Marantz AV7701 Prepro Official Owner's thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #901 of 1059 Old 05-20-2015, 09:54 AM
jdsmoothie's Avatar
Quoted: 14325 Post(s)
Liked: 6764
If the INPUT ASSIGN table displays CBL/SAT = HDMI 4, and GAME = None, then that should do the trick. Try using another input (eg. HDMI 5) as a test.
jdsmoothie is offline
post #902 of 1059 Old 05-20-2015, 10:20 AM
tedcousens's Avatar
Quoted: 28 Post(s)
resolution: dual issues. not only was HDMI 1 intermittent, it was killing the cables. I replaced the cable plugged it into 1, nothing, into 4 - got signal. Reassigned CBL/SAT to 4. All good. For now. Thanks for the help and support JD.
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
post #903 of 1059 Old 05-20-2015, 10:23 AM
jdsmoothie's Avatar
Liked: 6764
post #904 of 1059 Old 06-14-2015, 07:44 PM
luvthefloyd's Avatar
Hi,
I'm trying to connect my 7701 to my Netgear C3700 so i can use the remote app. When i do it pretty much kills my internet (app works fine thought).
I have my Oppo 103 connected to the Netgear with no issues at all.
Any ideas whats going on? Thanks.
By Grabthar's hammer.......... What a savings.
luvthefloyd is offline
post #905 of 1059 Old 06-15-2015, 04:03 AM
DutchOven88's Avatar
Quoted: 17 Post(s)
First I'd make sure you're using the switch ports (I've made this mistake in the past) and not the wlan port... Then check the cable or swap the port on the back of the router. Let us know
AV7701
MM7055
B&W CM9 Fronts
B&W CM5 Rears
B&W CMC1 Center
Martin Logan BalancedForce 210 Sub
Oppo 103D
DutchOven88 is offline
post #906 of 1059 Old 06-16-2015, 12:12 AM
Yeah i ran through all that. Correct ports, cable switch. It's definitely the 7701.
In fact i can keep the ethernet plugged into the 7701 while its off an the internet works just fine. Once i power it up no internet.
Someone else has to have run into this weirdness.
Btw, we have a lot of the same gear
post #907 of 1059 Old 06-16-2015, 04:00 AM
Quoted: 17 Post(s)
Warranty item? Sounds like there could be a wiring issue then in the network connection on the marantz Could be a short or cross that causes the router to go into protection.
Love the setup. Need more space to let it really breathe when volume is up but hey. Small apartment in the city.
post #908 of 1059 Old 06-16-2015, 07:38 PM
jbeemon's Avatar
Sounds like you have an address conflict. Check your network setup on the Marantz and make sure it is set to auto if it's not. If your switch is giving it the same address as your computer, you would not get internet access, but would if the Marantz is turned off. I'm no network whiz, but have had address problems in the past which manifested in the manner you describe.
luvthefloyd likes this.
jbeemon is offline
post #909 of 1059 Old 06-16-2015, 08:31 PM
Your suggestion lead to the solution!
Went into the network settings DCHP was set to off, switched to on and voila!
Am now running its first firmware update ever, estimated at 40 mins!
Thank you very much for the help.
post #910 of 1059 Old 06-16-2015, 08:33 PM
I just moved into a small house so i have a similar issue. The speakers are really much closer together than what i'd really like but hey thats life.
post #911 of 1059 Old 06-16-2015, 08:59 PM
Quoted: 17 Post(s)
Nice! That's helpful to know didn't even think about that route.
post #912 of 1059 Old 06-20-2015, 11:22 AM
rblankster's Avatar
Quoted: 27 Post(s)
Liked: 30
I'm looking at possibly replacing my Marantz 7701 with a McIntosh MX151 (used). Any thoughts on Room Perfect vs the Audyssey I have now? Any comments on the MX151 overall? I know there is a MX160 due shortly so I suspect I will be seeing MX151s available. I plan on staying 5.1 for a long time since my room limits what I can do.
Klipsch RF-7 II, RC64 II, RS62 II
Klipsch R-115SW & Velodyne FSR-15 SW
McIntosh MC205 Amplifier (200W plus X5)
McIntosh MX151 A/V Control Center
Sony KDL-60NX810 TV
OPPO BDP-93 Blu-Ray
rblankster is offline
post #913 of 1059 Old 06-24-2015, 12:23 PM
KBMAN's Avatar
Quoted: 258 Post(s)
Liked: 146
Yo People,
I just snagged a 7701 used (in great shape!) for $700...looks promising, and I'm sure it will outmatch my dying Integra DHC 40.1
What is the latest firmware? Thanks in advance... And if I need to update, how do you do that with this unit?
