Onkyo TX-NR818 "official" owner's thread discussion - Page 306 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
Old 02-16-2014, 05:17 PM
mpalmieri1203's Avatar
Liked: 44
Because the center channel sound will be diverted to the preout with no sound being presented in the center speaker. If the objective is to obtain only the rumbles and grumbles of speech as opposed to actual spoken word this is the way to go. I truly believe he will get the most out of what he has if he follows a traditional setup. Let's be honest the sub he has isn't actually hitting anything below 40hZ regardless of the specs.
mpalmieri1203 is offline
Old 02-16-2014, 05:28 PM
ragingmain's Avatar
So you are saying if I hook up to the Pre Out than it turns off the output from the Speaker Level side?
ragingmain is offline
Old 02-16-2014, 05:31 PM
Liked: 44
I believe it does. I actually think on our 818s you need to go in to the menu and select to enable ALL the Preouts not just for individual channels so in effect you'd lose all audio from all channels unless you purchase an amplifier and run the preouts to the amp.
Old 02-16-2014, 05:32 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4774
I thought I read early in this thread that this avr will simultaneously output to the preout and speaker level outs......one way to find out! I'm familiar with the sub, I have one (unused at the moment as I have four better subs wink.gif ).
lovinthehd is offline
Old 02-16-2014, 05:34 PM
ragingmain's Avatar
I am busy doing my stats HW for my Project Management class or I would go hook it up and try
Old 02-16-2014, 05:39 PM
Liked: 44
If it does that's the way to go.
Old 02-16-2014, 05:42 PM
primetimeguy's Avatar
Quoted: 547 Post(s)
Liked: 356
I think that is the case but then you have to run the center full range for it to work. If you engage the receiver crossover you'll route bass to the sub out and none will be sent to center channel preout.
primetimeguy is online now
Old 02-16-2014, 06:12 PM
ragingmain's Avatar
What if you set the CC XO low like to 40-50hz?  The rest would be sent to the sub correct?
Old 02-16-2014, 06:23 PM
Quoted: 547 Post(s)
Liked: 356
Yes if you set it to 40hz,anything below that goes to your main sub connected to the sub preout. But anything above that now goes to the center channel speaker AND the sub you connected to the preout for the center. So your are forcing your speaker to play lower than it can and then also doubling up those same frequencies to your center channel sub.
Old 02-16-2014, 06:32 PM
ragingmain's Avatar
Crap.  This is exactly what I was afraid of.  Although I can limit how high the sub goes to minimize the doubling of frequencies by using the LPF but I cannot stop the CC from trying to play lower frequencies than it is rated for.
Old 02-16-2014, 06:35 PM
Quoted: 547 Post(s)
Liked: 356
Yep, back to waiting for the new sub. :-)
ragingmain likes this.
Old 02-16-2014, 06:52 PM
Liked: 44
That's really not too much of an issue. Your speaker just WON'T reproduce the sound. What are your normal listening levels like? Do you have an SPL meter? Might be a nice investment so you can get some idea of what's going on when you get your SVS in. If you've never experienced premium bass prepare to be amazed.
Old 02-16-2014, 06:56 PM
Quoted: 547 Post(s)
Liked: 356
Distortion will rise significantly as it tries to play frequencies it cannot.  Remember it will get 20hz or lower content when set to full range.
Another thing he'd need to remember is to adjust the center subwoofer phase to get best blend with center channel.
Old 02-16-2014, 07:28 PM
Niroe64's Avatar
Quoted: 18 Post(s)
Liked: 45
Hey guys, I am currently running 7.1 with heights instead of rears and had a question about powering my speakers using the 818. My fronts and center are klipsch with a sensitivity in the mid nineties but I am still using four of my old surrounds for the sides and heights that come from the Onkyo THX 9400 system and have a sensitivity in the low low eighties. I plan on getting some klipsch surrounds soon but in the meantime would you guys suggest I forgo using the heights as to not take any potential power and headroom away from the good speakers or can the 818 still handle the demand? I know things like listening volume and levels come into play so for reference I am only about 4-8 ft away from each speaker and the trim levels on the onkyo speakers are -3 to -1 while the klipsch are -7. I listen around -12 in roughly an 8x10 room, crossovers all at 80. Thanks!
