Onkyo TX-NR818 "official" owner's thread discussion - Page 298 - AVS Forum | Home Theater Discussions And Reviews
 73Likes
post #8911 of 10546 Old 01-16-2014, 08:05 AM
bonginator's Avatar
Another question for the Onkyo 818 owners. I have the following configuration:
Onkyo 818
Vienna acoustics bach grand mains (4 ohms)
Infinity kappa 5 surrounds (will be replaced by vienna Hayden grand 4ohms shortly)
SVS sb-13 ultra sub
BIC center channel
Since I will be driving four speakers that are 4 ohm, I am starting to look at a four channel amp to add to my setup. I probably will buy used to keep the cost down. Can any of you recommend a high quality amps that would work for my setup that arent too old? I am new to the audiophile stuff and want to buy something that will last me a while. I don't go crazy playing my system loudly - just use it for movies and music. It is in a large living room. 20 x 20 x 15' high.
Thanks for the recommendations. I am looking for manufacturer and model recommendations for the amps.
Ideally budget of under $1K and under $600 even better.
bonginator is offline
post #8912 of 10546 Old 01-16-2014, 08:33 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5260
Onkyo 818
SVS sb-13 ultra sub
BIC center channel
Emotiva make good amps at good prices. Check out their website for the specs and new prices. The XPA-5 would suit your requirements. New price is currently $799 but they have Sales from time to time.
http://shop.emotiva.com/collections/amplifiers/products/xpa-3
If you don't want to stretch to $799 then start the search for a good used one using the classifieds here on AVS or various auction sites etc.
I have the XPA-3 and have had it for a few years now - never given me any problems. A good, reliable amp. I also have 3 x other Emotiva amps and they are all good and have all been very reliable. All in use every day.
kbarnes701 is offline
post #8913 of 10546 Old 01-16-2014, 11:01 AM
bonginator's Avatar
Thanks for the recommendation. I will do some research on that model. Any others to consider that are high quality that I might find gently used?
post #8914 of 10546 Old 01-16-2014, 01:38 PM
Wryker's Avatar
Quoted: 135 Post(s)
Liked: 62
Originally Posted by MassConfusion View Post
Anyone here have comcast?? I'm wondering why I can't surround sound from it, I messed with the settings on the settop box but nothing works
I have Comcrap ...I mean Comcast and this AVR and no issues. What show are you having this issue?
I know in my area every CW show comes through BLASTING my center channel so bad it sounds horrible....I guess that's adequate since most of their shows are horrible....OH NO HE DIDNT!
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #8915 of 10546 Old 01-16-2014, 01:57 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
A little more information than "messed" would help....helps to relay actual information as to what you've done...
lovinthehd is offline
post #8916 of 10546 Old 01-17-2014, 08:18 PM
revlisoft's Avatar
I bought an 818 this fall and in the past month, the audio has no sound output when I turn it on and am watching TV. I have to turn it off and on again to get sound output to my speakers. Is this a known issue or an early sign of an issue?
Thanks. Want to report it if it is am indicator of a problem.
Search through this thread but 2+ people already have this issue and most likely you'll require to bring it in for repairs to replace a faulty HDMI board.
revlisoft is offline
post #8917 of 10546 Old 01-17-2014, 08:57 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
Wow 799 now for one...shesh I remember them being $499. They are great AMP for the buck, I use 3 as well.
Who needs 4K?... just go see your optometrist.
NODES is offline
post #8918 of 10546 Old 01-17-2014, 09:11 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
Does not surprise me at all....I will never trust an Onkyo product with HDMI
NODES is offline
post #8919 of 10546 Old 01-18-2014, 02:59 AM
kbarnes701's Avatar
Liked: 5260
I think mine was about $499. Creeping inflation as their reputation strengthened I guess.  Still good value at 800 bucks though IMO.
post #8920 of 10546 Old 01-18-2014, 06:01 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
I'm experiencing an odd issue with the 818 and my Sub (PB12-NSD), every time the audio format changes - surround to stereo - in addition to the click, my sub gets a signal and sends out a slightly audible tone. This also occurs when I got through the Speaker Settings the Level Calibration menus, each time I switch speakers, it sends out the slightly audible tone. Does anyone else experience this, or might it be a defect?