PS...I have no need for room correction... HTotM: 'Duck and Cover' theater gettin a face-lift!
KBMAN is offline
post #914 of 1059 Old 06-25-2015, 10:00 AM
KBMAN's Avatar
Quoted: 258 Post(s)
Liked: 146
The source device must be connected with either an analog cable or if passing PCM 2.0, an optical/coax digital cable as HDMI cannot be passed to the Zone 2 pre-outs or Media Player Out.
That's great info, but how can I hook-up my Buttkickers (with the remote volume also) with this 7701 with PS3 bluray???
KBMAN is offline
post #915 of 1059 Old 06-25-2015, 02:08 PM
jdsmoothie's Avatar
Liked: 6764
The usual connection after running Audyssey using only Sub pre-out 1, would be to use a "Y" splitter cable connected to Sub pre-out 1 with one going to the sub and the other going to the Buttkicker amp with volume control via the Buttkicker amp.
post #916 of 1059 Old 06-25-2015, 02:19 PM
KBMAN's Avatar
Quoted: 258 Post(s)
Liked: 146
Thanks JD,
And as my logic follows...I could maybe take that split sub out to an analog input, and then assign that input to ZONE 2 OUTPUT????
KBMAN is offline
post #917 of 1059 Old 06-30-2015, 05:55 AM
rblankster's Avatar
Quoted: 27 Post(s)
Liked: 30
Found a new in the box McIntosh MX151 for a very reasonable price - Amazing unit in terms of sound and build quality! I will be selling my AV7701 shortly.
Sony KDL-60NX810 TV
OPPO BDP-93 Blu-Ray
post #918 of 1059 Old 06-30-2015, 10:20 PM
Couple questions for the experts.
Can you power up/down the unit with the remote app?
Is there a way to activate my sub in Stereo listening mode?
post #919 of 1059 Old 07-01-2015, 01:52 AM
jdsmoothie's Avatar
Liked: 6764
1. Yup. That's the purpose of a remote app.
2. Yup. Ensure FL/FR speakers are set to SMALL/80Hz.
post #920 of 1059 Old 07-01-2015, 09:32 AM
k is theres something i need to do with the remote app or marantz for the power button to work?
post #921 of 1059 Old 07-01-2015, 09:50 AM
jdsmoothie's Avatar
Liked: 6764
Sorry, yes .... as when using any DLNA/Airplay app, in order to power on the AVR, the "IP Control" setting (p. 131 Owner's manual) must be set to "Always ON."
post #922 of 1059 Old 07-01-2015, 11:59 AM
Thank you! That did the trick.
So is there no easy way to be able to enable/disable the sub depending on what I'm listening to? Without going into programming mode.
post #923 of 1059 Old 07-01-2015, 12:09 PM
jdsmoothie's Avatar
Liked: 6764
If you don't want to use Audyssey, you can use either DIRECT or PURE DIRECT with stereo audio and the sub will be disabled.
post #924 of 1059 Old 07-01-2015, 12:49 PM
JD you seem to be the man where it comes to Marantz. One more for you.
Is there a setting i need to configure in order to power on/off my Panny VT65 through my pre?
post #925 of 1059 Old 07-01-2015, 01:02 PM
jdsmoothie's Avatar
Liked: 6764
It may not always work, but set VieraLink on the TV to ON and set HDMI Control on the 7701 to ON as well. Generally much easier to replace the stock remote with a Harmony remote.
post #926 of 1059 Old 07-01-2015, 01:07 PM
I hear you, i'm trying to run everything through apps on my iPhone.
Dumb question, what part of the menu do i find HDMI control?
post #927 of 1059 Old 07-01-2015, 01:18 PM
jdsmoothie's Avatar
Liked: 6764
Video - HDMI Setup - HDMI Control (p. 117 Owner's manual)
post #928 of 1059 Old 07-01-2015, 01:21 PM
Disregard, i figured it out.
I'm wondering if the HDMI into the TV needs to be specific for Viera to work.
post #929 of 1059 Old 07-01-2015, 01:28 PM
Bummer that didn't do it (switching to HDMI 2).
post #930 of 1059 Old 07-01-2015, 03:49 PM
Have i pretty much exhausted my options?