AVR Onkyo 818
Fronts Klipsch RF-62II's
Center Klipsch RC-62II
Sides Klipsch RB-51's
Sub SVS PB 2000
Blu-Ray Sony Ps3 Screen Samsung UN46D8000
Niroe64 is offline
Old 02-16-2014, 07:43 PM
ragingmain's Avatar
Personally being only 4-8 feet away I would say you are fine in leaving your highs hooked up.  You're plenty close enough to get full sound without having to crank it and putting strain on your 818.
Old 02-16-2014, 07:50 PM
lovinthehd's Avatar
Liked: 4774
Like he said, Wednesday can't arrive soon enough so he can forget all about this plan.... smile.gif
Old 02-16-2014, 10:56 PM
Fishtank's Avatar
Agreed its basically nonsense but he knows it.... and since we are 90 posts in...
Wired center chanel, Center pre-out to the old sub, x-over at 80hz.
The intent was to enrich the center channel not provide LFE, 80hz happens to be the lower end of the human vocal range anyhow isnt it?
This way his SVS will still hande the lfe, crappy sub will play 80-150hz on the center channel, center channel will play what it plays. I do think the speaker terminals stay active with the pre-out in use. not sure tho.
Fishtank is offline
Old 02-16-2014, 11:13 PM
kevin g.'s Avatar
Quoted: 324 Post(s)
Liked: 137
...unless you're watching James Earl Jones, or Michael Clarke Duncan retrospectives...
mpalmieri1203 and ragingmain like this.
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
Old 02-17-2014, 06:27 PM
bonginator's Avatar
Ok. I may be crazy but I just ordered a Nova Pre Amp/DAC and Nova 220 amp so I can play stereo streaming music from my Apple TV and iMac. I also wanted more power to drive my front channel 4 ohm speakers so am going to set this up so my onkyo processes for HT and Nova will process when listening to streaming music. Hope this works!
Need to figure out how to set it up so I can do HT with the onkyo and music with the nova as processor.
bonginator is offline
Old 02-17-2014, 09:44 PM
ragingmain's Avatar
48 hours, ish
Old 02-17-2014, 10:11 PM
lovinthehd's Avatar
Liked: 4774
Your Onkyo couldn't play streaming music from your Apple thingies?
Old 02-17-2014, 10:41 PM
bonginator's Avatar
It could . It just didn't have the power to drive my 4 ohm speakers which are fronts and surrounds. I needed an amp for my speakers and decided the DAC/pre combo for music would be good plus the 2 channel amp for my fronts would help. I will be adding another amp for my other channels.
Old 02-17-2014, 11:19 PM
jontyrees's Avatar
Liked: 38
Just curious, but you know 4ohm speakers are actually easier to drive than 8ohm, right? A receiver will make more power into the lower impedance. Now whether the amp is stable when putting out that much more power is another question. You don't really need a more powerful amp for lower impedance speakers though.
jontyrees is offline
Old 02-17-2014, 11:21 PM
jontyrees's Avatar
Liked: 38
jontyrees's Avatar
Liked: 38
Old 02-17-2014, 11:22 PM
wvu80's Avatar
Quoted: 314 Post(s)
Liked: 280
I thought your Onk 818 would drive about 125 wpc into 4 ohms. My Onk 717 has two power options in the setup menu, 6 ohms and 4 ohms, I think around 110 wpc.
Will your 818 deliver enough power on 4 ohms?
wvu80 is online now
Old 02-17-2014, 11:47 PM
theoneofgod's Avatar
Quoted: 14 Post(s)
Liked: 30
It does have a 6ohm setting too.
theoneofgod is offline
Old 02-18-2014, 12:48 AM
lovinthehd's Avatar
Liked: 4774
What speakers? I can maybe seeing adding another amp via the preouts (as I do that smile.gif ) but another DAC and preamp? What is that going to do except complicate matters?
Old 02-18-2014, 07:33 AM
wvu80's Avatar
Quoted: 314 Post(s)
Liked: 280
I love that Onk 818, I think it hits a performance/features-to-cost point that is virtually unmatched. My Onk 717 comes close with just a little less power and is currently $200 cheaper. so I'm satisfied and my 717 meets all my needs. When I need advice on how to use my 717, the 818 thread usually answers all my questions.
wvu80 is online now
Old 02-18-2014, 07:36 AM
wvu80's Avatar
Quoted: 314 Post(s)
Liked: 280
I'm considering doing that as well, adding additional power amp for my L/R in a 5.1 setup (center channel is different).
Would you mind expanding on what you are using, and what benefits you are getting from the additional power?
wvu80 is online now
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
