Onkyo TX-NR818 "official" owner's thread discussion - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #10081 of 10533 Old 12-05-2014, 01:45 PM
zeus33's Avatar
Quoted: 1491 Post(s)
Liked: 1270
Originally Posted by kevin g. View Post
I have not updated since receiving my 818 Refurb...I know there are a couple for it, are they sequential, or cumulative? As in, would I have to do separate updates one by one? Or put the last on in, and have all the updates in one?
Read the instructions for the firmware. One of the firmware updates specifically states that "you must be on xxxxxx firmware before upgrading to this one". It's a lot easier to take a few minutes to read before hand than deal with a bricked unit after the fact.
zeus33 is offline
post #10082 of 10533 Old 12-06-2014, 01:31 AM
theoneofgod's Avatar
Quoted: 14 Post(s)
Liked: 30
Good point, but as he has already said the AV's running 1110-8103-0101-000 he is good.
theoneofgod is offline
post #10083 of 10533 Old 12-06-2014, 07:14 PM
sixtytooneratio's Avatar
upgrade
I am currently running the original firmware on my unit.Has the upgrades offered by Onkyo made a BIG difference?
I have zero issues with the unit and adhere to the adage,"If it ain't broke,don't fix it".
I would upgrade only if would make a large difference.
sixtytooneratio is offline
post #10084 of 10533 Old 12-06-2014, 07:55 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
The major fix is a 24Hz bug resolve. Worth the upgrade.
PlayNice is offline
post #10085 of 10533 Old 12-17-2014, 06:35 AM
wtxgringo's Avatar
Quoted: 53 Post(s)
Liked: 64
Quick ?, just got a new Sony tv & setup was a breeze, when I accessed the apps & tried watching Youtube, had no audio. I'm assuming I'll need to connect an optical cable from the avr to the tv correct? Thx
"To the journey..."
Sony KDL60W630B; Onkyo TX-NR818
Polk RTi A7 Mains; Polk RTi CSi A6 Center; Polk RTi A5 Wides & Surrounds
HSU VTF2-Mk4, Dish Network 722k, Iogear WiFi Hub
Teac PD-H600; Marantz BD7004;
Orbit TT Red Plinth, Acrylic Platter, Ortofon OM 5E Cartridge
wtxgringo is online now
post #10086 of 10533 Old 12-17-2014, 07:11 AM
Quoted: 14 Post(s)
Liked: 30
If the TV/apps don't support ARC, then yes.
post #10087 of 10533 Old 12-17-2014, 07:50 AM
wtxgringo's Avatar
Quoted: 53 Post(s)
Liked: 64
Gottit, thx. Switched from hdmi1 to hdmi2/arc & enabled rihd on the avr. Works great now.
"To the journey..."
post #10088 of 10533 Old 12-17-2014, 03:56 PM
grpape's Avatar
So I decided to replace my Sony 5800es with the 818 (own both, but did it basically for the Audyssey dynamic volume that the wife likes). After setting it all up (FL/FR/Center and highs through Emotiva, surrounds/rear surrounds through 818). I then went ahead and chose front highs in the amp section in the speaker set up. Running neo:x or PLllz should have the highs working correct?
I know there is a step on pg.49 in the owners manual (to choose which set of speakers you want to be prioritized to run first between SB/FH, FW, etc.). I can't get it to work. All I get is "not available" showing up on the front display. Is there something I am doing wrong? Those who run 9.1 or 9.2, did you do this step? Or did you just set the amp selection (to which set of speakers you wanted to run) and then just change the decoding. I'm just wondering if this step is necessary for the FH (or any set of speakers running of an external amp) to work correctly.
Thanks for any help
grpape is offline
post #10089 of 10533 Old 12-17-2014, 08:18 PM
fokakis1's Avatar
Quoted: 49 Post(s)
Liked: 52
Thanks for any help
Nothing is wrong. The 818 allows you to connect more speakers than it can process at one time. For instance, if you had 11 speakers connected and set to large/small (IOW not set to "none") this preference setting would no longer be "not available" and you would be allowed to set a priority for your preferred speaker configuration. The 818 would then default to your preference. Since you don't have FW speakers connected (and set to large/small) there are no other configurations available to set as your preference.
And yes, PLIIz will mix in your heights very nicely with pretty much anything you can feed it.
fokakis1 is offline
post #10090 of 10533 Old 12-18-2014, 10:47 PM
grpape's Avatar
Thanks for getting back fokakis. I was just wondering because one of the options is FH/SB. I am running both and was just wondering it this needed to be chosen to work correctly. It sounds fine, so I'll take it as working correctly.
grpape is offline
post #10091 of 10533 Old 12-19-2014, 01:25 PM
Ewingr's Avatar
Quoted: 62 Post(s)
How hook to powered soundbar?
I know seems stupid, but I'm in a short term situation where I have no speakers, and want to send sound out to a Yamaha powered soundbar. I'm not sure how to do that. The soundbar has SPD/IF, Coax, and Analog ports.
I thought I could run RCA plugs from Zone2 out to the RCAs on the soundbar, but didn't work
Can anyone tell me how I should send the sound to the soundbar?
Ewingr is offline
post #10092 of 10533 Old 12-20-2014, 07:44 AM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Anybody having issues with the new firmware or has it been working out for you? FW release 12/18/2014.
PlayNice is offline
post #10093 of 10533 Old 12-20-2014, 06:24 PM
mingus's Avatar
Quoted: 58 Post(s)
Is it pretty common to have hum issues with the 818 using an external amp? i had bad luck last time i tried. I am happy with the receiver, just want to add a 2 channel amp.
