Marantz AV7701 Prepro Official Owner's thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #91 of 1056 Old 09-19-2012, 02:00 PM
bfreedma's Avatar
Liked: 51
Originally Posted by jdsmoothie View Post
It's generally not cost effective to use the Pro Kit on an XT model as it simply allows for more tweaking of XT. At a cost of $700 [$550 (kit) + $150 (license)], you're better served upgrading to an XT32 model rather than going XT+Pro Kit.
+1
You can always add the Pro kit later when the upgrade bug strikes.
bfreedma is offline
post #92 of 1056 Old 09-20-2012, 11:05 AM
Kevin C Brown's Avatar
Liked: 27
Originally Posted by Krobar View Post
Valid point and if I had the additional cash for a PR-SC5509 I probably would have bought it. I run Genelec monitors on long XLR cables so will likely see an increase in noise if I went the RCA which may even outweigh the benefits of XT32. Also as you may have seen with BD/HDDVD I am a first week grey import adopter of new formats so hopefully am only a few years away from 4K BD and a 4K TV and the Marantz being able to switch 4K will be useful at that point.
The 4311 is not the bragain here in the UK that it is in the USA and even at this point in its life will cost me a little bit more than the 7701 although XT32 and Denonlink are both nice to have. What do you think of your 7005? Will you be upgrading to XT32 soon?
Ahhh, I can see that you have thought about it then !!
I'm happy with the AV7005 for now, but yeah, I want XT32 someday. I was really disappointed that the AV7701 won't have it. I actually had an A100 here (the anniversary model of the 4311) for a little while, but I couldn't get myself to open the box. I.e., I want a pre/pro as a pre/pro and not an AVR as a pre/pro.
So most likely I'll be looking at the Marantz 8xxx when it comes out. I just can't bring myself to get an Onkyo/Integra with all the software/hardware/fw/support issues I've come across over the years. The Marantz AV7005, for me, has been absolutely trouble free from the start. So I'm really inclined to stay with them. I was looking at the Outlaw SSP, but alas, that didn't come to pass.
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #93 of 1056 Old 09-20-2012, 03:27 PM
Krobar's Avatar
Quoted: 17 Post(s)
I was briefly tempted by the Emotiva but decided not to take the risk; in the end the 3 zone with Android control and proven track record was worth more to me than a likely slightly cleaner signal path for stereo. My dad has an AVP and it is a rock solid and lovely sounding unit; a better experience than I've had with any Onkyo (Including my current IR RDC-7.1) and hopefully an indicator of Denon/Marantz quality.
Krobar is offline
post #94 of 1056 Old 09-25-2012, 11:44 AM
gimp's Avatar
Wow, you still have that IR RDC-7.1? I dumped mine for an AVP long ago. I'm still incredibly angry with Oinkyo for they way they screwed us. I'll never never ever ever buy a Oinkyo product.
On a happier note I picked up a Marantz AV-7005 for a second system and absolutely love it.
gimp is offline
post #95 of 1056 Old 09-26-2012, 12:54 PM
BruceOmega's Avatar
I still have my IR RDC 7.1! Its in my big system, but I've only partially reassembeld that since I moved to a new house (2 channel, not 7.1 at the moment) and it's not getting used very much.
I just bought a Marantz receiver for a second system as well. I got the SR7007 and so far I am extremely pleased, so much so that I will be looking seriously at one of the upcoming new Marantz PrePros to replace the IR unit.
Bruce
BruceOmega is offline
post #96 of 1056 Old 09-26-2012, 06:36 PM
ccfunk's Avatar
This will be my first Pre/Pro and I 'm gonna get the Marantz AV 7701 when it is available. As far as XT 32 room correction goes, my installer says It may not even be necessary. This would all depend on your room configuration. Worst case could have him use Pro Kit setup that I hear of?
Also I primarily will listen to 2 channel pure mode using my Vincent Amp. In the case is the Audyssey correction disabled anyway??
ccfunk is offline
post #97 of 1056 Old 09-26-2012, 06:53 PM
exm
exm's Avatar
Quoted: 120 Post(s)
Liked: 80
What is your setup? 5.1? 7.2? XT32 is obviously better but really shines with dual subs. You might want to use Audyssey even if 2 channel mode, but that's a personal decision you should experiment with.
Either way, if the AV7701 sounds anything like the AV7005 you'll be happy.
exm is online now
post #98 of 1056 Old 09-27-2012, 07:01 PM
ccfunk's Avatar
Currently 5.1 using a B&K Av 301 receiver with external amp for main fronts.
I'm going for 7.1 when I get the Marantz Pre/pro. I will get there 5 channel amp 7055 and continue to use my 2 channel amp for front mains.
Want to go with 2 front width speaker set-up.
