Onkyo TX-NR818 "official" owner's thread discussion - Page 352 - AVS Forum | Home Theater Discussions And Reviews
 73Likes
post #10531 of 10546 Old 04-28-2017, 08:33 AM
blackjackmark's Avatar
Quoted: 167 Post(s)
Liked: 69
Originally Posted by sixtytooneratio View Post
Originally Posted by blackjackmark View Post
Well the 818 is totally non responsive. No lights, no sounds, nada. Have unplugged and removed all wires and will try it in an hour but I'm guessing it's down for the count.
Like others, I think this is my last Onkyo.
How many years did you get out of your unit???Is it covered under Onkyo's extended warranty coverage?
It was covered once for the no audio issue but this is a different issue and from what I understand it wouldn't be covered.
blackjackmark is online now
post #10532 of 10546 Old 04-28-2017, 04:44 PM
sixtytooneratio's Avatar
Quoted: 13 Post(s)
[QUOTE=blackjackmark;52591785]It was covered once for the no audio issue but this is a different issue and from what I understand it wouldn't be covered.[/QPush the issue with Onkyo.E-Mail Jack.Cooper@US.onkyo.com.,doesn't cost a penny to ask.They don't like dissatisfied customers.
sixtytooneratio is offline
post #10533 of 10546 Old 05-08-2017, 06:39 AM
ameridian's Avatar
Received mine 1/2014 and it worked fine until around a week ago when it started to show the classic no speaker matrix display, no sound and no net symptoms. Powered off/on a few times to correct then turned off auto-standby and just left it powered on 24/7...Didn't even waste time on a reset. I replaced it yesterday with a Yamaha 5.1 from the garage while waiting on return box and repair. Don't we just love it when a relatively cheap product proves to be more reliable than something costing more than twice as much.
ameridian is offline
post #10534 of 10546 Old 05-11-2017, 11:25 PM
budtz's Avatar
Hey all,
I have a small problem with listening to something in stereo. Its typically Spotify or flac files. If I switch over to another 2-channel source, it’s still stereo even thou I have set the unit to PLII on that source. It also says PLII in the display - but its Stereo. Ether switching to actual stereo and back to PLII fixes it - or turning it off and on.
Seems like the receiver has a bug where switching from streaming music to a 2-channel PLII source – it can’t switch. Pretty big bug id say.
Any1 have this?
budtz is offline
post #10535 of 10546 Old 05-20-2017, 06:39 AM
ameridian's Avatar
Got back the repaired unit yesterday. Can't fault Onkyo's repair service - prompt and efficient. Looks like they're replacing your HDMI board, having the bad "B" revision TI BGA dts chip, with a refurbished board having the newer "D" revision TI BGA dts chip. Your old board then enters the refurbish cycle for chip replacement.
Before:
http://www.pbase.com/eldata/image/165493857/original
After:
http://www.pbase.com/eldata/image/165493860/original
post #10536 of 10546 Old 05-23-2017, 09:40 AM
boidsonly's Avatar
@ameridian ,
My unit is starting the "failure to connect" to my router; if I am lucky enough to get it to connect, it drops the connection after a few songs. Additionally, it occasionally turns off and restarts by itself. I think it is about to bite the proverbial capacitor....
Where can I take advantage of the MB replacement and what buzz words do I need to use, if any, to convince Onkyo to honor the replacement policy? Looks like they squared you away.
Jeff
boidsonly is offline
post #10537 of 10546 Old 05-23-2017, 12:08 PM
ameridian's Avatar
@boidsonly
Onkyo acknowledges failed units and extending warrranties until 2018
https://repair.onkyousa.com/na/
In addition to giving them the unit's S/N, you have to check all that applies from the following (you can follow the link above and not commit to anything);
Loss of sound experienced on a specific channel
Loss of sound experienced on all channels
Speaker indicator on display is not showing
Speaker indicator on display is on
"Now Initializing..." message on display is showing constantly
Network settings in Setup Menu is grayed out (unselectable)
Loss of video on HDMI output
Noise/crackled audio comes out of speakers (after verifying speaker wires and audio connections are secure)
An affected serial number and the three bold items above will definitely convince them until they receive and inspect your unit. Seem to recall mention of a fee of $75.00 for **additional** repairs not covered by this extended warranty which isn't too bad IMO. But I'm not certain what happens if they find your unit never did qualify in the first place. You may want to speak to someone there first to avoid any deception and fees you never expected.
