Marantz AV7701 Prepro Official Owner's thread - Page 35 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
Old 03-23-2016, 11:01 AM
luvthefloyd's Avatar
I'll check but doesn't reseting the unit disable Audyssey?
By Grabthar's hammer.......... What a savings.
luvthefloyd is offline
Old 03-23-2016, 12:07 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 10296 Post(s)
Liked: 4766
Helps if you quote who you are responding to so we know what you are responding to.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, SVS, Oppo
Ask me how to get a FREE HEOS 1 HS2 wireless/Bluetooth speaker.
jdsmoothie is offline
Old 05-03-2016, 06:40 PM
tedcousens's Avatar
Quoted: 28 Post(s)
How do I get CBL/SAT to play out of zone 2 or 3 please? I have an rca cable and have done it before, just don't remember how...
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
Old 05-04-2016, 06:24 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
As long as your cable/sat box can output audio out of the analog audio outputs simultaneously with the HDMI output, then with the RCA cable connected to the CBL/SAT analog audio inputs, simply power on Zone 2/3 and select CBL/SAT.
Old 05-04-2016, 10:03 AM
KBMAN's Avatar
Quoted: 219 Post(s)
Liked: 119
hey jdsmoothie ,
I had a 7701 for a brief moment, and now have the 7702, so this is a bit off topic...However I'm looking at tedcousens post about cable/sat question, but my situation relates to controlling my buttkicker amp volume thru zone 2/3. First off, is this possible at all (with the 7702)??? I would need to feed the analog .LFE signal back into the zone 2/3 of the AVR, and then out to the buttkicker amp (therefor controlling the volume of my bass shakers thru zone control on the Marantz remote).
I know I was successful with this on the Integra DHC 40.1, but I know that each AVP has certain limitations. Thanks for any input!
KBMAN is offline
Old 05-04-2016, 10:41 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
Originally Posted by KBMAN View Post
hey jdsmoothie ,
Not recommended no, as you would have to use a "Y" splitter on the sub pre-out #1 to your sub and the buttkicker.
Old 05-04-2016, 07:23 PM
KBMAN's Avatar
Quoted: 219 Post(s)
Liked: 119
Lightbulb "Y" Splitting....
Not recommended no, has you would have to use a "Y" splitter on the sub pre-out #1 to your sub and the buttkicker.
What kind of harm do you think it would do to use a Y Splitter on the sub out? I am currently using one for the center channel: To split the signal to the HSU Mid-Bass-Module...no problems at all
KBMAN is offline
Old 05-05-2016, 01:44 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
No problem using the "Y" splitter, I simply meant that is the required configuration when using a buttkicker. The point is that with your use case, you would have a signal going to the sub and back into the AVP at the same time .... that's the part that isn't recommended.
Old 06-05-2016, 02:22 PM
tedcousens's Avatar
Quoted: 28 Post(s)
Any info on getting my 7701 to see my network after installing Windows 10? It keeps telling me ---empty---
Thanks for the help, you always know what to do. Especially JD!
Roi Batty
Old 06-05-2016, 02:47 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
Try rebooting the router and doing a network reset on the AV7701 (ie. press the MOVIE+MUSIC buttons while powering on the AVP).
Old 06-05-2016, 03:18 PM
tedcousens's Avatar
Quoted: 28 Post(s)
no luck and now, pandora doesnt work either. Odd that SiriusXM and Internet Radio work but Meid SErver is still aempty and Pandora is reporting 'no network connection'
jd - any other suggestions?
btw, I pressed the AVP power on and off with MUSIC and MOVIE - that seemed to reboot the network so I guess that was the right one.
Roi Batty
Old 06-05-2016, 05:27 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
Other than doing a few more resets in a row ...
Old 06-06-2016, 06:56 PM
BillBradley's Avatar
I had configured the av7701 a few years ago and was able to watch directv (HDMI) on the TV while bypassing the av7701. Over the weekend I was only getting audio from the TV. I reset the unit and everything was back working, I changed the HDMI control to on so that I could watch TV without powering up the unit and amps. When I set HDMI Control to on the HDMI Audio Out is turned off. When I change HDMI Control to off HDMI Audio Out can be changed to AVP. Am I missing something here. Thanks.
BillBradley is offline
Old 06-07-2016, 02:37 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4766
HDMI Audio Out only applies when the AVP is powered ON, so not in play for your use case.
Old 06-10-2016, 05:11 PM
tedcousens's Avatar
Quoted: 28 Post(s)
Of note: I can cast from PC via Windows Media Player to 7701 so the connection is there, but the Media Server on the 7701 will not recognize the file in the PC- all appropriate files are shared so who knows?
Roi Batty
Old 08-05-2016, 11:58 AM
unxpectederror's Avatar
Hi All, is the 7701 capable of 4K @ 60hz?
I just got a 4K cable box and when its plugged directly into the TV it works at 60hz but when I plug it into the 7701 the best I can get working on my TV is 4K at 24hz which is awful (Stuttering picture). I tested both cables used and both work at 60P if connected directly to the tv.
I fear that i've answered my own question but just wanted to check.
unxpectederror is offline
Old 08-05-2016, 01:01 PM
Quoted: 20 Post(s)
No. The AV7701 came out way before 4K was even a thing. The AV7702 won't do it either, but the AV7702 MkII will, that was the major upgrade it received as well as a few other things, and why it commands a much higher price now.
If you want to continue using the AV7701 for sound, and want 4K picture, you'll have to get something like an HD Fury splitter or a UHD Blu Ray player with 2 HDMI outputs, like the Samsumg model.
PS4/Nvidia Shield --> Marantz AV7701 --> Emotiva XPA-5 --> Ascend Acoustics Sierra Towers/Horizon Center with RAAL tweeters (L/C/R), HTM 200 SE (surrounds), Dual Rythmik F12 subs
sludgeogre is offline