CC
ccfunk is offline
post #99 of 1056 Old 09-28-2012, 05:20 AM
jdsmoothie's Avatar
Quoted: 12140 Post(s)
Liked: 5529
Actually it more depends on whether you prefer better audio fidelity .... as XT32 will provide that upgrade much more so than using the Pro Kit on an XT unit. Some would say using XT+Pro Kit might provide a 10% improvement, while going from XT to XT32 provides a 20-30% improvement.
Although using PURE or DIRECT modes will disable Audyssey, you will more than likely find you prefer using Audyssey once you adjust to it.
jdsmoothie is offline
post #100 of 1056 Old 09-28-2012, 06:08 AM - Thread Starter
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
^you sure about this? I always heard the Pro kit over writes the buffer and makes your unit an XT32. Now I don't own a Pro kit, but was on the edge of buying one. I also just assumed if you had an XT32, the Pro would even improve that too??
Life is enjoyable with good quality
Dr_Mark is offline
post #101 of 1056 Old 09-28-2012, 06:14 AM
ccotenj's Avatar
Liked: 101
the pro kit enhances whatever flavor of audyssey you have... it doesn't make a xt unit a xt32 unit...
echoing earlier comments... the difference between xt and xt32 is significant... the addition of the pro kit is minimal... "worth it" to some (myself included, since i'm a geek redface.gif ), but it's the icing on the cake, it doesn't change the flavor of the cake...
there is zero doubt that a xt32 piece would be a better choice than a "xt + pro" piece... none...
- chris
ccotenj is offline
post #102 of 1056 Old 09-28-2012, 06:17 AM
erwinfrombelgium's Avatar
Quoted: 419 Post(s)
Liked: 217
http://www.audyssey.com/audio-technology/multeq
A difference of Pro vs standard is that you can use up to 32 measuring positions. While XT32 differs from XT in that it uses up to 32x the filter resolution (for mains. for subs 4x). Maybe you got that confused?
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #103 of 1056 Old 09-28-2012, 06:17 AM
ccotenj's Avatar
Liked: 101
i've never seen a room that doesn't require help in the modal zone, and that is where xt32 really shines...
"pure" mode is the worst mode to use if you are striving for fidelity...
- chris
ccotenj is offline
post #104 of 1056 Old 09-28-2012, 06:21 AM
Quoted: 1394 Post(s)
Liked: 588
Just found this thread.
Has anyone actually gotten the 7701 or is this more like an "anticipation" thread?
JimP is offline
post #105 of 1056 Old 09-28-2012, 06:30 AM
jdsmoothie's Avatar
Liked: 5529
AFAIK, the 7701 hasn't been released yet, but very soon though ... so anticipation for now. smile.gif
post #106 of 1056 Old 09-28-2012, 07:29 AM - Thread Starter
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
I thought the kit "combined with a laptop" enabled the 32 bit filtering and then saved the whole enchilada to the unit. I didn't think it kept ther current system intact with a few tweaks. hmm... to bad...
Dr_Mark is offline
post #107 of 1056 Old 09-28-2012, 07:46 AM
jdsmoothie's Avatar
Liked: 5529
Nope ...as Chris noted ... the Pro Kit only allows tweaks of the Audyssey version used on the AVR which is why if someone is considering the kit ($700) or having an installer use their kit (~$400), you're generally better served just upgrading to an AVR with XT32 and bypass the XT model.
post #108 of 1056 Old 09-28-2012, 08:02 AM - Thread Starter
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
That $1100 addition would automatically drive me to the AV8801. I was on the edge of committing to my dealer for a 7701 and the pro kit.
Dr_Mark is offline
post #109 of 1056 Old 09-28-2012, 08:06 AM
jdsmoothie's Avatar
Liked: 5529
Or do as Chris did and choose the 4311CI (selling his AV7005 and external amp for a Denon AVR 4311CI/A100). smile.gif Based on the posts in the Denon 4311CI thread on the benefit of XT32 over XT, if budget is not an issue, then either the 4311CI/A100, 4520CI, or 8801 would be the better choices over the 7701+Pro Kit.
post #110 of 1056 Old 09-28-2012, 08:38 AM - Thread Starter
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
^this I think Denon/Marantz shot themselves in the foot over this.
Dr_Mark is offline
post #111 of 1056 Old 09-28-2012, 09:04 AM
Krobar's Avatar
Quoted: 17 Post(s)
My dealer has told me to expect delivery in the 2nd or 3rd week of October.
Krobar is offline
post #112 of 1056 Old 09-28-2012, 09:07 AM
Krobar's Avatar
Quoted: 17 Post(s)
Good to hear a positive review of the 7005 from someone with similar taste in sound. I'm slightly soured towards Onkyo as well after their treatment of the modular platform; what really irritates me is you can tell from the service manual that multichannel PCM HDMI would have been possible but they chose to dump the platform.
