tv stand at all, she wants to mount the LCD on the wall which is great, but where am i going to put the Onkyo Receiver/XBOX and PS3?
Is there any nice looking quality rack you guys could recommend to replace the tv stand so that i can place my AV reciever / ps3 and box on?
lamonsasa is offline
post #8195 of 10506 Old 10-06-2013, 05:00 PM
EternalFlame's Avatar
Thanx for help, yeah I see now that i can use 818 as preamp for 3802, devolution of technology :)
EternalFlame is offline
post #8196 of 10506 Old 10-06-2013, 05:31 PM
fokakis1's Avatar
Quoted: 49 Post(s)
Liked: 52
Program one of the macro buttons on the Onkyo remote to power on zone 2 and the receiver. Be sure to power the receiver first, then zone 2 in the program sequence. This will turn both on and off with one button press.
Control4 Automation Programmer
fokakis1 is offline
post #8197 of 10506 Old 10-06-2013, 05:46 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Originally Posted by jake608 View Post
If u don't mind me asking what's your speaker layout? I'm still debating front heights vs rear surrounds.
My secondary amp is running my front wides and I still have a surround back but just one speaker. So I am actually running 10.2![/quote][quo
I am running front Heights and Surround backs...External amps I use the 818 as a pre pro.
Who needs 4K?... just go see your optometrist.
NODES is offline
post #8198 of 10506 Old 10-06-2013, 05:47 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
glass A/V floating shelves. cool.gif
NODES is offline
post #8199 of 10506 Old 10-06-2013, 05:49 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Simple run one HDMi to the 818 for sound and the other HDMI directly into TV.
NODES is offline
post #8200 of 10506 Old 10-06-2013, 05:51 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Originally Posted by tim_1335 View Post
Hi guys,
My 3009 has the 24p bug even after updating the firmware to the latest one. Any ideas on how to fix this?
I think the bug is similar to the 818 24p bug.
did u ask in the 3009 forum? Something tells me Onkyo never fixed the x09 models...
NODES is offline
post #8201 of 10506 Old 10-06-2013, 05:51 PM
Quoted: 303 Post(s)
Liked: 43
post #8202 of 10506 Old 10-06-2013, 05:53 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Originally Posted by fulhamx5 View Post
i ve purchased an onkyo cr n755
same specififaticions with onkyo 818.
it has wifi
but i s not easy to see its screen. i have lots of flac files . i have to go closer to see music files.
it has dlna. can i conenct it from my macbook air and see the files on my laptops screen
Are you saying the N755 has the same specs as the 818?
NODES is offline
post #8203 of 10506 Old 10-06-2013, 05:57 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
can u recommend any to me?
something like this
http://www.ebay.com/itm/2-Tier-Dual-Glass-Shelf-Wall-Mount-Bracket-Under-TV-Component-Cable-Box-DVR-DVD-/400572933082
NODES is offline
post #8204 of 10506 Old 10-06-2013, 07:42 PM
lovinthehd's Avatar
Liked: 4775
Thanx for help, yeah I see now that i can use 818 as preamp for 3802, devolution of technology smile.gif
I think you're wasting your time personally.
post #8205 of 10506 Old 10-06-2013, 07:50 PM
Quoted: 303 Post(s)
Liked: 43
post #8206 of 10506 Old 10-06-2013, 11:54 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
that one says it holds "17.6 lbs each shelf" so thats not good for the nr818 which weighs 40 lbs..
Of course not....I am just showing what it looks like....There is much more heavy duty ones available.
NODES is offline
post #8207 of 10506 Old 10-07-2013, 02:00 AM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 152
I find my family seems incapable of using a remote with macros as they seem to wave it around while the macro is running which leaves some devices out of sync with each other and no sound or picture. (I have a Harmony remote that I use for everything but have removed the macros). rolleyes.gif
However I have found a simpler workaround: Just to use an 'intelligent' power extender cable that uses the 818 as 'master' and this then turns the other sockets on when the 818 draws power. Much neater solution and the family continue to operate 'the amp' as before (by pressing the front panel button rather than the remote). However, I'd gladly have given up the network stuff, which I have zero interest in just for a simple assignable 12 volt trigger.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #8208 of 10506 Old 10-07-2013, 06:31 AM
Why?
post #8209 of 10506 Old 10-07-2013, 07:30 AM
Fishtank's Avatar
Why?
Why?
Without knowing your denon specifically you will likely gain very little to nothing.
While I'm more that satisfied with using my 818's internal amps, the $800 I spent mostly went to Audyseey / THX / HDMI ports.... licensing and connectivity. You generally pre-amp to quality power or don't bother.
Unless you just want a few more channels powered, at which case your gonna run an entire Denon avr just to get 2 extra channels, going from the Denon to the Onkyo makes even less sense as you loose the 818's processing.... which is why you bought it.