I have not tried the latest firmware, will install when I return home the 23rd. I do not see any change log, but definitely new firmware available.
mingus is offline
post #10094 of 10533 Old 12-20-2014, 07:38 PM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
No hum issues here with external amps.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
post #10095 of 10533 Old 12-20-2014, 07:54 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 273
I got a hum from bad interconnects, replaced them and no issues with a hum.
Who needs 4K?... just go see your optometrist.
NODES is offline
post #10096 of 10533 Old 12-21-2014, 05:15 AM
supercell's Avatar
The firmware update is to add Spotify Connect.
supercell is offline
post #10097 of 10533 Old 12-21-2014, 12:35 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
I don't use Spotify so I am wondering if it's worth the upgrade meaning has anyone bricked their unit with this update?
PlayNice is offline
post #10098 of 10533 Old 12-21-2014, 04:40 PM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 273
if it ain't broke....mess with it? Is that how that saying goes?
Did you see what happened in the 80 inch Vizio thread since the last firmware?
NODES is offline
post #10099 of 10533 Old 12-21-2014, 08:36 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Yes I have been following both the 80" thread and the M series thread. A lot of people are not happy. I have been managing as I don't think its that bad but I already use the smart dimming feature so not really a biggie to me. However I do hope they fix things soon.
PlayNice is offline
post #10100 of 10533 Old 12-22-2014, 08:45 AM
grpape's Avatar
No humming hear running a Emotive.
Does anyone find that voices are a bit muffled coming from the center channel? If so, is there anything to fix this? I put some rear plugs into the rear ports of my Energy C-3 center speaker (take away some of the bass), but it still seems muffled. All the levels of the speakers are within good range (+2--8, nothing near 12). Do you thing running Audyssey again would help this?
grpape is offline
post #10101 of 10533 Old 12-22-2014, 09:06 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
well that would be independent on your particular cc speaker, not anything related to the 818.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #10102 of 10533 Old 12-22-2014, 10:26 AM
NODES's Avatar
Quoted: 652 Post(s)
Liked: 273
reset unit and try Audyssey again....set your speakers at 80hz.
NODES is offline
post #10103 of 10533 Old 12-22-2014, 10:36 AM
primetimeguy's Avatar
Quoted: 571 Post(s)
Liked: 360
If you have Dynamic EQ on try turning if off.
primetimeguy is online now
post #10104 of 10533 Old 12-22-2014, 05:12 PM
supercell's Avatar
No issues so far with the upgrade. I don't use Spotify either, but I'm a flashaholic.
post #10105 of 10533 Old 12-22-2014, 07:18 PM
fokakis1's Avatar
Quoted: 49 Post(s)
Liked: 52
Correct. Since the other options involve FW, and you don't have FW (correct?), you're stuck using modes that work with FH/SB. You need not do anything else to get it right. Enjoy.
fokakis1 is offline
post #10106 of 10533 Old 12-22-2014, 07:28 PM
fokakis1's Avatar
Quoted: 49 Post(s)
Liked: 52
If you're using a power conditioner and two or more of your 3-prong bearing components are plugged in to it you could pick up a ground loop hum/buzz. The good news is that this can be fairly easy to resolve.
fokakis1 is offline
post #10107 of 10533 Old 12-24-2014, 03:48 AM
mingus's Avatar
Quoted: 58 Post(s)
thanks, the company that made my amp walked me through many things, including unplugging everything on the same circuit, changing cables, cheater plugs, etc. and never could get rid of the hum. amp is sold, was thinking about trying another amp and see what happens. I was just curious if anyone else had hum issues that couldn't be resolved. thanks again
mingus is offline
post #10108 of 10533 Old 12-25-2014, 09:59 AM
fokakis1's Avatar
Quoted: 49 Post(s)
Liked: 52
Does your setup involve an incoming coax for cable/satellite? As an installer I have found many situations where a hum/buzz was introduced in to a system. Many came after adding a component, such as your amplifier, but ended up coming from a source that seemed unrelated to the amp. Adding the amp is what set off the problem in another area of the system.
You said, "the company that made my amp." Was is a custom build? Have you tried an ordinary, mass-produced amp just to see? I have found that most gear I buy ultimately costs me nothing. I research and buy in at a price I know I can sell it for in the future. Find a reliable amp with good resale value. You won't know till you try. Then we'll help you troubleshoot.
Control4 Automation Programmer
fokakis1 is offline
post #10109 of 10533 Old 12-25-2014, 05:57 PM
mingus's Avatar
Quoted: 58 Post(s)
no satellite or coax connections. the amp was an Jolida. it had the bypass feature, i thought it would be nice to use for music listening. never did get it to work well with the 818.
http://www.jolida.com/product/jd-302crc
now, for some reason now can not get the Audyssey light to light up when watching a movie. strange.
mingus is offline
post #10110 of 10533 Old 12-26-2014, 04:05 PM
D-Rex's Avatar
No Sound from my Onkyo 818, need help
Can anyone provide me some trouble shooting pointers to determine if I have a real problem with my receiver or if I have somehow diverted the sound away from my main speakers? I can't get sound from any of my devices, such as the cable box, the blu ray player, or the CD player. I was once streaming Pandora but I can't get the NET button to even pull it up anymore. Is it something I have done or the receiver? Thanks!
D-Rex is offline
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