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #8921 of 10546 Old 01-19-2014, 11:42 AM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Well, I tried everything under the sun to stop the thump from the 818 and was unsuccessful. I bought it from Crutchfield and they were out, so I have a NR1010 on the way; had to pay some extra in difference, but they gave me a good deal.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #8922 of 10546 Old 01-19-2014, 12:26 PM
keyser's Avatar
Quoted: 47 Post(s)
What is the latest firmware for the 818?
Birgir "keyser"
keyser is offline
post #8923 of 10546 Old 01-19-2014, 05:33 PM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
I have a HK signature 5 channel amp that gets high marks. If you find one used they are a pretty good amp which can handle difficult loads. I really like the amp and will miss it the day it dies.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
post #8924 of 10546 Old 01-21-2014, 07:40 PM
MassConfusion's Avatar
lol, you're right, I was just wondering if it was possible to get tru surround from a cable box, I've been away which is why I've taken so long to respond
settings on box
audio output : advanced (other options: tv speakers, stereo)
compression: none (other options light, heavy)
stero output: matrix ( other options: stereo, mono)
I do have it currently being passed through on my xbox one, and my xbox one is sending uncompressed to the 818. .
When I hit the movie/tv button on the onkyo remote I only get multichannel options.
I'm running a 5.0 setup
MassConfusion is offline
post #8925 of 10546 Old 01-22-2014, 12:01 PM
Spiderm0n's Avatar
I'm very close to buying a new HT receiver, and the 818 seems like the best bet from a cost and features perspective. I will need 7.1 and really want Audyssey MultEQ XT32. I've seen lots of comments regarding HDMI issues, but can't get a sense how many people with the 818 are actually experiencing them. Onecall has a 4 year extended warranty for $45. Even adding $45 to the 818's price, I don't see any other options close to offering what the 818 does for this price. Does this make sense?
My Gear: Sony VPL-HW40ES, 130" Spandex Screen, Onkyo TX-NR818, Fusion 12 Tempests (LCR), Axiom M3 & M2 Surrounds, Mach 5 UXL 18 Subwoofer
My theater: Escape from New York theater build
Spiderm0n is offline
post #8926 of 10546 Old 01-22-2014, 12:18 PM
lovinthehd's Avatar
Liked: 4781
settings on box
What cable box make/model? Usually there's an audio menu selection of 2 ch or Dolby/5.1 but depends on your box and your service level....if your audio output info above is complete it doesn't seem you have the 5.1 option and only mono or 2 ch....
post #8927 of 10546 Old 01-22-2014, 12:27 PM
Wryker's Avatar
Quoted: 135 Post(s)
Liked: 62
I'm happy with mine. I did have an issue w/2 HDMI ports but re-initializing it fixed it and that happened right after I got it and haven't had any issue since. I have 7.2 and will go to 9.2 with this in my man cave. I've had it for just over a year.
Wryker is offline
post #8928 of 10546 Old 01-22-2014, 11:28 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
$45 for 4 year extended get er done!
NODES is offline
post #8929 of 10546 Old 01-25-2014, 09:38 AM
kbreese's Avatar
Just took my 818 out and plugged it in and WTF?? The power cord plug freely slides in and out of the back. There is almost no resistance to hold it in there. Anyone else experience this?
Panasonic 60VT60
Sherwood P-965
Parasound 2X205
Sherbourn 5X200
SVS-12
Polk LSi9's
kbreese is offline
post #8930 of 10546 Old 01-25-2014, 09:44 AM
migraine24-7's Avatar
Liked: 191
Originally Posted by kbreese View Post
Just took my 818 out and plugged it in and WTF?? The power cord plug freely slides in and out of the back. There is almost resistance to hold it in there. Anyone else experience this?
Yep me too. New cord didn't help. I cut a small piece of cardboard and used it as a shim. Works great but shouldn't have too.
GO BLUE
migraine24-7 is offline
post #8931 of 10546 Old 01-25-2014, 10:00 AM
kbreese's Avatar
Thats absolutely ridiculous that they are shipping them out like this. Really worries me about their QC on such a simple thing like this that the blatantly screwed up on and apparently don't even care!
