Onkyo TX-NR818 "official" owner's thread discussion - Page 331 - AVS Forum | Home Theater Discussions And Reviews
 73Likes
post #9901 of 10547 Old 08-21-2014, 06:26 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
Originally Posted by coli View Post
The network chip is on the same board as the HDMI. I bet ground loop issues is frying that board.
Nice...they are trying to avoid saying HDMI board failure.
NODES is offline
post #9902 of 10547 Old 08-21-2014, 08:21 PM
EaglePC's Avatar
Hey there anyone can answer my question on TX-NR818 audyssey setting my sub @ 26.5FT when my room is only 16' x10'
RF61ii's
RC42ii
WS24's
RW-10D subwoofer
ONKYO AVR TX NR818
Oppo BDP-103
Cyber Power PFC 1500VA UPS
LG 55in 240hz LED 55LM7600 TV
EaglePC is offline
post #9903 of 10547 Old 08-21-2014, 08:31 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
What's the question?
PlayNice is offline
post #9904 of 10547 Old 08-21-2014, 08:58 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
I think he means why it is setting it at 26.5 ft
NODES is offline
post #9905 of 10547 Old 08-21-2014, 09:27 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Oh I see now, silly me. I would say could be your room/sub location or it could be the AVR or it could be the mic. Hard to tell. Some people have a hard time getting the Audussey to work (even if it measures right). It's just a tool sometimes even the best tools can't fix every problem.
Try moving the sub maybe it's in a bad spot.
PlayNice is offline
post #9906 of 10547 Old 08-21-2014, 10:15 PM
zeus33's Avatar
Quoted: 1559 Post(s)
Liked: 1405
x10'
It's a measure of acoustical range, not actual feet and inches. There are all sorts of variables that effect the acoustical "distance".
lovinthehd likes this.
zeus33 is online now
post #9907 of 10547 Old 08-22-2014, 05:05 AM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 91
Originally Posted by laserjock II View Post
I don't have a problem yet but I put in the SN and checked the "loss of audio on HDMI" radio button and it came back with a message saying "this receiver doesn't need to be returned, it isn't the problem that is covered by this extension" or something like that.
Same here. I checked "Network Connection is Greyed Out" or something like that. Got the same result as you. I don't have any problem either. Was just trying to see if it would be covered. ???
Ed
old corps is offline
post #9908 of 10547 Old 08-22-2014, 06:41 AM
miad911's Avatar
Originally Posted by Ungoy View Post
I got the replacement unit from Crutchfield yesterday, and Audyssey works wonderfully, just the way it's supposed to. Also don't have the audio cutting out on the optical input. Good times. Now I just need to finish off the theater room downstairs and move this to its new home.
Mine got same Audyssey setting problem. I just figured out the mic that came with this unit is defective. I just tried old mic which came with 609 model and works fine through XT32 full set up. Still replacement is on the way.
miad911 is offline
post #9909 of 10547 Old 08-22-2014, 09:08 AM
Ungoy's Avatar
Quoted: 17 Post(s)
Mine was definitely not the Audyssey microphone. I tried the Audyssey mic that came with my TX-SR508, and my friend's Audyssey mic that came with his Marantz 6008. My receiver behaved the same way. Once I got the new receiver, everything has been working great!
I hope that Onkyo is covering the HDMi board issue. I'm still debating on whether or not I should buy their extended warranty.
Ungoy is offline
post #9910 of 10547 Old 08-22-2014, 09:17 AM
Ungoy's Avatar
Quoted: 17 Post(s)
Ed
I went to the Onkyo page, and put in my serial number, and selected 2 options, the network greyed out + loss of audio on all channels, and it says I'm eligible. I hope that is a good sign. I hope to never have the problem, but it looks like audio loss is covered. It might depend on the combination of problems selected.
old corps likes this.
Ungoy is offline
post #9911 of 10547 Old 08-23-2014, 05:23 AM
madcity's Avatar
output signal strength - possible issue??
I am trying to troubleshoot an issue I am having with my setup. I have the 818 receiver connected to an Epson 3020 projector. Everything works great until I plug my Mac into the 818 and start watching Youtube videos. After about 20 -25 minutes the projector shuts off from overheating. Epson says to check the signal coming out to make sure it isn't sending too much power to the projector. I have tried the PC and Game 2 channels and it happens on both. Never have a problem watching cable tv or movies/games from playstation. Any ideas? I am also going to post in the projector section. thanks
madcity is offline
post #9912 of 10547 Old 08-23-2014, 01:34 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
so if you unplug the mac it all works fine and dandy? did you try the play station again?
NODES is offline
post #9913 of 10547 Old 08-23-2014, 11:16 PM
horseflesh's Avatar
Quoted: 96 Post(s)
Liked: 48
"Sending too much power" really sounds like BS.
How is the Mac connected to the 818? HDMI?
horseflesh is offline
post #9914 of 10547 Old 08-24-2014, 01:46 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
It could be true...the Mac is the most powerful computer around
Tom Riddle likes this.
NODES is offline
post #9915 of 10547 Old 08-26-2014, 03:51 AM
NickWells's Avatar
Ready, Aim, Fire!...
NickWells is offline
post #9916 of 10547 Old 08-27-2014, 03:01 AM
jake608's Avatar
Hdmi reset
I have had my 818 returned due to the HDMI board issue and it was replaced. Now I am having the same issue. Losing volume and now the ARC will not work.