Fishtank is offline
post #8210 of 10506 Old 10-07-2013, 11:48 AM
lovinthehd's Avatar
Liked: 4775
Why?
Well, what do you think you will achieve by doing this? Why did you get the 818 if you want to use the other unit?
post #8211 of 10506 Old 10-07-2013, 11:53 AM
tbird8450's Avatar
Quoted: 44 Post(s)
Liked: 55
Originally Posted by myoda View Post
tbird:
Are your speakers bookshelf or floorstanders? What were your settings before adjusting the crossover? The 818 has a more complex version of Audyssey than the 805. It runs it faster too. Have you thought about adding another sub?
FL and FR are floorstanders. Audyssey set my fronts (including center) to 40Hz, surrounds I believe were set to 60Hz. I bumped each of them up. Another sub is not really doable with my current setup. I'm not wanting in the LFE department, though.
tbird8450 is offline
post #8212 of 10506 Old 10-07-2013, 02:12 PM
skybolt's Avatar
Liked: 24
Sorry to change subject, but has anyone had to put fans on this unit?
My HDMI switching board just blew after 10 months. It is in an air controlled room with exauhst fan running through the cabinet it is in. I believe mine failed due to internal heat.
My thought is to add a fan to the case to help remove the heat on hte board. has anyone else had to do this? If so what did you use?
Skybolt
skybolt is offline
post #8213 of 10506 Old 10-07-2013, 02:56 PM
Fishtank's Avatar
IMO heat is just an easy-mode answer. Onkyo's run hot, it's an easy target.
EVERYTHING ELSE in the receiver is almost always OK... but the non-wearable part at the top near the back... likely one of the cooler internal locations... dies from heat all the time. How much heat kills an Onkyo HDMI board??? Why did they only use heat sensitive material there. It's gonna be some pcb with some chips, I'm not personally concerned about heat anyhow.
I would have to guess as well to provide an alternative theory, poor mounting and stress from taught / heavy hdmi cables would be my guess, or just bad QC. Sourced a bad part and bought a few million of em'.
Fishtank is offline
post #8214 of 10506 Old 10-07-2013, 03:04 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2968
From my reading i thought it was an inferior part on 2011 and 2012 models, that they caught too late ('11 problems showed up as '12s were coming out) so they corrected it for 2013?
My 818 has been pushed a couple of times and does not get what Id call "hot".
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #8215 of 10506 Old 10-07-2013, 03:13 PM
skybolt's Avatar
Liked: 24
Thats good to hear.
The parts that went on the PCB where caps, they typically only go from over heating, over voltage usually pops them. But from what I understand there is a new PCB added to this one to "Fix" the issue. So you're probably spot on with the defective parts not being caught in time.
skybolt is offline
post #8216 of 10506 Old 10-07-2013, 03:21 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
Skybolt
Oh boy....here we go again. It is not the heat that killed your unit, its the crappy HDMI board that was put in it
NODES is offline
post #8217 of 10506 Old 10-07-2013, 03:24 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 271
The day when there is no HDMI failures on the Onkyo is the day they finally get rid of their last defective HDMI board....but who knows when that will be this started in 2007 eek.gif
NODES is offline
post #8218 of 10506 Old 10-07-2013, 03:35 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2968
the 809 I bought my Dad is still kicking, he is at 12 months.
post #8219 of 10506 Old 10-07-2013, 03:43 PM
Quoted: 257 Post(s)
Liked: 152
Just tried to search for this but 'THX' gets too many results on this thread. rolleyes.gif
Regarding the subwoofer setting in the THX audio setup for 'THX Select which was set to 'OFF' after I'd run set up. I switched it back to 'ON' but does this mean I won't get EQ below a certain frequency or does it simply turn on or off a filter to protect smaller subs? I'll be building a pair of 15" sealed subs soon enough, but my current sub goes down to 18Hz -3dB and is boosted by being in a corner too.
I'm still playing around with the set up as it's taking me a while to get my head around the way Onkyo do things (having owned Denon and Arcam amps/processors previously). I can't seem to get it to turn on to the last input, so I've set everything up on the BD input which it always defaults to; analogue connection from my TV, HDMI connection from my Lumagen video processor which switches sources between PVR or BluRay. It seems to work OK this way since I only have three sources to listen to, but I'm surprised it can't just revert to the last used input.
post #8220 of 10506 Old 10-07-2013, 04:43 PM
Thanx for info. Thing goes like this I have 5.2 system with big front AR9, surr Mission MX6, cen Kef R600, 2x active subwoofers mission & jamo. When I go over 75 volume sound get so harsh and distorted its pissing me off. Its like amp can process some hard music HM :)
No I dont whant to have 818 as preamp for 3802 (its opposite) I will first kill my self than do that.
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
