Marantz AV7701 Prepro Official Owner's thread - Page 26 - AVS Forum
 1Likes
post #751 of 763 Old 11-01-2014, 04:28 AM
Selden Ball's Avatar
Quoted: 618 Post(s)
Liked: 466
They are not. The manual is correct. HDMI and S/PDIF are not down-converted to the stereo analog pre-outs in D+M equipment released in 2012, which included the 7701. That feature started being added in a limited form in D+M's 2013 model year, when it worked only for stereo digital audio. This year (2014) it supposedly works for multichannel PCM.
In other words, you might want to consider getting a 7702 or 8802.
In the meantime, you'll have to use players which have stereo analog outputs if you want to be able hear them in other Zones. External HDMI to stereo converters sometimes work acceptably.
Selden
Marantz SR7009/7.1.4/FH+TM/DefTech PM1000/LCR+TM amped
Selden Ball is offline
post #752 of 763 Old 11-01-2014, 07:08 AM
Liked: 0
Thumbs down
This is quite disappointing.... I mean, if it is advertised as Zone2 out for HDMI and audio out and it does not do that, is it acceptable to ask Marantz to "fix," the issue by sending me a refurb that does do it from 2013? I like the Pre-Amp and does everything else flawlessly except this 1 thing.... What are your thoughts. It's almost a case of "false advertisement."
andrewin303 is offline
post #753 of 763 Old 11-01-2014, 07:12 AM
DutchOven88's Avatar
Originally Posted by andrewin303 View Post
Quick edit.... I am talking about the Zone2 HDMI out and Zone2 RCA out, are they not in sync? I mean logically I think they would be but the manual says something completely different.
You'll be able to use the hdmi to carry the signal to the screen. You will have to use that device to parse out the audio to another amp.
AV7701
MM7055
B&W CM9 Fronts
B&W CM5 Rears
B&W CMC1 Center
Martin Logan BalancedForce 210 Sub
Oppo 103D
DutchOven88 is offline
post #754 of 763 Old 11-01-2014, 07:15 AM
Quoted: 618 Post(s)
Liked: 466
HDMI input signals *are* sent to the Zone 2 HDMI output, but it explicitly says on page 100 of the 7701's owner's manual
NOTE
In ZONE2 or ZONE3, the digital audio signals input from the HDMI, COAXIAL or OPTICAL connector
cannot be played back. When playing back in ZONE2 or ZONE3, make an analog connection.
Selden
post #755 of 763 Old 11-01-2014, 11:42 PM
Yet my system outputs 7701 hdmi audio to zone 2...
AV7701
MM7055
B&W CM9 Fronts
B&W CM5 Rears
B&W CMC1 Center
Oppo 103D
post #756 of 763 Old 11-02-2014, 01:04 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 1775 Post(s)
Liked: 1700
The Zone 2 HDMI monitor out will pass the rear HDMI source audio/video to either a TV or another AVR. The Zone 2 pre-outs will pass an analog connected source or on board source (ie. networking, Tuner, USB).
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST (Sat/Sun too if you leave message)
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #757 of 763 Old 11-02-2014, 06:10 AM
Yes Wanted to illustrate the current usage of zone 2, I'm running audio in zone one to the preouts and then zone two video to a TV along with its audio
post #758 of 763 Old 11-12-2014, 03:56 AM
PravinE's Avatar
Liked: 0
Hi All,
What is the latest firmware version number for Marantz AV7701? if there any location where we can see the change log.
Pravin
PravinE is offline
post #759 of 763 Old 11-15-2014, 01:45 PM
tedcousens's Avatar
Network is locked up -
I went to Media Server to play some music and pressed too many buttons and the screen is locked up. There are no other network issues. How do I reboot the network without losing all my favorite streaming channels?
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
post #760 of 763 Old 11-15-2014, 02:06 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1700
First try a "soft reset" by unplugging the unit for 10 minutes.
post #761 of 763 Old 11-15-2014, 03:09 PM
tedcousens's Avatar
Thank you JD - that did the trick. Annoying but I cannot afford to replace the unit right now....
thanks again.
Roi Batty
post #762 of 763 Old 11-17-2014, 01:15 PM
gferrell's Avatar
Originally Posted by PravinE View Post
Hi All,
Pravin
Mine is up to date and says:
6450-3179-0000-4550-3097
I suppose Marantz may have the info on it's website.
Wishing I could post in the Ultra Hi-End HT Gear ($20,000+)
gferrell is offline
post #763 of 763 Old 11-18-2014, 09:52 PM
PravinE's Avatar
Liked: 0
Thanks... I updated the same.. but I don't see any difference... is there any changes which we can see in the console?
Processing : Marantz AV7701 and MM7055.
Source : Pioneer BDP-LX55, Asus TV Pro with 3TB HDD and Videocon d2h HD Set top box
TV : Sony EX400 LCD 46 Inch
Speakers : Klipsch RF-82, RC-62, RS-42 and SW-112
PravinE is offline