boidsonly likes this.
post #10538 of 10546 Old 05-23-2017, 02:51 PM
boidsonly's Avatar
@boidsonly
Thank you for the info. I answered all the questions I know to be true and it qualified.
I'll probably move the repaired unit downstarts and buy a newer model in the next few months.
post #10539 of 10546 Old 05-23-2017, 03:05 PM
GoatLocker's Avatar
Quoted: 22 Post(s)
Liked: 26
I don't think they actually check for the loss of sound issue, since it can be intermittent in some cases. After my 818 failed, I went ahead and sent in my HT-RC180 in even though it wasn't failing and they replaced the HDMI board. Anything that is not fixed by swapping the HDMI board will probably incur additional charges, but at least the shipping is free...
GoatLocker is offline
post #10540 of 10546 Old 05-23-2017, 05:30 PM
ameridian's Avatar
Makes sense. In fact, I was thinking to send mine in late next year if it hadn't failed by then.
sixtytooneratio likes this.
post #10541 of 10546 Old 06-20-2017, 11:06 AM
TomKarelis's Avatar
I had the same HDMI loss problem with my Onkyo TX-RN818. It was around December 2016. It was repaired and sent back to me without a problem. I have a dedicated theater room that doesn't get much use due to my work schedule. Last night I went up to watch a movie and the unit was completely dead. It would not power on at all. No other computers or components were affected. I have all the computers and components in the control room plugged into a surge protecting battery back up.
I'm asking the group if this is related to the prior problem or the repair that they have done? I have asked for help on the Onkyo support forum, but not heard back yet. Should I cut my losses on this receiver and buy a Denon or Yamaha?
Tom.
TomKarelis is offline
post #10542 of 10546 Old 06-21-2017, 03:03 AM
T100's Avatar
Quoted: 31 Post(s)
Liked: 25
I'm going to say no, this is what I have had happen to mine and others, believe it a bad relay and moved on to another brand. Hope this helps.
TomKarelis likes this.
T100 is offline
post #10543 of 10546 Old 06-21-2017, 04:51 PM
Quoted: 13 Post(s)
Tom.
It wouldn't hurt to complain.E-Mail Jack.Cooper@Onkyo.US.Com.
post #10544 of 10546 Old 06-30-2017, 04:51 AM
Liked: 0
HI
I need some advise from expert people of the forum for my 818.I recently purchased secondhand from a dealer and he mentioned that the new HDMI board is refitted on that but when i check in the ONKYO site for the serial number it is displayed that mine is eligible for HDMI board retrofitting and they will send me a box.I checked again with the dealer and he was sure that board is changed,Can i ask how to identify new board is fitted please.
Second i noticed that the speaker display icon of FL,C,FR are slightly dim compared to other speaker icon like SBR,SBL,FH,FL,this is more prominent when i dim the display,Can i check it is normal or there is a potential fault lurking .Thanks
rawat97 is offline
post #10545 of 10546 Old 09-18-2017, 10:58 AM
budtz's Avatar
unit turnes on but no audio and no relay click
My unit has started showing problems: unit turnes on but no audio and no relay click. tunring it of and on again gets me audio after the relay click. What could be cousing this?
budtz is offline
post #10546 of 10546 Old 09-22-2017, 09:07 AM
beerninja's Avatar
Quoted: 87 Post(s)
Liked: 68
Same exact thing started happening to me a couple days ago. My unit is pretty old, way past the warranty expiration date so I'm not sure if that special customer care program still applies to me...
beerninja is offline
Onkyo Tx Nr818 , Receivers Amplifiers , Onkyo , Audyssey