Panasonic 60VT60
Sherwood P-965
Parasound 2X205
Sherbourn 5X200
SVS-12
Polk LSi9's
kbreese is offline
post #8932 of 10546 Old 01-25-2014, 10:10 AM
Liked: 191
I hear ya. But the unit is awesome. I've owned a few Onkyos over the yrs.. And I love this one. Is it a joke that I had to do this? YES! But I can live with it.
GO BLUE
post #8933 of 10546 Old 01-25-2014, 10:27 AM
kbreese's Avatar
Now I just read about the 24p problem here:
http://www.amazon.com/review/R30318LD9VLISU/ref=cm_cd_pg_pg1?ie=UTF8&asin=B007JOO4XE&cdForum=Fx1EM00BME9E91O&cdPage=1&cdThread=Tx1G1W8M7ILG4C&store=electronics#wasThisHelpful
And now I guess I have to go and find the FW fix and download and install it (Which I'll have to figure out how to do) because apparently Onkyo isn't making it available with automatic update.
Any other issues, tips or tricks I should know while hooking this up? What about the HDMI? Any particular ports I should avoid or anything like that?
EDIT: WIth the firmware updates, do I have to install each FW update that is newer then what my receiver currently has, one after the other, or do I just install the very latest FW update and that includes all the older updates?
Panasonic 60VT60
Sherwood P-965
Parasound 2X205
Sherbourn 5X200
SVS-12
Polk LSi9's
kbreese is offline
post #8934 of 10546 Old 01-25-2014, 10:47 AM
Liked: 191
First check your firmware number and see if u need to update.
GO BLUE
post #8935 of 10546 Old 01-25-2014, 10:49 AM
Liked: 191
post #8936 of 10546 Old 01-25-2014, 11:10 AM
Chatoboy's Avatar
Quoted: 18 Post(s)
Had the same issue with mine. Just wrap some electrical tape around part of the cord that slides in to receiver. Just about the perfect width too. Hope this helps.
migraine24-7 likes this.
Receiver: Denon AVR-X4200W
Front LRC: Ascend Sierra 2
Surround: Axiom Qs8
Sub: Rythmik F15hp
TV: Samsung UN65KS8500
Source: PS4 Pro, Direct TV
Chatoboy is offline
post #8937 of 10546 Old 01-25-2014, 12:58 PM
kbreese's Avatar
Thanks for the tips. Was just reading the Auddysey FAQ on this forum, and my goodness, it says I MUST mount the mic on a tripod or stand for proper calibration. So frustrating, I don't even have a tripod or boom stand. Damn this is annoying, lol.
Also, still trying to figure out how I see what my current firmware version is.
Panasonic 60VT60
Sherwood P-965
Parasound 2X205
Sherbourn 5X200
SVS-12
Polk LSi9's
kbreese is offline
post #8938 of 10546 Old 01-25-2014, 03:55 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Press the Home button on the remote and select Firmware Update. Most likely, you already have the firmware that updated the frame rate issue, but there have been some updates since. I owned the 818 for a brief time - great receiver - before changing to the 1010, and I bypassed video completely by holding on the receiver Cab/Sat and Return simultaneously and then pressing Enter until it says "skip".
As for the tripod, it is the only way to go with Audyssey. Below is some links for a cheap and easy solution, available on Amazon. You will need to purchase both for it to work with the mic,
http://www.amazon.com/gp/product/B000978D58/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #8939 of 10546 Old 01-25-2014, 06:30 PM
ameridian's Avatar
The Audyssey mike is more like a camera than a standard mike in terms of mounting capability (threaded mount) so you're better off getting something intended for a camera than something intended for a standard mike. Furthermore, a tripod can be much cheaper, here's one for $5.95;
http://www.adorama.com/TPAIP50.html?gclid=CMGz0rvimrwCFe5lOgod3yEAdA
ameridian is offline
post #8940 of 10546 Old 01-25-2014, 06:32 PM
ChemEngr's Avatar
Hi,
Is it possible to bi-amp the front speakers (Polk Audio Monitor70) and still have the front heights? I have Audiosource amp-100 as an external amplifier. I have read a few posts saying that bi-amping is not worth it, but still would like to know. Thanks.
ChemEngr is offline
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
