Marantz AV7701 Prepro Official Owner's thread - Page 30 - AVS | Home Theater Discussions And Reviews
 7Likes
post #871 of 892 Old 03-13-2015, 09:05 AM
Vocalpoint's Avatar
Quoted: 13 Post(s)
Originally Posted by DutchOven88 View Post
What application do you plan on using the Pre-pro for?
100% use in our media room. We have a HTPC, XBox360 and Oppo BDP 105 and a Pace STB in here for sources.
The prepro will be mated to the just arrived (this morning!) Marantz 7055. The room is all Monitor Audio for fronts, center and sides.
Cheers,
VP
Vocalpoint is offline
post #872 of 892 Old 03-13-2015, 09:42 AM
DutchOven88's Avatar
Cheers,
VP
If you're planning on taking advantage of atmos and/or auro then you've also got better room correction in the 7702. You'd probably still be best passing video straight to a proj/monitor via oppo. If audio is only running through 7055 and you're o Ly usong a 5.1 then the 7701 is great.
AV7701
MM7055
B&W CM9 Fronts
B&W CM5 Rears
B&W CMC1 Center
Martin Logan BalancedForce 210 Sub
Oppo 103D
DutchOven88 is online now
post #873 of 892 Old 03-13-2015, 10:20 AM
Vocalpoint's Avatar
Quoted: 13 Post(s)
We have no plans to move to Atmos or Auro. As far as the current room correction goes - the MCACC calibration in the Elite has been excellent thus far. Again - I have never tried anything else - so I have nothing to compare to
That's exactly what we are doing right now. For big screen action - the Oppo feeds video to our Espon directly and simply sends the bitstreamed audio to the Pioneer Elite VSX-23THX. As as far as the family is concerned - this is pure excitement for them.
I guess that's what I am trying to gauge here. Kinda feel like the Elite is getting slightly long in the tooth and what I really want is to get my pre-pro relatively current without busting the bank (latest HDMI, perhaps 4K capability for future expansion and the usual basic extras that a pre-pro should have circa 2014-2015).
So unless the 7702 contains massively better "basics" - I am thinking that a new (or slightly loved 7701) might fit the bill perfectly? I really do not need to spend extra cash if those extras see no usage.
Thoughts?
VP
post #874 of 892 Old 03-13-2015, 10:30 AM
7701 has 4k pass through for sources not sourced by the oppo. Personally don't see a need for the 7702 in your situation. Love the audio control on the 7701 but again, the step up would also beg a speaker and amp modification (more channels).
Something else to consider are external sources, will you want a NAS? Those can be fun for streaming content to the oppo which can read media straight off of a computer (twonky or directly) or you can access media directly from either marantz (01/02). Always a fun addition there.
post #875 of 892 Old 03-13-2015, 10:49 AM
Vocalpoint's Avatar
Quoted: 13 Post(s)
We have a NAS in place but it's not something I would bother to access directly using the pre-pro. J.River Media Center is on the HTPC and it handles all media streaming to the PCs, ipads and of course the HT system in the media room.
VP
post #876 of 892 Old 03-14-2015, 12:46 PM
tedcousens's Avatar
Quoted: 18 Post(s)
I found some Deutsche Grammophone Beethoven vinyl at a yard sale so I pulled out an old turntable and hooked it up. It has a two pronged plug and a separate ground wire- any ideas as to where on the 7701 I can ground the turntable and get rid of the buzz? right now I have the grounding wire taped to a third prong and plugged into the wall. It works but it's messy...
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
post #877 of 892 Old 03-14-2015, 12:50 PM
Vocalpoint's Avatar
Quoted: 13 Post(s)
Update.
Just joined the av7701 family. Found one new - got a smoking deal and will be here next week!
VP
post #878 of 892 Old 03-14-2015, 12:54 PM
Vocalpoint's Avatar
Quoted: 13 Post(s)
The TT should have a L/R RCA input plugs AND a ground wire in a single grouping coming out the back. The L/R of course goes to Phono on the av7701 and the ground wire goes to the signal ground screw on the back of av7701.(right next to the RS232C plug)
I would be very wary about taping anything to a "prong" that is anywhere near electricity.