Krobar is offline
post #113 of 1056 Old 09-28-2012, 09:16 AM
jdsmoothie's Avatar
Liked: 5529
Great! Thanks for the update.
post #114 of 1056 Old 09-29-2012, 07:31 AM
ccotenj's Avatar
Liked: 101
yup... i really liked my av7005, but the 4311 is a superior unit... no doubt there... objective results bear this out...
possibly... but it's product differentiation... i doubt they'll actually sell any significant number of the av8xxx models to begin with, but they would sell significantly fewer if that wasn't a differentiating feature... the more that potential buyers start to understand "what really matters" vs. "what they wish/hope matters", the harder it is to sell a comparatively expensive piece...
- chris
ccotenj is offline
post #115 of 1056 Old 09-29-2012, 07:47 AM
Bill Mac's Avatar
Quoted: 1268 Post(s)
Liked: 1445
But I would assume Denon and Marantz would sell many more 3313s, 7007s and 7701s if XT32 was onboard. I would have definitely bought the 3313 or the 7701 if either unit had XT32. I went with the 4311 which I'm quite happy with but would have preferred a more current unit. The lack of XT32 will I'm sure provide more sales for Onkyo wink.gif. Those that can afford the 4520 and the 8801 would probably go for them whether the lower cost units had XT32 or not IMO.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #116 of 1056 Old 09-29-2012, 07:56 AM
ccotenj's Avatar
Liked: 101
maybe...
but the fact that onkyo goes directly from xt32 to 2eq as you drop down the model lines tells me something about the marketplace though... wink.gif
also, onkyo has always been the "feature/price leader", this is no different...
going by your theory, they'd sell a lot more of their lower models if they made them more feature rich as well... but it don't work that way if you have multiple models in your product line... you can't cannibalize your own sales...
also, note the last sentence in my previous post... even though some are learning, there are still people who will wilingly spend money "hoping" for better results... look how many av7005's got sold, for example... smile.gif
- chris
ccotenj is offline
post #117 of 1056 Old 09-29-2012, 08:53 AM
Bill Mac's Avatar
Liked: 1445
maybe...
also
That was a choice made by Onkyo. Maybe their market research (if they actually do any smile.gif) indicated lower end AVR buyers are not concerned with what level Audyssey is in the AVRs that they buy.
True but D&M could have stepped it up in their mid level models.
Since when are the 3313, 7707 and the 7701 lower tier models? How can you say that it would not work? I have seen numerous posts here on AVS from those that are buying Onkyo AVRs instead of Denons due to the lack of XT32. How would D&M be cannibalizing their sales if they offered XT32 in the 3313, 7007 and 7701? What D&M should have done was offer XT32 in these three units then forgo Audyssey Pro and offer it only in the 4520/8801 units.
I still believe those with the funds to buy top of the line components will continue to do so because they can. Of course many in that group are looking for the best in performance and features. But some just want to be able to lay claim to the fact they own the top of the line components wink.gif.
Bill
post #118 of 1056 Old 09-29-2012, 09:24 AM
ccotenj's Avatar
Liked: 101
whatever...
- chris
ccotenj is offline
post #119 of 1056 Old 09-29-2012, 10:57 AM
Krobar's Avatar
Quoted: 17 Post(s)
I suppose the 4311 vs 7701 choice depends on your priorities. The 4311 is now available with £50 of the price I agreed for a 7701 in the UK but the features that matter to me on each look a bit like this:
AV7701:
XLR - Important as I currently use XLR to my Genelecs and some runs are over 20 feet.
4K Support - Will be important in about 2 years, I keep my gear usually for 5 years or more. Having to run a second HDMI to the display to work around this is awkward.
Airplay to Zone2 - I use 3 Zones and will sometimes use Airplay
Zone 2 HDMI - Will likely be used when I move house
192 Flac Support - Just about relevant as I have some of these and its nice not to be forced to downsample the files
Most of the other new features are irrelevant to me. All of the losses from last years model are irrelevant to me.
AVR4311:
XT32 - Relevant as I'm assured it would give a decent boost in SQ
Denonlink - Just about relevant but eventually will rip my SACDs and hence have no use for a disc spinner and Denon are unikely to offer a decent media streamer with Denonlink
11.2 - Irrelevant as I only use 5.1 and 2 additional zones
If I'm missing something then let me know. The 7701 just has too many advantages as far as I can see; 4312 vs 7701 would be a much more difficult call but there is a significant price difference. The Onkyo 818 was the next best as far as I can see but I never could work out it if it could passthrough and overlay 4K and the other really nice feature of DSF playback is unfortnuately stereo only but it is a third cheaper and offers XT32.
Krobar is offline
post #120 of 1056 Old 10-11-2012, 12:20 PM
Krobar's Avatar
Quoted: 17 Post(s)
Krobar is offline
