Onkyo TX-NR818 "official" owner's thread discussion - Page 336 - AVS Forum
post #10051 of 10066 Old 11-14-2014, 04:12 PM
RPGMasta's Avatar
Quoted: 12 Post(s)
Originally Posted by mattfini79 View Post
Which listening mode do people prefer to use for watching movies?
I've been using the 818 for about six months now, and I've been experimenting with all of the listening modes, and I'm curious to know which one people think is best.
I use Direct for all Dolby TrueHD and DTS-HD Blurays.
Sometimes our circuits get shorted by external interference,
Signals get crossed and the balance distorted by internal incoherence.
RPGMasta is offline
post #10052 of 10066 Old 11-15-2014, 07:48 AM
Patrick Murphy's Avatar
Liked: 44
Having a 7.1 system utilizing WIDE setup mode, I use either NEO:X or Audyssey DSX.
wtxgringo likes this.
Patrick Murphy is offline
post #10053 of 10066 Old 11-15-2014, 02:29 PM
en6ads's Avatar
Wake up to music.
Hi Guys. Does anyone know how to automatically turn this unit on to a certain digital audio input? Maybe an android wake on Lan app that has an alarm / automatic on time?
What I'm trying to do is wake up to bbc radio. I use the iPlayer radio app and tune in on android that have alarm features, but I can't figure out how to then turn on the receiver automatically.
en6ads is offline
post #10054 of 10066 Old 11-18-2014, 12:44 AM
EuroMartin's Avatar
I prefer the ProLogic IIz with my Front High speakers. I find that this gives me a very balanced and enveloping experience in all types of situations so I actually never change it!
Cardiacfatboy likes this.
EuroMartin is offline
post #10055 of 10066 Old 11-18-2014, 08:42 AM
kevin g.'s Avatar
Quoted: 74 Post(s)
Liked: 57
+1
This was my preferred listening choice as well, DVD's, gaming, sports, etc...
I got my first BluRay player in the Xbox One, so I have not watched many BR discs, yet...but I have the One set to 5.1 Uncompressed, and the Onkyo's listening mode to multichannel.
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #10056 of 10066 Old 11-18-2014, 10:13 PM
horseflesh's Avatar
Quoted: 74 Post(s)
Liked: 37
I have side and rear speakers in addition to front LCR, so I use IIx. I have experimented with all the Neo and THX stuff but IIx sounds best with 5.1 material. For music, I may use All Channel Stereo or one of the IIx music modes, depending on how the room is being used.
horseflesh is offline
post #10057 of 10066 Old 11-21-2014, 10:51 PM
NODES's Avatar
Quoted: 117 Post(s)
Liked: 62
I use stereo for Music and Neo X for my movies(using heights and wides).
NODES is online now
post #10058 of 10066 Old 11-21-2014, 11:17 PM
Niroe64's Avatar
Quoted: 17 Post(s)
Liked: 38
I use pure Audio for music and straight decode for movies with audyssey on the movie curve and dynamic eq off.
AVR Onkyo 818
Fronts Klipsch RF-62II's
Center Klipsch RC-62II
Sides Onkyo SKR-980's
Sub SVS PB 2000
Blu-Ray Sony Ps3 Screen Samsung UN46D8000
Niroe64 is offline
post #10059 of 10066 Old 11-22-2014, 05:33 PM
bbibb's Avatar
Hi All,
This happens every now and then (maybe every 5 months or so), and most recently happened tonight. I thought I would run it by you guys.
I have TX-NR818 connected to a Panasonic projector, an HTPC, and a Samsung blue ray player. All connections are HDMI. I am running a 7.2 speaker configuration.
Every now and then when I power up the 818, I will either get no video, or very fuzzy video. The fuzziness starts with the ONKYO logo start-up screen. If I remember correctly, the Onkyo image is a little red (I got the no video problem tonight).
To fix, I do some sequence of the following:
1. Power down the 818 and remove power plug. Re-insert power plug and restart.
2. Disconnect and re-connect the hdmi cables from the sources
3. Disconnect and re-connect the hdmi cable to the projector.
4. Switch inputs on the projector.
I cannot figure out which combination works, but all of a sudden, BAM, I get the most beautiful image known to man.
Does anyone else have this happening. If so, what is the true sequence to fix?
Brady
bbibb is offline
post #10060 of 10066 Old 11-22-2014, 05:37 PM
NODES's Avatar
Quoted: 117 Post(s)
Liked: 62
Originally Posted by bbibb View Post
Hi All,
Might have to send it in for a repair, it could be the dreaded HDMI issue popping up on you.
NODES is online now
post #10061 of 10066 Old 11-22-2014, 07:11 PM
bbibb's Avatar
I was thinking symptom of the HDMI problem was no sound. This receiver is two years old has had this problem since new.
Since I can eventually fix it, I never send it in. I was kind of wondering what the proper sequence is to get it working again.
Any information would be greatly appreciated.
Brady
bbibb is offline
post #10062 of 10066 Old 11-22-2014, 08:44 PM
NODES's Avatar
Quoted: 117 Post(s)
Liked: 62
I would just send it in and be done with the problem, instead of doing what you are doing now...pulling wires, turning things off and on...just to make it work.
After a week that would drive me up the wall.
NODES is online now
post #10063 of 10066 Old 11-25-2014, 01:03 PM
Cardiacfatboy's Avatar
Talking
And that's damn near atmos..
Cardiacfatboy is offline
post #10064 of 10066 Old 11-25-2014, 01:06 PM
Is there anyone here thinking of either upgrading to a 3030 for atmos or perhaps following audessy to Denon in the form of the 7200W ?
post #10065 of 10066 Old 11-25-2014, 01:08 PM
I'm thinking 3030 with Dali Ikon 6 5.1 with set of Ikon 1Mk2's and 4 Dali Kompas ceilings for atmos ?
post #10066 of 10066 Old Yesterday, 08:44 PM
NODES's Avatar
Quoted: 117 Post(s)
Liked: 62
My next upgrade is to the Denon X5200 or X7200 series.
NODES is online now
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