VP
post #879 of 892 Old 03-14-2015, 01:03 PM
Selden Ball's Avatar
Quoted: 1296 Post(s)
Liked: 690
The AV7701's ground connection is on its back panel, in between the RS-232C and Flasher connections, immediately above the CD RCA analog inputs.
Selden
Marantz SR7009+MM9000/Atmos 7.1.4 (FH+TM:DefTech PM1000)/LCR+TM amped
Selden Ball is offline
post #880 of 892 Old 03-14-2015, 01:32 PM
tedcousens's Avatar
Quoted: 18 Post(s)
VP
Found it!~ Disaster averted!! Thank you to you and Selden for responding.
Roi Batty
post #881 of 892 Old 03-22-2015, 01:46 PM
tedcousens's Avatar
Quoted: 18 Post(s)
Loose HDMI input
Is anyone else haveing difficulty with a loose HDMI input? I occasionally have to jiggle the cable in the back of the unit to keep signal flowing - is this repairable? I have switched out cables numerous times (admittedly not expensive cables) but sometimes I lose the signal. Would more expensive cables help? Is this repairable? I do not have any game consoles- could I broadcast my cable box through the game channel?
Thanks everyone, I always get great advice and answers on this forum. You are all the best!!
Roi Batty
post #882 of 892 Old 03-22-2015, 02:36 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3764 Post(s)
Liked: 2186
You may want to consider locking HDMI adapters as noted in the link below ....
http://www.amazon.com/Blue-Echo-lock.../dp/B001QV2AKK
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #883 of 892 Old 03-22-2015, 04:18 PM
tedcousens's Avatar
Quoted: 18 Post(s)
JD is the best!
Just ordered a set! Thanks!
Roi Batty
post #884 of 892 Old 04-12-2015, 12:46 PM
Liked: 0
I need to be able to get analog audio out to go to a set of headphones my elderly mother uses to hear the TV. I just need whatever source is selected to send analog audio to headphone. Is the MEDIA PLAYER OUT the correct connection? I can't seem to get any sound from those jacks. Any ideas?
Audiophilic is offline
post #885 of 892 Old 04-12-2015, 01:22 PM
Liked: 0
Just to clarify, these are wireless, powered headphones that accept RCA inputs.
post #886 of 892 Old 04-12-2015, 04:05 PM
There's an analog out on the lower left portion of the panel labeled media player from the perspective of looking at the rear panel
post #887 of 892 Old 04-12-2015, 04:28 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
The source device must be connected with either an analog cable or if passing PCM 2.0, an optical/coax digital cable as HDMI cannot be passed to the Zone 2 pre-outs or Media Player Out.
Audiophilic likes this.
post #888 of 892 Old Today, 02:07 PM
Quoted: 18 Post(s)
Liked: 1
Volume Increasing to 100 and Locking
The last few days I have an an issue with the AV7701. When I increase the volume on the remote control it continues all the way up to 100 no matter what I try to do to stop it. If I shut the preamp off for a few minutes an restart it might be OK for awhile, or it might just do it again right from the start.
I am sure it's some sort of software glitch but is there anyway to repair it. It really is a PITA.
Other than that, I love the unit.
Thanks very much.
Ian
ihmeyers is offline
post #889 of 892 Old Today, 02:36 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
Try unplugging the 7701 power cord for 10 minutes which is a "soft reset" and will result in no loss of settings.
post #890 of 892 Old Today, 02:43 PM
Quoted: 18 Post(s)
Liked: 1
Thanks very much JD. I will do that.
Is that a known bug?
ihmeyers is offline
post #891 of 892 Old Today, 02:58 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
Not that I'm aware of, no.
post #892 of 892 Old Today, 03:06 PM
Quoted: 18 Post(s)
Liked: 1
That seemed to work. I also changed the batteries in the remote (the original pair) and so far so good.
Thanks much.
ihmeyers is offline