Does anyone remember the remote control sequence to reset the receiver?
jake608 is offline
post #9917 of 10547 Old 08-27-2014, 04:56 AM
bargervais's Avatar
Quoted: 1640 Post(s)
Liked: 971
To reset the AV receiver to its factory defaults, turn it on and, while holding down CBL/SAT, press ON/STANDBY. “Clear” will appear on the AV receiver’s display and the AV receiver will enter standby mode.
This is done on the receiver not the remote.
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-RZ710 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
post #9918 of 10547 Old 08-28-2014, 08:18 PM
madcity's Avatar
yes, I am using the mini display port to HDMI. In a different thread someone thought that the Mac was sending out a raw signal and the projector was having to work harder to decode the signal. I would think that if this was the case then the 818 would not pass the signal straight through without some level of decoding. I have no idea if I am using the correct terms to describe this.
madcity is offline
post #9919 of 10547 Old 08-28-2014, 09:10 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
so is it just a mini display port to hdmi cable or an adapter?
NODES is offline
post #9920 of 10547 Old 08-28-2014, 09:15 PM
madcity's Avatar
it is a mini display port to hdmi adaptor and then an approx. 12' long hdmi cable
madcity is offline
post #9921 of 10547 Old 08-28-2014, 09:18 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
switch it out for a cable...no adapter I bet that will be your resolution.
NODES is offline
post #9922 of 10547 Old 08-28-2014, 09:23 PM
madcity's Avatar
ok, I will try a cable only without the adaptor. thanks
madcity is offline
post #9923 of 10547 Old 08-28-2014, 11:04 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
So my 818 is starting to flake on me....it will turn on and get picture but the click is not there that turns on the built in amps.
Meaning no speakers show on the display = no sound output until I turn off and then back on.
I am thinking of buying a refurb 929 to hold me off until the Denon 13.2's mature.
NODES is offline
post #9924 of 10547 Old 08-29-2014, 09:45 AM
zeus33's Avatar
Liked: 1405
Go to their site and see if you are covered for a repair:
Onkyo acknowledges failed units and extending warrranties until 2018
Supposedly, they are turning the repairs around pretty quickly under this program as well.
post #9925 of 10547 Old 08-29-2014, 11:06 PM
cissado's Avatar
Waiting for my unit to come back from Onkyo for an audio loss issue. I have a question with zone 2 and 3 music listening. I can only hear FM now in those zones because I have everything connected with hdmi cables. I want to eventually connect my TV (music channels) to the zones as well. I understand I need to plug in the red and white cables to hear the sound in those zones. My question is do I need to change the settings in the receiver anywhere to do this? and... How can I ensure that the hdmi cable is the one being used for all other TV viewing etc... when I'm not listening in zones 2 or 3?
One more question about Roku 3. Am I out of luck in hearing music from the Roku in Z2 and 3 because it only has an hdmi connection on it?
cissado is offline
post #9926 of 10547 Old 08-30-2014, 10:38 PM
investmentcar's Avatar
I think you are correct. When the hdmi board starts having issues, only non-hdmi audio sources can be played. The repair should fix the problem.
investmentcar is offline
post #9927 of 10547 Old 08-31-2014, 03:28 AM
supercell's Avatar
Quoted: 13 Post(s)
When you select "stereo mode," does it play in 2.0 or 2.1? Is there any way to easily switch between 2.0 and 2.1?
supercell is offline
post #9928 of 10547 Old 08-31-2014, 07:02 AM
cissado's Avatar
Hello, thanks for the reply. I made my post confusing by the way I wrote it. Sorry, not great at writing things down.
I'm getting back the receiver and my other audio issues will hopefully be fixed.
My question was about using both hdmi and analog cables for sound at the same time. Does the receiver toggle between them or does one need to specifically change the allocations inside the receiver's menu? As it is now, I can't hear sound (from my TV) in zone 2 because the hdmi cannot be heard in zone 2 by design . It can only be heard with an analog cable. If I connected the analog, would I have to change anything inside the receiver's menu to use the analog 'only' for zone two? I want to use the hdmi for everything else.
I will probably just connect it and see what happens.
cissado is offline
post #9929 of 10547 Old 08-31-2014, 07:15 AM
Oh yeah. You can either
  • connect both analog and digital cables from each input. The Audio Selector function (I think it is called) can then be set to Auto. However, this will cause an echo (lag) between the main zone and the other zones if you listen to the same input at the same time.
  • or, connect only analog cables from each input. The volume will be lower but you won't get the echo.
I say all that without looking up the Roku 3. It probably doesn't have analog anyway.
Ever since I switched from an old receiver to an hdmi receiver with zones, I have always found this limitation frustrating. I thought I was going to get rid of all of those extra analog cables. I guess it is either too hard to do or not worth trying to charge the consumer more money for a rarely desired feature.
I have the 929 now. It is slightly improved over the 818, it can play the Net input across all zones in sync via Whole House Mode. However, Whole House Mode seems to disable the sub.
Good luck!
John
post #9930 of 10547 Old 08-31-2014, 07:50 AM
cissado's Avatar
Good luck!
John
Yeah, I was eyeing the 929 for exactly that reason, if I couldn't get this 818 to work with the audio issues, but they fixed it so fast, I'll keep it for a while. I use a seperate amp, so I didn't really need the power section. Thanks for the help!
cissado is offline
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
